研发干货丨关于RK3399 开发板休眠、关机功能简析
飞凌嵌入式 2021-11-25 13:57 次阅读
RK3399 主板
文章目录
Power按键
~短按休眠和长按关机
关机命令
~poweroff命令关机
OK3399-C平台采用RK3399 主CPU芯片设计,支持底板Power按键休眠唤醒以及关机功能,Linux命令行也可以通过命令进行关机,下面对这两种方式进行简单的解析。
Power按键
Power按键的休眠唤醒功能一般是与PMIC芯片和CPU相关的,硬件上该按键会连接到PMIC的PWRON引脚和CPU对应的引脚上。
先来看power按键在PMIC侧的响应机制,POWER键按下以后,经过TdbPWRONF时间以后,INT引脚变为低电平,触发中断。内核驱动响应中断,执行休眠程序。
如果PWRON继续保持低电平超过TdPWRONLP,PMIC就会响应,RK3399板卡将进行关机。
f_0dd0d732357aa037478d3a458cd1b1b6&t=jpg&o=&s=&v=1610680194
RK3399短按休眠和长按关机
Log信息
[ 10.250531] PM: Syncing filesystems ... done. [ 10.255148] test message. //加入的测试信息 [ 10.256842] Freezing user space processes ... (elapsed 0.003 seconds) done. [ 10.260770] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done. [ 10.263308] Suspending console(s) (use no_console_suspend to debug) INFO: sleep mode config[0xde]: INFO: AP_PWROFF INFO: SLP_ARMPD INFO: SLP_PLLPD INFO: DDR_RET INFO: SLP_CENTER_PD INFO: wakeup source config[0x804]: INFO:
GPIO
interrupt can wakeup system INFO: PWM interrupt can wakeup system INFO: PWM CONFIG[0x4]: INFO: PWM: PWM2D_REGULATOR_EN INFO: APIOS info[0x0]: INFO: not config INFO: GPIO POWER INFO: INFO: GPIO1_C1 INFO: GPIO1_B6 INFO: PMU_MODE_CONG: 0x1477bf51
涉及驱动文件
kernel/kernel/power/suspend.c/** * enter_state - Do common work needed to enter system sleep state. * @state: System sleep state to enter. * * Make sure that no one else is trying to put the system into a sleep state. * Fail if that's not the case. Otherwise, prepare for system suspend, make the * system enter the given sleep state and clean up after wakeup. */ static int enter_state(suspend_state_t state) { int error; trace_suspend_resume(TPS("suspend_enter"), state, true); if (state == PM_SUSPEND_FREEZE) { #ifdef CONFIG_PM_DEBUG if (pm_test_level != TEST_NONE && pm_test_level <= TEST_CPUS) {                        pr_warning("PM: Unsupported test mode for suspend to idle,"                                   "please choose none/freezer/devices/platform.\n");                        return -EAGAIN;                } #endif        } else if (!valid_state(state)) {                return -EINVAL;        }        if (!mutex_trylock(&pm_mutex))                return -EBUSY;        if (state == PM_SUSPEND_FREEZE)                freeze_begin(); #ifndef CONFIG_SUSPEND_SKIP_SYNC        trace_suspend_resume(TPS("sync_filesystems"), 0, true);        printk(KERN_INFO "PM: Syncing filesystems ... ");        sys_sync();        printk("done.\n");        trace_suspend_resume(TPS("sync_filesystems"), 0, false); #endif        pr_debug("PM: Preparing system for sleep (%s)\n", pm_states[state]);        pm_suspend_clear_flags();        error = suspend_prepare(state);        if (error)                goto Unlock;        if (suspend_test(TEST_FREEZER))                goto Finish;        trace_suspend_resume(TPS("suspend_enter"), state, false);        pr_debug("PM: Suspending system (%s)\n", pm_states[state]);        pm_restrict_gfp_mask();        error = suspend_devices_and_enter(state);        pm_restore_gfp_mask(); Finish:        pr_debug("PM: Finishing wakeup.\n");        suspend_finish(); Unlock:        mutex_unlock(&pm_mutex);        return error; }
通过代码可知,Power按键触发的休眠和关机会执行sys_sync函数,进行系统数据的保存,这与突然掉电导致的异常关机是有很大区别的。
RK3399关机命令
RK3399 平台Linux下的关机命令有shutdown、halt、poweroff命令等.
