点击蓝字 ╳ 关注我们
吴文璐
深圳开鸿数字产业发展有限公司
OS框架开发工程师
一、前言
二、ArkUI中的线程
void AceContainer::InitializeTask()
auto flutterTaskExecutor = Referenced::MakeRefPtr();
flutterTaskExecutor->InitPlatformThread(useCurrentEventRunner_);
taskExecutor_ = flutterTaskExecutor;
// No need to create JS Thread for DECLARATIVE_JS
if (type_ == FrontendType::DECLARATIVE_JS) {
GetSettings().useUIAsJSThread = true;
} else {
flutterTaskExecutor->InitJsThread();
enum class TaskType : uint32_t {
PLATFORM = 0,
UI,
IO,
GPU,
JS,
BACKGROUND,
UNKNOWN,
auto&& touchEventCallback = [context = pipelineContext_, id = instanceId_](
const TouchEvent& event, const std::function& markProcess) {
ContainerScope scope(id);
context->GetTaskExecutor()->PostTask(
[context, event, markProcess]() {
context->OnTouchEvent(event);
CHECK_NULL_VOID_NOLOG(markProcess);
markProcess();
TaskExecutor::UI);
三、各种类型的TaskRunner如何初始化?
void FlutterTaskExecutor::InitPlatformThread(bool useCurrentEventRunner)
#ifdef OHOS_STANDARD_SYSTEM
platformRunner_ = flutter::CurrentTaskRunner(useCurrentEventRunner);
#else
fml::EnsureInitializedForCurrentThread();
platformRunner_ = fml::GetCurrent().GetTaskRunner();
#endif
FillTaskTypeTable(TaskType::PLATFORM);
fml::RefPtr PlatformTaskRunner::CurrentTaskRunner(bool useCurrentEventRunner)
return PlatformTaskRunnerAdapter::CurrentTaskRunner(useCurrentEventRunner);
fml::RefPtr PlatformTaskRunnerAdapter::CurrentTaskRunner(bool useCurrentEventRunner)
if (useCurrentEventRunner) {
return fml::MakeRefCounted(useCurrentEventRunner);
if (taskRunner_) {
return taskRunner_;
taskRunner_ = fml::MakeRefCounted(useCurrentEventRunner);
return taskRunner_;
PlatformTaskRunnerAdapter::PlatformTaskRunnerAdapter(bool useCurrentEventRunner)
: fml::TaskRunner(nullptr)
eventRunner_ = OHOS::Current();
} else {
eventRunner_ = OHOS::GetMainEventRunner();
eventHandler_ = std::make_shared(eventRunner_);
void PlatformTaskRunnerAdapter::closure task)
eventHandler_->PostTask(std::move(task));
void FlutterTaskExecutor::InitOtherThreads(const flutter::TaskRunners& taskRunners)
uiRunner_ = taskRunners.GetUITaskRunner();
ioRunner_ = taskRunners.GetIOTaskRunner();
#ifdef NG_BUILD
gpuRunner_ = taskRunners.GetRasterTaskRunner();
#else
gpuRunner_ = taskRunners.GetGPUTaskRunner();
#endif
//...此处省略若干行
FlutterAceView* FlutterAceView::CreateView(int32_t instanceId, bool useCurrentEventRunner, bool usePlatformThread)
FlutterAceView* aceSurface = new Platform::FlutterAceView(instanceId);
if (aceSurface != nullptr) {
aceSurface->IncRefCount();
flutter::Settings settings;
settings.instanceId = instanceId;
settings.platform = flutter::ACE_PLATFORM_OHOS;
#ifndef GPU_DISABLED
settings.enable_software_rendering = false;
#else
settings.enable_software_rendering = true;
#endif
#ifdef ENABLE_ROSEN_BACKEND
settings.use_system_render_thread = SystemProperties::GetRosenBackendEnabled();
#endif
settings.platform_as_ui_thread = usePlatformThread;
settings.use_current_event_runner = useCurrentEventRunner;
// ...此处省略若干行
auto shell_holder = std::make_unique(settings, false);
aceSurface->SetShellHolder(std::move(shell_holder));
return aceSurface;
OhosShellHolder::OhosShellHolder(
flutter::Settings settings,
bool is_background_view)
: settings_(std::move(settings))
// ...此处省略若干行
// The current thread will be used as the platform thread. Ensure that the
// message loop is initialized.
