PyTorch教程-13.6. 多个 GPU 的简洁实现
jf_pJlTbmA9 来源:PyTorch 作者:PyTorch 2023-06-05 15:44 次阅读
为每个新模型从头开始实施并行性并不好玩。此外,优化同步工具以获得高性能有很大的好处。在下文中,我们将展示如何使用深度学习框架的高级 API 来执行此操作。数学和算法与第 13.5 节中的相同。毫不奇怪,您至少需要两个 GPU 才能运行本节的代码。
import torch
from torch import nn
from d2l import torch as d2l
from mxnet import autograd, gluon, init, np, npx
from mxnet.gluon import nn
from d2l import mxnet as d2l
npx.set_np()
13.6.1。玩具网络
让我们使用一个比13.5 节中的 LeNet 更有意义的网络 ,它仍然足够容易和快速训练。我们选择了一个 ResNet-18 变体(He et al. , 2016)。由于输入图像很小,我们对其进行了轻微修改。特别地,与第 8.6 节的不同之处在于,我们在开始时使用了更小的卷积核、步长和填充。此外,我们删除了最大池化层。
#@save
def resnet18(num_classes, in_channels=1):
  """A slightly modified ResNet-18 model."""
  def resnet_block(in_channels, out_channels, num_residuals,
           first_block=False):
    blk = []
    for i in range(num_residuals):
      if i == 0 and not first_block:
        blk.append(d2l.Residual(out_channels, use_1x1conv=True,
                    strides=2))
      else:
        blk.append(d2l.Residual(out_channels))
    return nn.Sequential(*blk)
  # This model uses a smaller convolution kernel, stride, and padding and
  # removes the max-pooling layer
  net = nn.Sequential(
    nn.Conv2d(in_channels, 64, kernel_size=3, stride=1, padding=1),
    nn.BatchNorm2d(64),
    nn.ReLU())
  net.add_module("resnet_block1", resnet_block(64, 64, 2, first_block=True))
  net.add_module("resnet_block2", resnet_block(64, 128, 2))
  net.add_module("resnet_block3", resnet_block(128, 256, 2))
  net.add_module("resnet_block4", resnet_block(256, 512, 2))
  net.add_module("global_avg_pool", nn.AdaptiveAvgPool2d((1,1)))
  net.add_module("fc", nn.Sequential(nn.Flatten(),
                    nn.Linear(512, num_classes)))
  return net
#@save
def resnet18(num_classes):
  def resnet_block(num_channels, num_residuals, first_block=False):
    blk = nn.Sequential()
        blk.add(d2l.Residual(
          num_channels, use_1x1conv=True, strides=2))
      else:
        blk.add(d2l.Residual(num_channels))
    return blk
  net = nn.Sequential()
  net.add(nn.Conv2D(64, kernel_size=3, strides=1, padding=1),
      nn.BatchNorm(), nn.Activation('relu'))
  net.add(resnet_block(64, 2, first_block=True),
      resnet_block(128, 2),
      resnet_block(256, 2),
      resnet_block(512, 2))
  net.add(nn.GlobalAvgPool2D(), nn.Dense(num_classes))
  return net
13.6.2。网络初始化
我们将在训练循环内初始化网络。有关初始化方法的复习,请参阅第 5.4 节。
net = resnet18(10)
# Get a list of GPUs
devices = d2l.try_all_gpus()
# We will initialize the network inside the training loop
The initialize function allows us to initialize parameters on a device of our choice. For a refresher on initialization methods see Section 5.4. What is particularly convenient is that it also allows us to initialize the network on multiple devices simultaneously. Let’s try how this works in practice.
net = resnet18(10)
# Initialize all the parameters of the network
net.initialize(init=init.Normal(sigma=0.01), ctx=devices)
Using the split_and_load function introduced in Section 13.5 we can divide a minibatch of data and copy portions to the list of devices provided by the devices variable. The network instance automatically uses the appropriate GPU to compute the value of the forward propagation. Here we generate 4 observations and split them over the GPUs.