Poweroff命令关机
Log信息:
[root@rk3399:/]# poweroff [root@rk3399:/]# stop finishedStopping input-event-daemon: done stop auto-reboot finished Stopping dnsmasq: OK Stopping vsftpd: stopped vsftpd (pid 1072) OK [ 20.099392] [BT_RFKILL]: bt shut off power [ 20.132245] configfs-gadget gadget: unbind function 'Function FS Gadget'/ffffffc07b025a38 Stopping sshd: OK Stopping lighttpd: OK Gracefully shutting down php-fpm . done Stopping dhcpcd... stopped /sbin/dhcpcd (pid 924) killall: rkisp_3A_server: no process killed Stopping network: OK stop finishedStopping system message bus: done Saving random seed... done. Stopping logging: OK umount: can't remount adb read-only umount: devtmpfs busy - remounted read-only [ 21.589884] EXT4-fs (mmcblk2p8): re-mounted. Opts: (null) The system is going down NOW! Sent SIGTERM to all processes Sent SIGKILL to all processes Requesting system poweroff [ 23.597578] cpu cpu4: min=816000, max=816000 [ 23.598572] cpu cpu0: min=816000, max=816000 [ 23.669985] I : [File] : drivers/gpu/arm/midgard_for_linux/platform/rk/mali_kbase_config_rk.c; [Line] : 274; [Func] : kbase_platform_rk_shutdown(); to make vdd_gpu enabled for turning off pd_gpu in pm_framework. [ 23.671701] rk-vcodec ff660000.rkvdec: shutdown [ 23.672132] rk-vcodec ff650000.vpu_service: shutdown [ 23.673046] rk808 0-001b: System power off [ 23.673419] rk808 0-001b: test message //加入的测试信息 [root@rk3399:/]# poweroff --help BusyBox v1.27.2 (2020-03-19 09:39:13 UTC) multi-call binary. Usage: poweroff [-d DELAY] [-n] [-f] Halt and shut off power -d SEC Delay interval -n Do not sync -f Force (don't go through init)
Poweroff命令做的事可以从打印信息上看出来,其实可以分为两部分,一是配置系统,停止当前的服务,进行数据保存。二是调用电源管理驱动对应的接口,完成电源配置,RK3399 主板进行关机。
涉及驱动文件
kernel/drivers/mfd/rk808.cstatic void rk808_syscore_shutdown(void) { int ret; struct rk808 *rk808 = i2c_get_clientdata(rk808_i2c_client); if (!rk808) { dev_warn(&rk808_i2c_client->dev, "have no rk808, so do nothing here\n"); return; } /* close rtc int when power off */ regmap_update_bits(rk808->regmap, RK808_INT_STS_MSK_REG1, (0x3 << 5), (0x3 << 5));        regmap_update_bits(rk808->regmap, RK808_
RTC
_INT_REG, (0x3 << 2), (0x0 << 2));        /*         * For PMIC that power off supplies by write register via i2c bus,         * it's better to do power off at syscore shutdown here.         *         * Because when run to kernel's "pm_power_off" call, i2c may has         * been stopped or PMIC may not be able to get i2c transfer while         * there are too many devices are competiting.         */         if (system_state == SYSTEM_POWER_OFF) {                /* power off supplies ! */                if (pm_shutdown) {                        dev_info(&rk808_i2c_client->dev, "System power off\n"); ret = pm_shutdown(rk808->regmap); if (ret) dev_err(&rk808_i2c_client->dev, "System power off error!\n"); mdelay(10); dev_info(&rk808_i2c_client->dev, "Cpu should never reach here, stop!\n"); while (1) ; } } }#define DEV_OFF_RST BIT(3) static int rk808_shutdown(struct regmap *regmap) { int ret; ret = regmap_update_bits(regmap, RK808_DEVCTRL_REG, DEV_OFF_RST, DEV_OFF_RST); return ret; }
