如何动态添加修改删除定时任务?那么我们一起看看具体怎么实现,先看下本节大纲:
(1)思路说明;
(2)代码解析;
(3)修改定时任务执行周期特别说明;
接下来看看本节的大纲:
(1)思路说明;
(a)首先这里我们需要重新认识一个类ThreadPoolTaskScheduler:线程池任务调度类,能够开启线程池进行任务调度。
(b)ThreadPoolTaskScheduler.schedule()方法会创建一个定时计划ScheduledFuture,在这个方法需要添加两个参数,Runnable(线程接口类)和CronTrigger(定时任务触发器)
(c)在ScheduledFuture中有一个cancel可以停止定时任务。
(2)代码解析;
根据以上的思路分析,我们很容易就知道如何进行编码了,先提供代码如下:
package com.kfit.task;
**import **java.util.concurrent.ScheduledFuture;
**import **org.springframework.beans.factory.annotation.Autowired;
**import **org.springframework.context.annotation.Bean;
importorg.springframework.scheduling.concurrent.ThreadPoolTaskScheduler;
**import **org.springframework.scheduling.support.CronTrigger;
**import **org.springframework.stereotype.Component;
**import **org.springframework.web.bind.annotation.RequestMapping;
**import **org.springframework.web.bind.annotation.RestController;
- @author Angel --守护天使
- @version v.0.1
- @date 2017年4月6日
@RestController
@Component
**public **class DynamicTask {
@Autowired
**private** ThreadPoolTaskSchedulerthreadPoolTaskScheduler;
**private **ScheduledFuture? future;
@Bean
**public** ThreadPoolTaskSchedulerthreadPoolTaskScheduler() {
**return****new**ThreadPoolTaskScheduler();
@RequestMapping("/startCron")
**public** String startCron() {
future = threadPoolTaskScheduler.schedule(**new** MyRunnable(), **new** CronTrigger("0/5 * * * * *"));
System. ***out*** .println("DynamicTask.startCron()");
**return ** "startCron";
@RequestMapping("/stopCron")
**public** String stopCron() {
**if** (future != **null** ) {
future.cancel( **true** );
System. ***out*** .println("DynamicTask.stopCron()");
**return ** "stopCron";
@RequestMapping("/changeCron10")
**public** String startCron10() {
stopCron();// 先停止,在开启.
future = threadPoolTaskScheduler.schedule(**new** MyRunnable(), **new** CronTrigger("*/10 * * * * *"));
System. ***out*** .println("DynamicTask.startCron10()");
**return ** "changeCron10";
**private ****class** MyRunnable **implements** Runnable {
@Override
**public ****void** run() {
System. ***out*** .println("DynamicTask.MyRunnable.run()," + **new** Date());
(a)我们首先了一个类DynamicTask;
(b)定义了两个变量,threadPoolTaskScheduler和future 其中future是treadPoolTaskScheduler执行方法schedule的返回值,主要用于定时任务的停止。
(c)编写启动定时器的方法startCron();
(d)编写停止方法stopCron(),这里编码的时候,需要注意下需要判断下future为null的时候,不然就很容易抛出NullPointerException;
(e)编写修改定时任务执行周期方法changeCron10(),这里的原理就是关闭之前的定时器,创新在创建一个新的定时器。
(3)修改定时任务执行周期特别说明;
在上一篇博客中,我们使用了一种方式通过全局变量的方式修改cron参数的值,那么在这里的我们也是可以这么做的,这里简单提供下思路,大家自己去实现。
注意ThreadPoolTaskScheduler中的schedule()第二个参数支持Trigger:
ThreadPoolTaskScheduler.schedule([Runnable]( "in java.lang") arg0, [Trigger]( "in org.springframework.scheduling")arg1)
那么我们就可以自己定义一个Trigger,然后动态进行修改了,这里提供核心的代码如下:
private String cronStr = "*/5 * * * * *";
@RequestMapping("/startCron1")
**public** String startCron1(){
System. ***out*** .println("startCron1 >>>>");
threadPoolTaskScheduler.schedule(**new** MyRunnable(), **new** Trigger(){
@Override
**public** DatenextExecutionTime(TriggerContext triggerContext){
**return****new** CronTrigger(cronStr).nextExecutionTime(triggerContext);
System. ***out*** .println("startCron1 <<<<");
**return ** "startCron1";
JAVA
19文章
2964浏览量
104686 -
代码
30文章
4774浏览量
68504