fml::RefPtr gpu_runner;
fml::RefPtr ui_runner;
fml::RefPtr io_runner;
fml::RefPtr platform_runner =
PlatformTaskRunnerAdapter::CurrentTaskRunner(settings_.use_current_event_runner);
if (is_background_view) {
auto single_task_runner = thread_host_.ui_thread->GetTaskRunner();
gpu_runner = single_task_runner;
ui_runner = single_task_runner;
io_runner = single_task_runner;
} else {
if (settings_.platform_as_ui_thread) {
ui_runner = platform_runner;
} else {
ui_runner = thread_host_.ui_thread->GetTaskRunner();
if (!settings_.use_system_render_thread) {
gpu_runner = thread_host_.gpu_thread->GetTaskRunner();
} else {
gpu_runner = ui_runner;
if (settings_.use_io_thread) {
io_runner = thread_host_.io_thread->GetTaskRunner();
} else {
io_runner = ui_runner;
flutter::TaskRunners task_runners(thread_label, // label
platform_runner, // platform
gpu_runner, // gpu
ui_runner, // ui
io_runner // io
void FlutterTaskExecutor::InitJsThread(bool newThread)
if (newThread) {
jsThread_ = std::make_unique(GenJsThreadName());
jsRunner_ = jsThread_->GetTaskRunner();
} else {
jsRunner_ = uiRunner_;
PostTaskToTaskRunner(
jsRunner_, [weak = AceType::WeakClaim(this)] { FillTaskTypeTable(weak, TaskType::JS); }, 0);
void RosenFontLoader::LoadFromNetwork(const OHOS::RefPtr& context)
auto weakContext = AceType::RawPtr(context));
[weak = AceType::WeakClaim(this), weakContext] {
auto fontLoader = weak.Upgrade();
auto context = weakContext.Upgrade();
if (!fontLoader || !context) {
return;
std::vector fontData;
if (!DownloadManager::GetInstance().Download(fontLoader->familySrc_, fontData) || fontData.empty()) {
return;
//...此处省略若干行
TaskExecutor::BACKGROUND);
四、ArkUI中的看门狗
原文标题:ArkUI中的线程和看门狗机制
文章出处:【微信公众号:OpenAtom OpenHarmony】欢迎添加关注!文章转载请注明出处。
举报投诉
鸿蒙
57文章
2386浏览量
42956 -
OpenHarmony
25文章
3741浏览量
16460
文章出处:【微信号:gh_e4f28cfa3159,微信公众号:OpenAtom OpenHarmony】欢迎添加关注!文章转载请注明出处。
安利给工程师!看门狗相关知识
看门狗能够及时检测并采取相应措施,从而避免系统长时间处于故障状态。本文将详细介绍看门狗的工作原理及其正确使用方法。 同时通过具体示例解析,教你如何在一个简单的LuatOS项目中集成看门狗定时器,设置
抄作业!看门狗定时器必备知识
Air201在模组内部集成了硬件看门狗,今天就一起来聊聊~ 本文将带你了解看门狗的工作原理、应用架构、定时时间设置、软硬件看门狗的区别,以及看门狗定时器的典型应用场景及关键设计因素等内
一文详解看门狗/电压监控芯片规格书
一、关于一些看门狗、电压监控的疑问?1.什么是看门狗?看门狗,又叫Watchdog,本质上来说就是一个定时器电路,一般有一个输入和一个输出,其中输入叫做喂狗,输出一般连接到另外一个部分的复位端,一般
单片机开发:使用内部看门狗定时器(WDT)还是外挂看门狗芯片?
在电子产品中,有时候需要看门狗定时器(WDT),看门狗芯片有外部和内置两种。在设计之初,要不要使用看门狗芯片?这是个值得考虑的问题。在本文中,英锐恩技术工程师对内部和外部
发表于 09-25 13:46
软件看门狗和硬件看门狗的区别
软件看门狗和硬件看门狗都是用于监控系统崩溃的工具,它们的作用是在系统出现故障或异常情况时自动恢复系统。 软件看门狗是一种程序,运行在操作系统中,通过定时检测系统是否正常运行来判断系统
TLF35584中集成的看门狗工作应用案例
看门狗输入引脚 WDI 具有集成的下拉电流 IWDI 。看门狗输入 WDI 可以在“Closed Window”内或随后的“Open Window”期间转换为高电平。
发表于 03-18 11:27
•4075次阅读
求助,关于看门狗定时器的喂狗时间和多APP看门狗的问题求解
参考例程,在看门狗定时器时间的配置上,我看到如下函数:
/* Step 3- Write match value */
#if(WDT_DEMO == WDT_INTERRUPT_DEMO
发表于 02-21 06:50
什么是看门狗?如何实现对系统程序的监控?
看门狗通过定时器计数器和相关的控制逻辑来实现功能。在系统正常运行时,定时器会以固定的时间间隔重复计数,如果系统一切正常,那么定时器会定期被重置。
