【节能学院】安科瑞DJSF1352-RN直流电表在尼日利亚太阳能混合动力系统的应用
江苏安科瑞电器制造有限公司 2021-12-13 14:27 次阅读
摘要
本文介绍了安科瑞DJSF1352-RN直流电表在尼日利亚小型光伏发电设施直流侧的应用。主要用于光伏系统中的电流的计量,通过霍尔对电路系统进行计量、通讯和控制等。
Abstract: This paper introduces the application of Acrel DJSF1352-RN DC energy meter in the DC side of a photovoltaic system in Nigeria. It is mainly used to measure the DC current in the photovoltaic system, and cooperate with hall current sensor to measure, communicate and control the circuit system.
01 项目概述
公司位于尼日利亚,是一家新能源公司。主要在非洲从事光伏发电项目。客户要使用直流电表,用于光伏系统中直流侧的监测计量。
The company is located in Nigeria and is a new energy company. Mainly engaged in photovoltaic power generation projects in Africa. The customer wants to use DC meters and hall sensors for monitor current and voltage at the DC side of photovoltaic system.
02 DJSF1352-RN介绍
DJSF1352-RN导轨式直流电能表,主要针对电信基站、直流充电桩、太阳能光伏等应用场合而设计,该系列仪表可测量直流系统中的电压、电流、功率以及正反向电能等。在实际使用现场,即可计量总电能,又可计量规定时间段内的电能。检测的结果既可用于本地显示,又能与工控设备、计算机连接,组成测控系统。
仪表可具有红外通讯接口RS-485通讯接口,同时支持Modbus-RTU协议和DLT645-97(07)协议;可带继电器报警输出和开关量输入功能;根据不同要求,通过仪表面板按键,对变比、报警、通讯进行设置;具有开关量事件记录(Modbus协议)、编程和事件设置记录(645协议)、数据瞬时和定时冻结功能(645协议)、电压电流功率值记录功能。
DJSF1352-RN rail-mounted DC power meter designed for telecommunications base stations, DC charging piles, solar photovoltaic and other applications, this series of meters can measure the voltage, current, power and forward and reverse energy and so on in the DC system.The actual use of the site, you can measure the total power, but also measure the energy within a specified period of time. The test results can be used for local display, but also with industrial control equipment, computers to form a measurement and control system.
The meter can have infrared communication interface and RS-485 communication interface, and supports Modbus-RTU protocol and DLT645-97 (07) protocol at the same time.The meter can have relay alarm output and digital input function;You can set the ratio, alarm, and communication through the meter panel keys according to different requirements.The meter can have event recording of switch (Modbus protocol), programming and event setting records (645 protocol), instantaneous and timing freeze function of data (645 protocol), value recording function of voltage and current power.
03 型号及功能介绍
Note:when dual DC input(D)function is selected,if Hall current sensor input is used in current channel,a power supply module shall be provided to supply power to the second Hall sensor;if D function is not provided,the built-in power supply of electric meter can be used.
04 开口式霍尔电流传感器
05 客户要求
客户有一个太阳能混合动力系统。PV板,电池储能与柴油发生器电信站,三者连接到同一根母线。客户想用直流仪表来监测母线的电流电压。他们的太阳能系统是电信基站,辅助电源是DC48V,电流是DC100A。
The customer have a solar hybrid system. PV panel, battery storage and diesel generator for a telecom station,All the 3 systems are connected to a single bus bar. They wants to know the watt hour reading from the bus bar using a DC meter. And their solar site is a telecom site. the power supply voltage is DC 48V, the current is DC100A.
  • 智能电表
    DJSF1352-RN-2导轨式直流电能表安装使用说明书V1.0
     DJSF1352-RN-2导轨式直流电能表说明书V1.1
    发表于 02-19 14:32 0次下载
    安科DJSF1352新能源直流监控电表
    1.概述   DJSF1352新能源直流监控电表 带有双路直流输入,主要针对电信基站、直流充电桩、太阳能
    的头像 发表于 02-11 10:24 97次阅读
