米尔MYS-8MMX开发板试用体验测评——dql2016
米尔电子 2021-10-25 17:46 次阅读
米尔MYS-8MMX开发板试用体验测评四
日前,米尔科技发布了关于MYS-8MMX开发板的测评公告,公告发布后,吸引了各大媒体平台的测评者争相报名,本期我们分享其中一名优秀测评者的测评报告,供各位参考。如需要查看往期优秀测评内容的可点击下方链接查看:
米尔MYS-8MMX开发板试用体验测评——tobot
再来一份关于米尔MYS-8MMX开发板试用体验测评报告——robe.zhang
米尔MYS-8MMX开发板试用体验测评——donatello1996
想要了解优秀测评者“dql2016”关于MYS-8MMX开发板测评原文的可以复制下方链接查看:
https://bbs.elecfans.com/jishu_2159854_1_1.html
【米尔MYS-8MMX开发板免费试用】sdk安装
拿到板子要想开发自己的应用程序首先就得安装sdk,交叉编译工具。米尔给我们提供了适合不同用户需求的SDK以及十分详细的安装手册。按照手册进行SDK装,安装完毕会有提示:
先生效一下环境变量,现在这个SDK目录内容如下:
查看下environment-setup-aarch64-poky-linux这个脚本的内容:
1.cat environment-setup-aarch64-poky-linux
内容如下:
1.# Check for LD_LIBRARY_PATH being set, which can break SDK and generally is a bad practice
2.# http://tldp.org/HOWTO/Program-Library-HOWTO/shared-libraries.html#AEN80
3.# http://xahlee.info/UnixResource_dir/_/ldpath.html
4.# Only disable this checkIFyou are absolutely know what you are doing!
5.if [ ! -z "$LD_LIBRARY_PATH" ]; then
6. echo "Your environment is misconfigured, you probably need to 'unset LD_LIBRARY_PATH'"
7. echo "but please check why this was set in the first place and that it's safe to unset."
8. echo "The SDK will not operate correctly in most cases when LD_LIBRARY_PATH is set."
9. echo "For more references see:"
10. echo "http://tldp.org/HOWTO/Program-Library-HOWTO/shared-libraries.html#AEN80"
11. echo "http://xahlee.info/UnixResource_dir/_/ldpath.html"
12. return 1
13.fi
14.export SDKTARGETSYSROOT=/media/nrjd/fsl-imx-xwayland/5.4-zeus/sysroots/aarch64-poky-linux
15.export PATH=/media/nrjd/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/bin:/media/nrjd/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/sbin:/media/nrjd/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/bin:/media/nrjd/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/sbin:/media/nrjd/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/bin/../x86_64-pokysdk-linux/bin:/media/nrjd/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/bin/aarch64-poky-linux:/media/nrjd/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/bin/aarch64-poky-linux-musl:$PATH
16.export PKG_CONFIG_SYSROOT_DIR=$SDKTARGETSYSROOT
17.export PKG_CONFIG_PATH=$SDKTARGETSYSROOT/usr/lib/pkgconfig:$SDKTARGETSYSROOT/usr/share/pkgconfig
18.export CONFIG_SITE=/media/nrjd/fsl-imx-xwayland/5.4-zeus/site-config-aarch64-poky-linux
19.export OECORE_NATIVE_SYSROOT="/media/nrjd/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux"
20.export OECORE_TARGET_SYSROOT="$SDKTARGETSYSROOT"
21.export OECORE_ACLOCAL_OPTS="-I /media/nrjd/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/share/aclocal"
22.export OECORE_BASELIB="lib"
23.export OECORE_TARGET_ARCH="aarch64"
24.export OECORE_TARGET_OS="linux"
25.unset command_not_found_handle
26.export CC="aarch64-poky-linux-gcc-mcpu=cortex-a53+crc --sysroot=$SDKTARGETSYSROOT"
27.export CXX="aarch64-poky-linux-g++-mcpu=cortex-a53+crc --sysroot=$SDKTARGETSYSROOT"
28.export CPP="aarch64-poky-linux-gcc -E-mcpu=cortex-a53+crc --sysroot=$SDKTARGETSYSROOT"
29.export AS="aarch64-poky-linux-as "
30.export LD="aarch64-poky-linux-ld--sysroot=$SDKTARGETSYSROOT"
31.export GDB=aarch64-poky-linux-gdb
32.export STRIP=aarch64-poky-linux-strip
33.export RANLIB=aarch64-poky-linux-ranlib
34.export OBJCOPY=aarch64-poky-linux-objcopy
35.export OBJDUMP=aarch64-poky-linux-objdump
36.export READELF=aarch64-poky-linux-readelf
37.export AR=aarch64-poky-linux-ar
38.export NM=aarch64-poky-linux-nm
39.export M4=m4
40.export TARGET_PREFIX=aarch64-poky-linux-
41.export CONFIGURE_FLAGS="--target=aarch64-poky-linux --host=aarch64-poky-linux --build=x86_64-linux --with-libtool-sysroot=$SDKTARGETSYSROOT"
42.export CFLAGS=" -O2 -pipe -g -feliminate-unused-debug-types "
43.export CXXFLAGS=" -O2 -pipe -g -feliminate-unused-debug-types "
44.export LDFLAGS="-Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed"
45.export CPPFLAGS=""
46.export KCFLAGS="--sysroot=$SDKTARGETSYSROOT"
47.export OECORE_DISTRO_VERSION="5.4-zeus"
48.export OECORE_SDK_VERSION="5.4-zeus"
49.export ARCH=ARM64
50.export CROSS_COMPILE=aarch64-poky-linux-
51.
