一、简介
- 专栏总目录
- AP6256是正基科技推出的一款低成本,低功耗的双模模块。是一款SDIO接口单通道802.11ac双频支持BT5.0 蓝牙WiFi二合一模块。
- Model:AP6256:SDIO WIFI + UART BT
- Chip:BCM43456
- WiFi: 2.4G&5G
- BT:5.0
- WIFI Throughput:up:196 Mbits/sec down: 187 Mbits/sec
二、DTS配置
2.1 配置SDIO
/* SDIO接口Wi-Fi专用配置:SDIO接口节点 */
&sdio {
max-frequency = < 150000000 >; /* sdio接口的最大频率,可调整 */
supports-sdio;
bus-width = < 4 >; /* 4线模式,可调整1线模式 */
disable-wp;
cap-sd-highspeed;
cap-sdio-irq;
keep-power-in-suspend;
mmc-pwrseq = < &sdio_pwrseq >;
non-removable;
num-slots = < 1 >;
pinctrl-names = "default";
pinctrl-0 = < &sdiom0_pins >;
sd-uhs-sdr104; /* 支持SDIO3.0 */
status = "okay";
2.2 WIFI的配置
- WIFI_REG_ON: Wi-Fi的电源使能PIN脚配置 ( 控制WIFI模块电源的GPIO )
- WL_REG_ON由sdio_pwrseq节点进行管理控制,不需要在wireless-wlan节点下面重复添加WIFI,poweren_gpio配置;
/* SDIO接口Wi-Fi专用配置: WIFI_REG_ON: Wi-Fi的电源使能PIN脚 */
sdio_pwrseq: sdio-pwrseq {
compatible = "mmc-pwrseq-simple";
clocks = < &hym8563 >;
clock-names = "ext_clock";
pinctrl-0 = < &wifi_enable_h >;
reset-gpios = < &gpio0 RK_PC4 GPIO_ACTIVE_LOW >; /*跟电源使能状态恰好相反:高有效为LOW,低有效则为HIGH。切记:这个配置跟下面的WIFI,poweren_gpio是互斥的,不能同时配置!!!*/
/*特别注意:reset-gpios的GPIO_ACTIVE 配置跟poweren_gpio配置的电源使能状态恰好是相反的*/
/* SDIO接口Wi-Fi专用配置:WIFI_REG_ON脚的pinctrl的配置 */
&pinctrl {
sdio-pwrseq {
wifi_enable_h: wifi-enable-h {
rockchip,pins = < 0 RK_PC4 RK_FUNC_GPIO &pcfg_pull_none >; /* 对应上面的WIFI_REG_ON,关掉上下拉,防止不能拉高或拉低 */
- WIFI节点配置
/* Wi-Fi节点 */
wireless_wlan: wireless-wlan {
compatible = "wlan-platdata";
wifi_chip_type = "ap6256"; //模块名称
pinctrl-0 = < &wifi_host_wake_irq >;
WIFI,host_wake_irq = < &gpio0 RK_PB2 GPIO_ACTIVE_HIGH >; //WIFI模块唤醒CPU的
//WIFI,poweren_gpio = < &gpio0 RK_PC4 GPIO_ACTIVE_HIGH >; //控制WIFI模块电源的GPIO,配置了sdio_pwrseq就不需要再配置poweren_gpio
status = "okay";
- WIFI,host_wake_irq的配置说明:
/* WIFI_WAKE_HOST: Wi-Fi中断通知主控的PIN脚。
* 特别注意:确认下这个Wi-Fi pin脚跟主控的pin的硬件连接关系,直连的话就是GPIO_ACTIVE_HIGH;
* 如果中间加了一个反向管就要改成低电平GPIO_ACTIVE_LOW触发
- WIFI_WAKE_HOST脚的pinctrl的配置:
&pinctrl {
wireless-wlan {
wifi_host_wake_irq: wifi-host-wake-irq {
rockchip,pins = < 0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_down >;
/* 注意一般Wi-Fi的wake host pin都是高电平触发,
* 所以默认这里要配置为下拉; 如果客户的硬件设计
* 是反向的则要改为上拉,总之要初始化为与触发电平
* 相反的状态
2.3 蓝牙的配置
以下UART相关的都要配置为实际使用的UART口的所对应PIN,注意RTS/CTS pin一定要按照SDK设计
接(具体接法参考7.3章节的UART描述),很多客户反馈的异常都是因为这两个PIN脚没有接导致初始化
异常,下面假设蓝牙使用UART4:
bt_uart6: wireless_bluetooth: wireless-bluetooth {
compatible = "bluetooth-platdata";
clocks = < &hym8563 >; //外部时钟
uart_rts_gpios = < &gpio1 RK_PA2 GPIO_ACTIVE_LOW >; //uart的rts脚
pinctrl-names = "default", "rts_gpio";
pinctrl-0 = < &uart6m1_rtsn >;
pinctrl-1 = < &uart6_gpios >;
BT,reset_gpio = < &gpio3 RK_PA6 GPIO_ACTIVE_HIGH >; //蓝牙的复位脚
BT,wake_host_irq = < &gpio0 RK_PC5 GPIO_ACTIVE_HIGH >; //蓝牙模块唤醒CPU的GPIO
status = "okay";
&pinctrl {
uart6_gpios: uart6-gpios {
rockchip,pins = < 1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none >;
- 蓝牙对应的uart6配置
/* 打开对应的UART配置 */
&uart6 {
/* 这里配置对应主控UART的TX/RX/CTS PIN ,不要配置RTS PIN*/
pinctrl-0 = < &uart6m1_xfer &uart6m1_ctsn >;
status = "okay";
三 、内核配置
3.1 WIFI配置:kernel配置defconfig
- MK文件中定义的Kernel defconfig:
- kernel的defconfig对应到这个文件: "kernel\\arch\\arm64\\configs\\rockchip_linux_defconfig"
# Kernel defconfig
export RK_KERNEL_DEFCONFIG=rockchip_linux_defconfig
cd kernel
make ARCH=arm64 menuconfig
make savedefconfig
选择:Device Drivers ---> Network device support ---> Wireless LAN ---> Rockchip Wireless LAN support
Wi-Fi驱动可编译到内核或者ko方式, 切记下面两个配置必须二选一,否则Wi-Fi无法加载!
