树莓派-GPIO功能及复用功能表
jf_70714899 来源:jf_70714899 作者:jf_70714899 2023-05-09 15:43 次阅读
GPIO
板上有两个5V引脚和两个3.3V引脚,以及一些不可配置的接地引脚(0V)。其余引脚都是通用3.3V引脚,意味着输出设置为3.3V,输入为3.3V容差。
OUTPUTS
指定为输出引脚的GPIO引脚可以设置为高电平(3.3V)或低电平(0V)。
INPUTS
指定为输入引脚的GPIO引脚可以读取为高电平(3.3V)或低电平(0V)。使用内部上拉或下拉电阻更容易做到这一点。引脚GPIO2和GPIO3具有固定的上拉电阻,但对于其他引脚,这可以在软件中配置。
MORE
除了简单的输入和输出设备,GPIO引脚还可以用于各种替代功能,有些可用于所有引脚,有些可用于特定引脚。
PWM (脉冲宽度调制)
Software PWM available on all pins
Hardware PWM available on GPIO12, GPIO13, GPIO18, GPIO19
SPI
SPI0: MOSI (GPIO10); MISO (GPIO9); SCLK (GPIO11); CE0 (GPIO8), CE1 (GPIO7)
SPI1: MOSI (GPIO20); MISO (GPIO19); SCLK (GPIO21); CE0 (GPIO18); CE1 (GPIO17); CE2 (GPIO16)
I2C
Data: (GPIO2); Clock (GPIO3)
EEPROM Data: (GPIO0); EEPROM Clock (GPIO1)
Serial
TX (GPIO14); RX (GPIO15)
有关GPIO引脚高级功能的更多信息,请参见interactive pinout diagram
raspi-gpio
raspi-gpio是一个在树莓派上使用的GPIO控制工具,可以获取GPIO状态以及设置GPIO
安装
sudo apt -y install raspi-gpio
使用说明
Use:
raspi-gpio get [GPIO]
OR
raspi-gpio set [options]
OR
raspi-gpio funcs [GPIO]
OR
raspi-gpio raw
GPIO is a comma-separated list of pin numbers or ranges (without spaces),
e.g. 4 or 18-21 or 7,9-11
Note that omitting [GPIO] from raspi-gpio get prints all GPIOs.
raspi-gpio funcs will dump all the possible GPIO alt funcions in CSV format
or if [GPIO] is specified the alternate funcs just for that specific GPIO.
Valid [options] for raspi-gpio set are:
ip set GPIO as input
op set GPIO as output
a0-a5 set GPIO to alternate function alt0-alt5
pu set GPIO in-pad pull up
pd set GPIO pin-pad pull down
pn set GPIO pull none (no pull)
dh set GPIO to drive to high (1) level (only valid if set to be an output)
dl set GPIO to drive low (0) level (only valid if set to be an output)
Examples:
raspi-gpio get Prints state of all GPIOs one per line
raspi-gpio get 20 Prints state of GPIO20
raspi-gpio get 20,21 Prints state of GPIO20 and GPIO21
raspi-gpio set 20 a5 Set GPIO20 to ALT5 function (GPCLK0)
raspi-gpio set 20 pu Enable GPIO20 ~50k in-pad pull up
raspi-gpio set 20 pd Enable GPIO20 ~50k in-pad pull down
raspi-gpio set 20 op Set GPIO20 to be an output
raspi-gpio set 20 dl Set GPIO20 to output low/zero (must already be set as an output)
raspi-gpio set 20 ip pd Set GPIO20 to input with pull down
raspi-gpio set 35 a0 pu Set GPIO35 to ALT0 function (SPI_CE1_N) with pull up
