计算机系统对数值类型的编码、运算、转换原理介绍4
jf_78858299 来源:元闰子的邀请 作者:元闰子 2023-05-09 16:31 次阅读
数值类型转换
数值类型间的转换,可以分成 2 类: 宽转换 (Widening Conversion)和 窄转换 (Narrowing Conversion)。
宽转换指往表示范围更广的类型转换,比如从 int 到 long、从 long 到 float;窄转换则相反。
整型间转换
(1)宽转换
整型间的宽转换不会产生溢出,无符号整数场景,高位补零;有符号整数场景,高位补符号位。
// C++
int main() {
    int8_t i1 = 100;
    cout << "int8_t  i1: " << bitset<8>(i1) << endl;
    cout << "int16_t i1: " << bitset<16>((int16_t) i1) << endl;
    int8_t i2 = -100;
    cout << "int8_t  i2: " << bitset<8>(i2) << endl;
    cout << "int16_t i2: " << bitset<16>((int16_t) i2) << endl;
    uint8_t i3 = 200;
    cout << "uint8_t  i3: " << bitset<8>(i3) << endl;
    cout << "uint16_t i3: " << bitset<16>((uint16_t) i3) << endl;
    return 0;
// 输出结果
int8_t  i1: 01100100
int16_t i1: 0000000001100100
int8_t  i2: 10011100
int16_t i2: 1111111110011100
uint8_t  i3: 11001000
uint16_t i3: 0000000011001000
(2)窄转换
整型间的窄转换直接进行高位截断,只保留低 n 位。比如 16 位的 int16 转换为 8 位的 int8,直接保留 int16 类型值的低 8 位作为转换结果。
// C++
int main() {
    int16_t i1 = 200;
    cout << "int16_t i1: " << bitset<16>(i1) << endl;
    cout << "int8_t  i1: " << bitset<8>((int8_t) i1) << endl;
    int16_t i2 = -200;
    cout << "int16_t i2: " << bitset<16>(i2) << endl;
    cout << "int8_t  i2: " << bitset<8>((int8_t) i2) << endl;
    uint16_t i3 = 300;
    cout << "uint16_t i3: " << bitset<16>(i3) << endl;
    cout << "uint8_t  i3: " << bitset<8>((uint8_t) i3) << endl;
    return 0;
// 输出结果
int16_t i1: 0000000011001000
int8_t  i1: 11001000
int16_t i2: 1111111100111000
int8_t  i2: 00111000
uint16_t i3: 0000000100101100
uint8_t  i3: 00101100
(3)无符号整数与有符号整数间的转换
无符号整数与有符号整数间的转换规则是:
  • 如果两者二进制位数一致,比如 int8uint8 的转换,则二进制数值不变,只是改变编码方式;
  • 如果位数不一致,比如 int16uint8 的转换,则二进制数值,先按照宽转换或窄转换规则转换,再改变编码方式。
// C++
int main() {
    uint8_t i1 = 200;
    cout << "uint8_t i1, decimal: " << +i1 << ", binary: " << bitset<8>(i1) << endl;
    cout << "int8_t  i1, decimal: " << +(int8_t) i1 << ", binary: " << bitset<8>((int8_t) i1) << endl;
    int16_t i2 = -300;
    cout << "int16_t i2, decimal: " << +i2 << ", binary: " << bitset<16>(i2) << endl;
    cout << "uint8_t i2, decimal: " << +(uint8_t) i2 << ",  binary: " << bitset<8>((uint8_t) i2) << endl;
    return 0;
// 输出结果
uint8_t i1, decimal: 200, binary: 11001000
int8_t  i1, decimal: -56, binary: 11001000
int16_t i2, decimal: -300, binary: 1111111011010100
uint8_t i2, decimal: 212,  binary: 11010100
整数与浮点数间转型
(1)宽转换
整型到浮点数类型的转换这一方向,为宽转换:
  • 如果浮点数的精度,能够表示整数,则正常转换。
  • 如果浮点数精度,无法表示整数,则需要近似,会导致精度丢失。
// Java
public static void main(String[] args) {
    int i1 = 1234567;
    System.out.printf("int i1: %d, float i1: ", i1);
    System.out.println((float) i1);
    int i2 = 123456789;
    System.out.printf("int i2: %d, float i2: ", i2);
    System.out.println((float) i2);
// 输出结果
int i1: 1234567, float i1: 1234567.0
int i2: 123456789, float i2: 1.23456792E8
上述例子中,i2=123456789 超过 float 类型能够表示的精度,所以为近似后的结果 1.23456792E8
那么,为什么 123456789 会近似为 1.23456792E8
要解释该问题,首先要把它们转换成二进制表示:
    System.out.println("int i2:   " + int2BinaryStr(i2));
    System.out.println("float i2: " + float2BinaryStr((float) i2));
// 输出结果