KO 配置:[* ] build wifi ko modules
CONFIG_WIFI_BUILD_MODULE=y # CONFIG_WIFI_LOAD_DRIVER_WHEN_KERNEL_BOOTUP is not set -
buildin 配置:[* ] Wifi load driver when kernel bootup
CONFIG_WIFI_LOAD_DRIVER_WHEN_KERNEL_BOOTUP=y # CONFIG_WIFI_BUILD_MODULE is not set -
buildin 只能选择一个型号,realtek 模组和 ap6xxx 模组不能同时选择为y,且realtek的也只能选择其
中一个;
ap6xxx 和 cypress 也是互斥的,只能选择一个且如果选择ap6xxx,cypress的配置自动消失,去掉ap
配置,cypress自动出现;
ko方式则可以选择多个Wi-Fi
3.2 蓝牙配置:kernel配置defconfig
- 正基和海华的模块使用内核的默认CONFIG_BT_HCIUART 驱动:
cd kernel make ARCH=arm64 menuconfig make savedefconfig
选择: Networking support ---> Bluetooth subsystem support ---> Bluetooth device drivers
注意:配置完成后要保存到对应的defconfig
四、Wi-Fi/BT的文件及更新及编译说明
4.1 查看板上生成的ko文件和firmware / nvram文件
- 正基/海华模组以AP6256为例:对应的Wi-Fi/BT的firmware在SDK中的位置:
external/rkwifibt/firmware/broadcom/AP6256/ ├── bt │ └── BCM4345C5.hcd └── wifi ├── fw_bcm43456c5_ag.bin ├── fw_bcm43456c5_ag_mfg.bin └── nvram_ap6256.txt - 经过编译规则编译后,对应的文件被拷贝到工程的output目录:(kernel4.19内核由system变更为vendor目录)
buildroot/output/rockchip_rk3xxxx/target/ /system(vendor)/lib/modules/bcmdhd.ko #驱动ko(如果是ko编译的话) /system(vendor)/etc/firmware/fw_bcm43456c5_ag.bin #驱动firmware文件存放位置 /system(vendor)/etc/firmware/fw_bcm43456c5_ag_mfg.bin #驱动firmware文件存放位置 /system(vendor)/etc/firmware/nvram_ap6256.txt #驱动nvram文件存放位置 /system(vendor)/etc/firmware/BCM4345C5.hcd #蓝牙firmware文件(如果有蓝牙功能) - 最终烧录到机器中后,Wi-Fi运行时所需的文件及存放位置:
4.2 编译配置说明
- mk文件配置路径:3588_linux5.10_v1.0.5/device/rockchip/rk3588/BoardConfig-rk3588-pi5.mk
- 兼容正基和Realtek
- RK_WIFIBT_TTY这个参数根据蓝牙对应的串口来配置,此处蓝牙对应的是uart6
# Define WiFi BT chip # Compatible with Realtek and AP6XXX WiFi : RK_WIFIBT_CHIP=ALL_AP # Compatible with Realtek and CYWXXX WiFi : RK_WIFIBT_CHIP=ALL_CY # Single WiFi configuration: AP6256 or CYW43455: RK_WIFIBT_CHIP=AP6256 export RK_WIFIBT_CHIP=ALL_AP # Define BT ttySX export RK_WIFIBT_TTY=ttyS6
审核编辑:汤梓红
调试
7文章
653浏览量
35875 -
DTS
1文章
55浏览量
16843 -
开发板
26文章
6419浏览量
120781 -
WIF
4浏览量
10848 -
RK3588
8文章
588浏览量
7554
瑞芯微RK3588开发板RK3588 EVB和RK3588S EVB解读
RK3588-WIF/BT调试之AP6256
