PyTorch教程-9.6. 递归神经网络的简洁实现
jf_pJlTbmA9 来源:PyTorch 作者:PyTorch 2023-06-05 15:44 次阅读
与我们大多数从头开始的实施一样, 第 9.5 节旨在深入了解每个组件的工作原理。但是,当您每天使用 RNN 或编写生产代码时,您会希望更多地依赖于减少实现时间(通过为通用模型和函数提供库代码)和计算时间(通过优化这些库实现)。本节将向您展示如何使用深度学习框架提供的高级 API 更有效地实现相同的语言模型。和以前一样,我们首先加载时间机器数据集。
import torch
from torch import nn
from torch.nn import functional as F
from d2l import torch as d2l
from mxnet import np, npx
from mxnet.gluon import nn, rnn
from d2l import mxnet as d2l
npx.set_np()
from flax import linen as nn
from jax import numpy as jnp
from d2l import jax as d2l
No GPU/TPU found, falling back to CPU. (Set TF_CPP_MIN_LOG_LEVEL=0 and rerun for more info.)
import tensorflow as tf
from d2l import tensorflow as d2l
9.6.1. 定义模型
我们使用由高级 API 实现的 RNN 定义以下类。
class RNN(d2l.Module): #@save
  """The RNN model implemented with high-level APIs."""
  def __init__(self, num_inputs, num_hiddens):
    super().__init__()
    self.save_hyperparameters()
    self.rnn = nn.RNN(num_inputs, num_hiddens)
  def forward(self, inputs, H=None):
    return self.rnn(inputs, H)
Specifically, to initialize the hidden state, we invoke the member method begin_state. This returns a list that contains an initial hidden state for each example in the minibatch, whose shape is (number of hidden layers, batch size, number of hidden units). For some models to be introduced later (e.g., long short-term memory), this list will also contain other information.
  def __init__(self, num_hiddens):
    super().__init__()
    self.rnn = rnn.RNN(num_hiddens)
    if H is None:
      H, = self.rnn.begin_state(inputs.shape[1], ctx=inputs.ctx)
    outputs, (H, ) = self.rnn(inputs, (H, ))
    return outputs, H
Flax does not provide an RNNCell for concise implementation of Vanilla RNNs as of today. There are more advanced variants of RNNs like LSTMs and GRUs which are available in the Flax linen API.
class RNN(nn.Module): #@save
  num_hiddens: int
  @nn.compact
  def __call__(self, inputs, H=None):
    raise NotImplementedError
    super().__init__()
    self.rnn = tf.keras.layers.SimpleRNN(
      num_hiddens, return_sequences=True, return_state=True,
      time_major=True)
    outputs, H = self.rnn(inputs, H)
    return outputs, H
继承自9.5 节RNNLMScratch中的类 ,下面的类定义了一个完整的基于 RNN 的语言模型。请注意,我们需要创建一个单独的全连接输出层。RNNLM
class RNNLM(d2l.RNNLMScratch): #@save
  """The RNN-based language model implemented with high-level APIs."""
  def init_params(self):
    self.linear = nn.LazyLinear(self.vocab_size)
  def output_layer(self, hiddens):
    return self.linear(hiddens).swapaxes(0, 1)
    self.linear = nn.Dense(self.vocab_size, flatten=False)
    self.initialize()
  training: bool = True
  def setup(self):
    self.linear = nn.Dense(self.vocab_size)
  def forward(self, X, state=None):
    embs = self.one_hot(X)
    rnn_outputs, _ = self.rnn(embs, state, self.training)
    return self.output_layer(rnn_outputs)
    self.linear = tf.keras.layers.Dense(self.vocab_size)
    return tf.transpose(self.linear(hiddens), (1, 0, 2))
9.6.2. 训练和预测
在训练模型之前,让我们使用随机权重初始化的模型进行预测。鉴于我们还没有训练网络,它会产生无意义的预测。
data = d2l.TimeMachine(batch_size=1024, num_steps=32)
rnn = RNN(num_inputs=len(data.vocab), num_hiddens=32)
model = RNNLM(rnn, vocab_size=len(data.vocab), lr=1)
model.predict('it has', 20, data.vocab)
'it hasgggggggggggggggggggg'
rnn = RNN(num_hiddens=32)
'it hasxlxlxlxlxlxlxlxlxlxl'
'it hasnvjdtagwbcsxvcjwuyby'
接下来,我们利用高级 API 训练我们的模型。
trainer = d2l.Trainer(max_epochs=100, gradient_clip_val=1, num_gpus=1)
trainer.fit(model, data)
poYBAGR9NrKAA2V1ABG9IJKp_s8858.svg
poYBAGR9NrmAC0QYABHpbt_PvZk929.svg
with d2l.try_gpu():
  trainer = d2l.Trainer(max_epochs=100, gradient_clip_val=1)
poYBAGR9NsGAZ5qbABHCG7mYLzs874.svg
与第 9.5 节相比,该模型实现了相当的困惑度,但由于实现优化,运行速度更快。和以前一样,我们可以在指定的前缀字符串之后生成预测标记。
model.predict('it has', 20, data.vocab, d2l.try_gpu())
'it has and the time trave '
'it has and the thi baid th'
'it has our in the time tim'
9.6.3. 概括
深度学习框架中的高级 API 提供标准 RNN 的实现。这些库可帮助您避免浪费时间重新实现标准模型。此外,框架实施通常经过高度优化,与从头开始实施相比,可显着提高(计算)性能。
9.6.4. 练习
您能否使用高级 API 使 RNN 模型过拟合?
