目的
为了达到节能状态,采用RTCalarm唤醒睡眠。
- 开启RTC以及RTC alarm
- 修改drv_rtc.c中rtc_init,增加连择时钟源,代码如下:
static rt_err_t _rtc_init(void)
#ifdef BSP_RTC_USING_LSE
Cy_RTC_SelectClockSource(CY_RTC_CLK_SELECT_WCO);
#else
Cy_RTC_SelectClockSource(CY_RTC_CLK_SELECT_ILO);
#endif
if (cyhal_rtc_init(&rtc_obj) != RT_EOK)
LOG_E("rtc init failed.");
return -RT_ERROR;
return RT_EOK;
- 增加alarm方面的函数如下:
static struct rt_alarm * p_alarm_hour = RT_NULL;
/* 闹钟的回调函数,多个闹钟,可以有多个回调函数,用于创建闹钟时注册。闹钟时间到了,会执行此函数 */
static void alarm_hour_cb(rt_alarm_t alarm, time_t timestamp)
LOG_D("alarm_hour_cb ok!
static void rtc_alarm_hour_create(void)
static time_t now;
struct tm *p_tm;
struct rt_alarm_setup alarm_setup_test;
if (p_alarm_hour != RT_NULL)
return;
now = time(NULL);
p_tm = localtime(&now);
alarm_setup_test.flag = RT_ALARM_SECOND;
alarm_setup_test.wktime.tm_year = p_tm->tm_year;
alarm_setup_test.wktime.tm_mon = p_tm->tm_mon;
alarm_setup_test.wktime.tm_mday = p_tm->tm_mday;
alarm_setup_test.wktime.tm_wday = p_tm->tm_wday;
alarm_setup_test.wktime.tm_hour = p_tm->tm_hour + 1;
alarm_setup_test.wktime.tm_min = p_tm->tm_min;
alarm_setup_test.wktime.tm_sec = p_tm->tm_sec;
p_alarm_hour = rt_alarm_create(alarm_hour_cb, &alarm_setup_test);
static void rtc_alarm_hour_start(void)
rt_alarm_start(p_alarm_hour);
static void rtc_alarm_hour_stop(void)
rt_alarm_stop(p_alarm_hour);
static void rtc_alarm_hour_delete(void)
if (rt_alarm_delete(p_alarm_hour) == RT_EOK)
- 修改rt_hw_rtc_init函数,增加alarm创建与启动。
static int rt_hw_rtc_init(void)
rt_err_t result = RT_EOK;
ifx32_rtc_dev.ops = &_rtc_ops;
if (rt_hw_rtc_register(&ifx32_rtc_dev, "rtc", RT_DEVICE_FLAG_RDWR, RT_NULL) != RT_EOK)
LOG_E("rtc init failed");
result = -RT_ERROR;
else
LOG_D("rtc init success");
/* 设置ALARM*/
rtc_alarm_hour_create();
rtc_alarm_hour_start();
return result;
- 修改主函数代码如下:
#include
#include
#include "drv_gpio.h"
#define LED_PIN GET_PIN(0, 0)
#define USE_SECONDS_FOR_ALARM 10
#define LONG_GLITCH_DELAY_MS 100u /* in ms */
#define RTC_INTERRUPT_PRIORITY 3u
void set_rtc_alarm_date_time(void);
cyhal_rtc_t rtc_obj;
int main(void)
cy_rslt_t result;
__enable_irq();
rt_pin_mode(LED_PIN, PIN_MODE_OUTPUT);
rt_thread_mdelay(500);
/* Initialize RTC */
cyhal_rtc_enable_event(&rtc_obj, CYHAL_RTC_ALARM, RTC_INTERRUPT_PRIORITY, true);