raspi-gpio set 20 op pn dh Set GPIO20 to ouput with no pull and driving high
GPIO功能及复用功能表
转载来自:https://rpideveloper.com/topic/34/gpio
  • 物联网
  • 工控机
  • GPIO
  • 树莓派
    GPIO树莓中的应用
    树莓(Raspberry Pi)是一款由英国树莓基金会开发的信用卡大小的单板计算机,它具有强大的功能和灵活性,可以用于各种项目和应用。通
    的头像 发表于 01-09 09:41 234次阅读
    树莓传感器使用方法 树莓 Raspberry Pi 4优缺点
    开发和物联网应用。以下是一些基本的树莓传感器使用方法: 1. 连接传感器 GPIO引脚 :树莓GP
    的头像 发表于 12-06 10:35 917次阅读
    树莓开发的最佳编程语言选择
    应用。 1. Python 优势: 易学易用: Python以其简洁的语法和强大的功能而闻名,非常适合初学者。 广泛的库支持: Python拥有大量的库,如GPIO Zero、PiGPIO等,这些库使得控制树莓
    的头像 发表于 11-11 11:34 975次阅读
    树莓与Arduino的区别是什么
    在当今的科技世界中,树莓(Raspberry Pi)和Arduino是两个经常被提及的名字。它们都是开源硬件平台,但它们的目标、功能和用途却大相径庭。 1. 目标和用途 树莓
    的头像 发表于 11-11 11:14 1287次阅读
    树莓gpio有什么用,树莓gpio接口及编程方法
    一、树莓GPIO的用途 树莓(Raspberry Pi)是一款小巧、功能强大的单板计算机,广
    的头像 发表于 10-22 18:09 1334次阅读
    什么是树莓树莓是什么架构的
    信用卡大小,但具备所有PC的基本功能。 起源与背景 2006年,树莓的早期概念基于Atmel的ATmega644单片机。 2012年3月,由英国剑桥大学的埃本·阿普顿(Eben Upton)正式发售
    的头像 发表于 10-22 17:33 1432次阅读
    树莓和单片机的优缺点是什么
    (Raspberry Pi) 优点: 强大的处理能力 :树莓配备了高性能的CPU和GPU,可以运行复杂的操作系统,如Linux和Windows 10 IoT Core。 丰富的扩展性 :通过GPIO(通用输入输出
    的头像 发表于 08-30 18:21 1972次阅读
    树莓功能用途是什么
    树莓(Raspberry Pi)是一款由英国树莓基金会研发的信用卡大小的单板计算机,自2012年推出以来,已经发展出多个型号和版本。树莓
    的头像 发表于 08-30 18:01 3190次阅读
    树莓gui开发用什么ide
    树莓(Raspberry Pi)是一款功能强大的微型计算机,可以运行多种操作系统,如Raspbian、Ubuntu等。在树莓派上进行GUI(图形用户界面)开发,可以使用多种集成开发环
    的头像 发表于 08-30 16:49 1096次阅读
    树莓5,Raspberry Pi 5 评测
    完全盖住”。稍后我们将在评测中讨论其中的原因。 我们先来看看树莓5的两个新功能。 首先,我们有了实时时钟的电池备份。树莓5现在可以在没
    发表于 06-19 14:51
    Hailo联手树莓,开创人工智能新纪元
    近日,人工智能处理器领导品牌Hailo正式宣布与树莓展开深度合作。Hailo将为树莓推出专用AI套件,支持树莓
    的头像 发表于 06-06 16:08 806次阅读
    树莓携手Hailo为其新品注入人工智能功能
    套件用于支持树莓5的AI功能。此次合作将以先进的人工智能功能助力专业以及创作爱好者在智能家居、安全、机器人等领域中提升解决方案效率。 Hailo的首席执行官兼联合创始人Orr Dan
    的头像 发表于 06-06 10:18 460次阅读
    Waveshare推出树莓红外热像仪,可智能检测报警和过热问题
    Waveshare近日推出针对树莓的红外线热像仪。此设备能借助GPIO接口与树莓派对接,拓展其功能领域。除正常的
    的头像 发表于 05-20 14:45 728次阅读
    STM8L152C6芯片的引脚复用功能怎么配置啊?
    各位大侠求助,STM8L152C6芯片的引脚复用功能怎么配置啊,比如我想用USART3,它是在PE6——USART3_TX,PE7——USART3_RX ,但是这两个引脚还有一些其他的复用功能,我怎么让它开启USART3的功能
    发表于 05-07 06:00
    APM510/FT电能质量分析多功能表
    APM510/FT电能质量分析多功能表按 IEC 国际标准设计,具有全电量测量、电能统计、电能质 量分析(包括谐波、间谐波、闪变)、故障录波功能(包括电压暂升暂降中断、冲击电流等记录)、事件记录功 能及网络通讯等
    的头像 发表于 03-08 16:11 444次阅读
    APM510/FT电能质量分析多<b class='flag-5'>功能表</b>
