** allEq(全部eq或个别isNull):**
allEq(Map< R,V > params);
allEq(Map< R,V > params,boolean null2IsNull);
allEq(boolean condition, Map< R, V > params, boolean null2IsNull);
** Eq(等于):**
eq(R column,Object val);
eq(boolean condition,R column,Object val);
** ne(不等于):**
ne(R column,Object val);
ne(boolean condition,R column,Object val);
** gt(大于):**
gt(R column,Object val);
gt(boolean condition,R column,Object val);
ge(大于等于):
ge(R column,Object val);
ge(boolean condition,R column,Object val);
** lt(小于):**
lt(R column,Object val);
lt(boolean condition,R column,Object val);
** le(小于等于):**
le(R column,Object val);
le(boolean condition,R column,Object val);
** between(between 值1 and 值2):**
between(R column,Objcet val1,Object val2);
between(boolean condition,R column,Objcet val1,Object val2);
** notBetween(not between 值1 and 值2):**
notBetween(R column,Object val1,Object val2);
notBetween(boolean condition,R column,Object val1,Object val2);
** like(like'%值%'):**
like(R column,Object val);
like(boolean condition,R column,Object val);
** notLike(not like'%值%'):**
notLike(R column,Object val);
notLike(boolean condition,R column,Object val);
** likeLeft(like '%值'):**
likeLeft(R column,Object val);
likeLeft(boolean condition,R column,Object val);
** likeRight(like'值%'):**
likeRight(R column,Object val);
likeRight(boolean condition,R column,Object val);
** isNull:**
isNull(R column);
isNull(boolean condition,R column);
** isNotNull:**
isNotNull(R column);
isNotNull(boolean condition,R column);
** in:**
in(R column,Collection< ? > value);
in(R column,Object... values);
in(boolean condition,R column,Collection< ? > value);
in(boolean condition,R column,Object... values);
** notIn:**
notIn(R column,Collection< ? > value);
notIn(R column,Object... values);
notIn(boolean condition,R column,Collection< ? > value);
notIn(boolean condition,R column,Object... values);
** inSql(字段in,sql语句):**
inSql(R column,String inValue);
inSql(boolean condition,R column,String inValue);
** notInSql:**
notInSql(R column,String inValue);
notInSql(boolean condition,R column,String inValue);
** groupBy:**
groupBy(R... columns);
groupBy(boolean condition,R... columns);
** orderBy:**
orderBy(boolean condition, boolean isAsc, R... columns);
** orderByAsc:**
orderByAsc(R... columns);
orderByAsc(boolean condition, R... columns);
** orderByDesc:**
orderByDesc(R... columns);
orderByDesc(boolean condition, R... columns);
** having:**
having(String sqlHaving, Object... params);
having(boolean condition, String sqlHaving, Object... params);
** func:**
func(Consumer< Children > consumer);
func(boolean condition,Consumer< Childern > consumer);
// 例如:func(i - > if(true){i.eq("id",1)}else{i.ne("id",1)})
** or(不调用or则默认为使用and连接):**
or()
or(boolean condition);
** and:**
and(Consumer< Param > consumer);
and(boolean condition,Consumer< Param > consumer);
** nested(正常嵌套不带and或者or):**
nested(Consumer< Param > consumer);
nested(boolean condition,Consumer< Param > consumer);
// 例如:nested(i - > i.eq("name","张山").eq("status","dead")) ==》
// name = '张山' and status = 'dead'
** exists:**
exists(String existSql);
exists(boolean condition, String existSql);
** notExists:**
notExists(String notExistsSql)
notExists(boolean condition, String notExistsSql)
举报投诉
Val
3浏览量
8294 -
null
17浏览量
3861
一文了解Java中的构造器
C ++ 引入了构造器(constructor,也叫构造函数)的概念,它是在创建对象时被自动调用的特殊方法。 Java 也采用了构造器,并且
发表于 11-22 09:32
•375次阅读
![](https://file1.elecfans.com/web2/M00/83/A6/wKgaomRl4RWAeONHAADfCe4-RXY811.png)
![](https://file.elecfans.com/web2/M00/B1/97/pYYBAGS2ZTmAGmoSAACdnsGvVOM090.png)
矩阵的构造
怎样构造一个矩阵,它的指定位置元素为1,其他为0,比如A=[2,2,3,3,1]则构造一个B,它是3*5的矩阵B=[0,0,0,0,1;1,1,0,0,0;0,0,1,1,0]
发表于 06-04 13:53
使用Labview提供的.NET包的构造器节点问题
请问下各位大虾,有使用过构造器节点调用.NET做的dll文件吗?为什么加载程序时Labview打开很慢?是否是网络设置的关系?
发表于 03-19 10:34
绝缘型反激式转换器电路设计:变压器构造设计其1
在计算前项的数值后,接着进入变压器T1的构造设计的阶段。对平时只设计电子部件的人们来说,组合铁芯和骨架、绕组,且必须具备经验法则的变压器设计,简直就像是异世界一样。而且,变压器是电源设
发表于 11-30 11:38
labview调用.net构造器占用内存
本人在labview中第一次调用.net 构造器遇到了占用内存的问题。在这里描述下希望可以帮到又需要的人。现象:labview是在windows任务管理器中 内存使用一直增加 大概一两个小时后会提示
发表于 05-09 09:40
OHOS HDF 图谱-2-HdfObject对象构造器
OHOS HDF 图谱-2-HdfObject对象构造器梁开祝 2022.05.09【说明: “OHOS HDF 图谱”系列文章,是《沉浸式剖析OpenHarmony源代码》一书第9章内容的补充材料
发表于 05-12 17:00
基于Agent技术的机群智能构造器的设计
提出了一种基于 Agent 技术的机群智能构造器CIB 通过一种系统构造机制CIB 实现了对机群系统的自动配置部署和引导从而构造出用户定制的机群系统同时它提供了遵循用户心智模型的GUI
发表于 09-26 15:31
•15次下载
![基于Agent技术的机群智能<b class='flag-5'>构造</b><b class='flag-5'>器</b>的设计](https://file.elecfans.com/web2/M00/49/24/pYYBAGKhtDuAa4-LAAANfT_ImWA331.jpg)
蒸汽锅炉与蒸汽发生器的构造标准
蒸汽锅炉其实可以理解为蒸汽发生器,我们讲清楚了蒸汽锅炉的构造标准,就可理解了蒸汽发生器的构造标准了,那么蒸汽锅炉与蒸汽发生器的
发表于 12-07 16:03
•3991次阅读
