基于PIC18系列单片机的DHT11温湿度采集系统设计
CHANBAEK 来源:逗比小憨憨 作者:逗比小憨憨 2023-06-16 16:36 1257次阅读
基于PIC18系列(PIC18F4520)单片机+DHT11的温湿度采集系统的设计与制作(Proteus仿真部分)
Proteus仿真图:
Proteus仿真连线图
程序源码:
//main.c
* This Code is written to Developed to Extract Temperature and Humidity
* Data from the DHT11 Sensor using the one-wire Communication protocol.
* And Displays the Extracted Data on a 20x4 LCD Display.
* The Project uses an external XTAL of 4MHZ.
* Website: https://space.bilibili.com/314404732
//doubixiaohanhan
#include "prototyper.h"
#pragma config OSC = HS
#pragma config LVP = OFF
#pragma config WDT = OFF
void main (void)
	unsigned char RH_Integral;
	unsigned char RH_Decimal;
	unsigned char Temp_Integral;
	unsigned char Temp_Decimal;
	unsigned char Checksum;
	unsigned char DataValid;
	Port_Init ();
	//doubixiaohanhan
	LCD_Init ();
	LCD_Stuff ();
	while (1)
		DHT11_Start ();
		if (DHT11_Response ())
			RH_Integral = DHT11_Read ();
			RH_Decimal  = DHT11_Read ();
			Temp_Integral = DHT11_Read ();
			Temp_Decimal  = DHT11_Read ();
			Checksum = DHT11_Read ();
			DataValid = Check_Parity (Checksum, RH_Integral, RH_Decimal, Temp_Integral, Temp_Decimal);
			if (DataValid)
				DisplayTemp (Temp_Integral, Temp_Decimal);
				DisplayHumidity (RH_Integral, RH_Decimal);
				Delay10KTCYx (120);				// A minimum Sample Period of 1.2 seconds @4MHZ
			else
				Parity_Error ();
		} //doubixiaohanhan
		else
			Sensor_Unresponsive ();
//config.c
void Port_Init (void)
	TRISCbits.TRISC2 = 0; 			// Pin Used to Check Pwr on Ckt
	LATCbits.LATC2   = 1; 			//
	TRISD = 0x00;					// Port used for LCD
	LATD  = 0x00;
//doubixiaohanhan
void LCD_Init (void)
	OpenXLCD (FOUR_BIT & LINES_5X7);
	while (BusyXLCD());
	WriteCmdXLCD (DISPLAY_ON);  		 // TURN DISPLAY ON cursor off
	while (BusyXLCD());
	WriteCmdXLCD (0x80);				 // begin at the first line
	while (BusyXLCD());
	WriteCmdXLCD (CLRSCR);	 			 // clear the lcd screen
void LCD_Stuff (void)
	while (BusyXLCD());
	putrsXLCD ("DHT11 Interfacing");
	while (BusyXLCD());
	WriteCmdXLCD (0xC0);
	while (BusyXLCD());
	putrsXLCD ("Temp = "); //doubixiaohanhan
	while (BusyXLCD());
	WriteCmdXLCD (0xC9);
	while (BusyXLCD());
	putrsXLCD (".");
	while (BusyXLCD());
	WriteCmdXLCD (0xCC);
	while (BusyXLCD());
	putrsXLCD ("deg");
	while (BusyXLCD());
	WriteCmdXLCD (0x94);
	while (BusyXLCD());
	putrsXLCD ("Humi = ");
	while (BusyXLCD());
	WriteCmdXLCD (0x9D);
	while (BusyXLCD());
	putrsXLCD (".");
	while (BusyXLCD());
	WriteCmdXLCD (0xA0);
	while (BusyXLCD());
	putrsXLCD ("%");
void SerialInit (void)
   RCSTAbits.SPEN 	 = 0;	// disable serial port before configuring other parameters
   TXSTAbits.SYNC    = 0;	// enable usart in asynchronous mode
   //doubixiaohanhan
