plc常用的英语词汇都有哪些
wtipoasfe 来源:工控PLC学习 2023-03-10 15:20 次阅读
1. PLC编程控制器
2. absolute 绝对
3. absoluteoutput 绝对最大输出
4 .actuator 执行器
5. against 对比
6. allocate 分配
7. alter 改变修改
8. ambient 环境周围ambient operating temperature
9. analog模拟 analogoutput
10. analysis分析thecollection an and analysis of data
12. applicable可用the applicableCPU for the module
13.assign分配
14.back up battey 备用电池
15.barcode reader/ID 条形码阅读器
16.base unit 主基板
17.baud波特[bo:d]
18. beforehand 事先
19 .binary二进制
20.buffer memory缓冲存储器
21. bus总线
22. case外壳do notremove the module's print board from the case
23. characteristic特征I/Ocharacterristic
24. check校验the datalink status canbe checked
25. child-station 子站
26. common terminal 公共端
27. compatible 兼容compatiblewith the MODBUS protocol
28. compound 混合compoundsystem communication [`compaund]
29. condensation 结露
30. condition 条件conditionsetting
31. conductive 导电conductivemetal picees
32. configuration 组态systemconfiguration
33. configure 组态
34. confirm 确认how toconfirm the operation of the module
35. consumption 消耗currentconsumption
36. content 目录
37. control level 控制级
38. convenient方便moreconvenient and easy-to-use
39. conventionaly 传统whichconventionaly has been used
40. conversion转换Analog-Digital conversion module
41. converter 转换器
42. conveyor 传送conveyorline
43. corrosive 腐蚀corrosivegas
44. countermeasure 对策countermeasure for mis-inpute
45. cutoff 切断
46. debug 调试isrecommended before debugging
47. dedicated 屏蔽cc-linkdedicated cable
48. dedicated 专用dedicatedtransmission protocol
49. default value 缺省值
50. define 解释阐明Offset value and gain value are defined as follow. [di`fain]
51. design 设计design asystem
52. device level 现场级
53. diagnosis 诊断diagnosisfunction
54. digital 数字digitalinpute
55. DIN rail 导轨
56. diverse 不同的各种各样的
57. download 下载
58. duplicate 完全一样
59. dust 灰尘
60. eliminate 免得[i`limineit]
61. enterprise level 管理级
62. erase 清除
63. exceed 超出The numberadmitted must not exceed 200
64. execute 执行date linkis executed using these parameters
65. expand 扩展can beeapanded up to 255 networks
66. faulty故 障站
67. field bus 现场总线
68. fix 固定
69. flexibly 灵活的to supporta variety systerm flexibly
70. flow 流量
71. format 格式transmission format [`fo:maet]
72. fuse 融丝
73. graph 图标坐标图曲线图voltage output characterristicgraph
74. guaranteed 担保nomaloperration cannot be guaranteed
75. handle 处理
76. hardware manual 硬件手册
77. hint 提示programminghints
78. humidity 湿度ambientoperating humdlity
79. individual 独立的
80. inductance 电感inductanceload
81. initiate 实施发起can be initiate by a computer [i`nifieit]
82. input 输入
83. input point 输入点数
84. install 安装
85. instruction 指令the FROMinstruction
86. insulation隔离form rubberprovides good insulation [,insju`leifn]
87. interface 接口
88. interlocking 互锁can be usedfor sequence program interlocking
89. internal external 内部外部internal connection
90. interrupt 中断excute aninterrupt processing
91. invalid无效errorinvalid station function
92. magnetic有磁性的magneticfields [maeg`netik]
93. main circuit 主回路
94. malfunction 故障causesystem malfunction
95. mandatory 强制
96. mantenance 维护maintenancecosts are reduced
97. manual 手册User'Manual
98. mechanical 机械michanicallife机械寿命
99. module 模块mount orremove the module [`modju:l]
100. momentary power failure 瞬时断电
101. monitor 监视
102. mount 固定mount orremove the module
103. multiple 多样mutipleremote i/o modules
104. negative 负
105. observation观察
106. occupy 占用occupies 1station
107. occur 发生
108. offline 离线offlinetest
109. offset gain 偏置增益
110. oil mist 油雾
112. optical loop 光缆回路
113. optimum 最佳的optimumcontrol
114. output 输出
115. overall 总的overalldistance
116. overview 总揽communication overview
117. parameter 参数
118. path 路径transmission path
119. per network
120. perform 进行normal datalink cannot be performed
121. performance specifations 性能规格
122. peripheral 外围Whenutilizing peripheral device to assign I/O number.
