AIMB-786
LGA1151第8代Intel Core i7/i5/i3/ Pentium/Celeron母板 支持独立三显, DDR4, USB 3.1, SATA 3.0
Intel第8代Core i7/i5/i3/Pentium/Celeron处理器, Q370芯片组
4个DIMM插槽,最高支持64 GB DDR4 2400/2666
支持三显示VGA/DVI-D/DP和双GbE LAN
支持SATA RAID 0, 1, 5, 10, USB 3.1
支持Intel vPro, AMT & TPM技术
注1: TPM模块需要使用Intel vPro和TPM技术
注2:Intel第八代处理器,仅支持Windows 10(64-bit)
研华AIMB-786G2同款产品枭杰科技ATX嵌入式工业级ATX主板IAMB-Q37JW-00AE支持8th/9th代IntelCore i7/ i5 /i3, PentiumCeleron LGA1151 Socket智能处理器
1. 英特尔 Coffee Lake 处理器 (最高 95W TDP)
2. 4 * DDR4 2666MHz U-DIMM 最高支持 128GB (ECC仅限C246)
3. 2 * 10/100/1000 Base-TX 网口
4. 1 * HDMI, 1 * DP, 1 * VGA, 1 * DVI-D
5. 10 * COM (COM1/2 支持 RS232/422/485), 4 * USB3.1 Gen.2, 4 * USB3.1 Gen.1 & 4 * USB2.0
6. 2 * PCIe x16 槽, 1 * PCIe x4 槽, 1 * PCIe x1 槽, 2 * PCI 槽, 1 * M.2 (PCIex4 SATA 接口, M-key支持NVMe, 2242/2260/2280/22110), 1* M.2 (2230, E-key)
7. 5 * SATA III (6Gb/s) 支持 RAID 0, 1, 5, 10
8. 支持 TPM1.2/2.0 (板载可选)
Model | ||
Dimensions | – IAMB-Q37JW | |
Dimensions | – IAMB-Q37JW-00AE | |
Form Factor | ||
Dimensions | – ATX (305 * 244mm) | |
Processor System | ||
CPU Generation | – Intel LGA1151 Gen 8 Coffee Lake Processor (Max. 95W TDP) | |
CPU SKU | – Core i7/i5/i3, Pentium, Celeron | |
Core Number | – (by CPU) | |
Max Speed | – (by CPU) | |
L2 Cache | – (by CPU) | |
Chipset | – Q370 | |
BIOS | – AMI Flash ROM | |
Expansion Slot | ||
PCI | – 2 | |
PCIe | – 1 * PCIe x1, 1 * PCIe x4, 2 * PCIe x16. Support NVMe * Note: there are two configurations if plug one PCIe x16 card in one slot, the other slot is disable; or plug one PCIe x8 card in one slot, the other slot is able to plug one PCIe x8/x4/x1 card | |
M.2 (E-key) | – 1 (E-key, 2230) | |
M.2 (M-key) | – 1 (PCIex4 with SATA interface, M-key support NVMe, 2242/2260/2280/22110) | |
SIM Card Holder | – 0 | |
Memory | ||
Technology | – DDR4 2666MHz Dual CH SDRAM non-ECC | |
Max. | – 128GB | |
Socket | – 4 * U-DIMM | |
Graphics | ||
Controller | – Intel HD Graphics | |
VRAM | – Shared Memory | |
VGA | –1 (Max. Resolution: 1920×1200@60Hz) | |
HDMI 1.4 | –1 (Max. Resolution: 4096×2160@30Hz) | |
DVI-D | –1(Max. Resolution: 1920×1200@60Hz) | |
DisplayPort | –1 (Max. Resolution: 4096×2304@60Hz) | |
Multi Display | –Triple Displays | |
Ethernet | ||
Ethernet | – 10/100/1000 Mbps | |
Controller | – 2 * Intel GbE (1 * i219LM, 1 * i211AT) | |
Connector | – 2 * RJ45 | |
Audio | ||
CODEC | – HD Audio : REALTEK ALC662 | |
Channel | – 6 Channel | |
SATA | ||
