基于DWC2的USB驱动开发-0x06 DWC2 USB2.0 IP 头文件与寄存器的读写操作 (qq.com)
前言
上一篇我们介绍了控制器的寄存器,而驱动的编写底层无非就是配置各种寄存器,所以第一步先要准备寄存器的头文件,对寄存器的操作进行封装。
我们这里提供两种形式,结构体形式和宏的形式。
结构体形式的头文件
该方式的好处是方便阅读,且编辑器可以自动补全输入。
先定义一个总的结构体包含所有寄存器
typedef struct usb_otg_reg {
gotgctl_u gotgctl;
gotgint_u gotgint;
gahbcfg_u gahbcfg;
gusbcfg_u gusbcfg;
grstctl_u grstctl;
gintsts_u gintsts;
gintmsk_u gintmsk;
grxstsr_u grxstsr;
grxstsp_u grxstsp;
grxfsiz_u grxfsiz;
gnptxfsiz_u gnptxfsiz;
gnptxsts_u gnptxsts;
uint32_t reserved_0;
gpvndctl_u gpvndctl;
uint32_t reserved_1[3];
ghwcfg1_u ghwcfg1;
ghwcfg2_u ghwcfg2;
ghwcfg3_u ghwcfg3;
ghwcfg4_u ghwcfg4;
uint32_t reserved_2[2];
gdfifocfg_u gdfifocfg;
uint32_t reserved_3;
grefclk_u grefclk;
uint32_t reserved_4[38];
hptxfsiz_u hptxfsiz;
dieptxf1_u dieptxf1;
uint32_t reserved_5[446];
dcfg_u dcfg;
dctl_u dctl;
dsts_u dsts;
uint32_t reserved_6;
diepmsk_u diepmsk;
doepmsk_u doepmsk;
daint_u daint;
daintmsk_u daintmsk;
uint32_t reserved_7[4];
dthrctl_u dthrctl;
uint32_t reserved_8;
deachint_u deachint;
deachintmsk_u deachintmsk;
diepeachmsk0_u diepeachmsk0;
uint32_t reserved_9[15];
doepeachmsk0_u doepeachmsk0;
uint32_t reserved_10[31];
diepctl0_u diepctl0;
uint32_t reserved_11;
diepint0_u diepint0;
uint32_t reserved_12;
dieptsiz0_u dieptsiz0;
diepdma0_u diepdma0;
dtxfsts0_u dtxfsts0;
diepdmab0_u diepdmab0;
diepctl1_u diepctl1;
uint32_t reserved_13[119];
doepctl0_u doepctl0;
uint32_t reserved_14;
doepint0_u doepint0;
uint32_t reserved_15;
doeptsiz0_u doeptsiz0;
doepdma0_u doepdma0;
uint32_t reserved_16;
doepdmab0_u doepdmab0;
doepctl1_u doepctl1;
uint32_t reserved_17[183];
pcgcctl_u pcgcctl;
pcgcctl1_u pcgcctl1;
} usb_otg_reg_t;
然后每个寄存器都按照结构体解析
以 gotgctl_u gotgctl;
为例
typedef union gotgctl_union {
uint32_t w;
struct {
uint32_t sesreqscs:1; // [0]
uint32_t sesreq:1; // [1]
uint32_t vbvalidoven:1; // [2]
uint32_t vbvalidovval:1; // [3]
uint32_t avalidoven:1; // [4]
uint32_t avalidovval:1; // [5]
uint32_t bvalidoven:1; // [6]
uint32_t bvalidovval:1; // [7]
uint32_t hstnegscs:1; // [8]
uint32_t hnpreq:1; // [9]
uint32_t hstsethnpen:1; // [10]
uint32_t devhnpen:1; // [11]
uint32_t ehen:1; // [12]
uint32_t reserved_0:2; // [13,14]
uint32_t dbncefltrbypass:1; // [15]
uint32_t conldsts:1; // [16]
uint32_t dbnctime:1; // [17]
uint32_t asesvld:1; // [18]
uint32_t bsesvld:1; // [19]
uint32_t otgver:1; // [20]
uint32_t curmod:1; // [21]
uint32_t multvalidbc:5; // [22,26]
uint32_t chirpen:1; // [27]
uint32_t reserved_1:3; // [28,30]
uint32_t testmode_corr_eusb2:1; // [31]
} _b;
} gotgctl_u;
配置寄存器即配置结构体的位域
所只要按照如下方式先定义寄存器基地址
#define USB_MAC_REG_BASEADDR 0x03000000
然后定义一个指向上述结构体的指针,注意要添加volatile否则编译器会优化导致问题。
static volatile usb_otg_reg_t* g_usb_reg = (usb_otg_reg_t*)USB_MAC_REG_BASEADDR;
然后就可以通过如下形式写指定的位域,读也类似。
g_usb_reg->gotgctl._b.sesreq = 1;
如果直接访问整个寄存器则可以用g_usb_reg->gotgctl.w
宏形式的头文件
该方式是先定义寄存器的偏移地址
#define CFG_GOTGCTL_ADDR 0x0000
然后定义位域的MASK操作值和位域的偏移值
#define TESTMODE_CORR_EUSB2_OFFSET 31
#define TESTMODE_CORR_EUSB2_MASK 0x80000000
#define CHIRPEN_OFFSET 27
#define CHIRPEN_MASK 0x08000000
#define MULTVALIDBC_OFFSET 22
#define MULTVALIDBC_MASK 0x07C00000
#define CURMOD_OFFSET 21
#define CURMOD_MASK 0x00200000
#define OTGVER_OFFSET 20
#define OTGVER_MASK 0x00100000
#define BSESVLD_OFFSET 19
#define BSESVLD_MASK 0x00080000
#define ASESVLD_OFFSET 18
#define ASESVLD_MASK 0x00040000
#define DBNCTIME_OFFSET 17
#define DBNCTIME_MASK 0x00020000
#define CONLDSTS_OFFSET 16
#define CONLDSTS_MASK 0x00010000
#define DBNCEFLTRBYPASS_OFFSET 15
#define DBNCEFLTRBYPASS_MASK 0x00008000
#define EHEN_OFFSET 12
#define EHEN_MASK 0x00001000
#define DEVHNPEN_OFFSET 11
#define DEVHNPEN_MASK 0x00000800
#define HSTSETHNPEN_OFFSET 10
#define HSTSETHNPEN_MASK 0x00000400
#define HNPREQ_OFFSET 9
#define HNPREQ_MASK 0x00000200
#define HSTNEGSCS_OFFSET 8
#define HSTNEGSCS_MASK 0x00000100
#define BVALIDOVVAL_OFFSET 7
#define BVALIDOVVAL_MASK 0x00000080
#define BVALIDOVEN_OFFSET 6
#define BVALIDOVEN_MASK 0x00000040
#define AVALIDOVVAL_OFFSET 5
#define AVALIDOVVAL_MASK 0x00000020
#define AVALIDOVEN_OFFSET 4
#define AVALIDOVEN_MASK 0x00000010
#define VBVALIDOVVAL_OFFSET 3
#define VBVALIDOVVAL_MASK 0x00000008
#define VBVALIDOVEN_OFFSET 2
#define VBVALIDOVEN_MASK 0x00000004
#define SESREQ_OFFSET 1
#define SESREQ_MASK 0x00000002
#define SESREQSCS_OFFSET 0
#define SESREQSCS_MASK 0x00000001
然后提供寄存器读写的宏
#define SOC_READ_REG(addr) ((volatile uint32_t) * ((volatile uint32_t *)(addr)))
#define SOC_WRITE_REG(addr, value) (*((volatile uint32_t *)(addr)) = (value))
#define USB_OTG_READ_REG(addr) SOC_READ_REG(USB_MAC_REG_BASEADDR + addr)
#define USB_OTG_WRITE_REG(addr,value) SOC_WRITE_REG(USB_MAC_REG_BASEADDR + addr,value)
按照读-修改-写的操作方式
比如
uint32_t tmp = USB_OTG_READ_REG(CFG_GOTGCTL_ADDR); /* 读 */
tmp &= ~SESREQ_MASK; /* 清除需要修改的位 */
tmp |= 1 << SESREQ_OFFSET; /* 写对应的位值为1 */
对于端点相关寄存器的处理
端点相关的寄存器内容都是一样的只是开始地址不一样
diepctl0_u diepctl0; 端点0
diepctl1_u diepctl1; 端点1 偏移0x20
可以根据端点偏移0x20得到后面端点对应的寄存器的地址。
最好是将其改为数组形式,因为端点0和后续端点有一点不一样,后续的端点单独设置为数组,通过数组索引得到端点对应的寄存器。
doepctlxxx
等相关的也类似。
宏方式则直接通过端点1的地址偏移0x20得到后续寄存器地址。
总结
以上介绍了寄存器相关的头文件,这是驱动编写的第一步。保证寄存器的读写OK之后,后面就可以开始进行驱动的编写了。后面就是要不断的参考编程手册和寄存器描述。
附录 头文件
结构体
#ifndef USB_OTG_REG_H
#define USB_OTG_REG_H
#define USB_OTG_IP_VERSION 1
uint32_t w;
struct {
} _b;
} gotgctl_u;
typedef union gotgint_union {
uint32_t w;
struct {
uint32_t reserved_0:2; // [0,1]
uint32_t sesenddet:1; // [2]
uint32_t reserved_1:5; // [3,7]
uint32_t sesreqsucstschng:1; // [8]
uint32_t hstnegsucstschng:1; // [9]
uint32_t reserved_2:7; // [10,16]
uint32_t hstnegdet:1; // [17]
uint32_t adevtoutchg:1; // [18]
uint32_t dbncedone:1; // [19]
uint32_t multvalpchng:1; // [20]
uint32_t reserved_3:11; // [21,31]
} _b;
} gotgint_u;
typedef union gahbcfg_union {
uint32_t w;
struct {
uint32_t glbintrmsk:1; // [0]
uint32_t hbstlen:4; // [1,4]
uint32_t dmaen:1; // [5]
uint32_t reserved_0:1; // [6]
uint32_t nptxfemplvl:1; // [7]
uint32_t ptxfemplvl:1; // [8]
uint32_t reserved_1:12; // [9,20]
uint32_t remmemsupp:1; // [21]
uint32_t notialldmawrit:1; // [22]
uint32_t ahbsingle:1; // [23]
uint32_t invdescendianess:1; // [24]
uint32_t reserved_2:7; // [25,31]
} _b;
} gahbcfg_u;
typedef union gusbcfg_union {
uint32_t w;
struct {
uint32_t toutcal:3; // [0,2]
uint32_t phyif:1; // [3]
uint32_t ulpi_utmi_sel:1; // [4]
uint32_t fsintf:1; // [5]
uint32_t physel:1; // [6]
uint32_t ddrsel:1; // [7]
uint32_t srpcap:1; // [8]
uint32_t hnpcap:1; // [9]
uint32_t usbtrdtim:4; // [10,13]
uint32_t reserved:1; // [14]
uint32_t phylpwrclksel:1; // [15]
uint32_t otgi2csel:1; // [16]
uint32_t ulpifsls:1; // [17]
uint32_t ulpiautores:1; // [18]
uint32_t ulpiclksusm:1; // [19]
uint32_t ulpiextvbusdrv:1; // [20]
uint32_t ulpiextvbusindicator:1; // [21]
uint32_t termseldlpulse:1; // [22]
uint32_t complement:1; // [23]
uint32_t indicator:1; // [24]
uint32_t ulpi:1; // [25]
uint32_t ic_usbcap:1; // [26]
uint32_t ic_usbtrafctl:1; // [27]
uint32_t txenddelay:1; // [28]
uint32_t forcehstmode:1; // [29]
uint32_t forcedevmode:1; // [30]
uint32_t corrupttxpkt:1; // [31]
} _b;
} gusbcfg_u;
typedef union grstctl_union {
uint32_t w;
struct {
uint32_t csftrst:1; // [0]
uint32_t piufssftrst:1; // [1]
uint32_t frmcntrrst:1; // [2]
uint32_t intknqflsh:1; // [3]
uint32_t rxfflsh:1; // [4]
uint32_t txfflsh:1; // [5]
uint32_t txfnum:5; // [6,10]
uint32_t reserved:19; // [11,29]
uint32_t dmareq:1; // [30]
uint32_t ahbidle:1; // [31]
} _b;
} grstctl_u;
typedef union gintsts_union {
uint32_t w;
struct {
uint32_t curmodsts:1; // [0]
uint32_t modemis:1; // [1]
uint32_t otgint:1; // [2]
uint32_t sof:1; // [3]
uint32_t rxflvl:1; // [4]
uint32_t nptxfemp:1; // [5]
uint32_t ginnakeff:1; // [6]
uint32_t goutnakeff:1; // [7]
uint32_t ulpickint:1; // [8]