使用 RNN实现第 9.1 节的自回归模型。
  • 神经网络
  • pytorch
    递归神经网络(RNN)
    递归神经网络(RNN)RNN是最强大的模型之一,它使我们能够开发如分类、序列数据标注、生成文本序列(例如预测下一输入词的SwiftKey keyboard应用程序),以及将一个序列转换为另一个序列
    发表于 07-20 09:27
    PyTorch教程之从零开始的递归神经网络实现
    电子发烧友网站提供《PyTorch教程之从零开始的递归神经网络实现.pdf》资料免费下载
    发表于 06-05 09:55 0次下载
    <b class='flag-5'>PyTorch</b>教程之从零开始的<b class='flag-5'>递归</b><b class='flag-5'>神经网络</b><b class='flag-5'>实现</b>
    PyTorch教程9.6递归神经网络简洁实现
    电子发烧友网站提供《PyTorch教程9.6递归神经网络简洁实现.pdf》资料免费下载
    发表于 06-05 09:56 0次下载
    <b class='flag-5'>PyTorch</b>教程<b class='flag-5'>9.6</b>之<b class='flag-5'>递归</b><b class='flag-5'>神经网络</b>的<b class='flag-5'>简洁</b><b class='flag-5'>实现</b>
    PyTorch教程10.3之深度递归神经网络
    电子发烧友网站提供《PyTorch教程10.3之深度递归神经网络.pdf》资料免费下载
    发表于 06-05 15:12 0次下载
    <b class='flag-5'>PyTorch</b>教程10.3之深度<b class='flag-5'>递归</b><b class='flag-5'>神经网络</b>
    PyTorch教程10.4之双向递归神经网络
    电子发烧友网站提供《PyTorch教程10.4之双向递归神经网络.pdf》资料免费下载
    发表于 06-05 15:13 0次下载
    <b class='flag-5'>PyTorch</b>教程10.4之双向<b class='flag-5'>递归</b><b class='flag-5'>神经网络</b>
    PyTorch教程16.2之情感分析:使用递归神经网络
    电子发烧友网站提供《PyTorch教程16.2之情感分析:使用递归神经网络.pdf》资料免费下载
    发表于 06-05 10:55 0次下载
    <b class='flag-5'>PyTorch</b>教程16.2之情感分析:使用<b class='flag-5'>递归</b><b class='flag-5'>神经网络</b>
    使用PyTorch构建神经网络
    PyTorch是一个流行的深度学习框架,它以其简洁的API和强大的灵活性在学术界和工业界得到了广泛应用。在本文中,我们将深入探讨如何使用PyTorch构建神经网络,包括从基础概念到高级
    的头像 发表于 07-02 11:31 707次阅读
    递归神经网络是循环神经网络
    递归神经网络(Recurrent Neural Network,简称RNN)和循环神经网络(Recurrent Neural Network,简称RNN)实际上是同一个概念,只是不同的翻译方式
    的头像 发表于 07-04 14:54 744次阅读
    递归神经网络与循环神经网络一样吗
    递归神经网络(Recursive Neural Network,RvNN)和循环神经网络(Recurrent Neural Network,RNN)是两种不同类型的神经网络结构,它们在
    的头像 发表于 07-05 09:28 841次阅读
    递归神经网络结构形式主要分为
    结构形式。 Elman网络 Elman网络是一种基本的递归神经网络结构,由Elman于1990年提出。其结构主要包括输入层、隐藏层和输出层,其中隐藏层具有时间延迟单元,可以存储前一时刻
    的头像 发表于 07-05 09:32 523次阅读
    rnn是递归神经网络还是循环神经网络
    RNN(Recurrent Neural Network)是循环神经网络,而非递归神经网络。循环神经网络是一种具有时间序列特性的神经网络,能
    的头像 发表于 07-05 09:52 567次阅读
    PyTorch神经网络模型构建过程
    PyTorch,作为一个广泛使用的开源深度学习库,提供了丰富的工具和模块,帮助开发者构建、训练和部署神经网络模型。在神经网络模型中,输出层是尤为关键的部分,它负责将模型的预测结果以合适的形式输出。以下将详细解析
    的头像 发表于 07-10 14:57 495次阅读
    递归神经网络实现方法
    (Recurrent Neural Network,通常也简称为RNN,但在此处为区分,我们将循环神经网络称为Recurrent RNN)不同,递归神经网络更侧重于处理树状或图结构的数据,如句法分析树、自然语言的语法结构等。以下
    的头像 发表于 07-10 17:02 316次阅读
    递归神经网络和循环神经网络的模型结构
    递归神经网络是一种旨在处理分层结构的神经网络,使其特别适合涉及树状或嵌套数据的任务。这些网络明确地模拟了层次结构中的关系和依赖关系,例如语言中的句法结构或图像中的层次表示。它使用
    的头像 发表于 07-10 17:21 648次阅读
    <b class='flag-5'>递归</b><b class='flag-5'>神经网络</b>和循环<b class='flag-5'>神经网络</b>的模型结构
    pytorch中有神经网络模型吗
    当然,PyTorch是一个广泛使用的深度学习框架,它提供了许多预训练的神经网络模型。 PyTorch中的神经网络模型 1. 引言 深度学习是一种基于人工
    的头像 发表于 07-11 09:59 696次阅读