   			/******************* BaudRater Generation *************************/
   BAUDCONbits.BRG16 = 0;	// use the 8 bit spbrg protocol
   TXSTAbits.BRGH    = 1;  	// use High speed
   SPBRG = 0x19;			// to get a baud rate of 9600 bps @4MHZ
   RCSTAbits.SPEN 	 = 1;	// enable serial port //doubixiaohanhan
   TXSTAbits.TXEN    = 1;	// enable usart transmit
//process.c
void DelayFor18TCY (void)
	Delay10TCYx (2);		        // a delay of 20 TCY
void DelayPORXLCD (void)
	Delay1KTCYx (15);     			// a delay of 15ms at 4 MHZ
//doubixiaohanhan
void DelayXLCD (void)
	Delay1KTCYx (5);				// a delay of 5ms at 4 MHZ
void serialTx (unsigned char rx_data)
	TXREG = rx_data;
	Delay10TCY();
void DHT11_Start (void)
	Data_Dxn = 0; 				// DataPin is set as an Output pin
	Data_Out = 0; 				// Pull the DataBus line Low
	Delay1KTCYx (20); 			// A Delay of At least 18ms @4MHZ
	Data_Out = 1;
	Delay10TCYx (3);			// A Delay of atleast 30us @4MHZ
	Data_Dxn = 1; 				// DataPin set as an Input pin//doubixiaohanhan
short int  DHT11_Response (void)
	Delay10TCYx (4);			// A Delay of 40us @ 4MHZ
	if (Data_In == 0)			// If Data line is low
		Delay10TCYx (8);		// A Delay of 80us @ 4MHZ
		if (Data_In == 1)		// If Data Line is High
			Delay10TCYx (5);	// A Delay of 50us @ 4MHZ
			return 1;
unsigned char DHT11_Read (void)
	unsigned char i;
	unsigned char data = 0x00;
	unsigned char Time = 0;
	for (i = 0; i < 8; i++)
		while (!Data_In)			// Wait Till Line goes High
			Time++;
			if (Time > 100)
				break;
			Delay1TCY (); 			// A Delay of 1us @ 4MHZ
		}//doubixiaohanhan
		Delay10TCYx (3); 			// Wait for atleast 30us to check if bit is either 1 or 0
		if (!Data_In)				// Bit is 0
			data = (data < < 1) | 0;
		else
			data = (data < < 1) | 1; // Bit is 1
			Time = 0;
			while (Data_In)			// Wait till Databus goes Low
				Time++;
				if (Time > 100)
					break;
				Delay1TCY ();
	return data;
unsigned char Check_Parity (unsigned char parity, unsigned char RHI, unsigned char RHD, unsigned char TI, unsigned char TD)
	if (parity == (RHI + RHD + TI + TD))
		return 1;
	else
		return 0;
void Humidity_Serial (unsigned char Int_Part, unsigned char Float_Part)
	unsigned char Tens;
	unsigned char Ones;
	unsigned char Dec;
	Tens = Int_Part / 10;
	Ones = Int_Part % 10;
	Dec = Float_Part;
	Tens += 48;				// Convet To ASCII Counterparts
	Ones += 48;  			//
	Dec  += 48; 			//
	serialTx ('H');
	Delay1KTCYx (2);
	serialTx ('\\r');
	serialTx (Tens);
	Delay1KTCYx (2);
	serialTx (Ones);
	Delay1KTCYx (2);
	serialTx ('.');
	Delay1KTCYx (2);
	serialTx (Dec);
	serialTx ('\\r');
	Delay1KTCYx (2);
	serialTx ('\\r');
	Delay1KTCYx (2);
void Temp_Serial (unsigned char Int_Part, unsigned char Float_Part)
	unsigned char Tens;