uint32_t i2cint:1; // [9]
uint32_t erlysusp:1; // [10]
uint32_t usbsusp:1; // [11]
uint32_t usbrst:1; // [12]
uint32_t enumdone:1; // [13]
uint32_t isooutdrop:1; // [14]
uint32_t eopf:1; // [15]
uint32_t rstrdoneint:1; // [16]
uint32_t epmis:1; // [17]
uint32_t iepint:1; // [18]
uint32_t oepint:1; // [19]
uint32_t incompsoin:1; // [20]
uint32_t incompip:1; // [21]
uint32_t fetsusp:1; // [22]
uint32_t resetdet:1; // [23]
uint32_t prtint:1; // [24]
uint32_t hchint:1; // [25]
uint32_t ptxfemp:1; // [26]
uint32_t lpm_int:1; // [27]
uint32_t conldstschng:1; // [28]
uint32_t disconnint:1; // [29]
uint32_t sessreqint:1; // [30]
uint32_t wkupint:1; // [31]
} _b;
} gintsts_u;
typedef union gintmsk_union {
uint32_t w;
struct {
uint32_t reserved:1; // [0]
uint32_t modemismsk:1; // [1]
uint32_t otgintmsk:1; // [2]
uint32_t sofmsk:1; // [3]
uint32_t rxflvlmsk:1; // [4]
uint32_t nptxfempmsk:1; // [5]
uint32_t ginnakeffmsk:1; // [6]
uint32_t goutnakeffmsk:1; // [7]
uint32_t ulpickintmsk:1; // [8]
uint32_t i2cintmsk:1; // [9]
uint32_t erlysuspmsk:1; // [10]
uint32_t usbsuspmsk:1; // [11]
uint32_t usbrstmsk:1; // [12]
uint32_t enumdonemsk:1; // [13]
uint32_t isooutdropmsk:1; // [14]
uint32_t eopfmsk:1; // [15]
uint32_t rstrdoneintmsk:1; // [16]
uint32_t epmismsk:1; // [17]
uint32_t iepintmsk:1; // [18]
uint32_t oepintmsk:1; // [19]
uint32_t incompsoinmsk:1; // [20]
uint32_t incompipmsk:1; // [21]
uint32_t fetsuspmsk:1; // [22]
uint32_t resetdetmsk:1; // [23]
uint32_t prtintmsk:1; // [24]
uint32_t hchintmsk:1; // [25]
uint32_t ptxfempmsk:1; // [26]
uint32_t lpm_intmsk:1; // [27]
uint32_t conldstschngmsk:1; // [28]
uint32_t disconnintmsk:1; // [29]
uint32_t sessreqintmsk:1; // [30]
uint32_t wkupintmsk:1; // [31]
} _b;
} gintmsk_u;
typedef union grxstsr_union {
uint32_t w;
struct {
uint32_t chnum:4; // [0,3]
uint32_t bcnt:11; // [4,14]
uint32_t dpid:2; // [15,16]
uint32_t pktsts:4; // [17,20]
uint32_t fn:4; // [21,24]
uint32_t reserved:7; // [25,31]
} _b;
} grxstsr_u;
typedef union grxstsp_union {
uint32_t w;
struct {
uint32_t chnum_pop:4; // [0,3]
uint32_t bcnt_pop:11; // [4,14]
uint32_t dpid_pop:2; // [15,16]
uint32_t pktsts_pop:4; // [17,20]
uint32_t fn_pop:4; // [21,24]
} _b;
} grxstsp_u;
typedef union grxfsiz_union {
uint32_t w;
struct {
uint32_t rxfdep:11; // [0,10]
uint32_t reserved:21; // [11,31]
} _b;
} grxfsiz_u;
typedef union gnptxfsiz_union {
uint32_t w;
struct {
uint32_t nptxfstaddr:11; // [0,10]
uint32_t reserved_0:5; // [11,15]
uint32_t nptxfdep:11; // [16,26]
uint32_t reserved_1:5; // [27,31]
} _b;
} gnptxfsiz_u;
typedef union gnptxsts_union {
uint32_t w;
struct {
uint32_t nptxfspcavail:16; // [0,15]
uint32_t nptxqspcavail:8; // [16,23]
uint32_t nptxftop:7; // [24,30]
uint32_t reserved:1; // [31]
} _b;
} gnptxsts_u;
typedef union gpvndctl_union {
uint32_t w;
struct {
uint32_t regdata:8; // [0,7]
uint32_t vctrl:8; // [8,15]
uint32_t regaddr:6; // [16,21]
uint32_t regwr:1; // [22]
uint32_t reserved_0:2; // [23,24]
uint32_t newregreq:1; // [25]
uint32_t vstsbsy:1; // [26]
uint32_t vstsdone:1; // [27]
uint32_t disulpidrv:1; // [31]
} _b;
} gpvndctl_u;
typedef union ghwcfg1_union {
uint32_t w;
struct {
uint32_t epdir:32; // [0,31]
} _b;
} ghwcfg1_u;
typedef union ghwcfg2_union {
uint32_t w;
struct {
uint32_t otgmode:3; // [0,2]
uint32_t otgarch:2; // [3,4]
uint32_t singpnt:1; // [5]
uint32_t hsphytype:2; // [6,7]
uint32_t fsphytype:2; // [8,9]
uint32_t numdeveps:4; // [10,13]
uint32_t numhstchnl:4; // [14,17]
uint32_t periosupport:1; // [18]
uint32_t dynfifosizing:1; // [19]
uint32_t multiprocintrpt:1; // [20]
uint32_t reserved:1; // [21]
uint32_t nptxqdepth:2; // [22,23]
uint32_t ptxqdepth:2; // [24,25]
uint32_t tknqdepth:5; // [26,30]
uint32_t otg_enable_ic_usb:1; // [31]
} _b;
} ghwcfg2_u;
typedef union ghwcfg3_union {
uint32_t w;
struct {
uint32_t xfersizewidth:4; // [0,3]
uint32_t pktsizewidth:3; // [4,6]
uint32_t otgen:1; // [7]
uint32_t i2cintsel:1; // [8]
uint32_t vndctlsupt:1; // [9]
uint32_t optfeature:1; // [10]
uint32_t rsttype:1; // [11]
uint32_t adpsupport:1; // [12]
uint32_t hsicmode:1; // [13]
uint32_t bcsupport:1; // [14]
uint32_t lpmmode:1; // [15]
uint32_t dfifodepth:16; // [16,31]
} _b;
} ghwcfg3_u;
typedef union ghwcfg4_union {
uint32_t w;
struct {
uint32_t numdevperioeps:4; // [0,3]
uint32_t partialpwrdn:1; // [4]
uint32_t ahbfreq:1; // [5]
uint32_t hibernation:1; // [6]
uint32_t extendedhibernation:1; // [7]
uint32_t reserved:1; // [8]
uint32_t enhancedlpmsupt1:1; // [9]
uint32_t servintflow:1; // [10]
uint32_t ipgisocsupt:1; // [11]
uint32_t acgsupt:1; // [12]
uint32_t enhancedlpmsupt:1; // [13]
uint32_t phydatawidth:2; // [14,15]
uint32_t numctleps:4; // [16,19]
uint32_t iddgfltr:1; // [20]
uint32_t vbusvalidfltr:1; // [21]
uint32_t avalidfltr:1; // [22]
uint32_t bvalidfltr:1; // [23]
uint32_t sessendfltr:1; // [24]
uint32_t dedfifomode:1; // [25]
uint32_t ineps:4; // [26,29]
uint32_t descdmaenable:1; // [30]
uint32_t descdma:1; // [31]
} _b;
} ghwcfg4_u;
typedef union gdfifocfg_union {
uint32_t w;
struct {
uint32_t gdfifocfg:16; // [0,15]
uint32_t epinfobaseaddr:16; // [16,31]
} _b;
} gdfifocfg_u;
typedef union grefclk_union {
uint32_t w;
struct {
uint32_t sof_cnt_wkup_alert:10; // [0,9]
uint32_t reserved:4; // [10,13]
uint32_t refclkmode:1; // [14]
uint32_t refclkper:17; // [15,31]
} _b;
} grefclk_u;
typedef union hptxfsiz_union {
uint32_t w;
struct {
uint32_t ptxfstaddr:12; // [0,11]
uint32_t reserved_0:4; // [12,15]
uint32_t ptxfsize:12; // [16,27]
uint32_t reserved_1:4; // [28,31]
} _b;
} hptxfsiz_u;
typedef union dieptxf1_union {
uint32_t w;
struct {
uint32_t inepntxfstaddr:11; // [0,10]
uint32_t inepntxfdep:9; // [16,24]
uint32_t reserved_1:7; // [25,31]
} _b;
} dieptxf1_u;
typedef union dcfg_union {
uint32_t w;
struct {
uint32_t devspd:2; // [0,1]
uint32_t nzstsouthshk:1; // [2]
uint32_t ena32khzsusp:1; // [3]
uint32_t devaddr:7; // [4,10]
uint32_t perfrint:2; // [11,12]
uint32_t endevoutnak:1; // [13]
uint32_t xcvrdly:1; // [14]
uint32_t erraticintmsk:1; // [15]
uint32_t reserved:1; // [16]
uint32_t ipgisocsupt_dev:1; // [17]
uint32_t epmiscnt:5; // [18,22]
uint32_t descdma_dev:1; // [23]
uint32_t perschintvl:2; // [24,25]
uint32_t resvalid:6; // [26,31]
} _b;
} dcfg_u;
typedef union dctl_union {
uint32_t w;
struct {
uint32_t rmtwkupsig:1; // [0]
uint32_t sftdiscon:1; // [1]
uint32_t gnpinnaksts:1; // [2]
uint32_t goutnaksts:1; // [3]
uint32_t tstctl:3; // [4,6]
uint32_t sgnpinnak:1; // [7]
uint32_t cgnpinnak:1; // [8]
uint32_t sgoutnak:1; // [9]
uint32_t cgoutnak:1; // [10]
uint32_t pwronprgdone:1; // [11]
uint32_t reserved_0:1; // [12]
uint32_t gmc:2; // [13,14]
uint32_t ignrfrmnum:1; // [15]
uint32_t nakonbble:1; // [16]
uint32_t encontonbna:1; // [17]
uint32_t deepsleepbeslreject:1; // [18]
uint32_t servint:1; // [19]
uint32_t reserved_1:12; // [20,31]
} _b;
} dctl_u;
typedef union dsts_union {
uint32_t w;
struct {
uint32_t suspsts:1; // [0]
uint32_t enumspd:2; // [1,2]
uint32_t errticerr:1; // [3]
uint32_t reserved_0:4; // [4,7]
uint32_t soffn:14; // [8,21]
uint32_t devlnsts:2; // [22,23]
uint32_t reserved_1:8; // [24,31]
} _b;
} dsts_u;
typedef union diepmsk_union {
uint32_t w;
struct {
uint32_t xfercomplmsk_in:1; // [0]
uint32_t epdisbldmsk_in:1; // [1]
uint32_t ahberrmsk_in:1; // [2]
uint32_t timeoutmsk:1; // [3]
uint32_t intkntxfempmsk:1; // [4]
uint32_t intknepmismsk:1; // [5]
uint32_t inepnakeffmsk:1; // [6]
uint32_t reserved_0:1; // [7]
uint32_t txfifoundrnmsk:1; // [8]
uint32_t bnainintrmsk:1; // [9]
uint32_t reserved_1:3; // [10,12]
uint32_t nakmsk:1; // [13]
uint32_t reserved_2:18; // [14,31]
} _b;
} diepmsk_u;
typedef union doepmsk_union {
uint32_t w;
struct {
uint32_t xfercomplmsk_out:1; // [0]