    <b class='flag-5'>安科</b><b class='flag-5'>瑞</b><b class='flag-5'>DJSF1352</b>新能源<b class='flag-5'>直流</b>监控<b class='flag-5'>电表</b>
    安科DJSF1352-RN直流电能表 新能源计量 带UL认证
     DJSF1352-RN采用液晶显示,具有 RS485 功能可与微机进行数据交换。适合充电桩直流计量、蓄电池、太阳能电池板等直流信号设备电量测量和电能计量使用,亦可用于工矿企业,民用建
    的头像 发表于 02-06 15:01 146次阅读
    <b class='flag-5'>安科</b><b class='flag-5'>瑞</b><b class='flag-5'>DJSF1352-RN</b><b class='flag-5'>直流电</b>能表 新能源计量 带UL认证
    DJSF1352-RN导轨式直流电能表安装使用说明书V2.1
    电子发烧友网站提供《DJSF1352-RN导轨式直流电能表安装使用说明书V2.1.pdf》资料免费下载
    发表于 01-15 14:49 0次下载
    安科DJSF1352-RN光储直柔直流电表 光伏发电储计量 485通信直流电能表逆变器
    安科 程瑜 187 0211 2087 产品简介   DJSF1352型电子式直流电能表采用液晶显示,具有RS485功能可与微机进行数据交换。产品由测量单元、数据处理单元、通讯单元、
    的头像 发表于 01-08 10:25 234次阅读
    <b class='flag-5'>安科</b><b class='flag-5'>瑞</b><b class='flag-5'>DJSF1352-RN</b>光储直柔<b class='flag-5'>直流电表</b> 光伏发电储<b class='flag-5'>能</b>计量 485通信<b class='flag-5'>直流电</b>能表逆变器
    安科DJSF1352-RN各界面设置演示
    安科
    jf_25373932
    发布于 :2024年12月18日 17:29:57
    DJSF1352-RN 导轨式直流电能表 输入电压1500V 带双路计量,电信基站、直流桩、太阳能光伏可用
    安科戴婷 187+0616=8553 1 概述 DJSF1352-RN导轨式直流电能表带有双路直流输入,主要针对电信基站、
    的头像 发表于 12-13 17:30 309次阅读
    <b class='flag-5'>DJSF1352-RN</b> 导轨式<b class='flag-5'>直流电</b>能表 输入电压1500V 带双路计量,电信基站、<b class='flag-5'>直流</b>桩、<b class='flag-5'>太阳能</b>光伏可用
    DJSF1352双通道直流计量电能表储能行业、直流充电桩等的应用
    安科徐赟杰18706165067 1 两路直流电能表概述 DJSF1352-RN导轨式直流电能表带有双路
    的头像 发表于 11-29 11:03 498次阅读
    <b class='flag-5'>DJSF1352</b>双通道<b class='flag-5'>直流</b>计量电能表<b class='flag-5'>在</b>储能行业、<b class='flag-5'>直流</b>充电桩等的应用
    直流充电桩计量双回路导轨式电能表DJSF1352-RN/D
    及计量 Modbus-RTU、645规约、698规约 导轨结构,4模体积小巧方便安装 支持分流器或霍尔传感器输入方式 可支持双通讯 2、产品概述 DJSF1352-RN导轨式直流电能表带有双路直流输入,主要针对电信基站、
    的头像 发表于 11-19 15:16 588次阅读
    <b class='flag-5'>直流</b>充电桩计量双回路导轨式电能表<b class='flag-5'>DJSF1352-RN</b>/D
    DJSF1352-RN导轨式直流电能表安装使用说明书 V2.1
    冯东铖  17821170233DJSF1352-RN导轨式直流电能表带有双路直流输入,主要针对电信基站、直流充电桩、太阳能光伏等应用场合而
    发表于 11-08 15:48 0次下载
    安科DJSF1352直流电能表海外光伏储系统中的应用
    的应用,可以使电路设计更简单,更高效。目前直流配电光伏+储系统中,可以通过光伏或电池直接进行直流供电,
    的头像 发表于 11-04 14:40 324次阅读
    <b class='flag-5'>安科</b><b class='flag-5'>瑞</b><b class='flag-5'>DJSF1352</b><b class='flag-5'>直流电</b>能表<b class='flag-5'>在</b>海外光伏储<b class='flag-5'>能</b><b class='flag-5'>系统</b>中的应用
    安科风力发电储直流电表DJSF1352-RN 带CE认证
    安科CE认证储计量直流表主要针对电信基站、直流充电桩、太阳能光伏等应用场合而设计,该系列仪表
    的头像 发表于 09-18 10:05 903次阅读
    <b class='flag-5'>安科</b><b class='flag-5'>瑞</b>风力发电储<b class='flag-5'>能</b><b class='flag-5'>直流电表</b><b class='flag-5'>DJSF1352-RN</b> 带CE认证
    哪款直流电能表可在电信基站、直流充电桩、太阳能光伏用
    安科徐赟杰18706165067 电信基站、直流充电桩、太阳能光伏等应用场合中,可使用DJSF135
    的头像 发表于 09-03 13:38 1314次阅读
    哪款<b class='flag-5'>直流电</b>能表可在电信基站、<b class='flag-5'>直流</b>充电桩、<b class='flag-5'>太阳能</b>光伏用
    安科DJSF系列光伏直流电能计量表 DJSF1352-RN
    DJSF1352型电子式直流电能表采用液晶显示,具有RS485功能可与微机进行数据交换。产品由测量单元、数据处理单元、通讯单元、显示单元等组成,具有电能测量、数据处理、实时监测等功能。
    的头像 发表于 07-19 09:57 512次阅读
    <b class='flag-5'>安科</b><b class='flag-5'>瑞</b><b class='flag-5'>DJSF</b>系列光伏<b class='flag-5'>直流电</b>能计量表 <b class='flag-5'>DJSF1352-RN</b>
    双路直流输入,正反向电能计量导轨式UL认证直流电表DJSF1352-RN
    ★ 概述 DJSF1352-RN导轨式直流电能表带有双路直流输入,主要针对 电信基站、直流充电桩、太阳能光伏 等应用场合而设计,该系列仪表可
    的头像 发表于 05-13 10:42 1138次阅读
    双路<b class='flag-5'>直流</b>输入,正反向电能计量导轨式UL认证<b class='flag-5'>直流电表</b><b class='flag-5'>DJSF1352-RN</b>
