ArmSoM推出的W3rk3588单板计算机采用核心板+底板设计方式,核心板采用LGA封装方式,核心板尺寸仅45mm*50mm*4.1mm,且RK3588 SOC所有Pin脚对外引出。ArmSoM W3 单板计算机接口示意图如下:
ArmSoM-W3 | |
SOC | RockChip RK3588 |
CPU | Quad Core Cortex-A76@2.4GHz +Quad Core Cortex-A55@1.8GHz, 8nm |
GPU | ARM Mali-G610 MP4 GPU,Support OpenGL ES3.2 / OpenCL 2.2 / Vulkan1.1, 450 GFLOPS |
NPU | 6 TOPS@INT8,Support INT4/INT8/INT16 mixed operation,Support framework switching of TensorFlow/MXNet/PyTorch/Caffe |
Encode&Decode | Decode:8K@60fps H.265/VP9/AVS2、8K@30fps H.264 AVC/MVC、4K@60fps AV1、1080P@60fps MPEG-2/-1/VC-1/VP8 , |
Encode:8K@30fps H.265 / H.264 | |
RAM | 4GB/8GB/16GB(up to 32GB)32bit LPDDR4/LPDDR4x,Defalut LPDDR4x 8GB |
Flash | 16GB/32GB/64GB/128GB/256GB eMMC5.1,support MicroSD card slot,Defaut eMMC 32GB |
M.2 M Key | The interface supports extension SSD |
Network | 2.5G Ethernet(RTL8125) |
Video output | 2 x HDMI2.1(just one support 8K@60fps or 4K@120fps,other support 4K@60fps),1 x MIPI-DSI(4K@60fps),1 x DP1.4(8K@30fps), |
Video input | 1 x HDMI RX2.0, 1 x 4Lanes MIPI CSI / 2 x 2Lanes MIPI CSI |
Voice | 2 x HDMI voice output ,1 x DP1.4 voice output,1 x headphone (ES8316) |
Wireless | M.2 E key interface support sdio、pcie、usb BT&wifi(AP6256,Intel AX210) |
USB | 2 x USB3.0, 2 x USB2.0, 1x USB Type-C3.1(DP1.4(8K@30fps)/OTG/PD fast charging) |
Others | Fan、RTC、LED、debug |
Button | Power Button、Reset Button、 Recovery Button、Root Button |
GPIO | 40 x GPIO(UART、SPI、I2C、I2S、PWM、ADC、 GPIO、 5V power 、3.3V power) |
Power | DC 12V/2.5A Aperture 2.5mm,support USB Type-C PD 2.0 ,9V/2A, 12V/2A, 15V/2A,support 12V POE power supply |
System | Android 12.0、Ubuntu 20.04、Ubuntu 22.04、Debian11、Buildroot、Armbian、Kylin OS |
Size | 148mm × 100.5mm |
Operating temperature | -10℃~ 70℃ |
Storage temperature | -20℃~ 70℃ |
ArmSoM W3计算机支持多种操作系统,包括Android 12.0、Ubuntu 20.04、Ubuntu 22.04、Debian11、Buildroot、Armbian、Kylin OS(麒麟)等,
审核编辑黄宇
举报投诉
计算机
19文章
7595浏览量
89642 -
开源
3文章
3512浏览量
43204 -
banana pi
1文章
120浏览量
3320
Banana Pi BPI-W3 ArmSoM-W3之RK3588-MIPI-DSI屏幕调试笔记
本文是基于RK3588平台,MIPI屏调试总结。硬件环境: ArmSoM-W3 RK3588开发板、MIPI-DSI显示屏( ArmSoM官方配件 ) 软件版本: OS:
Banana Pi 携手 ArmSoM 推出人工智能加速 RK3576 CM5 计算模块
”系统模块,根据你问的对象,可以称为 ArmSom-CM5 或 BPI-CM5 Pro——设计为由 Rockchip RK3576 驱动的 Raspberry Pi Compute M
发表于 12-11 18:38
RK3588平台产测之ArmSoM-W3 DDR压力测试
压力测试才能够经得起市场的检验
2. 环境介绍
软件版本: OS:ArmSoM-W3 Debian11
3.
发表于 10-09 19:29
armsom:为何选择rk3588开发与Jetson Nano引脚兼容的嵌入式产品
与Jetson Nano引脚兼容armsom研发团队对RK3588的开发积累了大量的经验,2022年已经开发量产过Jeston Nano形态的核心板(如下图
发表于 10-18 17:35
Banana Pi为何选择rk3588开发与Jetson Nano引脚兼容的嵌入式产品
至关重要,特别是对于依赖电池供电的产品。
如何实现与Jetson Nano引脚兼容
Banana PI & armsom研发团队对
发表于 11-02 12:30
【LGA封装RK3588核心板】基于RK3588,小而强大的ArmSom-W3 CORE BOARD
Armsom-RK3588 LGA Core board 是一款基于Rockchip RK3588芯片平台,采用LGA(506pin)封装设计的一款极小尺寸的RK3588核心板。
Banana Pi BPI-W3 RK3588开源硬件开发板DX
Banana Pi BPI-W3 RK3588开源硬件开发板DXF和原理图文档
Banana
发表于 09-04 16:50
•27次下载
RK3588这款单板计算机(SBC)让 Raspberry Pi 5黯然失色
,但设备在规格方面却越来越强大。 Armsom Sige7就是这样一台微型计算机,但却拥有强大的硬件能力。 八核处理器、Mali-G610 GPU、6 TOPS NPU 和 8K 显示器支持是 Raspberry Pi 梦寐以求
ArmSoM RK3588/RK3576核心板,Rockchip摄像头使用
1. Camera 简介 ArmSoM系列产品使用的是mipi-csi接口的摄像头 ArmSoM-Sige7支持双摄同显: rk3588开发板 2. RK3588硬件通路框图