uint32_t epdisbldmsk_out:1; // [1]
uint32_t ahberrmsk_out:1; // [2]
uint32_t setupmsk:1; // [3]
uint32_t outtknepdismsk:1; // [4]
uint32_t stsphsercvdmsk:1; // [5]
uint32_t back2backsetup:1; // [6]
uint32_t outpkterrmsk:1; // [8]
uint32_t bnaoutintrmsk:1; // [9]
uint32_t reserved_1:2; // [10,11]
uint32_t bbleerrmsk:1; // [12]
uint32_t nyetmsk:1; // [14]
uint32_t reserved_2:17; // [15,31]
} _b;
} doepmsk_u;
typedef union daint_union {
uint32_t w;
struct {
uint32_t inepint0:1; // [0]
uint32_t inepint1:1; // [1]
uint32_t inepint2:1; // [2]
uint32_t inepint3:1; // [3]
uint32_t inepint4:1; // [4]
uint32_t inepint5:1; // [5]
uint32_t inepint6:1; // [6]
uint32_t inepint7:1; // [7]
uint32_t inepint8:1; // [8]
uint32_t inepint9:1; // [9]
uint32_t inepint10:1; // [10]
uint32_t inepint11:1; // [11]
uint32_t inepint12:1; // [12]
uint32_t inepint13:1; // [13]
uint32_t inepint14:1; // [14]
uint32_t inepint15:1; // [15]
uint32_t outepint0:1; // [16]
uint32_t outepint1:1; // [17]
uint32_t outepint2:1; // [18]
uint32_t outepint3:1; // [19]
uint32_t outepint4:1; // [20]
uint32_t outepint5:1; // [21]
uint32_t outepint6:1; // [22]
uint32_t outepint7:1; // [23]
uint32_t outepint8:1; // [24]
uint32_t outepint9:1; // [25]
uint32_t outepint10:1; // [26]
uint32_t outepint11:1; // [27]
uint32_t outepint12:1; // [28]
uint32_t outepint13:1; // [29]
uint32_t outepint14:1; // [30]
uint32_t outepint15:1; // [31]
} _b;
} daint_u;
typedef union daintmsk_union {
uint32_t w;
struct {
uint32_t inepmsk0:1; // [0]
uint32_t inepmsk1:1; // [1]
uint32_t inepmsk2:1; // [2]
uint32_t inepmsk3:1; // [3]
uint32_t inepmsk4:1; // [4]
uint32_t inepmsk5:1; // [5]
uint32_t inepmsk6:1; // [6]
uint32_t inepmsk7:1; // [7]
uint32_t inepmsk8:1; // [8]
uint32_t inepmsk9:1; // [9]
uint32_t inepmsk10:1; // [10]
uint32_t inepmsk11:1; // [11]
uint32_t inepmsk12:1; // [12]
uint32_t inepmsk13:1; // [13]
uint32_t inepmsk14:1; // [14]
uint32_t inepmsk15:1; // [15]
uint32_t outepmsk0:1; // [16]
uint32_t outepmsk1:1; // [17]
uint32_t outepmsk2:1; // [18]
uint32_t outepmsk3:1; // [19]
uint32_t outepmsk4:1; // [20]
uint32_t outepmsk5:1; // [21]
uint32_t outepmsk6:1; // [22]
uint32_t outepmsk7:1; // [23]
uint32_t outepmsk8:1; // [24]
uint32_t outepmsk9:1; // [25]
uint32_t outepmsk10:1; // [26]
uint32_t outepmsk11:1; // [27]
uint32_t outepmsk12:1; // [28]
uint32_t outepmsk13:1; // [29]
uint32_t outepmsk14:1; // [30]
uint32_t outepmsk15:1; // [31]
} _b;
} daintmsk_u;
typedef union dthrctl_union {
uint32_t w;
struct {
uint32_t nonisothren:1; // [0]
uint32_t isothren:1; // [1]
uint32_t txthrlen:9; // [2,10]
uint32_t ahbthrratio:2; // [11,12]
uint32_t reserved_0:3; // [13,15]
uint32_t rxthren:1; // [16]
uint32_t rxthrlen:9; // [17,25]
uint32_t reserved_1:1; // [26]
uint32_t arbprken:1; // [27]
uint32_t reserved_2:4; // [28,31]
} _b;
} dthrctl_u;
typedef union deachint_union {
uint32_t w;
struct {
uint32_t eachinepint0:1; // [0]
uint32_t eachinepint1:1; // [1]
uint32_t eachinepint2:1; // [2]
uint32_t eachinepint3:1; // [3]
uint32_t eachinepint4:1; // [4]
uint32_t eachinepint5:1; // [5]
uint32_t eachinepint6:1; // [6]
uint32_t eachinepint7:1; // [7]
uint32_t eachinepint8:1; // [8]
uint32_t eachinepint9:1; // [9]
uint32_t eachinepint10:1; // [10]
uint32_t eachinepint11:1; // [11]
uint32_t eachinepint12:1; // [12]
uint32_t eachinepint13:1; // [13]
uint32_t eachinepint14:1; // [14]
uint32_t eachinepint15:1; // [15]
uint32_t eachoutepint0:1; // [16]
uint32_t eachoutepint1:1; // [17]
uint32_t eachoutepint2:1; // [18]
uint32_t eachoutepint3:1; // [19]
uint32_t eachoutepint4:1; // [20]
uint32_t eachoutepint5:1; // [21]
uint32_t eachoutepint6:1; // [22]
uint32_t eachoutepint7:1; // [23]
uint32_t eachoutepint8:1; // [24]
uint32_t eachoutepint9:1; // [25]
uint32_t eachoutepint10:1; // [26]
uint32_t eachoutepint11:1; // [27]
uint32_t eachoutepint12:1; // [28]
uint32_t eachoutepint13:1; // [29]
uint32_t eachoutepint14:1; // [30]
uint32_t eachoutepint15:1; // [31]
} _b;
} deachint_u;
typedef union deachintmsk_union {
uint32_t w;
struct {
uint32_t eachinepmsk0:1; // [0]
uint32_t eachinepmsk1:1; // [1]
uint32_t eachinepmsk2:1; // [2]
uint32_t eachinepmsk3:1; // [3]
uint32_t eachinepmsk4:1; // [4]
uint32_t eachinepmsk5:1; // [5]
uint32_t eachinepmsk6:1; // [6]
uint32_t eachinepmsk7:1; // [7]
uint32_t eachinepmsk8:1; // [8]
uint32_t eachinepmsk9:1; // [9]
uint32_t eachinepmsk10:1; // [10]
uint32_t eachinepmsk11:1; // [11]
uint32_t eachinepmsk12:1; // [12]
uint32_t eachinepmsk13:1; // [13]
uint32_t eachinepmsk14:1; // [14]
uint32_t eachinepmsk15:1; // [15]
uint32_t eachoutepmsk0:1; // [16]
uint32_t eachoutepmsk1:1; // [17]
uint32_t eachoutepmsk2:1; // [18]
uint32_t eachoutepmsk3:1; // [19]
uint32_t eachoutepmsk4:1; // [20]
uint32_t eachoutepmsk5:1; // [21]
uint32_t eachoutepmsk6:1; // [22]
uint32_t eachoutepmsk7:1; // [23]
uint32_t eachoutepmsk8:1; // [24]
uint32_t eachoutepmsk9:1; // [25]
uint32_t eachoutepmsk10:1; // [26]
uint32_t eachoutepmsk11:1; // [27]
uint32_t eachoutepmsk12:1; // [28]
uint32_t eachoutepmsk13:1; // [29]
uint32_t eachoutepmsk14:1; // [30]
uint32_t eachoutepmsk15:1; // [31]
} _b;
} deachintmsk_u;
typedef union diepeachmsk0_union {
uint32_t w;
struct {
uint32_t eachin_xfercomplmsk:1; // [0]
uint32_t eachin_epdisbldmsk:1; // [1]
uint32_t eachin_ahberrmsk:1; // [2]
uint32_t eachin_timeoutmsk:1; // [3]
uint32_t eachin_intkntxfempmsk:1; // [4]
uint32_t eachin_intknepmismsk:1; // [5]
uint32_t eachin_inepnakeffmsk:1; // [6]
uint32_t eachin_txfifoundrnmsk:1; // [8]
uint32_t eachin_bnainintrmsk:1; // [9]
uint32_t eachin_nakmsk:1; // [13]
} _b;
} diepeachmsk0_u;
typedef union doepeachmsk0_union {
uint32_t w;
struct {
uint32_t eachout_xfercomplmsk:1; // [0]
uint32_t eachout_epdisbldmsk:1; // [1]
uint32_t eachout_ahberrmsk:1; // [2]
uint32_t eachout_setupmsk:1; // [3]
uint32_t eachout_outtknepdismsk:1; // [4]
uint32_t eachout_stsphsrcvdmsk:1; // [5]
uint32_t eachout_back2backsetup:1; // [6]
uint32_t eachout_outpkterrmsk:1; // [8]
uint32_t eachout_bnaoutintrmsk:1; // [9]
uint32_t eachout_bbleerrmsk:1; // [12]
uint32_t eachout_nakmsk:1; // [13]
uint32_t eachout_nyetmsk:1; // [14]
} _b;
} doepeachmsk0_u;
typedef union diepctl0_union {
uint32_t w;
struct {
uint32_t mps_in:2; // [0,1]
uint32_t reserved_0:9; // [2,10]
uint32_t nextep_in:4; // [11,14]
uint32_t usbactep_in:1; // [15]
uint32_t reserved_1:1; // [16]
uint32_t naksts_in:1; // [17]
uint32_t eptype_in:2; // [18,19]
uint32_t reserved_2:1; // [20]
uint32_t stall_in:1; // [21]
uint32_t txfnum_in:4; // [22,25]
uint32_t cnak_in:1; // [26]
uint32_t snak_in:1; // [27]
uint32_t reserved_3:2; // [28,29]
uint32_t epdis_in:1; // [30]
uint32_t epena_in:1; // [31]
} _b;
} diepctl0_u;
typedef union diepint0_union {
uint32_t w;
struct {
uint32_t xfercompl_in:1; // [0]
uint32_t epdisbld_in:1; // [1]
uint32_t ahberr_in:1; // [2]
uint32_t timeout_in:1; // [3]
uint32_t intkntxfemp_in:1; // [4]
uint32_t intknepmis_in:1; // [5]
uint32_t inepnakeff_in:1; // [6]
uint32_t txfemp_in:1; // [7]
uint32_t txfifoundrn_in:1; // [8]
uint32_t bnaintr_in:1; // [9]
uint32_t reserved_0:1; // [10]
uint32_t pktdrpsts_in:1; // [11]
uint32_t bbleerr_in:1; // [12]
uint32_t nakintrpt_in:1; // [13]
uint32_t nyetintrpt_in:1; // [14]
uint32_t reserved_1:17; // [15,31]
} _b;
} diepint0_u;
typedef union dieptsiz0_union {
uint32_t w;
struct {
uint32_t xfersize_in:7; // [0,6]
uint32_t reserved_0:12; // [7,18]
uint32_t pktcnt_in:2; // [19,20]
uint32_t reserved_1:11; // [21,31]
} _b;
} dieptsiz0_u;
typedef union diepdma0_union {
uint32_t w;
struct {
uint32_t dmaaddr0_in:32; // [0,31]
} _b;
} diepdma0_u;
typedef union dtxfsts0_union {
uint32_t w;
struct {
uint32_t ineptxfspcavail:16; // [0,15]
uint32_t reserved:16; // [16,31]