int i2:   00000111010110111100110100010101
float i2: 01001100111010110111100110100011
接下来,我们根据 IEEE 浮点数的编码规则,尝试将 int i2 转换成 float i2
  1. int i2 的二进制 ,可以写成 ,对应到 的形式,可以确认 s = 0,E = 26,M = 1.11010110111100110100010101。
  2. float 类型中 k = 8,有,,得出 e = 153,按 k 位无符号编码表示为 。
  3. 同理,由 ,但由于 float 类型的 n = 23,而 m 一共有 26 位,因此需要按照 round-to-even 规则,对 0.11010110111100110100010101进行近似,保留 23 位小数,得到 0.11010110111100110100011,所以 m 为
  4. 最后,将 s、e、m 按照 float 单精度的编码格式组合起来,就是 ,转换成十进制,就是 1.23456792E8
(2)窄转换
浮点数类型到整型的转换这一方向,为窄转换:
  • 如果浮点数的整数部分,能够用整型表示,则直接舍去小数,保留整数部分。
  • 如果超出了整型范围,则结果为该整型的最大/最小值。
// Java
    float f1 = 12345.123F;
    System.out.print("float f1: ");
    System.out.print(f1);
    System.out.printf(",  int f1: %d\\n", (int) f1);
    float f2 = 1.2345E20F;
    System.out.print("float f2: ");
    System.out.print(f2);
    System.out.printf(",  int f2: %d\\n", (int) f2);
    float f3 = -1.2345E20F;
    System.out.print("float f3: ");
    System.out.print(f3);
    System.out.printf(", int f3: %d\\n", (int) f3);
// 输出结果
float f1: 12345.123,  int f1: 12345
float f2: 1.2345E20,  int f2: 2147483647
float f3: -1.2345E20, int f3: -2147483648
浮点数间转型
(1)宽转换
单精度 float 到 双精度 double 为宽转换,不会出现精度丢失的问题。
对于 ,规则如下:
  • s 保持不变。
  • 在 E 保持不变的前提下,因为 float 的 k = 8,而 double 的 k = 11,所以两者的 e 会有所不同。
  • 在 M 保持不变的前提下,float 的 n = 23,而 double 的 n =52,所以 m 需要低位补 52 - 23 = 29 个 0。
// Java
    float f1 = 1.2345E20F;
    System.out.print(", double f1: ");
    System.out.println((double) f1);
    System.out.println("float  f1: " + float2BinaryStr(f1));
    System.out.println("double f1: " + double2BinaryStr((double) f1));
// 输出结果
float  f1: 1.2345E20, double f1: 1.2344999897320129E20
float  f1: 01100000110101100010011011010000
double f1: 0100010000011010110001001101101000000000000000000000000000000000
(2)窄转换
doublefloat 为窄转换,会存在精度丢失问题。
如果 double 值超出了 float 的表示范围,则转换结果为 Infinity
// Java
    double d1 = 1E200;
    System.out.print("double d1: ");
    System.out.println(d1);
    System.out.print("float d1: ");
    System.out.println((float) d1);
    double d2 = -1E200;
    System.out.print("double d2: ");
    System.out.println(d2);
    System.out.print("float d2: ");
    System.out.println((float) d2);
// 输出结果
double d1: 1.0E200
float d1: Infinity
double d2: -1.0E200
float d2: -Infinity
如果 double 值还在 float 的表示范围内,则按照如下转换规则:
  • s 保持不变。
  • 对于 M,因为 float 的 n = 23,而 double 的 n = 52,所以转换到 float 之后,需要进行截断,只保留高 23 位。
// Java
    double d1 = 3.267393471324506;
    System.out.println("double d1: " + double2BinaryStr(d1));
    System.out.println("float  d1: " + float2BinaryStr((float) d1));
// 输出结果
double d1: 3.267393471324506
float  d1: 3.2673936
double d1: 0100000000001010001000111001111100110000001101000000010101110110
float  d1: 01000000010100010001110011111010
最后
本文花了很长的篇幅,深入介绍了计算机系统对数值类型的编码、运算、转换的底层原理。
数值类型间的转换是最容易出现隐藏 bug 的地方 ,特别是无符号整数与有符号整数之间的转换。所以,很多现代的编程语言,如 Java、Go 等都不再支持无符号整数,根除了该隐患。
另外,浮点数的编码方式,注定它只能精确表示一小部分的数值范围,大部分都是近似,所以才有了不能用等号来比较两个浮点数的说法。
数值类型虽然很基础,但使用时一定要多加小心。希望本文能够加深你对数值类型的理解,让你写出更健壮的程序。
  • 二进制
  • 计算机
  • 编程
    计算机系统结构
    计算机系统结构
    发表于 05-09 19:03
    什么是计算机系统计算机硬件和计算机软件?
