潍坊风尚米兰能耗监测系统的应用
jf_10510507 来源:jf_10510507 作者:jf_10510507 2023-06-06 14:21 次阅读
安科瑞 缪凯伦
Application of Weifang Fashion Milan Energy Consumption Monitoring System
1.背景信息 Background
统计显示,我国建筑能耗约占全国总能耗的28%,在我国每年新建的20亿平方米建筑中,其中99%是高能耗建筑;而既有的建筑中,仅有4%采取了节能措施,具有巨大的节能空间,能耗监测系统推广已经势在必行。节能降耗,计量先行。
Statistics show that building energy consumption accounts for about 28% of the country’s total energy consumption. Among the 2 billion square meters of buildings newly built in our country each year, 99% are high-energy buildings; and only 4% of the existing buildings use Energy-saving measures, so there is still a huge energy-saving space, the promotion of energy consumption monitoring system is imperative. Energy saving and consumption reduction, measurement first.
2.项目信息 Project Information
潍坊风尚米兰位于潍坊高密,处于山东半岛蓝色经济区和胶东半岛产业聚焦区的核心地带及“青潍整体化"的重要节点。
建筑配电箱里的安科瑞DTSD1352电能表均接入Acrel-5000能耗监测系统,对电能消耗的情况进行监管,随时掌握能耗情况,提高节能意识。
Weifang Fashion Milan is located in Gaomi, Weifang, at the core of the Shandong Peninsula Blue Economic Zone and the Jiaodong Peninsula Industrial Focus Zone and an important node of "QingWei Integration".
The Acrel DTSD1352 electric energy meters in the building distribution box are all connected to the Acrel-5000 energy consumption monitoring system to supervise the electric energy consumption, keep abreast of the energy consumption, and improve the awareness of energy saving.
3.系统架构 Structure
安科瑞Acrel-5000能耗分析管理系统以工作站主机、通讯设备、测控单元为基本工具,为大型公共建筑的实时数据采集及远程管理提供了基础平台,它可以和其他楼宇自动化系统进行数据转发构成复杂的监控系统。该能耗系统主要采用分层分布式计算机网络结构,如系统结构图所示:
Acrel-5000 energy consumption analysis and management system takes workstation host machine, communication equipment and measurement and control unit as basic tools, and provides a basic platform for real-time data collection and remote management of large public buildings. It can transmit data with other building automation systems to form a complex monitoring system.
The energy consumption system mainly adopts the layered distributed computer network structure, as follows:
4.主要功能 Main Function
4.1能耗综合主界面 Platform Overview
通过系统主界面可以反映各分店用能各分类能耗和折算为标准煤的综合能耗,并计算单位面积能耗。
The main interface of the system can reflect the energy consumption of each branch and the comprehensive energy consumption converted into standard coal, and calculate the energy consumption per unit area.
4.2分项用电数据统计 Itemized electricity consumption data statistics
将电耗进行逐时、逐日、逐月、逐年统计。统计数据采用饼图、柱状图、线图、区域图等各种图形展示方式,直观反映各项统计数据的数值、趋势和分布情况。
The system makes hourly, daily, month-by-month and year-by-year statistics of power consumption.The statistical data are presented by pie chart, bar chart, line chart, area chart and other graphics, which can directly reflect the value, trend and distribution of various statistical data.
4.3用电支路趋势分析 Trend analysis of branch circuit
统计各区域、各设备电能消耗,准确定位用电消耗回路,制定节能绩效考核制度,推动节能降耗的合理执行。为用能设备建立运行记录档案,长期跟踪记录设备运行过程中的能效分析评估结果,结合设备维护保养记录,为设备的运行维护提供依据。
Make statistics on the power consumption of each region and equipment, accurately locate the power consumption circuit, formulate the performance appraisal system of energy conservation, and promote the effective implementation of energy conservation and consumption reduction.
In order to establish operation record files for energy-using equipment, track and record the energy efficiency analysis and evaluation results in the operation process of the equipment for a long time, and provide basis for the operation and maintenance of the equipment in combination with the equipment maintenance record.