} _b;
} dtxfsts0_u;
typedef union diepdmab0_union {
uint32_t w;
struct {
uint32_t dmabuffaddr0_in:32; // [0,31]
} _b;
} diepdmab0_u;
typedef union diepctl1_union {
uint32_t w;
struct {
uint32_t mps_in1:11; // [0,10]
uint32_t nextep_in1:4; // [11,14]
uint32_t usbactep_in1:1; // [15]
uint32_t dpid_in1:1; // [16]
uint32_t naksts_in1:1; // [17]
uint32_t eptype_in1:2; // [18,19]
uint32_t reserved:1; // [20]
uint32_t stall_in1:1; // [21]
uint32_t txfnum_in1:4; // [22,25]
uint32_t cnak_in1:1; // [26]
uint32_t snak_in1:1; // [27]
uint32_t setd0pid_in1:1; // [28]
uint32_t setd1pid_in1:1; // [29]
uint32_t epdis_in1:1; // [30]
uint32_t epena_in1:1; // [31]
} _b;
} diepctl1_u;
typedef union doepctl0_union {
uint32_t w;
struct {
uint32_t mps_out:2; // [0,1]
uint32_t reserved_0:13; // [2,14]
uint32_t usbactep_out:1; // [15]
uint32_t naksts_out:1; // [17]
uint32_t eptype_out:2; // [18,19]
uint32_t snp_out:1; // [20]
uint32_t stall_out:1; // [21]
uint32_t reserved_2:4; // [22,25]
uint32_t cnak_out:1; // [26]
uint32_t snak_out:1; // [27]
uint32_t epdis_out:1; // [30]
uint32_t epena_out:1; // [31]
} _b;
} doepctl0_u;
typedef union doepint0_union {
uint32_t w;
struct {
uint32_t xfercompl_out:1; // [0]
uint32_t epdisbld_out:1; // [1]
uint32_t ahberr_out:1; // [2]
uint32_t setup_out:1; // [3]
uint32_t outtknepdis:1; // [4]
uint32_t stsphsercvd:1; // [5]
uint32_t outpkterr:1; // [8]
uint32_t bnaintr_out:1; // [9]
uint32_t reserved_1:1; // [10]
uint32_t pktdrpsts_out:1; // [11]
uint32_t bbleerr_out:1; // [12]
uint32_t nakintrpt_out:1; // [13]
uint32_t nyetintrpt_out:1; // [14]
uint32_t stuppktrcvd_out:1; // [15]
uint32_t reserved_2:16; // [16,31]
} _b;
} doepint0_u;
typedef union doeptsiz0_union {
uint32_t w;
struct {
uint32_t xfersize:7; // [0,6]
uint32_t pktcnt:1; // [19]
uint32_t reserved_1:9; // [20,28]
uint32_t supcnt:2; // [29,30]
uint32_t reserved_2:1; // [31]
} _b;
} doeptsiz0_u;
typedef union doepdma0_union {
uint32_t w;
struct {
uint32_t dmaaddr0_out:32; // [0,31]
} _b;
} doepdma0_u;
typedef union doepdmab0_union {
uint32_t w;
struct {
uint32_t dmabuffaddr0_out:32; // [0,31]
} _b;
} doepdmab0_u;
typedef union doepctl1_union {
uint32_t w;
struct {
uint32_t mps_out1:11; // [0,10]
uint32_t reserved_0:4; // [11,14]
uint32_t usbactep_out1:1; // [15]
uint32_t dpid_out1:1; // [16]
uint32_t naksts_out1:1; // [17]
uint32_t eptype_out1:2; // [18,19]
uint32_t snp_out1:1; // [20]
uint32_t stall_out1:1; // [21]
uint32_t reserved_1:4; // [22,25]
uint32_t cnak_out1:1; // [26]
uint32_t snak_out1:1; // [27]
uint32_t setd0pid_out1:1; // [28]
uint32_t setd1pid_out1:1; // [29]
uint32_t epdis_out1:1; // [30]
uint32_t epena_out1:1; // [31]
} _b;
} doepctl1_u;
typedef union pcgcctl_union {
uint32_t w;
struct {
uint32_t stoppclk:1; // [0]
uint32_t gatehclk:1; // [1]
uint32_t pwrclmp:1; // [2]
uint32_t rstpdwnmodule:1; // [3]
uint32_t reserved:1; // [4]
uint32_t enbl_l1gating:1; // [5]
uint32_t physleep:1; // [6]
uint32_t l1suspended:1; // [7]
uint32_t resetaftersusp:1; // [8]
uint32_t restoremode:1; // [9]
uint32_t exthiberen:1; // [10]
uint32_t exthiberclmp:1; // [11]
uint32_t exthibersw:1; // [12]
uint32_t essregrestored:1; // [13]
uint32_t restorevalue:18; // [14,31]
} _b;
} pcgcctl_u;
typedef union pcgcctl1_union {
uint32_t w;
struct {
uint32_t gateen:1; // [0]
uint32_t cntgateclk:2; // [1,2]
uint32_t ramgateen:1; // [3]
uint32_t reserved:28; // [4,31]
} _b;
} pcgcctl1_u;
gotgctl_u gotgctl;
gotgint_u gotgint;
gahbcfg_u gahbcfg;
gusbcfg_u gusbcfg;
grstctl_u grstctl;
gintsts_u gintsts;
gintmsk_u gintmsk;
grxstsr_u grxstsr;
grxstsp_u grxstsp;
grxfsiz_u grxfsiz;
ghwcfg1_u ghwcfg1;
ghwcfg2_u ghwcfg2;
ghwcfg3_u ghwcfg3;
ghwcfg4_u ghwcfg4;
grefclk_u grefclk;
dcfg_u dcfg;
dctl_u dctl;
dsts_u dsts;
diepmsk_u diepmsk;
doepmsk_u doepmsk;
daint_u daint;
dthrctl_u dthrctl;
pcgcctl_u pcgcctl;
} usb_otg_reg_t;
#endif
宏形式
#define CFG_GOTGINT_ADDR 0x0004
#define MULTVALPCHNG_OFFSET 20
#define MULTVALPCHNG_MASK 0x00100000
#define DBNCEDONE_OFFSET 19
#define DBNCEDONE_MASK 0x00080000
#define ADEVTOUTCHG_OFFSET 18
#define ADEVTOUTCHG_MASK 0x00040000
#define HSTNEGDET_OFFSET 17
#define HSTNEGDET_MASK 0x00020000
#define HSTNEGSUCSTSCHNG_OFFSET 9
#define HSTNEGSUCSTSCHNG_MASK 0x00000200
#define SESREQSUCSTSCHNG_OFFSET 8
#define SESREQSUCSTSCHNG_MASK 0x00000100
#define SESENDDET_OFFSET 2
#define SESENDDET_MASK 0x00000004
#define CFG_GAHBCFG_ADDR 0x0008
#define INVDESCENDIANESS_OFFSET 24
#define INVDESCENDIANESS_MASK 0x01000000
#define AHBSINGLE_OFFSET 23
#define AHBSINGLE_MASK 0x00800000
#define NOTIALLDMAWRIT_OFFSET 22
#define NOTIALLDMAWRIT_MASK 0x00400000
#define REMMEMSUPP_OFFSET 21
#define REMMEMSUPP_MASK 0x00200000
#define PTXFEMPLVL_OFFSET 8
#define PTXFEMPLVL_MASK 0x00000100
#define NPTXFEMPLVL_OFFSET 7
#define NPTXFEMPLVL_MASK 0x00000080
#define DMAEN_OFFSET 5
#define DMAEN_MASK 0x00000020
#define HBSTLEN_OFFSET 1
#define HBSTLEN_MASK 0x0000001E
#define GLBINTRMSK_OFFSET 0
#define GLBINTRMSK_MASK 0x00000001
#define CFG_GUSBCFG_ADDR 0x000c
#define CORRUPTTXPKT_OFFSET 31
#define CORRUPTTXPKT_MASK 0x80000000
#define FORCEDEVMODE_OFFSET 30
#define FORCEDEVMODE_MASK 0x40000000
#define FORCEHSTMODE_OFFSET 29
#define FORCEHSTMODE_MASK 0x20000000
#define TXENDDELAY_OFFSET 28
#define TXENDDELAY_MASK 0x10000000
#define IC_USBTRAFCTL_OFFSET 27
#define IC_USBTRAFCTL_MASK 0x08000000
#define IC_USBCAP_OFFSET 26
#define IC_USBCAP_MASK 0x04000000
#define ULPI_OFFSET 25
#define ULPI_MASK 0x02000000
#define INDICATOR_OFFSET 24
#define INDICATOR_MASK 0x01000000
#define COMPLEMENT_OFFSET 23
#define COMPLEMENT_MASK 0x00800000
#define TERMSELDLPULSE_OFFSET 22
#define TERMSELDLPULSE_MASK 0x00400000
#define ULPIEXTVBUSINDICATOR_OFFSET 21
#define ULPIEXTVBUSINDICATOR_MASK 0x00200000
#define ULPIEXTVBUSDRV_OFFSET 20
#define ULPIEXTVBUSDRV_MASK 0x00100000
#define ULPICLKSUSM_OFFSET 19
#define ULPICLKSUSM_MASK 0x00080000
#define ULPIAUTORES_OFFSET 18
#define ULPIAUTORES_MASK 0x00040000
#define ULPIFSLS_OFFSET 17
#define ULPIFSLS_MASK 0x00020000
#define OTGI2CSEL_OFFSET 16
#define OTGI2CSEL_MASK 0x00010000
#define PHYLPWRCLKSEL_OFFSET 15
#define PHYLPWRCLKSEL_MASK 0x00008000
#define USBTRDTIM_OFFSET 10
#define USBTRDTIM_MASK 0x00003C00
#define HNPCAP_OFFSET 9
#define HNPCAP_MASK 0x00000200
#define SRPCAP_OFFSET 8
#define SRPCAP_MASK 0x00000100
#define DDRSEL_OFFSET 7
#define DDRSEL_MASK 0x00000080
#define PHYSEL_OFFSET 6
#define PHYSEL_MASK 0x00000040
#define FSINTF_OFFSET 5
#define FSINTF_MASK 0x00000020
#define ULPI_UTMI_SEL_OFFSET 4
#define ULPI_UTMI_SEL_MASK 0x00000010
#define PHYIF_OFFSET 3
#define PHYIF_MASK 0x00000008
#define TOUTCAL_OFFSET 0
#define TOUTCAL_MASK 0x00000007
#define CFG_GRSTCTL_ADDR 0x0010
#define AHBIDLE_OFFSET 31
#define AHBIDLE_MASK 0x80000000
#define DMAREQ_OFFSET 30
#define DMAREQ_MASK 0x40000000
#define TXFNUM_OFFSET 6
#define TXFNUM_MASK 0x000007C0
#define TXFFLSH_OFFSET 5
#define TXFFLSH_MASK 0x00000020
#define RXFFLSH_OFFSET 4
#define RXFFLSH_MASK 0x00000010
#define INTKNQFLSH_OFFSET 3
#define INTKNQFLSH_MASK 0x00000008
#define FRMCNTRRST_OFFSET 2
#define FRMCNTRRST_MASK 0x00000004
#define PIUFSSFTRST_OFFSET 1
#define PIUFSSFTRST_MASK 0x00000002
#define CSFTRST_OFFSET 0
#define CSFTRST_MASK 0x00000001
#define CFG_GINTSTS_ADDR 0x0014
#define WKUPINT_OFFSET 31
#define WKUPINT_MASK 0x80000000
#define SESSREQINT_OFFSET 30
#define SESSREQINT_MASK 0x40000000
#define DISCONNINT_OFFSET 29
#define DISCONNINT_MASK 0x20000000
#define CONLDSTSCHNG_OFFSET 28
#define CONLDSTSCHNG_MASK 0x10000000
#define LPM_INT_OFFSET 27
#define LPM_INT_MASK 0x08000000
#define PTXFEMP_OFFSET 26
#define PTXFEMP_MASK 0x04000000
#define HCHINT_OFFSET 25
#define HCHINT_MASK 0x02000000
