BPX-9422R-R0AE 可扩充无风扇嵌入式系统
1、配置:Intel酷睿i3-6300(2核4线程3.80GHz),可选其他6th/7th 代LGA 1151 Intel Xeon/Core i7/i5/i3 系列TDP80W以内处理器;
2、Intel C236芯片组,嵌入式无风扇EN50155, EN50121-3-2工控机;
3、配置:8GB DDR4 2400工控内存,最大尺寸32GB;
4、外置DVI-I、DVI-D、DisplayPort显示接口,支持3个独立高清显示器;
5、配置:128GB mSATA固态硬盘,可选其他容量的SSD/HDD;
6、宽温工作温度-40°C to 75°C;
7、6V to 36V宽幅工作电压,支持80V过压保护,
8、2个RJ45 Intel芯千兆网口,支持iAMT 11.0 ;
9、3个SIM卡槽,支持3G/4G/LTE/WiFi/GPRS/UMTS ;
10、4个2.5" SSD/HDD支持软RAID 0, 1, 5, 10 ;
11、外置2个SIM卡槽,4个2.5寸热插拔盒,1个CFast卡槽,6个USB,4个DB9 RS-232/422/485通讯串口;
12、1个PCIe x16,1个PCIe x4,2个PCI扩展插槽,最大支持250W功耗的PCI/PCIe扩展卡;
13、7个USB(1个内置USB2.0),4个COM,3个Mini PCIe,32pin DIO;
14、尺寸:172mm x 250mm x 210mm (6.8" x 9.8" x 8.3"),重量:5kg。
System | |
Processor | Quad Core Intel Xeon/Core i7/i5/i3 Processor (Kaby Lake-S/Skylake-S) |
Chipset | Intel C236 |
BIOS | AMI |
SIO | IT8786E |
Memory | 2 DDR42133MHz SO-DIMM, up to 32GB(ECC/Non-ECC) |
I/O Interface | |
Serial | 4 COM RS-232/422/485 |
USB | - 7USB 3.0 (6 External, 1 Internal) - 2USB 2.0 (Internal) |
Isolated DIO | 32Isolated DIO : 16DI, 16DO |
LED | Power, HDD |
SIM Card | 3SIM Card Socket(2External, 1 Internal) |
Expansion | |
Mini PCIe | 3 Mini PCIe Socket : - 2 Full-sizeMini PCIe for PCIe/USB/External SIM Card - 1 Full-sizeMini PCIefor PCIe/USB/Internal SIM Card/mSATA |
PCIe | - 1 PCIe x16Slot - 1PCIe x4 Slot |
PCI | 2 PCI Slot |
Graphics | |
Graphics Processor | Intel HD Graphics 530 |
Interface | - DVI-I: Up to 1920 x 1200 @ 60Hz - DVI-D: Up to 1920x 1200@ 60Hz - DisplayPort : Up to 4096 x 2304 @ 60Hz |
Storage | |
SATA | 4SATA III (6Gbps) support S/W RAID 0, 1, 5, 10 |
mSATA | 1SATA III (Mini PCIe Type, 6Gbps) |
Storage Device | - 1 CFast Socket (Internal) - 42.5" SSD/HDD Tray |
Audio | |
Audio Codec | Realtek ALC892, 5.1 Channel HD Audio |
Audio Interface | 1 Mic-in, 1 Line-out |
Ethernet | |
LAN 1 | Intel I219LM Gigabit LAN supports iAMT 11.0 |
LAN 2 | Intel I210 Gigabit LAN |
Power | |
Power Input | 6V to 36V, DC-in |
Power Interface | 3-pin Terminal Block : V+, V-, Frame Ground |
Ignition Control | 16 Mode(Internal) |
Remote Switch | 3-pin Terminal Block |
Surge Protection | Up to 80V/1ms Transient Power |
Others | |
TPM | Optional Infineon SLB9665 supports TPM 2.0, LPC Interface |
Watchdog Timer | Reset : 1 to 255 sec./min. per step |
Smart Management | Wake on LAN, PXE supported |
HW Monitor | Monitoring temperature, voltages. Auto throttling control when CPU overheats. |
Software Support | |
OS | Windows 10, Windows 8.1, Windows 7, Linux |
Mechanical | |
Dimension (W x L x H) | 172mm x 250mm x 210mm (6.8" x 9.8" x 8.3") |
Weight | BPX-9400R 系列: 5 kg (11 lb) BPX-9400 系列: 3.8 kg (8.4 lb) |
Mounting | Wallmount by mounting bracket |
Environment | |
Operating Temperature | 35W TDP CPU : -Core i7, i5, i3 : -40°C to 75°C (-40°F to 167°F) -Xeon E3-1268L v5 : -40°C to 70°C (-40°F to 158°F) 65W TDP CPU : Core i7, i5, i3 : -40°C to 55°C (-40°F to 131°F) 80W TDP CPU : Xeon E3-1275 v6, E3-1275 v5, E3-1225 v5 : -40°C to 45°C (-40°F to 113°F) |
Storage Temperature | -40°C to 85°C (-40°F to 185°F) |
Humidity | 5% to 95% Humidity, non-condensing |
Relative Humidity | 95% at 70°C |
Shock | - IEC 60068-2-27 - SSD : 50G @ wallmount, Half-sine, 11ms |
Vibration | - IEC 60068-2-64 |
EMC | CE, FCC, EN50155, EN50121-3-2 |
嵌入式
5103文章
19268浏览量
310022
ARMxy ARM嵌入式计算机支持Ubuntu OS快速部署AIoT解决方案
ARMxy ARM嵌入式计算机搭载 1 TOPS NPU支持深度学习
集特智能无风扇工控机有哪些优势?
工业边缘计算机支持二次编程
工业无风扇计算机的优点