x = np.random.uniform(size=(4, 1, 28, 28))
x_shards = gluon.utils.split_and_load(x, devices)
net(x_shards[0]), net(x_shards[1])
[08:00:43] src/operator/nn/./cudnn/./cudnn_algoreg-inl.h:97: Running performance tests to find the best convolution algorithm, this can take a while... (set the environment variable MXNET_CUDNN_AUTOTUNE_DEFAULT to 0 to disable)
(array([[ 2.2610207e-06, 2.2045981e-06, -5.4046786e-06, 1.2869955e-06,
     5.1373163e-06, -3.8297967e-06, 1.4339059e-07, 5.4683451e-06,
     -2.8279192e-06, -3.9651104e-06],
    [ 2.0698672e-06, 2.0084667e-06, -5.6382510e-06, 1.0498458e-06,
     5.5506434e-06, -4.1065491e-06, 6.0830087e-07, 5.4521784e-06,
     -3.7365021e-06, -4.1891640e-06]], ctx=gpu(0)),
 array([[ 2.4629783e-06, 2.6015525e-06, -5.4362617e-06, 1.2938218e-06,
     5.6387889e-06, -4.1360108e-06, 3.5758853e-07, 5.5125256e-06,
     -3.1957325e-06, -4.2976326e-06],
    [ 1.9431673e-06, 2.2600434e-06, -5.2698201e-06, 1.4807417e-06,
     5.4830934e-06, -3.9678889e-06, 7.5751018e-08, 5.6764356e-06,
     -3.2530229e-06, -4.0943951e-06]], ctx=gpu(1)))
Once data passes through the network, the corresponding parameters are initialized on the device the data passed through. This means that initialization happens on a per-device basis. Since we picked GPU 0 and GPU 1 for initialization, the network is initialized only there, and not on the CPU. In fact, the parameters do not even exist on the CPU. We can verify this by printing out the parameters and observing any errors that might arise.
weight = net[0].params.get('weight')
try:
  weight.data()
except RuntimeError:
  print('not initialized on cpu')
weight.data(devices[0])[0], weight.data(devices[1])[0]
(array([[[ 0.01382882, -0.01183044, 0.01417865],
     [-0.00319718, 0.00439528, 0.02562625],
     [-0.00835081, 0.01387452, -0.01035946]]], ctx=gpu(0)),
     [-0.00835081, 0.01387452, -0.01035946]]], ctx=gpu(1)))
Next, let’s replace the code to evaluate the accuracy by one that works in parallel across multiple devices. This serves as a replacement of the evaluate_accuracy_gpu function from Section 7.6. The main difference is that we split a minibatch before invoking the network. All else is essentially identical.
#@save
def evaluate_accuracy_gpus(net, data_iter, split_f=d2l.split_batch):
  """Compute the accuracy for a model on a dataset using multiple GPUs."""
  # Query the list of devices
  devices = list(net.collect_params().values())[0].list_ctx()
  # No. of correct predictions, no. of predictions
  metric = d2l.Accumulator(2)
  for features, labels in data_iter:
    X_shards, y_shards = split_f(features, labels, devices)
    # Run in parallel
    pred_shards = [net(X_shard) for X_shard in X_shards]
    metric.add(sum(float(d2l.accuracy(pred_shard, y_shard)) for
            pred_shard, y_shard in zip(
              pred_shards, y_shards)), labels.size)
  return metric[0] / metric[1]
13.6.3。训练
和以前一样,训练代码需要执行几个基本功能以实现高效并行:
需要在所有设备上初始化网络参数。
在迭代数据集时,小批量将被划分到所有设备上。
我们跨设备并行计算损失及其梯度。
梯度被聚合并且参数被相应地更新。
最后,我们计算精度(再次并行)以报告网络的最终性能。训练例程与前面章节中的实现非常相似,只是我们需要拆分和聚合数据。
def train(net, num_gpus, batch_size, lr):
  train_iter, test_iter = d2l.load_data_fashion_mnist(batch_size)