#define PRTINT_OFFSET 24
#define PRTINT_MASK 0x01000000
#define RESETDET_OFFSET 23
#define RESETDET_MASK 0x00800000
#define FETSUSP_OFFSET 22
#define FETSUSP_MASK 0x00400000
#define INCOMPIP_OFFSET 21
#define INCOMPIP_MASK 0x00200000
#define INCOMPSOIN_OFFSET 20
#define INCOMPSOIN_MASK 0x00100000
#define OEPINT_OFFSET 19
#define OEPINT_MASK 0x00080000
#define IEPINT_OFFSET 18
#define IEPINT_MASK 0x00040000
#define EPMIS_OFFSET 17
#define EPMIS_MASK 0x00020000
#define RSTRDONEINT_OFFSET 16
#define RSTRDONEINT_MASK 0x00010000
#define EOPF_OFFSET 15
#define EOPF_MASK 0x00008000
#define ISOOUTDROP_OFFSET 14
#define ISOOUTDROP_MASK 0x00004000
#define ENUMDONE_OFFSET 13
#define ENUMDONE_MASK 0x00002000
#define USBRST_OFFSET 12
#define USBRST_MASK 0x00001000
#define USBSUSP_OFFSET 11
#define USBSUSP_MASK 0x00000800
#define ERLYSUSP_OFFSET 10
#define ERLYSUSP_MASK 0x00000400
#define I2CINT_OFFSET 9
#define I2CINT_MASK 0x00000200
#define ULPICKINT_OFFSET 8
#define ULPICKINT_MASK 0x00000100
#define GOUTNAKEFF_OFFSET 7
#define GOUTNAKEFF_MASK 0x00000080
#define GINNAKEFF_OFFSET 6
#define GINNAKEFF_MASK 0x00000040
#define NPTXFEMP_OFFSET 5
#define NPTXFEMP_MASK 0x00000020
#define RXFLVL_OFFSET 4
#define RXFLVL_MASK 0x00000010
#define SOF_OFFSET 3
#define SOF_MASK 0x00000008
#define OTGINT_OFFSET 2
#define OTGINT_MASK 0x00000004
#define MODEMIS_OFFSET 1
#define MODEMIS_MASK 0x00000002
#define CURMODSTS_OFFSET 0
#define CURMODSTS_MASK 0x00000001
#define CFG_GINTMSK_ADDR 0x0018
#define WKUPINTMSK_OFFSET 31
#define WKUPINTMSK_MASK 0x80000000
#define SESSREQINTMSK_OFFSET 30
#define SESSREQINTMSK_MASK 0x40000000
#define DISCONNINTMSK_OFFSET 29
#define DISCONNINTMSK_MASK 0x20000000
#define CONLDSTSCHNGMSK_OFFSET 28
#define CONLDSTSCHNGMSK_MASK 0x10000000
#define LPM_INTMSK_OFFSET 27
#define LPM_INTMSK_MASK 0x08000000
#define PTXFEMPMSK_OFFSET 26
#define PTXFEMPMSK_MASK 0x04000000
#define HCHINTMSK_OFFSET 25
#define HCHINTMSK_MASK 0x02000000
#define PRTINTMSK_OFFSET 24
#define PRTINTMSK_MASK 0x01000000
#define RESETDETMSK_OFFSET 23
#define RESETDETMSK_MASK 0x00800000
#define FETSUSPMSK_OFFSET 22
#define FETSUSPMSK_MASK 0x00400000
#define INCOMPIPMSK_OFFSET 21
#define INCOMPIPMSK_MASK 0x00200000
#define INCOMPSOINMSK_OFFSET 20
#define INCOMPSOINMSK_MASK 0x00100000
#define OEPINTMSK_OFFSET 19
#define OEPINTMSK_MASK 0x00080000
#define IEPINTMSK_OFFSET 18
#define IEPINTMSK_MASK 0x00040000
#define EPMISMSK_OFFSET 17
#define EPMISMSK_MASK 0x00020000
#define RSTRDONEINTMSK_OFFSET 16
#define RSTRDONEINTMSK_MASK 0x00010000
#define EOPFMSK_OFFSET 15
#define EOPFMSK_MASK 0x00008000
#define ISOOUTDROPMSK_OFFSET 14
#define ISOOUTDROPMSK_MASK 0x00004000
#define ENUMDONEMSK_OFFSET 13
#define ENUMDONEMSK_MASK 0x00002000
#define USBRSTMSK_OFFSET 12
#define USBRSTMSK_MASK 0x00001000
#define USBSUSPMSK_OFFSET 11
#define USBSUSPMSK_MASK 0x00000800
#define ERLYSUSPMSK_OFFSET 10
#define ERLYSUSPMSK_MASK 0x00000400
#define I2CINTMSK_OFFSET 9
#define I2CINTMSK_MASK 0x00000200
#define ULPICKINTMSK_OFFSET 8
#define ULPICKINTMSK_MASK 0x00000100
#define GOUTNAKEFFMSK_OFFSET 7
#define GOUTNAKEFFMSK_MASK 0x00000080
#define GINNAKEFFMSK_OFFSET 6
#define GINNAKEFFMSK_MASK 0x00000040
#define NPTXFEMPMSK_OFFSET 5
#define NPTXFEMPMSK_MASK 0x00000020
#define RXFLVLMSK_OFFSET 4
#define RXFLVLMSK_MASK 0x00000010
#define SOFMSK_OFFSET 3
#define SOFMSK_MASK 0x00000008
#define OTGINTMSK_OFFSET 2
#define OTGINTMSK_MASK 0x00000004
#define MODEMISMSK_OFFSET 1
#define MODEMISMSK_MASK 0x00000002
#define CFG_GRXSTSR_ADDR 0x001C
#define FN_OFFSET 21
#define FN_MASK 0x01E00000
#define PKTSTS_OFFSET 17
#define PKTSTS_MASK 0x001E0000
#define DPID_OFFSET 15
#define DPID_MASK 0x00018000
#define BCNT_OFFSET 4
#define BCNT_MASK 0x00007FF0
#define CHNUM_OFFSET 0
#define CHNUM_MASK 0x0000000F
#define CFG_GRXSTSP_ADDR 0x0020
#define FN_POP_OFFSET 21
#define FN_POP_MASK 0x01E00000
#define PKTSTS_POP_OFFSET 17
#define PKTSTS_POP_MASK 0x001E0000
#define DPID_POP_OFFSET 15
#define DPID_POP_MASK 0x00018000
#define BCNT_POP_OFFSET 4
#define BCNT_POP_MASK 0x00007FF0
#define CHNUM_POP_OFFSET 0
#define CHNUM_POP_MASK 0x0000000F
#define CFG_GRXFSIZ_ADDR 0x0024
#define RXFDEP_OFFSET 0
#define RXFDEP_MASK 0x000007FF
#define CFG_GNPTXFSIZ_ADDR 0x0028
#define NPTXFDEP_OFFSET 16
#define NPTXFDEP_MASK 0x07FF0000
#define NPTXFSTADDR_OFFSET 0
#define NPTXFSTADDR_MASK 0x000007FF
#define CFG_GNPTXSTS_ADDR 0x002c
#define NPTXFTOP_OFFSET 24
#define NPTXFTOP_MASK 0x7F000000
#define NPTXQSPCAVAIL_OFFSET 16
#define NPTXQSPCAVAIL_MASK 0x00FF0000
#define NPTXFSPCAVAIL_OFFSET 0
#define NPTXFSPCAVAIL_MASK 0x0000FFFF
#define CFG_GPVNDCTL_ADDR 0x0034
#define DISULPIDRV_OFFSET 31
#define DISULPIDRV_MASK 0x80000000
#define VSTSDONE_OFFSET 27
#define VSTSDONE_MASK 0x08000000
#define VSTSBSY_OFFSET 26
#define VSTSBSY_MASK 0x04000000
#define NEWREGREQ_OFFSET 25
#define NEWREGREQ_MASK 0x02000000
#define REGWR_OFFSET 22
#define REGWR_MASK 0x00400000
#define REGADDR_OFFSET 16
#define REGADDR_MASK 0x003F0000
#define VCTRL_OFFSET 8
#define VCTRL_MASK 0x0000FF00
#define REGDATA_OFFSET 0
#define REGDATA_MASK 0x000000FF
#define CFG_GHWCFG1_ADDR 0x0044
#define EPDIR_OFFSET 0
#define EPDIR_MASK 0xFFFFFFFF
#define CFG_GHWCFG2_ADDR 0x0048
#define OTG_ENABLE_IC_USB_OFFSET 31
#define OTG_ENABLE_IC_USB_MASK 0x80000000
#define TKNQDEPTH_OFFSET 26
#define TKNQDEPTH_MASK 0x7C000000
#define PTXQDEPTH_OFFSET 24
#define PTXQDEPTH_MASK 0x03000000
#define NPTXQDEPTH_OFFSET 22
#define NPTXQDEPTH_MASK 0x00C00000
#define MULTIPROCINTRPT_OFFSET 20
#define MULTIPROCINTRPT_MASK 0x00100000
#define DYNFIFOSIZING_OFFSET 19
#define DYNFIFOSIZING_MASK 0x00080000
#define PERIOSUPPORT_OFFSET 18
#define PERIOSUPPORT_MASK 0x00040000
#define NUMHSTCHNL_OFFSET 14
#define NUMHSTCHNL_MASK 0x0003C000
#define NUMDEVEPS_OFFSET 10
#define NUMDEVEPS_MASK 0x00003C00
#define FSPHYTYPE_OFFSET 8
#define FSPHYTYPE_MASK 0x00000300
#define HSPHYTYPE_OFFSET 6
#define HSPHYTYPE_MASK 0x000000C0
#define SINGPNT_OFFSET 5
#define SINGPNT_MASK 0x00000020
#define OTGARCH_OFFSET 3
#define OTGARCH_MASK 0x00000018
#define OTGMODE_OFFSET 0
#define OTGMODE_MASK 0x00000007
#define CFG_GHWCFG3_ADDR 0x004c
#define DFIFODEPTH_OFFSET 16
#define DFIFODEPTH_MASK 0xFFFF0000
#define LPMMODE_OFFSET 15
#define LPMMODE_MASK 0x00008000
#define BCSUPPORT_OFFSET 14
#define BCSUPPORT_MASK 0x00004000
#define HSICMODE_OFFSET 13
#define HSICMODE_MASK 0x00002000
#define ADPSUPPORT_OFFSET 12
#define ADPSUPPORT_MASK 0x00001000
#define RSTTYPE_OFFSET 11
#define RSTTYPE_MASK 0x00000800
#define OPTFEATURE_OFFSET 10
#define OPTFEATURE_MASK 0x00000400
#define VNDCTLSUPT_OFFSET 9
#define VNDCTLSUPT_MASK 0x00000200
#define I2CINTSEL_OFFSET 8
#define I2CINTSEL_MASK 0x00000100
#define OTGEN_OFFSET 7
#define OTGEN_MASK 0x00000080
#define PKTSIZEWIDTH_OFFSET 4
#define PKTSIZEWIDTH_MASK 0x00000070
#define XFERSIZEWIDTH_OFFSET 0
#define XFERSIZEWIDTH_MASK 0x0000000F
#define CFG_GHWCFG4_ADDR 0x0050
#define DESCDMA_OFFSET 31
#define DESCDMA_MASK 0x80000000
#define DESCDMAENABLE_OFFSET 30
#define DESCDMAENABLE_MASK 0x40000000
#define INEPS_OFFSET 26
#define INEPS_MASK 0x3C000000
#define DEDFIFOMODE_OFFSET 25
#define DEDFIFOMODE_MASK 0x02000000
#define SESSENDFLTR_OFFSET 24
#define SESSENDFLTR_MASK 0x01000000
#define BVALIDFLTR_OFFSET 23
#define BVALIDFLTR_MASK 0x00800000
#define AVALIDFLTR_OFFSET 22
#define AVALIDFLTR_MASK 0x00400000
#define VBUSVALIDFLTR_OFFSET 21
#define VBUSVALIDFLTR_MASK 0x00200000
#define IDDGFLTR_OFFSET 20
#define IDDGFLTR_MASK 0x00100000
#define NUMCTLEPS_OFFSET 16
#define NUMCTLEPS_MASK 0x000F0000
#define PHYDATAWIDTH_OFFSET 14
#define PHYDATAWIDTH_MASK 0x0000C000
#define ENHANCEDLPMSUPT_OFFSET 13
#define ENHANCEDLPMSUPT_MASK 0x00002000