4.4能耗数据同环比分析 Comparative analysis of energy consumption data
将各种类型和各主要耗能设备的能耗与去年同期值和上月值进行同比环比分析,检验节能效果,根据分析结果执行节能绩效考核,以及节能目标的修正。
The energy consumption of various types and major energy-consuming equipment was analyzed on a year-on-year basis with the values of the same period last year and the values of the last month, and the energy-saving effect was tested. According to the analysis results, the energy-saving performance assessment was carried out and the energy-saving target was revised.
4.5能耗数据分时统计 Time-division statistics of energy consumption data
将能源类型、负载类型、区域能耗按照时间区分,按时、天、月、年、工作日、非工作日等对用能数据进行对比分析,掌握能源具体消耗情况。可将每天用能按时段设置峰、平、谷,统计各时段能耗,降低闲时能耗。
Classify the energy type, load type and regional energy consumption according to time, and compare and analyze the energy data on time, day, month, year, working day and non-working day, so as to grasp the specific energy consumption.Peak, level and valley can be set in the time period of daily energy use, and energy consumption of each period can be counted to reduce energy consumption in idle time.
4.6电能数据实时监测和预警 Real-time monitoring and early warning of electric power data
通过高精度智能仪表以技术手段实现自动化全实时、高密度的实时用能监测,减少用能的计量误差。实时监视现场仪表的回传数据,对电能进行合理的管控和预警,及时发现并改正运行中存在的用电异常,随时处理。按需设置重要设备的超标预警值,超标时醒目提醒并主动记录。
Automatic real-time and high-density real-time energy-using monitoring can be realized by high-precision intelligent instrument with technical means to reduce the measurement error of energy-using.
Monitor the back data of the field instruments in real time, control and warn the electric energy reasonably, find and correct the abnormal electricity in the operation in time, and deal with it at any time.
The warning value of exceeding the standard of important equipment is set as required. When exceeding the standard, it should be reminded and recorded actively.
5.项目小结 Project Summary
建筑是节能大户,做好潍坊风尚米兰的节能工作,对促使和带动节能工作,实现节能减排目标具有重要意义。
Building is a major energy saving consumer. Doing a good job in Weifang Fashion Milan’s energy saving work is of great significance to promoting and driving energy saving work and achieving energy saving and emission reduction goals.
参考文献 Bibliography
1、Technical requirements of the Ministry of Housing and Urban-Rural Development [2008] No. 114.
2、Solutions for enterprise micro-grid system
审核编辑黄宇
    浅析企业能耗在线监测系统的设计与应用
    摘要: 阐述企业能耗在线监测系统,实现对企业能源消耗情况的全面监测、分析和评估,通过信息化和可视化管理,全面提升了企业能源管理自动化水平。安科瑞任运业-15021601437 关键词:
