python下载snap7模块
pip3 install python-snap7
测试程序
demo.py
import snap7
import s7_utils
def connectPLC():
s7_utils.S7_200_Connect('192.168.1.2', 3, 0, 1, "1#PLC")
s7_utils.S7_200_Connect('192.168.1.3', 3, 0, 1, "2#PLC")
s7_utils.S7_200_Connect('192.168.1.4', 3, 0, 1, "3#PLC")
s7_utils.S7_200_Connect('192.168.1.5', 3, 0, 1, "4#PLC")
s7_utils.S7_200_Connect('192.168.1.6', 3, 0, 1, "5#PLC")
def getAllPLCData():
for bzplc in s7_utils.PLCArray:
plcobj = bzplc["plcObj"]
## 读取DB块
V = s7_utils.dbRead(plcobj, bool, 1, 200, 0, 4, 1)
PV = s7_utils.dbRead(plcobj, float, 1, 300, 0, 4, 0)、
## 读取M区
bj1 = s7_utils.mReadBool(plcobj,1,4)
bj2 = s7_utils.mReadBool(plcobj,1,3)
bj3 = s7_utils.mReadBool(plcobj,1,2)
bj4 = s7_utils.mReadBool(plcobj,1,1)
print(bzplc["name"]+"\\n","电压:",V,"频率",PV,"报警1",bj1,"报警2",bj2,"报警3",bj3,"报警4",bj4)
connectPLC()
getAllPLCData()
s7_utils.S7_200_DisconnectAll()
S7协议工具类
s7_utils.py
import snap7
from snap7.util import *
PLCArray = []
## 连接PLC 加入数组
def S7_200_Connect(ip, type, rack, slot, name):
plcObj = snap7.client.Client()
plcObj.disconnect()
plcObj.set_connection_type(type)
try:
plcObj.connect(ip, rack, slot)
except:
print(f"连接状态: {ip} 连接失败")
return 0
print(f"连接状态:{plcObj.get_connected()}{ip} 连接成功")
saveData = {
"plcObj": plcObj,
"name": name,
"ip": ip
PLCArray.append(saveData)
return 1
def S7_200_getplcObj(ip):
for plc in PLCArray:
if plc["ip"] == ip:
return plc["plcObj"]
return 1
## 关闭所有PLC连接
def S7_200_DisconnectAll():
# print(plc)
if plc["plcObj"] != None:
plc["plcObj"].disconnect()
return 1
## 读取DB块
def dbRead(plcObj, type, dbnum, startAddress, address, dblength, boolX):
DB块的读操作;如果是200smart系列的将dbnum设置为0
:param dbnum: DB1
:param dblength:
:return:
data = plcObj.read_area(snap7.types.Areas.DB, dbnum, startAddress, dblength)
# print(data)
if type == int:
return get_int(data, address)
elif type == bool:
return get_bool(data, address, boolX)
elif type == str:
return get_dword(data, address)
elif type == float:
return get_real(data, address)
elif type == bytes:
return get_byte(data, address)
else:
return None
## 写DB块
def dbWrite(plcObj, type, data, dbnum, startAddress, dblength, address):
DB块的写操作;如果是200smart系列的将dbnum设置为0
:param dbnum: DB块的序号
:param dblength:
:return: 字节长度,根据需要设定
if type == int:
set_int(data, address, data)
elif type == bool:
set_bool(data, address, 0, data)
elif type == str:
set_dword(data, address, data)
elif type == float:
set_real(data, address, data)
elif type == bytes:
set_byte(data, address, data)
else:
return None
plcObj.write_area(snap7.types.Areas.DB, dbnum, startAddress, data)
def mReadBool(plcObj, num, bit):
M区的读操作--------bool
:param num:
:param bit:
:return:
data = plcObj.read_area(snap7.types.Areas.MK, 0, num, 1)
# print(data)
return get_bool(data, 0, bit)
def mRead(plcObj, type, num):
M区的读操作--------int/word/dint/dword
:param num:
:return:
data = plcObj.read_area(snap7.types.Areas.MK, 0, num, 2)