#define ACGSUPT_OFFSET 12
#define ACGSUPT_MASK 0x00001000
#define IPGISOCSUPT_OFFSET 11
#define IPGISOCSUPT_MASK 0x00000800
#define SERVINTFLOW_OFFSET 10
#define SERVINTFLOW_MASK 0x00000400
#define ENHANCEDLPMSUPT1_OFFSET 9
#define ENHANCEDLPMSUPT1_MASK 0x00000200
#define EXTENDEDHIBERNATION_OFFSET 7
#define EXTENDEDHIBERNATION_MASK 0x00000080
#define HIBERNATION_OFFSET 6
#define HIBERNATION_MASK 0x00000040
#define AHBFREQ_OFFSET 5
#define AHBFREQ_MASK 0x00000020
#define PARTIALPWRDN_OFFSET 4
#define PARTIALPWRDN_MASK 0x00000010
#define NUMDEVPERIOEPS_OFFSET 0
#define NUMDEVPERIOEPS_MASK 0x0000000F
#define CFG_GDFIFOCFG_ADDR 0x005c
#define EPINFOBASEADDR_OFFSET 16
#define EPINFOBASEADDR_MASK 0xFFFF0000
#define GDFIFOCFG_OFFSET 0
#define GDFIFOCFG_MASK 0x0000FFFF
#define CFG_GREFCLK_ADDR 0x0064
#define REFCLKPER_OFFSET 15
#define REFCLKPER_MASK 0xFFFF8000
#define REFCLKMODE_OFFSET 14
#define REFCLKMODE_MASK 0x00004000
#define SOF_CNT_WKUP_ALERT_OFFSET 0
#define SOF_CNT_WKUP_ALERT_MASK 0x000003FF
#define CFG_HPTXFSIZ_ADDR 0x0100
#define PTXFSIZE_OFFSET 16
#define PTXFSIZE_MASK 0x0FFF0000
#define PTXFSTADDR_OFFSET 0
#define PTXFSTADDR_MASK 0x00000FFF
#define CFG_DIEPTXF1_ADDR 0x0104
#define INEPNTXFDEP_OFFSET 16
#define INEPNTXFDEP_MASK 0x01FF0000
#define INEPNTXFSTADDR_OFFSET 0
#define INEPNTXFSTADDR_MASK 0x000007FF
#define CFG_DCFG_ADDR 0x0800
#define RESVALID_OFFSET 26
#define RESVALID_MASK 0xFC000000
#define PERSCHINTVL_OFFSET 24
#define PERSCHINTVL_MASK 0x03000000
#define DESCDMA_DEV_OFFSET 23
#define DESCDMA_DEV_MASK 0x00800000
#define EPMISCNT_OFFSET 18
#define EPMISCNT_MASK 0x007C0000
#define IPGISOCSUPT_DEV_OFFSET 17
#define IPGISOCSUPT_DEV_MASK 0x00020000
#define ERRATICINTMSK_OFFSET 15
#define ERRATICINTMSK_MASK 0x00008000
#define XCVRDLY_OFFSET 14
#define XCVRDLY_MASK 0x00004000
#define ENDEVOUTNAK_OFFSET 13
#define ENDEVOUTNAK_MASK 0x00002000
#define PERFRINT_OFFSET 11
#define PERFRINT_MASK 0x00001800
#define DEVADDR_OFFSET 4
#define DEVADDR_MASK 0x000007F0
#define ENA32KHZSUSP_OFFSET 3
#define ENA32KHZSUSP_MASK 0x00000008
#define NZSTSOUTHSHK_OFFSET 2
#define NZSTSOUTHSHK_MASK 0x00000004
#define DEVSPD_OFFSET 0
#define DEVSPD_MASK 0x00000003
#define CFG_DCTL_ADDR 0x0804
#define SERVINT_OFFSET 19
#define SERVINT_MASK 0x00080000
#define DEEPSLEEPBESLREJECT_OFFSET 18
#define DEEPSLEEPBESLREJECT_MASK 0x00040000
#define ENCONTONBNA_OFFSET 17
#define ENCONTONBNA_MASK 0x00020000
#define NAKONBBLE_OFFSET 16
#define NAKONBBLE_MASK 0x00010000
#define IGNRFRMNUM_OFFSET 15
#define IGNRFRMNUM_MASK 0x00008000
#define GMC_OFFSET 13
#define GMC_MASK 0x00006000
#define PWRONPRGDONE_OFFSET 11
#define PWRONPRGDONE_MASK 0x00000800
#define CGOUTNAK_OFFSET 10
#define CGOUTNAK_MASK 0x00000400
#define SGOUTNAK_OFFSET 9
#define SGOUTNAK_MASK 0x00000200
#define CGNPINNAK_OFFSET 8
#define CGNPINNAK_MASK 0x00000100
#define SGNPINNAK_OFFSET 7
#define SGNPINNAK_MASK 0x00000080
#define TSTCTL_OFFSET 4
#define TSTCTL_MASK 0x00000070
#define GOUTNAKSTS_OFFSET 3
#define GOUTNAKSTS_MASK 0x00000008
#define GNPINNAKSTS_OFFSET 2
#define GNPINNAKSTS_MASK 0x00000004
#define SFTDISCON_OFFSET 1
#define SFTDISCON_MASK 0x00000002
#define RMTWKUPSIG_OFFSET 0
#define RMTWKUPSIG_MASK 0x00000001
#define CFG_DSTS_ADDR 0x0808
#define DEVLNSTS_OFFSET 22
#define DEVLNSTS_MASK 0x00C00000
#define SOFFN_OFFSET 8
#define SOFFN_MASK 0x003FFF00
#define ERRTICERR_OFFSET 3
#define ERRTICERR_MASK 0x00000008
#define ENUMSPD_OFFSET 1
#define ENUMSPD_MASK 0x00000006
#define SUSPSTS_OFFSET 0
#define SUSPSTS_MASK 0x00000001
#define CFG_DIEPMSK_ADDR 0x0810
#define NAKMSK_OFFSET 13
#define NAKMSK_MASK 0x00002000
#define BNAININTRMSK_OFFSET 9
#define BNAININTRMSK_MASK 0x00000200
#define TXFIFOUNDRNMSK_OFFSET 8
#define TXFIFOUNDRNMSK_MASK 0x00000100
#define INEPNAKEFFMSK_OFFSET 6
#define INEPNAKEFFMSK_MASK 0x00000040
#define INTKNEPMISMSK_OFFSET 5
#define INTKNEPMISMSK_MASK 0x00000020
#define INTKNTXFEMPMSK_OFFSET 4
#define INTKNTXFEMPMSK_MASK 0x00000010
#define TIMEOUTMSK_OFFSET 3
#define TIMEOUTMSK_MASK 0x00000008
#define AHBERRMSK_IN_OFFSET 2
#define AHBERRMSK_IN_MASK 0x00000004
#define EPDISBLDMSK_IN_OFFSET 1
#define EPDISBLDMSK_IN_MASK 0x00000002
#define XFERCOMPLMSK_IN_OFFSET 0
#define XFERCOMPLMSK_IN_MASK 0x00000001
#define CFG_DOEPMSK_ADDR 0x0814
#define NYETMSK_OFFSET 14
#define NYETMSK_MASK 0x00004000
#define BBLEERRMSK_OFFSET 12
#define BBLEERRMSK_MASK 0x00001000
#define BNAOUTINTRMSK_OFFSET 9
#define BNAOUTINTRMSK_MASK 0x00000200
#define OUTPKTERRMSK_OFFSET 8
#define OUTPKTERRMSK_MASK 0x00000100
#define BACK2BACKSETUP_OFFSET 6
#define BACK2BACKSETUP_MASK 0x00000040
#define STSPHSERCVDMSK_OFFSET 5
#define STSPHSERCVDMSK_MASK 0x00000020
#define OUTTKNEPDISMSK_OFFSET 4
#define OUTTKNEPDISMSK_MASK 0x00000010
#define SETUPMSK_OFFSET 3
#define SETUPMSK_MASK 0x00000008
#define AHBERRMSK_OUT_OFFSET 2
#define AHBERRMSK_OUT_MASK 0x00000004
#define EPDISBLDMSK_OUT_OFFSET 1
#define EPDISBLDMSK_OUT_MASK 0x00000002
#define XFERCOMPLMSK_OUT_OFFSET 0
#define XFERCOMPLMSK_OUT_MASK 0x00000001
#define CFG_DAINT_ADDR 0x0818
#define OUTEPINT15_OFFSET 31
#define OUTEPINT15_MASK 0x80000000
#define OUTEPINT14_OFFSET 30
#define OUTEPINT14_MASK 0x40000000
#define OUTEPINT13_OFFSET 29
#define OUTEPINT13_MASK 0x20000000
#define OUTEPINT12_OFFSET 28
#define OUTEPINT12_MASK 0x10000000
#define OUTEPINT11_OFFSET 27
#define OUTEPINT11_MASK 0x08000000
#define OUTEPINT10_OFFSET 26
#define OUTEPINT10_MASK 0x04000000
#define OUTEPINT9_OFFSET 25
#define OUTEPINT9_MASK 0x02000000
#define OUTEPINT8_OFFSET 24
#define OUTEPINT8_MASK 0x01000000
#define OUTEPINT7_OFFSET 23
#define OUTEPINT7_MASK 0x00800000
#define OUTEPINT6_OFFSET 22
#define OUTEPINT6_MASK 0x00400000
#define OUTEPINT5_OFFSET 21
#define OUTEPINT5_MASK 0x00200000
#define OUTEPINT4_OFFSET 20
#define OUTEPINT4_MASK 0x00100000
#define OUTEPINT3_OFFSET 19
#define OUTEPINT3_MASK 0x00080000
#define OUTEPINT2_OFFSET 18
#define OUTEPINT2_MASK 0x00040000
#define OUTEPINT1_OFFSET 17
#define OUTEPINT1_MASK 0x00020000
#define OUTEPINT0_OFFSET 16
#define OUTEPINT0_MASK 0x00010000
#define INEPINT15_OFFSET 15
#define INEPINT15_MASK 0x00008000
#define INEPINT14_OFFSET 14
#define INEPINT14_MASK 0x00004000
#define INEPINT13_OFFSET 13
#define INEPINT13_MASK 0x00002000
#define INEPINT12_OFFSET 12
#define INEPINT12_MASK 0x00001000
#define INEPINT11_OFFSET 11
#define INEPINT11_MASK 0x00000800
#define INEPINT10_OFFSET 10
#define INEPINT10_MASK 0x00000400
#define INEPINT9_OFFSET 9
#define INEPINT9_MASK 0x00000200
#define INEPINT8_OFFSET 8
#define INEPINT8_MASK 0x00000100
#define INEPINT7_OFFSET 7
#define INEPINT7_MASK 0x00000080
#define INEPINT6_OFFSET 6
#define INEPINT6_MASK 0x00000040
#define INEPINT5_OFFSET 5
#define INEPINT5_MASK 0x00000020
#define INEPINT4_OFFSET 4
#define INEPINT4_MASK 0x00000010
#define INEPINT3_OFFSET 3
#define INEPINT3_MASK 0x00000008
#define INEPINT2_OFFSET 2
#define INEPINT2_MASK 0x00000004
#define INEPINT1_OFFSET 1
#define INEPINT1_MASK 0x00000002
#define INEPINT0_OFFSET 0
#define INEPINT0_MASK 0x00000001
#define CFG_DAINTMSK_ADDR 0x081c
#define OUTEPMSK15_OFFSET 31
#define OUTEPMSK15_MASK 0x80000000
#define OUTEPMSK14_OFFSET 30
#define OUTEPMSK14_MASK 0x40000000
#define OUTEPMSK13_OFFSET 29
#define OUTEPMSK13_MASK 0x20000000
#define OUTEPMSK12_OFFSET 28
#define OUTEPMSK12_MASK 0x10000000
#define OUTEPMSK11_OFFSET 27
#define OUTEPMSK11_MASK 0x08000000
#define OUTEPMSK10_OFFSET 26
#define OUTEPMSK10_MASK 0x04000000
#define OUTEPMSK9_OFFSET 25
#define OUTEPMSK9_MASK 0x02000000
#define OUTEPMSK8_OFFSET 24
#define OUTEPMSK8_MASK 0x01000000
#define OUTEPMSK7_OFFSET 23
#define OUTEPMSK7_MASK 0x00800000
#define OUTEPMSK6_OFFSET 22