123. phase相swith offall phases of the power supply [`feiz]
124. point 要点
125. port 接口Rs232c port
126. positive 正
127.power line电源线
128. power on/off 上电断电
129. precaution 注意事项precaution when configuing system
130. print board 印刷电路板
131. procedure 过程follow theprocedure
132. programing interface 编程口
133. protocol 协议protocolcommunication issues
134. range 范围
135. rated input voltage 额定输入电压
136. ratio 比率
137. recommend 建议isrecommended before debugging
138. reduce 减少the numberof steps in operation program can be reduced
139. refer to 参照refer toChapter 6
140. register 数据寄存器
141. relay 继电器[`ri:lei]
142. remote I/O远程网络
143. reserved station预留主站
144. resistor 电阻resistorload阻性负载 terminating resistor
145. resolution 分解,解析nMaximum resolution最大分辨率
146. restriction 限制norestriction [ri`strikfn]
147. retry 重试
148. scan扫描link scan
149. screw螺丝Teminal-block screw
150. seamless network无缝网络
151. sequence programme顺控程序
152. serial communications module串口模块
153. series系列
154. servo伺服
155. short短路
156. signal信号
157. sink漏极sink commen
158. slot槽
159. soures源极sourescommen
160. specifications特性inputmodules specifications
161. stabilized power supply稳压电源
162. standby master station备用主站
163. start up起动
164. status状态data linkstatus
165. step drive步进
166. storage存储storagearea
167. store存储
168. switch off关断swith offall phases of the power supply
169. swith开关
170. table表格
171. transfer传输
172. transistor晶体管
173. transmission speed传输速度
174. transmit传送data istransmitted in unchanged code
175. triac双端三相可控硅开关
176. troubleshooting故障处理
177. unuseble不可以使用
178. upload上传
179. utilize利用Whenutilizing peripheral device to assign I/O number.
180. verify校验verify theset parameter contents
181. voltage电压highvoltage
182. watchdog看门狗
183. width范围it willvary in the width of [widθ]
184. wire chips线头
  • plc
    plc
原文标题:PLC常用的英语词汇都在这了
文章出处:【微信号:工控PLC学习,微信公众号:工控PLC学习】欢迎添加关注!文章转载请注明出处。
    《电脑爱好者俱乐部诊所常见问题超级丛书》
    [中文] 《电脑爱好者俱乐部诊所常见问题超级丛书》[EXE]http://www.ibeifeng.com/read.php?tid=5057&u=73481电脑专业英语词汇http://www.ibeifeng.com/read.php?tid=11558&u=73481
    发表于 12-20 21:21
    电脑爱好者俱乐部诊所常见问题超级丛书
    发表于 12-20 21:23
    新人必备电子专业英语词汇
    本帖最后由 eehome 于 2013-1-5 10:04 编辑 还在未一大堆电子专业英语词汇看不懂而苦恼吗?下载看看,每天进步一点点
    发表于 01-15 10:20
    硬件工程师+英语词汇+新手必备
    硬件工程师+英语词汇+新手必备
    发表于 08-02 14:34
    机械专业英语词汇
    机械专业英语词汇    陶瓷 ceramics    合成纤维 synthetic fibre
    发表于 02-25 15:20 41次下载
    公共广播设备英语词汇
    必备常识:公共广播设备英语词汇 PA publicaddresssystem        voltage 电压       AMPamplifier 功
    发表于 12-12 10:08 1272次阅读
    CAD中英语词汇对应的中文翻译
    在网上经常看到许多学习CAD的朋友询问到CAD中文英的意思是什么?以下是小编整理出来有关CAD制图软件中英语词汇对应的中文翻译,供大家参考,希望能对大家有所帮助。 2D Solid 二维实
    发表于 10-19 10:26 1w次阅读
    (免费)自动化专业英语词汇表(戴文进版)
    个人收集的英语词汇表-------(免费)自动化专业英语词汇表(戴文进版)--内容详细
    发表于 11-26 15:41 0次下载
    自动化专业英语词汇
    自动化专业英语词汇英语词汇 实用
    发表于 12-18 14:33 0次下载
    灯饰灯具英语词汇与照明术语精选_secret
    灯具资料,英语词汇与照明术语精选,好资料
    发表于 07-19 17:34 18次下载
    Datasheet中常用英语词汇翻译
    Datasheet中常用英语词汇翻译
    发表于 03-17 09:12 0次下载
    电子技术的专业英语词汇资源下载
    电子技术的专业英语词汇资源下载
    发表于 04-17 10:29 28次下载
    电子研发专业英语词汇
    电子研发专业英语词汇免费下载。
    发表于 05-12 09:35 16次下载
    网络安全术语词汇
    网络安全术语词汇
    发表于 05-25 10:29 4次下载
    网络安全术<b class='flag-5'>语词汇</b>表
    电气工程及其自动化专业英语——戴文进
    本书主要讨论电气工程及其自动化专业英语的阅读与翻译。全书分 4 部分,共计 30 单元,每单元含原文课文、专业英语词汇、课文注释及科技英语阅读与翻译知识等内容。专业内容涵盖电工电子、电机学、电气工程及计算机控制技术等。
    发表于 05-27 14:11 0次下载