  devices = [d2l.try_gpu(i) for i in range(num_gpus)]
  def init_weights(module):
    if type(module) in [nn.Linear, nn.Conv2d]:
      nn.init.normal_(module.weight, std=0.01)
  net.apply(init_weights)
  # Set the model on multiple GPUs
  net = nn.DataParallel(net, device_ids=devices)
  trainer = torch.optim.SGD(net.parameters(), lr)
  loss = nn.CrossEntropyLoss()
  timer, num_epochs = d2l.Timer(), 10
  animator = d2l.Animator('epoch', 'test acc', xlim=[1, num_epochs])
  for epoch in range(num_epochs):
    net.train()
    timer.start()
    for X, y in train_iter:
      trainer.zero_grad()
      X, y = X.to(devices[0]), y.to(devices[0])
      l = loss(net(X), y)
      l.backward()
      trainer.step()
    timer.stop()
    animator.add(epoch + 1, (d2l.evaluate_accuracy_gpu(net, test_iter),))
  print(f'test acc: {animator.Y[0][-1]:.2f}, {timer.avg():.1f} sec/epoch '
     f'on {str(devices)}')
def train(num_gpus, batch_size, lr):
  ctx = [d2l.try_gpu(i) for i in range(num_gpus)]
  net.initialize(init=init.Normal(sigma=0.01), ctx=ctx, force_reinit=True)
  trainer = gluon.Trainer(net.collect_params(), 'sgd',
              {'learning_rate': lr})
  loss = gluon.loss.SoftmaxCrossEntropyLoss()
    timer.start()
    for features, labels in train_iter:
      X_shards, y_shards = d2l.split_batch(features, labels, ctx)
      with autograd.record():
        ls = [loss(net(X_shard), y_shard) for X_shard, y_shard
           in zip(X_shards, y_shards)]
      for l in ls:
        l.backward()
      trainer.step(batch_size)
    npx.waitall()
    timer.stop()
    animator.add(epoch + 1, (evaluate_accuracy_gpus(net, test_iter),))
     f'on {str(ctx)}')
让我们看看这在实践中是如何工作的。作为热身,我们在单个 GPU 上训练网络。
train(net, num_gpus=1, batch_size=256, lr=0.1)
test acc: 0.90, 14.0 sec/epoch on [device(type='cuda', index=0)]
pYYBAGR9OuKAe7JBAAC_x5kwato614.svg
train(num_gpus=1, batch_size=256, lr=0.1)
test acc: 0.93, 14.3 sec/epoch on [gpu(0)]
poYBAGR9OuWAWF8-AADjgDgKCWc638.svg
接下来我们使用 2 个 GPU 进行训练。与 13.5 节中评估的 LeNet 相比,ResNet-18 的模型要复杂得多。这就是并行化显示其优势的地方。计算时间明显大于同步参数的时间。这提高了可伸缩性,因为并行化的开销不太相关。
train(net, num_gpus=2, batch_size=512, lr=0.2)
test acc: 0.89, 8.8 sec/epoch on [device(type='cuda', index=0), device(type='cuda', index=1)]
poYBAGR9OueAPCNJAACf4wqnIl8145.svg
train(num_gpus=2, batch_size=512, lr=0.2)
test acc: 0.91, 14.2 sec/epoch on [gpu(0), gpu(1)]
poYBAGR9OumAO48UAAD7oP2IzW8432.svg
13.6.4。概括
Gluon 通过提供上下文列表为跨多个设备的模型初始化提供原语。
在可以找到数据的设备上自动评估数据。
在尝试访问该设备上的参数之前,请注意初始化每个设备上的网络。否则你会遇到错误。
优化算法自动聚合多个 GPU。
13.6.5。练习
  • gpu
    gpu
  • pytorch
    新手小白怎么学GPU云服务器跑深度学习?
    新手小白想用GPU云服务器跑深度学习应该怎么做? 用个人主机通常pytorch可以跑但是LexNet,AlexNet可能就直接就跑不动,如何实现更经济便捷的实现
    发表于 06-11 17:09
    如何往星光2板子里装pytorch
    如题,想先gpu版本的pytorch只安装cpu版本的pytorch,pytorch官网提供了基于conda和pip两种安装方式。因为咱是risc架构没对应的conda,而使用pip安
    发表于 09-12 06:30
    pytorch模型转换需要注意的事项有哪些?
    和记录张量上的操作,不会记录任何控制流操作。 为什么不能是GPU模型? 答:BMNETP的编译过程不支持。 如何将GPU模型转成CPU模型? 答:在加载PyTorch的Python模型
    发表于 09-18 08:05
    Pytorch 1.1.0,来了!
    许多用户已经转向使用标准PyTorch运算符编写自定义实现,但是这样的代码遭受高开销:大多数PyTorch操作在GPU上启动至少一个内核,并且RNN由于其重复性质通常运行许多操作。但是
    的头像 发表于 05-05 10:02 5890次阅读
    <b class='flag-5'>Pytorch</b> 1.1.0,来了!