	unsigned char Ones;
	unsigned char Dec;
	Dec = Float_Part;
	Ones += 48;  			//
	Dec  += 48; 			//
	serialTx ('T');
	Delay1KTCYx (2);
	serialTx ('\\r');
	serialTx (Tens);
	Delay1KTCYx (2);
	serialTx (Ones);
	Delay1KTCYx (2);
	serialTx ('.');
	Delay1KTCYx (2);
	serialTx (Dec);
	serialTx ('\\r');
	Delay1KTCYx (2);
	serialTx ('\\r');
	Delay1KTCYx (2);
void ParityError (void)
	unsigned char i = 0;
	unsigned char Parity [] = "Parity Error";
	while (Parity [i] != '\\0')
		serialTx (Parity [i]);
		i++;
		Delay1KTCYx (2);
	serialTx ('\\r');
	Delay1KTCYx (2);
	serialTx ('\\r');
	Delay1KTCYx (2);
	Delay10KTCYx (50);
void SensorUnresponsive (void)
	unsigned char Response [] = "Sensor Unresponsive";
	while (Response [i] != '\\0')
		serialTx (Response [i]);
		i++;
		Delay1KTCYx (2);
	serialTx ('\\r');
	Delay1KTCYx (2);
	serialTx ('\\r');
	Delay1KTCYx (2);
	Delay10KTCYx (50);
void DisplayTemp (unsigned char Int_Part , unsigned char Float_Part)
	unsigned char Tens;
	unsigned char Ones;
	unsigned char Dec;
	Dec = Float_Part;
	while (BusyXLCD());
	WriteCmdXLCD (0xC7);
	if (Tens != 0)
		while (BusyXLCD());
		WriteDataXLCD (Tens + 48);
	else
		while (BusyXLCD());
		putrsXLCD (" "); 		// Write nothing
	while (BusyXLCD());
	WriteDataXLCD (Ones + 48);
	while (BusyXLCD());
	WriteCmdXLCD (0xCA);
	while (BusyXLCD());
	WriteDataXLCD (Dec + 48);
void DisplayHumidity (unsigned char Int_Part , unsigned char Float_Part)
	unsigned char Tens;
	unsigned char Ones;
	unsigned char Dec;
	Dec = Float_Part;
	while (BusyXLCD());
	WriteCmdXLCD (0x9B);
	while (BusyXLCD());
	while (BusyXLCD());
	while (BusyXLCD());
	WriteCmdXLCD (0x9E);
	while (BusyXLCD());
void Parity_Error (void)
	while (BusyXLCD());
	WriteCmdXLCD (CLRSCR); 		// Clear Screen
	while (BusyXLCD());
	putrsXLCD ("Parity Error!!");
	while (BusyXLCD());
void Sensor_Unresponsive (void)
	while (BusyXLCD());
	while (BusyXLCD());
	putrsXLCD ("Sensor Unresponsive!");
	while (BusyXLCD());
//prototyper.h
#include < p18f4520.h >
#include < delays.h >
#include < xlcd.h >
#define CLRSCR 		0x01
#define DISPLAY_ON 	0x0C
#define DISPLAY_OFF 0x08
#define Data_Dxn TRISCbits.TRISC1
#define Data_Out LATCbits.LATC1
#define Data_In  PORTCbits.RC1
//doubixiaohanhan
//doubixiaohanhan
void DHT11_Start (void);
short int DHT11_Response (void);
unsigned char DHT11_Read (void);
unsigned char Check_Parity (unsigned char, unsigned char, unsigned char, unsigned char, unsigned char);
void Port_Init (void);
void SerialInit (void);
void serialTx (unsigned char);
void Temp_Serial (unsigned char, unsigned char);
void Humidity_Serial (unsigned char, unsigned char);
void ParityError (void);
void SensorUnresponsive (void);