if type == int:
get_int(data, 0)
elif type == bool:
get_byte(data, 0)
elif type == "dint":
get_dint(data, 0)
else:
return None
def mWriteBool(plcObj, byte, bit, value):
M块的写操作---------bool
:param byte:
:param bit:
:param value:
:return:
data = plcObj.read_area(snap7.types.Areas.MK, 0, byte, 1)
set_bool(data, 0, bit, value)
plcObj.write_area(snap7.types.Areas.MK, 0, byte, data)
def mWrite2(plcObj, byte, value):
M块的写操作---------int/word/dint/dword
:param byte:
:param value:
:return:
data = plcObj.read_area(snap7.types.Areas.MK, 0, byte, 4)
# set_int(data, 0, value)
set_dint(data, 0, value)
举报投诉
西门子
92文章
2911浏览量
114290 -
鸿蒙
55文章
2168浏览量
42290
S7 PLC TCP/IP协议参考LABVIEW实例
通过以太网与S7-300系列PLC通信,不需要适配器。该示例提供了一个API,用于读取/写入PLC上的寄存器。[tr]据我所知,西门子从未公
发表于 02-15 23:51
基于S7-1500的S7通信编程
S7 协议是SIEMENS S7 系列产品之间通讯使用的标准协议,其优点是通信双方无论是在同- -MPI 总线上、同一PROFIBUS 总线上或同- 工业以太网中,都可
发表于 09-26 17:53
•39次下载
![基于<b class='flag-5'>S7</b>-1500的<b class='flag-5'>S7</b>通信编程](https://file.elecfans.com/web2/M00/49/DF/pYYBAGKhvG2ABHw7AAATXnwdP5U838.jpg)
S7-400基于PROFIBUS总线的S7单边通信的组态步骤
S7协议是SIEMENS S7系列产品之间通讯使用的标准协议 ,其优点是通信双方无论是在同一MPI总线上、同一PROFIBUS总线上或同一工业以太网中,都可
Python Snap7实现S7-1200 PLC通信控制
Snap7 是一个基于以太网与S7系列的西门子PLC通讯的开源库,支持包括S7系列的S7-200、S7
发表于 04-17 14:19
•1次下载
![<b class='flag-5'>Python</b> Snap<b class='flag-5'>7</b>实现<b class='flag-5'>S7</b>-1200 <b class='flag-5'>PLC</b>通信控制](https://file.elecfans.com/web1/M00/D9/4E/pIYBAF_1ac2Ac0EEAABDkS1IP1s689.png)
C#使用西门子S7协议读写PLC DB块
是我们上位机要读写的DB 3. 根据西门子S7 协议文档读取DB块的方式有很多种,直接根据该DB的偏移量进行读写也行,但读或写数据都需要进行对应的
发表于 04-19 10:05
•19次下载
![C#使用西门子<b class='flag-5'>S7</b><b class='flag-5'>协议</b>读写<b class='flag-5'>PLC</b> DB块](https://file.elecfans.com/web1/M00/D9/4E/pIYBAF_1ac2Ac0EEAABDkS1IP1s689.png)
python使用Snap7读写西门子S7系列PLC
Snap7是一个基于s7通信协议的开源软件包,作者是Davide Nardella,该软件包封装了S7通信的底层协议,可使用普通电脑
发表于 04-20 10:45
•4次下载
![<b class='flag-5'>python</b>使用Snap<b class='flag-5'>7</b>读写西门子<b class='flag-5'>S7</b>系列<b class='flag-5'>PLC</b>](https://file.elecfans.com/web1/M00/D9/4E/pIYBAF_1ac2Ac0EEAABDkS1IP1s689.png)
S7通信协议介绍 s7协议和profinet协议区别
S7协议和Profinet协议都是工业自动化领域中常用的通信协议,其中S7协议是传统的工控领域常
发表于 05-08 16:19
•2.2w次阅读
干货分享:宏集物联网HMI通过S7 MPI协议采集西门子400PLC数据
宏集物联网HMI集成了多个驱动来适配西门子200、300、400、1200、1500、LOGO等系列PLC,本文主要介绍宏集HMI通过S7 MPI协议采集西门子400
![干货分享:宏集物联网HMI<b class='flag-5'>通过</b><b class='flag-5'>S7</b> MPI<b class='flag-5'>协议</b>采集西门子400<b class='flag-5'>PLC</b><b class='flag-5'>数据</b>](https://file1.elecfans.com/web2/M00/ED/44/wKgZomZqg1aABbbgAAG9ZujEJLk752.png)
西门子S7协议与TCP协议的区别
在工业自动化领域,通信协议的选择对于确保设备间的顺畅通信和数据的可靠传输至关重要。西门子S7协议和TCP协议作为两种常用的通信
宏集物联网工控屏通过 S7 ETH 协议采集西门子 1200 PLC 数据
上周我们分享了宏集HMI通过S7 MPI协议采集西门子400 PLC数据的操作步骤。本周,我们将继续带来干货,重点介绍宏集HMI如何
![宏集物联网工控屏<b class='flag-5'>通过</b> <b class='flag-5'>S7</b> ETH <b class='flag-5'>协议</b>采集西门子 1200 <b class='flag-5'>PLC</b> <b class='flag-5'>数据</b>](https://file1.elecfans.com/web2/M00/F2/66/wKgaomZ1MV6AFYo5ADYM_65m7eQ436.png)