#define OUTEPMSK6_MASK 0x00400000
#define OUTEPMSK5_OFFSET 21
#define OUTEPMSK5_MASK 0x00200000
#define OUTEPMSK4_OFFSET 20
#define OUTEPMSK4_MASK 0x00100000
#define OUTEPMSK3_OFFSET 19
#define OUTEPMSK3_MASK 0x00080000
#define OUTEPMSK2_OFFSET 18
#define OUTEPMSK2_MASK 0x00040000
#define OUTEPMSK1_OFFSET 17
#define OUTEPMSK1_MASK 0x00020000
#define OUTEPMSK0_OFFSET 16
#define OUTEPMSK0_MASK 0x00010000
#define INEPMSK15_OFFSET 15
#define INEPMSK15_MASK 0x00008000
#define INEPMSK14_OFFSET 14
#define INEPMSK14_MASK 0x00004000
#define INEPMSK13_OFFSET 13
#define INEPMSK13_MASK 0x00002000
#define INEPMSK12_OFFSET 12
#define INEPMSK12_MASK 0x00001000
#define INEPMSK11_OFFSET 11
#define INEPMSK11_MASK 0x00000800
#define INEPMSK10_OFFSET 10
#define INEPMSK10_MASK 0x00000400
#define INEPMSK9_OFFSET 9
#define INEPMSK9_MASK 0x00000200
#define INEPMSK8_OFFSET 8
#define INEPMSK8_MASK 0x00000100
#define INEPMSK7_OFFSET 7
#define INEPMSK7_MASK 0x00000080
#define INEPMSK6_OFFSET 6
#define INEPMSK6_MASK 0x00000040
#define INEPMSK5_OFFSET 5
#define INEPMSK5_MASK 0x00000020
#define INEPMSK4_OFFSET 4
#define INEPMSK4_MASK 0x00000010
#define INEPMSK3_OFFSET 3
#define INEPMSK3_MASK 0x00000008
#define INEPMSK2_OFFSET 2
#define INEPMSK2_MASK 0x00000004
#define INEPMSK1_OFFSET 1
#define INEPMSK1_MASK 0x00000002
#define INEPMSK0_OFFSET 0
#define INEPMSK0_MASK 0x00000001
#define CFG_DTHRCTL_ADDR 0x0830
#define ARBPRKEN_OFFSET 27
#define ARBPRKEN_MASK 0x08000000
#define RXTHRLEN_OFFSET 17
#define RXTHRLEN_MASK 0x03FE0000
#define RXTHREN_OFFSET 16
#define RXTHREN_MASK 0x00010000
#define AHBTHRRATIO_OFFSET 11
#define AHBTHRRATIO_MASK 0x00001800
#define TXTHRLEN_OFFSET 2
#define TXTHRLEN_MASK 0x000007FC
#define ISOTHREN_OFFSET 1
#define ISOTHREN_MASK 0x00000002
#define NONISOTHREN_OFFSET 0
#define NONISOTHREN_MASK 0x00000001
#define CFG_DEACHINT_ADDR 0x0838
#define EACHOUTEPINT15_OFFSET 31
#define EACHOUTEPINT15_MASK 0x80000000
#define EACHOUTEPINT14_OFFSET 30
#define EACHOUTEPINT14_MASK 0x40000000
#define EACHOUTEPINT13_OFFSET 29
#define EACHOUTEPINT13_MASK 0x20000000
#define EACHOUTEPINT12_OFFSET 28
#define EACHOUTEPINT12_MASK 0x10000000
#define EACHOUTEPINT11_OFFSET 27
#define EACHOUTEPINT11_MASK 0x08000000
#define EACHOUTEPINT10_OFFSET 26
#define EACHOUTEPINT10_MASK 0x04000000
#define EACHOUTEPINT9_OFFSET 25
#define EACHOUTEPINT9_MASK 0x02000000
#define EACHOUTEPINT8_OFFSET 24
#define EACHOUTEPINT8_MASK 0x01000000
#define EACHOUTEPINT7_OFFSET 23
#define EACHOUTEPINT7_MASK 0x00800000
#define EACHOUTEPINT6_OFFSET 22
#define EACHOUTEPINT6_MASK 0x00400000
#define EACHOUTEPINT5_OFFSET 21
#define EACHOUTEPINT5_MASK 0x00200000
#define EACHOUTEPINT4_OFFSET 20
#define EACHOUTEPINT4_MASK 0x00100000
#define EACHOUTEPINT3_OFFSET 19
#define EACHOUTEPINT3_MASK 0x00080000
#define EACHOUTEPINT2_OFFSET 18
#define EACHOUTEPINT2_MASK 0x00040000
#define EACHOUTEPINT1_OFFSET 17
#define EACHOUTEPINT1_MASK 0x00020000
#define EACHOUTEPINT0_OFFSET 16
#define EACHOUTEPINT0_MASK 0x00010000
#define EACHINEPINT15_OFFSET 15
#define EACHINEPINT15_MASK 0x00008000
#define EACHINEPINT14_OFFSET 14
#define EACHINEPINT14_MASK 0x00004000
#define EACHINEPINT13_OFFSET 13
#define EACHINEPINT13_MASK 0x00002000
#define EACHINEPINT12_OFFSET 12
#define EACHINEPINT12_MASK 0x00001000
#define EACHINEPINT11_OFFSET 11
#define EACHINEPINT11_MASK 0x00000800
#define EACHINEPINT10_OFFSET 10
#define EACHINEPINT10_MASK 0x00000400
#define EACHINEPINT9_OFFSET 9
#define EACHINEPINT9_MASK 0x00000200
#define EACHINEPINT8_OFFSET 8
#define EACHINEPINT8_MASK 0x00000100
#define EACHINEPINT7_OFFSET 7
#define EACHINEPINT7_MASK 0x00000080
#define EACHINEPINT6_OFFSET 6
#define EACHINEPINT6_MASK 0x00000040
#define EACHINEPINT5_OFFSET 5
#define EACHINEPINT5_MASK 0x00000020
#define EACHINEPINT4_OFFSET 4
#define EACHINEPINT4_MASK 0x00000010
#define EACHINEPINT3_OFFSET 3
#define EACHINEPINT3_MASK 0x00000008
#define EACHINEPINT2_OFFSET 2
#define EACHINEPINT2_MASK 0x00000004
#define EACHINEPINT1_OFFSET 1
#define EACHINEPINT1_MASK 0x00000002
#define EACHINEPINT0_OFFSET 0
#define EACHINEPINT0_MASK 0x00000001
#define CFG_DEACHINTMSK_ADDR 0x083c
#define EACHOUTEPMSK15_OFFSET 31
#define EACHOUTEPMSK15_MASK 0x80000000
#define EACHOUTEPMSK14_OFFSET 30
#define EACHOUTEPMSK14_MASK 0x40000000
#define EACHOUTEPMSK13_OFFSET 29
#define EACHOUTEPMSK13_MASK 0x20000000
#define EACHOUTEPMSK12_OFFSET 28
#define EACHOUTEPMSK12_MASK 0x10000000
#define EACHOUTEPMSK11_OFFSET 27
#define EACHOUTEPMSK11_MASK 0x08000000
#define EACHOUTEPMSK10_OFFSET 26
#define EACHOUTEPMSK10_MASK 0x04000000
#define EACHOUTEPMSK9_OFFSET 25
#define EACHOUTEPMSK9_MASK 0x02000000
#define EACHOUTEPMSK8_OFFSET 24
#define EACHOUTEPMSK8_MASK 0x01000000
#define EACHOUTEPMSK7_OFFSET 23
#define EACHOUTEPMSK7_MASK 0x00800000
#define EACHOUTEPMSK6_OFFSET 22
#define EACHOUTEPMSK6_MASK 0x00400000
#define EACHOUTEPMSK5_OFFSET 21
#define EACHOUTEPMSK5_MASK 0x00200000
#define EACHOUTEPMSK4_OFFSET 20
#define EACHOUTEPMSK4_MASK 0x00100000
#define EACHOUTEPMSK3_OFFSET 19
#define EACHOUTEPMSK3_MASK 0x00080000
#define EACHOUTEPMSK2_OFFSET 18
#define EACHOUTEPMSK2_MASK 0x00040000
#define EACHOUTEPMSK1_OFFSET 17
#define EACHOUTEPMSK1_MASK 0x00020000
#define EACHOUTEPMSK0_OFFSET 16
#define EACHOUTEPMSK0_MASK 0x00010000
#define EACHINEPMSK15_OFFSET 15
#define EACHINEPMSK15_MASK 0x00008000
#define EACHINEPMSK14_OFFSET 14
#define EACHINEPMSK14_MASK 0x00004000
#define EACHINEPMSK13_OFFSET 13
#define EACHINEPMSK13_MASK 0x00002000
#define EACHINEPMSK12_OFFSET 12
#define EACHINEPMSK12_MASK 0x00001000
#define EACHINEPMSK11_OFFSET 11
#define EACHINEPMSK11_MASK 0x00000800
#define EACHINEPMSK10_OFFSET 10
#define EACHINEPMSK10_MASK 0x00000400
#define EACHINEPMSK9_OFFSET 9
#define EACHINEPMSK9_MASK 0x00000200
#define EACHINEPMSK8_OFFSET 8
#define EACHINEPMSK8_MASK 0x00000100
#define EACHINEPMSK7_OFFSET 7
#define EACHINEPMSK7_MASK 0x00000080
#define EACHINEPMSK6_OFFSET 6
#define EACHINEPMSK6_MASK 0x00000040
#define EACHINEPMSK5_OFFSET 5
#define EACHINEPMSK5_MASK 0x00000020
#define EACHINEPMSK4_OFFSET 4
#define EACHINEPMSK4_MASK 0x00000010
#define EACHINEPMSK3_OFFSET 3
#define EACHINEPMSK3_MASK 0x00000008
#define EACHINEPMSK2_OFFSET 2
#define EACHINEPMSK2_MASK 0x00000004
#define EACHINEPMSK1_OFFSET 1
#define EACHINEPMSK1_MASK 0x00000002
#define EACHINEPMSK0_OFFSET 0
#define EACHINEPMSK0_MASK 0x00000001
#define CFG_DIEPEACHMSK0_ADDR 0x0840
#define EACHIN_NAKMSK_OFFSET 13
#define EACHIN_NAKMSK_MASK 0x00002000
#define EACHIN_BNAININTRMSK_OFFSET 9
#define EACHIN_BNAININTRMSK_MASK 0x00000200
#define EACHIN_TXFIFOUNDRNMSK_OFFSET 8
#define EACHIN_TXFIFOUNDRNMSK_MASK 0x00000100
#define EACHIN_INEPNAKEFFMSK_OFFSET 6
#define EACHIN_INEPNAKEFFMSK_MASK 0x00000040
#define EACHIN_INTKNEPMISMSK_OFFSET 5
#define EACHIN_INTKNEPMISMSK_MASK 0x00000020
#define EACHIN_INTKNTXFEMPMSK_OFFSET 4
#define EACHIN_INTKNTXFEMPMSK_MASK 0x00000010
#define EACHIN_TIMEOUTMSK_OFFSET 3
#define EACHIN_TIMEOUTMSK_MASK 0x00000008
#define EACHIN_AHBERRMSK_OFFSET 2
#define EACHIN_AHBERRMSK_MASK 0x00000004
#define EACHIN_EPDISBLDMSK_OFFSET 1
#define EACHIN_EPDISBLDMSK_MASK 0x00000002
#define EACHIN_XFERCOMPLMSK_OFFSET 0
#define EACHIN_XFERCOMPLMSK_MASK 0x00000001
#define CFG_DOEPEACHMSK0_ADDR 0x0880
#define EACHOUT_NYETMSK_OFFSET 14
#define EACHOUT_NYETMSK_MASK 0x00004000
#define EACHOUT_NAKMSK_OFFSET 13
#define EACHOUT_NAKMSK_MASK 0x00002000
#define EACHOUT_BBLEERRMSK_OFFSET 12
#define EACHOUT_BBLEERRMSK_MASK 0x00001000
#define EACHOUT_BNAOUTINTRMSK_OFFSET 9
#define EACHOUT_BNAOUTINTRMSK_MASK 0x00000200
#define EACHOUT_OUTPKTERRMSK_OFFSET 8
#define EACHOUT_OUTPKTERRMSK_MASK 0x00000100
#define EACHOUT_BACK2BACKSETUP_OFFSET 6
#define EACHOUT_BACK2BACKSETUP_MASK 0x00000040