    的头像 发表于 11-18 14:22 225次阅读
    浅析企业<b class='flag-5'>能耗</b>在线<b class='flag-5'>监测</b><b class='flag-5'>系统</b>的设计与应用
    企业能耗在线监测系统的设计与应用
    安科瑞冯东铖  17821170233 摘要: 阐述企业能耗在线监测系统,实现对企业能源消耗情况的全面监测、分析和评估,通过信息化和可视化管理,全面提升了企业能源管理自动化水平。 关键
    的头像 发表于 11-11 16:56 205次阅读
    智能网关的校园电能能耗监测系统设计与应用
    介绍了一种基于智能网关的能耗监测系统的建设方法,并给出了系统的具体建设实施方法,具有一定的理论价值和实际工程意义。
    的头像 发表于 10-23 09:43 175次阅读
    智能网关的校园电能<b class='flag-5'>能耗</b><b class='flag-5'>监测</b><b class='flag-5'>系统</b>设计与应用
    建筑能耗监测系统方案
    随着全球能源危机日益严峻,与环境保护意识的不断增强,建筑能耗监测系统方案成为实现节能减排、推动绿色建筑发展的重要手段,是现代建筑管理的重要工具。 建筑能耗
    的头像 发表于 10-17 17:10 152次阅读
    能耗动态监测系统方案
    随着科技的飞速发展与全球对可持续发展的重视,能源管理成为了各行各业不可忽视的重要课题。能耗动态监测系统,作为能源管理领域的创新技术,正以其独特的优势,逐步成为企业节能减排、优化运营的关键工具。 一
    的头像 发表于 10-14 16:56 227次阅读
    浅析综合能耗监测系统在大型园区的应用
    摘要:大型综合园区已经成为多种能源消耗的重要区域,为了探索适用于大型综合园区的综合能耗监测系统,建立了综合能耗监测
    的头像 发表于 09-18 16:18 240次阅读
    浅析综合<b class='flag-5'>能耗</b><b class='flag-5'>监测</b><b class='flag-5'>系统</b>在大型园区的应用
    能耗管理系统新纪元:智能科技引领绿色生活风尚
    能耗管理系统新纪元:智能科技引领绿色生活风尚 在科技日新月异的今天,我们的生活正经历着前所未有的变革,而能耗管理系统作为连接环保与可持续发展
    的头像 发表于 08-15 18:17 481次阅读
    基于智能网关的校园电能能耗监测系统的应用
    ,本文介绍了一种基于智能网关的能耗监测系统的建设方法,并给出了系统的具体建设实施方法,具有一定的理论价值和实际工程意义。 关键词: 节能校园;智能网关;
    的头像 发表于 07-04 16:40 999次阅读
    基于智能网关的校园电能<b class='flag-5'>能耗</b><b class='flag-5'>监测</b><b class='flag-5'>系统</b>的应用
    基于智能网关的校园电能能耗监测系统设计与应用
    的头像 发表于 06-28 10:13 353次阅读
    基于智能网关的校园电能<b class='flag-5'>能耗</b><b class='flag-5'>监测</b><b class='flag-5'>系统</b>设计与应用
    连锁店面能耗监测系统
    一、前言连锁店面能耗监测系统是当代商业运营不可或缺的一部分,主要是通过实时监控系统和数据分析,助力企业管理方法其能源应用,降低企业成本,完成绿色可持续发展。本文将从三个方面详细描述这一
    的头像 发表于 06-05 16:00 330次阅读
    连锁店面<b class='flag-5'>能耗</b><b class='flag-5'>监测</b><b class='flag-5'>系统</b>
    大型公建能耗监测系统方案
    随着城市化进程的加快,大型公共建筑的数量不断增加,其能耗问题也日益凸显。为了有效管理和控制这些建筑的能耗,大型公建能耗监测系统应运而生。 大
    的头像 发表于 06-03 16:52 401次阅读
    浅谈煤矿企业能耗在线监测系统的设计与应用
    的头像 发表于 05-15 16:07 480次阅读
    浅谈煤矿企业<b class='flag-5'>能耗</b>在线<b class='flag-5'>监测</b><b class='flag-5'>系统</b>的设计与应用
    建筑能耗监测系统解决方案
    随着全球能源危机和环境问题的日益严重,建筑能耗监测系统成为了建筑行业的重要发展方向。对建筑内部各种能耗设备进行实时监测、数据采集、分析和管理
    的头像 发表于 04-26 16:47 542次阅读
    应用大型公建能耗监测系统流程
    随着城市化进程的加速和能源消耗的日益增长,建筑能耗已经成为城市发展的重要瓶颈。为了实现节能减排和高效管理的目标,建筑必须采取有效的措施对建筑能耗进行监测和管理。 大型公建能耗
    的头像 发表于 03-01 16:44 387次阅读
    建筑能耗监测系统解决方案
    经济。 建筑能耗监测系统解决方案,基于工业物联网系统,面向重点用能单位推出的一款工业能耗监测的解
    的头像 发表于 11-29 16:40 565次阅读