    第一章 计算机系统概论1. 什么是计算机系统计算机硬件和计算机软件?硬件和软件哪个更重要?解:P3计算机系统:由
    发表于 07-22 09:06
    什么是计算机系统?硬件和软件哪个更重要?
    第一章计算机系统概论1 .什么是计算机系统计算机硬件和计算机软件?硬件和软件哪个更重要?解: P3计算机系统:由
    发表于 07-26 07:18
    计算机系统中的软件系统
    专用计算机现代计算机运算速度最高可达每秒几万亿次几十亿次几亿次几万次计算机辅助制造是计算机应用领域之一其英文缩写是所谓的信息是指基本素材非数值
    发表于 09-13 07:22
    嵌入式计算机系统概述
    硬件子系统和软件子系统组成的,通过运行程序来协同工作计算机硬件:基本的计算机硬件系统运算器、控
    发表于 12-22 06:08
    简单介绍微型计算机的组成
    你了解自己的计算机?或者知道单片机的组成吗?这一小节主要简单介绍微型计算机的组成,以及微型计算机系统经常用到的概念,包括组成、工作过程、工作原理、
    发表于 01-10 07:11
    计算机系统概论
    1.1 计算机系统简介1.2 计算机的基本组成1.3 计算机硬件的主要技术指标1.4 本书结构
    发表于 04-11 09:31 0次下载
    微型计算机系统
             微型计算机系统与传统的计算机系统一样,也是由硬件系统和软件系统两大部分组成的。2.1
    发表于 03-03 08:31 0次下载
    什么是计算机系统的容错性
    什么是计算机系统的容错性             所谓容错是指在故障存在的情况下计算机系统不失效,仍然能够正常工作的特性
    发表于 01-08 13:49 1634次阅读
    深入理解计算机系统数值类型
    计算机系统中,整数可以分成 无符号(unsigned)整数 和 有符号(signed)整数 两大类,这之下,按照类型表示的 bit 位大小,又可细分成 8 位的 char/byte/int8
    的头像 发表于 08-19 15:17 1192次阅读
    计算机系统对数值类型编码运算转换原理介绍1
    。正因太熟悉,我们往往不会深究它们的底层原理。因为平时的工作中,知道个大概,也够用了。 但,在某些业务场景下,比如金融业务,数值运算不准确会带来灾难性的后果。这时,你就必须清楚数值类型
    的头像 发表于 05-09 16:30 1185次阅读
    <b class='flag-5'>计算机系统</b><b class='flag-5'>对数值</b><b class='flag-5'>类型</b>的<b class='flag-5'>编码</b>、<b class='flag-5'>运算</b>、<b class='flag-5'>转换</b>原理<b class='flag-5'>介绍</b>1
    计算机系统对数值类型编码运算转换原理介绍2
    的头像 发表于 05-09 16:31 925次阅读
    <b class='flag-5'>计算机系统</b><b class='flag-5'>对数值</b><b class='flag-5'>类型</b>的<b class='flag-5'>编码</b>、<b class='flag-5'>运算</b>、<b class='flag-5'>转换</b>原理<b class='flag-5'>介绍</b>2
    计算机系统对数值类型编码运算转换原理介绍3
    的头像 发表于 05-09 16:31 834次阅读
    <b class='flag-5'>计算机系统</b><b class='flag-5'>对数值</b><b class='flag-5'>类型</b>的<b class='flag-5'>编码</b>、<b class='flag-5'>运算</b>、<b class='flag-5'>转换</b>原理<b class='flag-5'>介绍</b>3
    计算机系统中的关键组件有哪些
    计算机系统中,关键组件的协同工作构成了其强大的数据处理和运算能力。这些组件不仅决定了计算机的性能,还影响着用户的使用体验。以下是对计算机系统中关键组件的详细阐述,包括它们的定义、功能
    的头像 发表于 07-15 18:18 1623次阅读
    微处理器如何控制计算机系统
    微处理器,作为计算机系统的核心部件,承担着控制整个计算机系统运行的重要任务。它不仅是计算机运算中心,还是控制中心,负责执行程序指令、处理数据以及协调
    的头像 发表于 08-22 14:21 504次阅读