/*************************************** LCD Functions ************************************///doubixiaohanhan
void LCD_Init (void);
void LCD_Stuff (void);
void DisplayTemp (unsigned char, unsigned char);
void DisplayHumidity (unsigned char, unsigned char);
void Parity_Error (void);
void Sensor_Unresponsive (void);
  • 单片机
  • Proteus
  • 仿真
  • DHT11
  • 温湿度采集系统
    温湿度检测系统》+折线图显示DHT11温湿度数据
    ,与单片机之间,采用单总线通信方式。DHT11的数据结构:8bit湿度整数数据+8bit湿度小数数据+8bit温度整数数据+8bit温度小数数据+8bit校验和本人只保留了
    发表于 06-28 22:25
    51单片机dht11温湿度传感器
    设计、软件设计这三个方面来阐述。1.系统方案先来看一下整体的架构图:硬件部分由STC89C52单片机DHT11温湿度传感器、BT08蓝牙串口模块和Android手机组成。传感器将
    发表于 07-14 07:45
    DHT11温湿度传感器介绍
    DHT11温湿度传感器介绍,1.实物原理图2.模块说明2.1 DHT11产品概述DHT11数字温湿度传感器是一款含有已校准数字信号输出的
    发表于 07-21 09:04
    stm32单片机如何从DHT11获取到温湿度的呢
    stm32获取DHT11模块温湿度数值原理解析stm32单片机如何从DHT11获取到温湿度的呢?首先可以通过
    发表于 11-22 06:11
    DHT11温湿度传感器简介
    DHT11温湿度传感器1、DHT11简介DHT11数字温湿度传感器是一款含有已校准数字信号输出的温湿度
    发表于 02-16 06:55
    基于DHT11的多点温湿度报警系统设计
    单片机为控制核心,采用DHT11温湿度传感器,12864LCD显示模块,实现了实验室多点温湿度参数的实时采集、显示和超限报警功能。
    发表于 09-14 10:09 7889次阅读
    基于<b class='flag-5'>DHT11</b>的多点<b class='flag-5'>温湿度</b>报警<b class='flag-5'>系统</b>设计
    DHT11采集温湿度源程序
    DHT11采集温湿度并用LCD12864显示的源程序.可以使用的哈,分享给大家
    发表于 01-07 16:56 171次下载
    温湿度DHT11资料
    含有已校准数字信号输出的温湿度复合传感器,它应用专用的数字模块采集技术和温湿度传感技术,确保产品具有极高的可靠性和卓越的长期稳定性。传感器包括一个电阻式感湿元件和一个NTC测温元件,并与一个高性能8位
    发表于 11-29 17:28 27次下载
    DHT11温湿度传感器的AVR单片机例程
    发表于 05-16 14:46 26次下载
    <b class='flag-5'>DHT11</b><b class='flag-5'>温湿度</b>传感器的AVR<b class='flag-5'>单片机</b>例程
    使用51单片机实现DHT11温湿度检测的代码程序免费下载
    本文档的做作业内容详细介绍的是使用51单片机实现DHT11温湿度检测的代码程序免费下载。
    发表于 10-18 11:31 139次下载
    使用51<b class='flag-5'>单片机</b>实现<b class='flag-5'>DHT11</b><b class='flag-5'>温湿度</b>检测的代码程序免费下载
    51单片机DHT11温湿度ESP8266WiFi手机APP显示设计
    系统方案DHT11温湿度传感器采集数据传送给单片机单片机将数据处理之后通过ESP8266Wi
    发表于 11-04 16:21 119次下载
    51<b class='flag-5'>单片机</b><b class='flag-5'>DHT11</b><b class='flag-5'>温湿度</b>ESP8266WiFi手机APP显示设计
    基于51单片机+DHT11温湿度+LCD1602显示
    main.clcd1602.clcd1602.hdelay.cdelay.h项目展示DHT11温湿度相关介绍DHT11产品概述DHT11数字温湿度
    发表于 11-12 11:51 123次下载
    基于51<b class='flag-5'>单片机</b>+<b class='flag-5'>DHT11</b><b class='flag-5'>温湿度</b>+LCD1602显示
    687【毕设课设】基于单片机温湿度DHT11智能晾衣架系统
    发表于 11-13 10:36 20次下载
    687【毕设课设】基于<b class='flag-5'>单片机</b><b class='flag-5'>温湿度</b><b class='flag-5'>DHT11</b>智能晾衣架<b class='flag-5'>系统</b>
    stm32获取DHT11模块温湿度数据原理解析
    发表于 11-13 20:06 55次下载
    stm32获取<b class='flag-5'>DHT11</b>模块<b class='flag-5'>温湿度</b>数据原理解析
    STM32单片机利用DHT11采集温湿度
    测量原理:DHT11内部集成了一个8位单片机、电阻湿度传感器和NTC来采集外部的温湿度单片机
    发表于 12-27 19:22 14次下载
    STM32<b class='flag-5'>单片机</b>利用<b class='flag-5'>DHT11</b><b class='flag-5'>采集</b><b class='flag-5'>温湿度</b>
