点击蓝字 ╳ 关注我们
周黎生
OpenHarmony知识体系工作组
背景说明
组件选型,能力对比
重构前后能力对比
重构完成的内容
重构中比较重要的点
import {ImageKnifeComponent} from '@ohos/imageknife'
import {ImageKnifeOption} from '@ohos/imageknife'
import {ImageKnifeDrawFactory} from '@ohos/imageknife'
@Entry
@Component
struct Index {
@State imageKnifeOption1: ImageKnifeOption =
{ // 加载一张本地的png资源(必选)
loadSrc: $r('app.media.pngSample'),
// 主图的展示模式是 缩放至适合组件大小,并且在组件底部绘制
mainScaleType: ScaleType.FIT_END,
// 占位图使用本地资源icon_loading(可选)
placeholderSrc: $r('app.media.icon_loading'),
// 失败占位图使用本地资源icon_failed(可选)
errorholderSrc: $r('app.media.icon_failed'),
// 绘制圆角30,边框5,边框"#ff00ff".用户自定义绘制(可选)
drawLifeCycle:ImageKnifeDrawFactory.createRoundLifeCycle(5,"#ff00ff",30)
build() {
Scroll() {
Flex({ direction: FlexDirection.Column, alignItems: ItemAlign.Center, justifyContent: FlexAlign.Center }) {
ImageKnifeComponent({ imageKnifeOption: this.imageKnifeOption1 })
.width(300) // 自定义组件已支持设置通用属性和事件,这里宽高设置放在链式调用中完成
.height(300)
.width('100%')
.height('100%')
import AbilityStage from '@ohos.application.Ability'
import { ImageKnife,ImageKnifeDrawFactory} from '@ohos/imageknife'
export default class EntryAbility extends Ability {
onCreate(want,launchParam) {
globalThis.ImageKnife = ImageKnife.with(this.context);
// 全局配置网络加载进度条
globalThis.ImageKnife.setDefaultLifeCycle(ImageKnifeDrawFactory.createProgressLifeCycle("#10a5ff", 0.5))
import {ImageKnifeComponent,ImageKnifeOption,ImageKnifeDrawFactory} from '@ohos/imageknife'
@Entry
@Component
struct Index {
build() {
Scroll() {
.height(300)
.width('100%')
.height('100%')
import {ImageKnifeOption,ImageKnifeComponent} from '@ohos/imageknife'
@Entry
@Component
struct BasicTestFeatureAbilityPage {
urls=[
"http://e.hiphotos.baidu.com/image/pic/item/a1ec08fa513d2697e542494057fbb2fb4316d81e.jpg",
"http://c.hiphotos.baidu.com/image/pic/item/30adcbef76094b36de8a2fe5a1cc7cd98d109d99.jpg",
"http://h.hiphotos.baidu.com/image/pic/item/7c1ed21b0ef41bd5f2c2a9e953da81cb39db3d1d.jpg",
"http://g.hiphotos.baidu.com/image/pic/item/55e736d12f2eb938d5277fd5d0628535e5dd6f4a.jpg",
"http://e.hiphotos.baidu.com/image/pic/item/4e4a20a4462309f7e41f5cfe760e0cf3d6cad6ee.jpg",
@State options:Array = []
aboutToAppear(){
this.options = this.urls.map((url)=>{
return {
loadSrc:url
console.log('this.options length ='+this.options.length)
build() {
Stack({ alignContent: Alignment.TopStart }) {
Column() {
List({ space: 20, initialIndex: 0 }) {
ForEach(this.options, (item) => {
ListItem() {
ImageKnifeComponent({imageKnifeOption:item}).width(300).height(300)
}, item => item.loadSrc)
.listDirection(Axis.Vertical) // 排列方向
.divider({ strokeWidth: 2, color: 0xFFFFFF, startMargin: 20, endMargin: 20 }) // 每行之间的分界线
.edgeEffect(EdgeEffect.None) // 滑动到边缘无效果
.chainAnimation(false) // 联动特效关闭
}.width('100%')
}.width('100%').height('100%').backgroundColor(0xDCDCDC).padding({ top: 5 })
渲染层重构的总结
原文标题:基于ArkUI框架开发-ImageKnife渲染层重构
文章出处:【微信公众号:OpenAtom OpenHarmony】欢迎添加关注!文章转载请注明出处。
举报投诉
鸿蒙
57文章
2272浏览量
42526 -
OpenHarmony
25文章
3558浏览量
15785
文章出处:【微信号:gh_e4f28cfa3159,微信公众号:OpenAtom OpenHarmony】欢迎添加关注!文章转载请注明出处。
ArkUI-X开发指南:【SDK配置和构建说明】
ArkUI-X SDK是ArkUI-X开源项目的编译产物,可将ArkUI-X SDK集成到现有Android和iOS应用工程中,使开发者基于一套ArkTS主代码,就可以构建支持多平台的
鸿蒙开发ArkUI-X基础知识:【ArkUI代码工程及构建介绍】
ArkUI作为OpenHarmony的默认开发框架,在本项目(ArkUI-X)中需要做到一套代码同时支持多平台构建,所以会采取共仓开发的方式
鸿蒙ArkUI-X跨平台开发:【bility开发说明(Android平台)】
本文介绍将ArkUI框架扩展到Android平台所需要的必要的类及其使用说明,开发者基于OpenHarmony,可复用大部分的应用代码(生命周期等)并可以部署到Android平台,降低跨平台应用
鸿蒙开发-ArkUI框架实战【日历应用 】
:eTS
关于eTS
eTS语言:基于TypeScript(简称TS)拓展的出来的,是OpenHarmony应用开发语言,使用ArkUI框架提供的组件进行界面开发。
什么是TypeSc
发表于 01-17 21:37