    基于PyTorch的深度学习入门教程之DataParallel使用多GPU
    讲到DataParallel使用多GPU。 在PyTorch中使用GPU比较简单,可以这样把模型放到GPU上。 model.gpu() 还可
    的头像 发表于 02-15 09:55 4068次阅读
    PyTorch在哪些地方分配GPU内存
    PyTorch 核心开发者和 FAIR 研究者 Zachary DeVito 创建了一个新工具(添加实验性 API),通过生成和可视化内存快照(memory snapshot)来可视化 GPU 内存的分配状态。这些内存快照记录了内存分配的堆栈跟踪以及内存在缓存分配器状态中
    发表于 10-27 11:34 724次阅读
    PyTorch教程3.5之线性回归的简洁实现
    电子发烧友网站提供《PyTorch教程3.5之线性回归的简洁实现.pdf》资料免费下载
    发表于 06-05 11:28 0次下载
    <b class='flag-5'>PyTorch</b>教程3.5之线性回归的<b class='flag-5'>简洁</b><b class='flag-5'>实现</b>
    PyTorch教程7.4之多个输入和多个输出通道
    电子发烧友网站提供《PyTorch教程7.4之多个输入和多个输出通道.pdf》资料免费下载
    发表于 06-05 10:17 0次下载
    <b class='flag-5'>PyTorch</b>教程7.4之<b class='flag-5'>多个</b>输入和<b class='flag-5'>多个</b>输出通道
    PyTorch教程9.6之递归神经网络的简洁实现
    电子发烧友网站提供《PyTorch教程9.6之递归神经网络的简洁实现.pdf》资料免费下载
    发表于 06-05 09:56 0次下载
    <b class='flag-5'>PyTorch</b>教程9.6之递归神经网络的<b class='flag-5'>简洁</b><b class='flag-5'>实现</b>
    PyTorch教程13.5之在多个GPU上进行训练
    电子发烧友网站提供《PyTorch教程13.5之在多个GPU上进行训练.pdf》资料免费下载
    发表于 06-05 14:18 0次下载
    <b class='flag-5'>PyTorch</b>教程13.5之在<b class='flag-5'>多个</b><b class='flag-5'>GPU</b>上进行训练
    PyTorch教程13.6多个GPU简洁实现
    电子发烧友网站提供《PyTorch教程13.6多个GPU简洁实现.pdf》资料免费下载
    发表于 06-05 14:21 0次下载
    <b class='flag-5'>PyTorch</b>教程<b class='flag-5'>13.6</b>之<b class='flag-5'>多个</b><b class='flag-5'>GPU</b>的<b class='flag-5'>简洁</b><b class='flag-5'>实现</b>
    PyTorch教程23.5之选择服务器和GPU
    电子发烧友网站提供《PyTorch教程23.5之选择服务器和GPU.pdf》资料免费下载
    发表于 06-06 09:17 0次下载
    <b class='flag-5'>PyTorch</b>教程23.5之选择服务器和<b class='flag-5'>GPU</b>
    PyTorch教程-13.2. 异步计算
    SageMaker Studio Lab 中打开笔记本 当今的计算机是高度并行的系统,由多个 CPU 内核(通常每个内核多个线程)、每个 GPU 多个处理元素以及每个设备通常
    的头像 发表于 06-05 15:44 577次阅读
    <b class='flag-5'>PyTorch</b>教程-13.2. 异步计算
    PyTorch教程-13.5。在多个 GPU 上进行训练
    13.5。在多个 GPU 上进行训练¶ Colab [火炬]在 Colab 中打开笔记本 Colab [mxnet] Open the notebook in Colab Colab
    的头像 发表于 06-05 15:44 909次阅读
    <b class='flag-5'>PyTorch</b>教程-13.5。在<b class='flag-5'>多个</b> <b class='flag-5'>GPU</b> 上进行训练
    PyTorch GPU 加速训练模型方法
    在深度学习领域,GPU加速训练模型已经成为提高训练效率和缩短训练时间的重要手段。PyTorch作为一个流行的深度学习框架,提供了丰富的工具和方法来利用GPU进行模型训练。 1. 了解GPU
    的头像 发表于 11-05 17:43 453次阅读