#define EACHOUT_STSPHSRCVDMSK_OFFSET 5
#define EACHOUT_STSPHSRCVDMSK_MASK 0x00000020
#define EACHOUT_OUTTKNEPDISMSK_OFFSET 4
#define EACHOUT_OUTTKNEPDISMSK_MASK 0x00000010
#define EACHOUT_SETUPMSK_OFFSET 3
#define EACHOUT_SETUPMSK_MASK 0x00000008
#define EACHOUT_AHBERRMSK_OFFSET 2
#define EACHOUT_AHBERRMSK_MASK 0x00000004
#define EACHOUT_EPDISBLDMSK_OFFSET 1
#define EACHOUT_EPDISBLDMSK_MASK 0x00000002
#define EACHOUT_XFERCOMPLMSK_OFFSET 0
#define EACHOUT_XFERCOMPLMSK_MASK 0x00000001
#define CFG_DIEPCTL0_ADDR 0x0900
#define EPENA_IN_OFFSET 31
#define EPENA_IN_MASK 0x80000000
#define EPDIS_IN_OFFSET 30
#define EPDIS_IN_MASK 0x40000000
#define SNAK_IN_OFFSET 27
#define SNAK_IN_MASK 0x08000000
#define CNAK_IN_OFFSET 26
#define CNAK_IN_MASK 0x04000000
#define TXFNUM_IN_OFFSET 22
#define TXFNUM_IN_MASK 0x03C00000
#define STALL_IN_OFFSET 21
#define STALL_IN_MASK 0x00200000
#define EPTYPE_IN_OFFSET 18
#define EPTYPE_IN_MASK 0x000C0000
#define NAKSTS_IN_OFFSET 17
#define NAKSTS_IN_MASK 0x00020000
#define USBACTEP_IN_OFFSET 15
#define USBACTEP_IN_MASK 0x00008000
#define NEXTEP_IN_OFFSET 11
#define NEXTEP_IN_MASK 0x00007800
#define MPS_IN_OFFSET 0
#define MPS_IN_MASK 0x00000003
#define CFG_DIEPINT0_ADDR 0x0908
#define NYETINTRPT_IN_OFFSET 14
#define NYETINTRPT_IN_MASK 0x00004000
#define NAKINTRPT_IN_OFFSET 13
#define NAKINTRPT_IN_MASK 0x00002000
#define BBLEERR_IN_OFFSET 12
#define BBLEERR_IN_MASK 0x00001000
#define PKTDRPSTS_IN_OFFSET 11
#define PKTDRPSTS_IN_MASK 0x00000800
#define BNAINTR_IN_OFFSET 9
#define BNAINTR_IN_MASK 0x00000200
#define TXFIFOUNDRN_IN_OFFSET 8
#define TXFIFOUNDRN_IN_MASK 0x00000100
#define TXFEMP_IN_OFFSET 7
#define TXFEMP_IN_MASK 0x00000080
#define INEPNAKEFF_IN_OFFSET 6
#define INEPNAKEFF_IN_MASK 0x00000040
#define INTKNEPMIS_IN_OFFSET 5
#define INTKNEPMIS_IN_MASK 0x00000020
#define INTKNTXFEMP_IN_OFFSET 4
#define INTKNTXFEMP_IN_MASK 0x00000010
#define TIMEOUT_IN_OFFSET 3
#define TIMEOUT_IN_MASK 0x00000008
#define AHBERR_IN_OFFSET 2
#define AHBERR_IN_MASK 0x00000004
#define EPDISBLD_IN_OFFSET 1
#define EPDISBLD_IN_MASK 0x00000002
#define XFERCOMPL_IN_OFFSET 0
#define XFERCOMPL_IN_MASK 0x00000001
#define CFG_DIEPTSIZ0_ADDR 0x0910
#define PKTCNT_IN_OFFSET 19
#define PKTCNT_IN_MASK 0x00180000
#define XFERSIZE_IN_OFFSET 0
#define XFERSIZE_IN_MASK 0x0000007F
#define CFG_DIEPDMA0_ADDR 0x0914
#define DMAADDR0_IN_OFFSET 0
#define DMAADDR0_IN_MASK 0xFFFFFFFF
#define CFG_DTXFSTS0_ADDR 0x0918
#define INEPTXFSPCAVAIL_OFFSET 0
#define INEPTXFSPCAVAIL_MASK 0x0000FFFF
#define CFG_DIEPDMAB0_ADDR 0x091c
#define DMABUFFADDR0_IN_OFFSET 0
#define DMABUFFADDR0_IN_MASK 0xFFFFFFFF
#define CFG_DIEPCTL1_ADDR 0x0920
#define EPENA_IN1_OFFSET 31
#define EPENA_IN1_MASK 0x80000000
#define EPDIS_IN1_OFFSET 30
#define EPDIS_IN1_MASK 0x40000000
#define SETD1PID_IN1_OFFSET 29
#define SETD1PID_IN1_MASK 0x20000000
#define SETD0PID_IN1_OFFSET 28
#define SETD0PID_IN1_MASK 0x10000000
#define SNAK_IN1_OFFSET 27
#define SNAK_IN1_MASK 0x08000000
#define CNAK_IN1_OFFSET 26
#define CNAK_IN1_MASK 0x04000000
#define TXFNUM_IN1_OFFSET 22
#define TXFNUM_IN1_MASK 0x03C00000
#define STALL_IN1_OFFSET 21
#define STALL_IN1_MASK 0x00200000
#define EPTYPE_IN1_OFFSET 18
#define EPTYPE_IN1_MASK 0x000C0000
#define NAKSTS_IN1_OFFSET 17
#define NAKSTS_IN1_MASK 0x00020000
#define DPID_IN1_OFFSET 16
#define DPID_IN1_MASK 0x00010000
#define USBACTEP_IN1_OFFSET 15
#define USBACTEP_IN1_MASK 0x00008000
#define NEXTEP_IN1_OFFSET 11
#define NEXTEP_IN1_MASK 0x00007800
#define MPS_IN1_OFFSET 0
#define MPS_IN1_MASK 0x000007FF
#define CFG_DOEPCTL0_ADDR 0x0B00
#define EPENA_OUT_OFFSET 31
#define EPENA_OUT_MASK 0x80000000
#define EPDIS_OUT_OFFSET 30
#define EPDIS_OUT_MASK 0x40000000
#define SNAK_OUT_OFFSET 27
#define SNAK_OUT_MASK 0x08000000
#define CNAK_OUT_OFFSET 26
#define CNAK_OUT_MASK 0x04000000
#define STALL_OUT_OFFSET 21
#define STALL_OUT_MASK 0x00200000
#define SNP_OUT_OFFSET 20
#define SNP_OUT_MASK 0x00100000
#define EPTYPE_OUT_OFFSET 18
#define EPTYPE_OUT_MASK 0x000C0000
#define NAKSTS_OUT_OFFSET 17
#define NAKSTS_OUT_MASK 0x00020000
#define USBACTEP_OUT_OFFSET 15
#define USBACTEP_OUT_MASK 0x00008000
#define MPS_OUT_OFFSET 0
#define MPS_OUT_MASK 0x00000003
#define CFG_DOEPINT0_ADDR 0x0B08
#define STUPPKTRCVD_OUT_OFFSET 15
#define STUPPKTRCVD_OUT_MASK 0x00008000
#define NYETINTRPT_OUT_OFFSET 14
#define NYETINTRPT_OUT_MASK 0x00004000
#define NAKINTRPT_OUT_OFFSET 13
#define NAKINTRPT_OUT_MASK 0x00002000
#define BBLEERR_OUT_OFFSET 12
#define BBLEERR_OUT_MASK 0x00001000
#define PKTDRPSTS_OUT_OFFSET 11
#define PKTDRPSTS_OUT_MASK 0x00000800
#define BNAINTR_OUT_OFFSET 9
#define BNAINTR_OUT_MASK 0x00000200
#define OUTPKTERR_OFFSET 8
#define OUTPKTERR_MASK 0x00000100
#define STSPHSERCVD_OFFSET 5
#define STSPHSERCVD_MASK 0x00000020
#define OUTTKNEPDIS_OFFSET 4
#define OUTTKNEPDIS_MASK 0x00000010
#define SETUP_OUT_OFFSET 3
#define SETUP_OUT_MASK 0x00000008
#define AHBERR_OUT_OFFSET 2
#define AHBERR_OUT_MASK 0x00000004
#define EPDISBLD_OUT_OFFSET 1
#define EPDISBLD_OUT_MASK 0x00000002
#define XFERCOMPL_OUT_OFFSET 0
#define XFERCOMPL_OUT_MASK 0x00000001
#define CFG_DOEPTSIZ0_ADDR 0x0B10
#define SUPCNT_OFFSET 29
#define SUPCNT_MASK 0x60000000
#define PKTCNT_OFFSET 19
#define PKTCNT_MASK 0x00080000
#define XFERSIZE_OFFSET 0
#define XFERSIZE_MASK 0x0000007F
#define CFG_DOEPDMA0_ADDR 0x0B14
#define DMAADDR0_OUT_OFFSET 0
#define DMAADDR0_OUT_MASK 0xFFFFFFFF
#define CFG_DOEPDMAB0_ADDR 0x0B1c
#define DMABUFFADDR0_OUT_OFFSET 0
#define DMABUFFADDR0_OUT_MASK 0xFFFFFFFF
#define CFG_DOEPCTL1_ADDR 0x0B20
#define EPENA_OUT1_OFFSET 31
#define EPENA_OUT1_MASK 0x80000000
#define EPDIS_OUT1_OFFSET 30
#define EPDIS_OUT1_MASK 0x40000000
#define SETD1PID_OUT1_OFFSET 29
#define SETD1PID_OUT1_MASK 0x20000000
#define SETD0PID_OUT1_OFFSET 28
#define SETD0PID_OUT1_MASK 0x10000000
#define SNAK_OUT1_OFFSET 27
#define SNAK_OUT1_MASK 0x08000000
#define CNAK_OUT1_OFFSET 26
#define CNAK_OUT1_MASK 0x04000000
#define STALL_OUT1_OFFSET 21
#define STALL_OUT1_MASK 0x00200000
#define SNP_OUT1_OFFSET 20
#define SNP_OUT1_MASK 0x00100000
#define EPTYPE_OUT1_OFFSET 18
#define EPTYPE_OUT1_MASK 0x000C0000
#define NAKSTS_OUT1_OFFSET 17
#define NAKSTS_OUT1_MASK 0x00020000
#define DPID_OUT1_OFFSET 16
#define DPID_OUT1_MASK 0x00010000
#define USBACTEP_OUT1_OFFSET 15
#define USBACTEP_OUT1_MASK 0x00008000
#define MPS_OUT1_OFFSET 0
#define MPS_OUT1_MASK 0x000007FF
#define CFG_PCGCCTL_ADDR 0x0E00
#define RESTOREVALUE_OFFSET 14
#define RESTOREVALUE_MASK 0xFFFFC000
#define ESSREGRESTORED_OFFSET 13
#define ESSREGRESTORED_MASK 0x00002000
#define EXTHIBERSW_OFFSET 12
#define EXTHIBERSW_MASK 0x00001000
#define EXTHIBERCLMP_OFFSET 11
#define EXTHIBERCLMP_MASK 0x00000800
#define EXTHIBEREN_OFFSET 10
#define EXTHIBEREN_MASK 0x00000400
#define RESTOREMODE_OFFSET 9
#define RESTOREMODE_MASK 0x00000200
#define RESETAFTERSUSP_OFFSET 8
#define RESETAFTERSUSP_MASK 0x00000100
#define L1SUSPENDED_OFFSET 7
#define L1SUSPENDED_MASK 0x00000080
#define PHYSLEEP_OFFSET 6
#define PHYSLEEP_MASK 0x00000040
#define ENBL_L1GATING_OFFSET 5
#define ENBL_L1GATING_MASK 0x00000020
#define RSTPDWNMODULE_OFFSET 3
#define RSTPDWNMODULE_MASK 0x00000008
#define PWRCLMP_OFFSET 2
#define PWRCLMP_MASK 0x00000004
#define GATEHCLK_OFFSET 1
#define GATEHCLK_MASK 0x00000002
#define STOPPCLK_OFFSET 0
#define STOPPCLK_MASK 0x00000001
#define CFG_PCGCCTL1_ADDR 0xE04
#define RAMGATEEN_OFFSET 3
#define RAMGATEEN_MASK 0x00000008
#define CNTGATECLK_OFFSET 1
#define CNTGATECLK_MASK 0x00000006
#define GATEEN_OFFSET 0
#define GATEEN_MASK 0x00000001
//HW module read/write macro
寄存器
31文章
5290浏览量
119789 -
usb
60文章
7872浏览量
263656 -
USB2.0
2文章
186浏览量
46011 -
驱动开发
130浏览量
12059 -
DWC2
35浏览量
118