Max Data Transfer Rate | – 5 * SATAIII support RAID 0, 1, 5, 10 | |
Rear I/O | ||
VGA | – 1 | |
DVI-D | – 1 | |
HDMI | – 1 | |
DisplayPort | – 1 | |
Ethernet | – 2 | |
USB | – 4 * USB 3.1 (Gen. 2) & 2 * USB3.1 (Gen. 1) | |
Audio | – 3 (Line-In, Line-Out, MIC) | |
Serial | – 1 (COM1 support RS232/422/485) | |
Internal Connector | ||
USB | – 2 * USB3.1 (Gen. 1), 4 * USB 2.0 | |
PS/2 | – 1 | |
Serial | – 9 (COM2 support RS232/422/485) | |
SATA | – 5 * SATAIII | |
M.2 (M-key) | – 1 (PCIex4 with SATA interface, M-key NVMe, 2242/2260/2280/22110) | |
GPIO | – 1 (8 bit) | |
Chassis intrusion | – 1 | |
Audio Header | – 1 | |
SMBUS | – 1 | |
AT mode | – 1 | |
TPM | – 1 (on board option) | |
Watchdog Timer | ||
Output | – From Super I/O to drag RESETCON# | |
Interval | – 256 segments (10sec ~ 255min) | |
Power Requirements | ||
Input PWR | – ATX PWR (8+24 pin) | |
Power On | AT/ATX Supported – AT : Directly PWR on as Power input ready – ATX : Press Button to PWR on after Power input ready | |
Certifications | ||
Certifications | – CE, FCC, LVD, RoHS, REACH | |
Environment | ||
Temperature | – Operating: 0°C ~ 60°C | |
– Storage:-20°C ~ 85°C |
现货销售研华Mini-ITX工控主板AIMB-285G2
Intel Core i7/i5/i3 LGA 1151 Mini-ITX 带 DP/HDMI/VGA, 2 COM, 4 USB3.0, Dual LAN, PCIe x 4,mini PCIE, DDR4, DC 输入
支持TPM 1.2 / 2.0 (可选)
支持12V DC输入
支持双屏显示:DP/HDMI/VGA/LVDS(可选)
支持 PCIe x 4 (Gen 3), 1个F/S miniPCIe 1个H/S miniPCIe, 4个USB 3.0和3个SATA III
两个 260-pin SO-DIMM最高可达16GB DDR4 2133 MHz SDRAM
支持 Intel 6th Gen Core i 处理器(LGA1151) 带Intel H110 芯片组
嵌入式
5096文章
19199浏览量
308294
三星S25 Ultra S Pen蓝牙被砍,Qi2磁吸技术惹的祸?
豪威发布新款1200万像素汽车CMOS,赋能ADAS和机器视觉
![豪威发布新款1200万像素汽车CMOS,赋能ADAS和机器视觉](https://file1.elecfans.com/web3/M00/08/62/wKgZO2evFy6ACFQ9AAGge-ypsBg738.png)
华为登顶!“国补” 下 2025 年这一市场将爆发
中国平板电脑市场2024年出货量增长4.3%
通过FPGA实现正弦波AD采集,只得到的一半波形
研华AIMB-523工业主板:赋能半导体检测设备,性能提升超20%
ESP32-S3-Korvo-1 V5.0运行cn_speech_commands_recognition复位问题求解
基于ESP32C3运行Homekit example报错如何解决?
pro 35T run_openocd报错的原因?
2023年全球元器件假货报告,哪个品牌最多假货?
![2023年全球元器件假货报告,哪个品牌最多假货?](https://file.elecfans.com/web2/M00/43/7B/pYYBAGJ-B6aAHuNPAAAf8J1Ebk4778.jpg)
研华工控机主板AIMB-705性能,研华705主板说明书
![研华工控机主板<b class='flag-5'>AIMB</b>-705性能,研华705主板说明书](https://file1.elecfans.com/web2/M00/C4/AB/wKgaomXun1aATI1pAAGHHaIdm5w869.jpg)
超低噪声、高PSRR、快速、射频、1.5-A低压差线性稳压器TPS786数据表
![超低噪声、高PSRR、快速、射频、1.5-A低压差线性稳压器TPS<b class='flag-5'>786</b>数据表](https://file.elecfans.com/web1/M00/D9/4E/pIYBAF_1ac2Ac0EEAABDkS1IP1s689.png)