for (;;)
rt_kprintf("Go to DeepSleep mode
/* Set the RTC generate alarm after 10 seconds */
set_rtc_alarm_date_time();
cyhal_system_delay_ms(LONG_GLITCH_DELAY_MS);
/* Go to deep sleep */
cyhal_syspm_deepsleep();
rt_kprintf("Wakeup from DeepSleep mode
cy_rslt_t result;
/* Print the RTC alarm time by UART */
//LOG_D("RTC alarm will be generated after 10 seconds
/* Set the RTC alarm for the specified number of seconds in the future by editing the macro(USE_SECONDS_FOR_ALARM) */
result = cyhal_rtc_set_alarm_by_seconds(&rtc_obj, USE_SECONDS_FOR_ALARM);
if (result != CY_RSLT_SUCCESS)
rt_kprintf("RTC alarm err
下载到开发板后,打开串口终端,显示系统进入睡眠,然后在10秒钟后唤醒
举报投诉
RTC
2文章
602浏览量
68009
英飞凌推出62mm CoolSiC™模块,为碳化硅开辟新应用领域
该62mm模块配备了英飞凌的CoolSiC MOSFET芯片,可实现极高的电流密度。其极低的开关损耗和传导损耗可以最大限度地减少冷却器件的尺寸。
发表于 07-14 17:40
•1742次阅读
DSP的PSC如何配置
这个程序大概什么意思,逐句求解一下!/*Enable Function for PSC0*/void PSC0_lPSC_enable(unsigned int PD, unsigned int
发表于 04-16 09:46
PSC开启模块出现以下错误
(SOC_PSC_0_REGS, HW_PSC_EMIFA, PSC_POWERDOMAIN_ALWAYS_ON,PSC_MDCTL_NEXT_ENABLE);}但出现以下错误:unr
发表于 11-04 09:06
浙江常年大量回收英飞凌二手模块系列IGBT模块
模块长期高价回收英飞凌IGBT模块FF300R12KT3_E 300A,1200V,共发射极,用于矩阵开关,双向变换器等 62mm ? 无锡不限量收购回收英飞凌IGBT模块电话151-5220-9946QQ2360670759
发表于 02-24 17:06
回收英飞凌ic 收购英飞凌ic
▄▅ TEL:135-3012-2202 ▄▅ QQ:8798-21252 ‖‖回收英飞凌ic ,回收英飞凌汽车ic,专业回收英飞凌ic,库存英飞凌汽车ic高价回收,汽车库存芯片专业回
发表于 05-15 15:24
重庆市长期高价回收各种英飞凌IGBT型号模块
长期高价回收英飞凌IGBT模块FF300R12KT3_E 300A,1200V,共发射极,用于矩阵开关,双向变换器等 62mm ?无锡不限量收购回收英飞凌IGBT模块FF400R12KT3_E
发表于 09-17 19:23
英飞凌PSoC62 实现超低功耗温湿度计
英飞凌PSoC62是一款Cortex-M0+与Cortex-M4的双内核MCU,其有着非常优秀的超低功耗性能。
温度计的器材
英飞凌PSoC62开发板 这是一款
发表于 06-03 10:14
Touch-activated Alarm circuits
Touch-activated Alarm,Attach trigger wire to the latch nut/bolt Isolate this Latch from any other metal parts
发表于 03-12 22:41
•758次阅读
英飞凌联合 RT-Thread 发布 PSoC™ 62 with CAPSENSE ™ evaluation kit开发板
近日,RT-Thread 社区团队打造了新品开发板:英飞凌联合 RT-Thread 发布 PSoC 62 with CAPSENSE evaluation kit开发板 (以下简称PSoC 6
【PSoC™62 for RT-Thread】RT-Thread携手英飞凌举办嵌入式网络应用开发沙龙,圆满落幕!
题的线下沙龙!此次沙龙聚焦使用英飞凌科技PSoC62在RT-Thread Studio平台上进行开发,并结合智能数据网关动手培训为开发者们提供了深入了解英飞凌与学习使用RT-Thread的良好机会,吸引了近150余名工程师报名参
STM32定时器,当PSC为1时,定时器时钟CK_CNT和CK_PSC的频率为什么是一样的
时钟周期和状态变化的概念 首先,时钟信号是一种周期性的信号,比如CK_PSC信号。一个完整的时钟周期包括从一个上升沿(信号从低电平变为高电平)开始,经过高电平阶段、下降沿(信号从高电平变为低电平