最终调用的的rk808shutdown接口函数,对RK808DEVCTRLREG寄存器写入DEVOFF_RST,触发RK3399主板关机。
f_559214e61cd13e0cfbf1b06ee1d05aa1&t=jpg&o=&s=&v=1610680203
进入飞凌嵌入式官网>>了解关于OK3399-C开发板的更多信息。
  • RK3399
  • 瑞芯微RK3399
    高清电视盒子方案分享,红外遥控适配过程全解析
    高效地控制电视设备。极大的提升了用户体验。 iTOP-RK3399平台介绍     红外遥控方案示例 iTOP-RK3399 开发板搭载了HS0038B 红外接收模块。接下来我们在RK3399
    的头像 发表于 12-17 10:46 231次阅读
    RK3576单板发布倒计时:RK3399RK3576对比
    好多人说RK3576是RK3399的升级版,某种程度上也可以这么说,RK3576在强大的多媒体功能的基础上,性能和接口都进行了升级 一、工艺 性能
    的头像 发表于 12-03 16:59 252次阅读
    <b class='flag-5'>RK</b>3576单板发布倒计时:<b class='flag-5'>RK3399</b>与<b class='flag-5'>RK</b>3576对比
    玩转RK3588开发板基于connector-split 功能实现多屏联动
    的头像 发表于 12-02 16:05 301次阅读
    玩转<b class='flag-5'>RK</b>3588<b class='flag-5'>开发板</b>基于connector-split <b class='flag-5'>功能</b>实现多屏联动
    【迅为】瑞芯微RK3588开发板RK3568开发板区别及优势
    RK3568开发板
    的头像 发表于 11-18 14:19 391次阅读
    【迅为】瑞芯微<b class='flag-5'>RK</b>3588<b class='flag-5'>开发板</b><b class='flag-5'>RK</b>3568<b class='flag-5'>开发板</b>区别及优势
    新品体验 | RK3576开发板
    RK3399RK3566、RK3568、RK3588、RK3576等型号的核心与评估
    的头像 发表于 11-01 08:08 754次阅读
    新品体验 | <b class='flag-5'>RK</b>3576<b class='flag-5'>开发板</b>
    瑞芯微RK3399开发板Android7.1修改网络优先级方法,触觉智能SBC3968开发板演示
    本文介绍Android7.1修改网络优先级方法,基于触觉智能SBC3968主板,搭载瑞芯微RK3399芯片,底板具备千兆网口、USB、HDMI、TYPE-C、音频等接口。可适用于工业主机、物联网设备、医疗健康设备、广告机、互动自助终端、教学实验平台、显示控制、车载安防和人脸识别等多个领域。
    的头像 发表于 10-09 11:37 260次阅读
    瑞芯微<b class='flag-5'>RK3399</b><b class='flag-5'>开发板</b>Android7.1修改网络优先级方法,触觉智能SBC3968<b class='flag-5'>开发板</b>演示
    RK3588!黑神话悟空,启动?-迅为电子RK3588开发板
    的头像 发表于 08-30 14:13 633次阅读
    <b class='flag-5'>RK</b>3588!黑神话悟空,启动?-迅为电子<b class='flag-5'>RK</b>3588<b class='flag-5'>开发板</b>
    HZ-CORE-RK3576开发板
    HZ-CORE-RK3576开发板
    的头像 发表于 08-29 13:58 351次阅读
    HZ-CORE-<b class='flag-5'>RK</b>3576<b class='flag-5'>开发板</b>
    Firefly-RK3399产品规格书
    Firefly-RK3399产品规格书
    发表于 07-16 10:50 3次下载
    RK3568开发板支持AMP双系统
    RK3568开发板支持AMP双系统
    的头像 发表于 06-04 15:33 725次阅读
    <b class='flag-5'>RK</b>3568<b class='flag-5'>开发板</b>支持AMP双系统
    慧视Viztra-ME025图像处理 中端性能的RK3399Pro板卡
    的Viztra-ME025图像处理就十分合适。Viztra-ME025图像处理采用国内智能AI芯片RK3399pro,植入公司自主研发的智能图像算法,基于输入的可见光
    的头像 发表于 06-01 08:29 444次阅读
    慧视Viztra-ME025图像处理<b class='flag-5'>板</b>  中端性能的<b class='flag-5'>RK3399</b>Pro板卡
    【OpenHarmony鸿蒙实战】在RK3399开发板实现智能门禁人脸识别
    基于RK3399开发板,使用OpenHarmony3.0-LTS开发的应用。通过定时获取摄像头数据,实现人脸识别比对等功能
    的头像 发表于 03-20 17:38 1359次阅读
    【OpenHarmony鸿蒙实战】在<b class='flag-5'>RK3399</b><b class='flag-5'>开发板</b>实现智能门禁人脸识别
    迅为iTOP-RK3588开发板Buildroot系统功能测试
    的头像 发表于 03-14 15:42 1384次阅读
    迅为iTOP-<b class='flag-5'>RK</b>3588<b class='flag-5'>开发板</b>Buildroot系统<b class='flag-5'>功能</b>测试
    KEGV-P-002开发板雷卯防雷防静电推荐图
      一、产品介绍 KEGV-P-002 Linux开发板是一款基于RK3399处理器的开发板,具有强大的性能和丰富的接口。这款开发板具有以下特点: 处理器:
    的头像 发表于 01-23 15:53 521次阅读
    KEGV-P-002<b class='flag-5'>开发板</b>雷卯防雷防静电推荐图
    rk3399移植Linux内核
    RK3399是一款由中国厂商瑞芯微推出的高性能处理器芯片,被广泛用于嵌入式系统开发。在进行应用程序开发之前,我们需要将Linux内核移植到RK3399上,以支持硬件的驱动和
    的头像 发表于 01-08 09:56 1149次阅读
