我们连接RGB的LCD屏后,先进入终端把开机启动的mxapp2关闭。有两种方式,一是killall mxapp2,二是用top查到mxapp2的进程,然后用kill 进程ID
执行测试
root@myir-yg2lx:~# framebuffer_test
The framebuffer device was opened successfully.
vinfo.xres=800
vinfo.yres=480
vinfo.bits_per_bits=32
vinfo.xoffset=0
vinfo.yoffset=0
red.offset=16
green.offset=8
blue.offset=0
transp.offset=0
finfo.line_length=3200
finfo.type = PACKED_PIXELS
The framebuffer device was mapped to memory successfully.
color: red rgb_val: 00FF0000
color: green rgb_val: 0000FF00
color: blue rgb_val: 000000FF
color: r & g rgb_val: 00FFFF00
color: g & b rgb_val: 0000FFFF
color: r & b rgb_val: 00FF00FF
color: white rgb_val: 00FFFFFF
color: black rgb_val: 00000000
注意 如果有上述输出,但是屏没有显示,是因为设备树没有更新,需要进入uboot执行:
=> setenv fdt_file myb-rzg2l-disp.dtb
=> saveenv
触摸测试
需要连接带触摸的屏,我这里是MY-TFT070-K
终端执行行“evtest”进入测试界面
root@myir-yg2lx:~# evtest
No device specified, trying to scan all of /dev/input/event*
Available devices:
/dev/input/event0: keyboard
/dev/input/event1: generic ft5x06 (79)
/dev/input/event2: A4TECH USB Device Keyboard
/dev/input/event3: A4TECH USB Device System Control
/dev/input/event4: A4TECH USB Device Consumer Control
/dev/input/event5: A4TECH USB Device
/dev/input/event6: A4TECH USB Device
Select the device event number [0-6]:
从结果我看到,触摸屏ft5x06为event1。我们输入1
Select the device event number [0-6]: 1
Input driver version is 1.0.1
Input device ID: bus 0x18 vendor 0x0 product 0x0 version 0x0
Input device name: "generic ft5x06 (79)"
Supported events:
Event type 0 (EV_SYN)
Event type 1 (EV_KEY)
Event code 330 (BTN_TOUCH)
Event type 3 (EV_ABS)
Event code 0 (ABS_X)
Value 155
Min 0
Max 799
Event code 1 (ABS_Y)
Value 476
Min 0
Max 479
Event code 47 (ABS_MT_SLOT)
Value 0
Min 0
Max 4
Event code 53 (ABS_MT_POSITION_X)
Value 0
Min 0
Max 799
Event code 54 (ABS_MT_POSITION_Y)
Value 0
Min 0
Max 479
Event code 57 (ABS_MT_TRACKING_ID)
Value 0
Min 0
Max 65535
Properties:
Property type 1 (INPUT_PROP_DIRECT)
Testing ... (interrupt to exit)
然后我们点击屏就有相应的输出:
Event: time 3029532101.3029532101, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value 34
Event: time 3029532101.3029532101, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 486
Event: time 3029532101.3029532101, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 172
Event: time 3029532101.3029532101, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 3029532101.3029532101, type 3 (EV_ABS), code 0 (ABS_X), value 486
Event: time 3029532101.3029532101, type 3 (EV_ABS), code 1 (ABS_Y), value 172
Event: time 3029532101.3029532101, -------------- SYN_REPORT ------------
Event: time 3029532101.3029532101, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 485
Event: time 3029532101.3029532101, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 171
Event: time 3029532101.3029532101, type 3 (EV_ABS), code 0 (ABS_X), value 485
Event: time 3029532101.3029532101, type 3 (EV_ABS), code 1 (ABS_Y), value 171
Event: time 3029532101.3029532101, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 484
Event: time 3029532101.3029532101, type 3 (EV_ABS), code 0 (ABS_X), value 484
Event: time 3029532101.30295322
Event: time 3029532101.3029532101, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value -1
Event: time 3029532101.3029532101, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
由上面可知,主要显示坐标值、键值,具体信息如下:
EV_SYN:同步事件
EV_KEY:按键事件,如 BTN_TOUCH 表示是触摸按键
EV_ABS:绝对坐标,如触摸屏上报的坐标
BTN_TOUCH:触摸按键
ABS_MT_SLOT:事件中对应的 value
ABS_MT_TRACKING_ID 表示采集信息开始
单点触摸信息是以 ABS 承载并按一定顺序发送,如:
ABS_X:是相对于屏幕绝对坐标 X
ABS_Y:是相对于屏幕绝对坐标 Y
而多点触摸信息则是以 ABS_MT 承载并按一定顺序发送,如:
ABS_MT_POSITION_X:表示屏幕接触面的中心点 x 坐标位置.
ABS_MT_POSITION_Y:表示屏幕接触面的中心点 Y 坐标位置
审核编辑:汤梓红
举报投诉
测试
9文章
6496浏览量
131771 -
触摸屏
42文章
2521浏览量
122663 -
开发板
26文章
6487浏览量
121327 -
米尔
56浏览量
8451
热点推荐
入门级i.MX6UL板卡的神经网络框架ncnn的移植与测试-米尔MYD-Y6ULX-V2开发板
米尔 MYD-Y6ULX-V2 开发板,基于 NXP i.MX6UL/i.MX6UL L处理器,该开发板被米尔称之为经典王牌产品。本次
系统启动时间优化方案--基于米尔MYD-YG2LX开发板
设接口,在工业、医疗、电力等行业都得到广泛的应用。
米尔基于瑞萨RZ/G2L开发板本文主要介绍基于MYD-YG2LX开发板进行系统启动时间优
发表于 05-09 18:03
【MYD-Y6ULX试用体验】基于米尔MYD-Y6ULX开发板的酒驾测试计-结项报告
MYD-Y6ULX开发板的酒驾测试计 首先是材料的准备:1.米尔MYD-Y6ULX开发套件一套
发表于 03-22 09:03
【米尔MYD-YT507开发板试用体验】Ubuntu的xfce桌面环境建立及远程穿透访问家中米尔MYD-YT507开发板
到eMMC和完全调教指南! ,我分享了在米尔MYD-YT507开发板上烧录Ubuntu18.04系统及系统基础调整,这篇文章中,分享的是xfce桌面环境的建立,以及如何在公司远程穿透访问家里内网的
试用视频丨国产开发板各项性能测试--米尔MYD-YT507H开发板
本篇测评由电子工程世界的优秀测评者“qinyunti”提供。此次的板卡测试,是米尔MYD-YT507H开发板的各项性能测试。完整试用视频戳这
在多媒体应用场景下ffmpeg网络视频播放器的体验--基于米尔MYD-YG2LX开发板
MYD-YG2LX开发板快捷高效的多媒体应用开发。过程https://www.sample-videos.com/index.php#sample-mp4-video下下测试mp
米尔基于瑞萨RZ/G2L开发板在工控领域的应用-基于SOEM的EtherCAT主站
本文介绍【米尔MYD-YG2LX开发板】在工控领域的应用,实现基于SOEM的EtherCAT主站。开发环境基于WSL2。
米尔MYD-YG2开发板触摸屏测试
