作为SpinalHDL语法篇的第一节,我们也从最简单的开始。
Bool类型定义
Bool类型就是Verilog中的单bit类型,定义方式如下:
Syntax | Description | Return |
Bool() | 创建Bool类型变量 | Bool |
True | 创建Bool类型变量,并赋值true |
Bool |
False | 创建Bool类型变量,并赋值false |
Bool |
Bool(value: Boolean) | 创建Bool类型变量,并使用Scala表达式赋值 | Bool |
Example:
val a = Bool()
val b = True
val c = False
val d = Bool( 1 > 2)
生成的Verilog代码如下:
wire a;
wire b;
wire c;
wire d;
assign b = 1'b1;
assign c = 1'b0;
assign d = 1'b0;
逻辑运算
下图为官方的逻辑运算解释,也不翻译了,很容易理解。
Operator | Description | Return type |
!x | Logical NOT | Bool |
x && y | Logical And | Bool |
x & y | Logical And | Bool |
x | y | |
x | y | Logical OR |
x ^ y | Logical XOR | Bool |
x.set[()] | Set x to True | Bool |
x.clear[()] | Set x to False | Bool |
x.setWhen(cond) | Set x when cond is True | Bool |
x.clearWhen(cond) | Clear x when cond is True | Bool |
x.riseWhen(cond) | Set x when x is False and cond is True | Bool |
x.fallWhen(cond) | Clear x when x is True and cond is True | Bool |
val e = a & b
val f = a | b
val g = a ^ b
val h = !a
val i = Bool()
i.set()
val j = Bool()
j.clear()
val k = True #这里必须有初值,否则下一句会报错
k.clearWhen(b)
val l = True
when(b){
l := False
val m = RegInit(False) #关于寄存器类型,这里先熟悉一下,后面章节会讲到
m.riseWhen(b)
边缘检测
x.edge[()] | Return True when x changes state | Bool |
x.edge(initAt: bool) | Same as x.edge but with a reset value | Bool |
x.rise[()] | Return True when x was low at the last cycle and is now high | Bool |
x.rise(initAt: Bool) | Same as x.rise but with a reset value | Bool |
x.fall[()] | Return True when x was high at the last cycle and is now low | Bool |
x.fall(initAt: Bool) | Same as x.fall but with a reset value | Bool |
x.edges[()] | Return a bundle (rise, fall, toggle) | BoolEdges |
x.edges(initAt: Bool) | Same as x.edges but with a reset value | BoolEdges |
val a = Bool()
val b = False
when(a.edge()){
b := True
val c = a.edge(False)
转换后的代码为:
module DemoBool (
input clk,
input reset
wire a;
reg b;
reg a_regNext;
wire when_DemoBool_l35;
reg a_regNext_1;
wire c;
always @(*) begin
b = 1'b0;
if(when_DemoBool_l35) begin
b = 1'b1;
end
end
assign when_DemoBool_l35 = (a ^ a_regNext);
assign c = (a ^ a_regNext_1);
always @(posedge clk) begin
a_regNext <= a;
end
always @(posedge clk or posedge reset) begin
if(reset) begin
a_regNext_1 <= 1'b0;
end else begin
a_regNext_1 <= a;
end
end
endmodule
val edgeBundle = myBool_2.edges(False)
when(edgeBundle.rise) {
// do something when a rising edge is detected
when(edgeBundle.fall) {
// do something when a falling edge is detected
when(edgeBundle.toggle) {
// do something at each edge
数值比对
x === y | Equality | Bool |
x =/= y | Inequality | Bool |
举报投诉
HDL
8文章
328浏览量
47495 -
语法
44浏览量
9882
STM32如何去使用bool类型
Q:STM32 如何使用bool类型?通常进行stm32相关编程的时候,bool类型表现更加直白,但编程过程中又不能直接使用,就可以参照工程中的头文件进行添加定义。如:stm32f10
发表于 08-04 08:10
bool定义的类型
[]bool定义的类型只有真和假两种值。[]Static申明的局部变量,存储在静态存储区。静态局部变量的初始化语句块第一次执行起作用。在随后的运行过程中,变量将保持上一次执行的值。[]枚举
发表于 08-12 07:11
程序中使用到bool类型,但编译时提示类型未定义的原因?
如果程序中使用到bool类型,但编译时提示类型未定义,这个时候可在头文件中加入下面一句:typedef enum {FALSE = 0,TRUE = 1} bool;
发表于 12-24 08:11
在SpinalHDL里switch方法有何用处呢
可以更快速高效的实现tkeep到byteCnt的转换:SpinalHDL在生成RTL时,仅SpinalHDL提供的语法会生成RTL电路,而其他代码则是起指导生成电路的作用,在上面代码里
发表于 06-22 14:25
在SpinalHDL里实现优雅的添加待跟踪波形信号
的RTL代码添加个原语约束也很容易,但学会了SpinalHDL怎么可以这么做呢,在SpinalHDL里,我们可以同样实现。SpinalHDL提供了addAttribute语法来帮助我们
发表于 06-22 14:37
在SpinalHDL中定义各种各样的复合数据类型
通过继承Bundle,在SpinalHDL中我们可以定义各种各样的复合数据类型。今天,关于Bundle的几个容易被忽略的点,一同来看下。》Bundle个人在使用SpinalHDL来描述电路时,凡是
发表于 06-28 15:21
在SpinalHDL中关于casez的使用
我们常常采用?表示我们不关心的位,而在SpinalHDL中,也存在这么一种表示方式。SpinalHDL整体的数据结构如下图所示:针对BitVector及其子类,SpinalHDL定义了一种特殊的
发表于 07-06 10:59
就Bits数据类型的初始化及使用方式做一个总结
Bits:初始化Bits意味这一组有Bool类型组成的向量,类似与我们在Verilog中的多比特位宽变量。在SpinalHDL中,声明一个Bits变量可采用如下形式(“[]”中为可选项):相较于
发表于 07-12 16:31
SpinalHDL的UInt与SInt数据类型能够进行有符号/无符号数操作
在Bits的基础上,SpinalHDL提供了UInt、SInt数据类型,从而能够进行有符号/无符号数操作。变量定义/初始化UInt/SInt的初始化与Bits类型相似:逻辑操作符UInt/SInt
发表于 07-14 14:45
SpinalHDL中Bundle与普通数据类型之间的连接赋值转换
SpinalHDL中Bundle与SystemVerilog中的packed struct很像,在某些场景下,与普通数据类型之间的连接赋值可以通过asBits,assignFromBits来实现
发表于 10-18 14:22
SpinalHDL中Bundle数据类型的转换
SpinalHDL中Bundle与SystemVerilog中的packed struct很像,在某些场景下,与普通数据类型之间的连接赋值可以通过asBits,assignFromBits来实现。