52.# Append environment subscripts
53.if [ -d "$OECORE_TARGET_SYSROOT/environment-setup.d" ]; then
54. for envfile in $OECORE_TARGET_SYSROOT/environment-setup.d/*.sh; do
55. . $envfile
56. done
57.fi
58.if [ -d "$OECORE_NATIVE_SYSROOT/environment-setup.d" ]; then
59. for envfile in $OECORE_NATIVE_SYSROOT/environment-setup.d/*.sh; do
60. . $envfile
61. done
62.fi
63.
都是些环境变量的设置。通过查看可知ARCH=arm64 CROSS_COMPILE=aarch64-poky-linux-
那么交叉编译工具就是
1.aarch64-poky-linux-gcc
版本是9.2.0,这个版本对c++ 11支持还是十分全面的,为后面的应用开发提供了方便。
【米尔MYS-8MMX开发板免费试用】+emmc读写测试
米尔MYS-8MMX开发板板载了8GB eMMC,性能测试主要测试 emmc 在 linux 系统下对文件的读写速度上的测试,测试一般结合time 与 dd 双命令进行测试。写文件测试
这里测试出写磁盘速度为 36.8MB/s。
读文件测试
这里测试出读速度为 238MB/s。
【米尔MYS-8MMX开发板免费试用】+ 使用mjpg-streamer和UVC摄像头搭建网络摄像头
手上正好有一个1600万像素的USB摄像头,支持UVC,十分适合用来做网络监控应用,借助米尔MYS-8MMX开发板强大的音视频处理能力,可玩性很高。搭建网络摄像头,板子上需要运行流媒体服务器,读取摄像头数据然后通过网络发送出去,目前常用的方案有MJPG-streamer、µStreamer 、Motion 等。这里我选择性能较高的MJPG-streamer,MJPG-streamer是一款免费基于IP地址的视频流服务器,它的输入插件从摄像头读取视频数据,这个输入插件产生视频数据并将视频数据复制到内存中,它有多个输出插件将这些视频数据经过处理,其中最重要的输出插件是网站服务器插件,它将视频数据传送到用户浏览器中,MJPG-streamer的工作就是将其中的一个输入插件和多个输出插件绑定在一起,所有的工作都是通过它的各个插件完成的。MJPG-streamer是SourceForge网站的一个开源项目:https://sourceforge.net/projects/mjpg-streamer/
目前项目已经迁移到github,这个版本增加了树莓派的支持:https://github.com/jacksonliam/mjpg-streamer
MJPG-streamer依赖jpeg库,因此首先进行jpeg 库的移植,jpeg源码包通过这个网址下载http://www.ijg.org/
最新版本是jpegsrc.v9d.tar.gzjpeg编译
·解压源码包
1.tar-xvfjpegsrc.v9d.tar.gz
·配置源码
1.cdjpegsrc.v9d
2.export CC=aarch64-poky-linux-gcc
3../configure --host=ARM-linux --prefix=/home/test/build_jpegsrc.v9d
·编译&安装
1.make
2.make install
mjpg-stream编译
·解压源码
1.tar-xvfmjpg-streamer-r63.tar.gz
进入源码目录
1.cdmjpg-streamer-r63
创建一个目录lib用来存放交叉编译的动态库文件
1.mkdir lib
输入编译命令并指定交叉编译器
1.make CC=aarch64-poky-linux-gcc
将在目录mjpg-streamer-test/mjpg-streamer-r63生成应用程序mjpg_streamer
几个主要文件介绍如下:
· input_testpicture.so。这是一个图像测试插件,它将预设好的图像编译成一个头文件,可以在没有摄像头的情况下传输图像,从而方便调试程序。
· input_uvc.so。此文件调用USB摄像头驱动程序V4L2,从摄像头读取视频数据。
· input_control.so。这个文件实现对摄像头转动的控制接口
· output_http.so。这是一个功能齐全的网站服务器,它不仅可以从单一文件夹中处理文件,还可以执行一定的命令,它可以从输入插件中处理一幅图像,也可以将输入插件的视频文件根据现有M-JPEG标准以HTTP视频数据服务流形式输出。
· output_file.so。这个插件的功能是将输入插件的JPEG图像存储到特定的文件夹下,它可以用来抓取图像。
将生成的mjpg-streamer-r63/plugins/output_file/output_file.so和mjpg-streamer-r63/plugins/input_uvc/input_uvc.so
拷贝到目录
mjpg-streamer-r63/lib
将上面编译的jpeg动态库libjpeg.so、libjpeg.so.9、libjpeg.so.9.4.0拷贝到目录
我这里搭建了nfs,将测试目录挂载到开发板,方便调试,动态库目录内容如下:
在终端输入命令指定环境变量
1.export LD_LIBRARY_PATH=/mnt/mjpg-streamer-test/mjpg-streamer-r63/lib
然后输入命令
1.
./mjpg_streamer -i "input_uvc.so -n
运行成功信息如下:
我的板子ip设置成了192.168.1.120,浏览器地址栏输入
1.http://192.168.1.120:8080/?action=snapshot
就可以看到图像了,回车可以进行单张抓拍,演示效果如下:
或者输入
1.http://192.168.1.120:8080/?action=stream
就可以看到实时视频了。
利用强大的curl可以方便的做到抓拍图片,下面是ubuntu和windows端的演示效果:
1.curl http://192.168.1.120:8080/?action=snapshot -o a.jpg
ubuntu端的效果
window端的效果
米尔电子领先的嵌入式处理器模块厂商
原文标题:米尔MYS-8MMX开发板试用体验测评——dql2016
文章出处:【微信公众号:米尔MYiR】欢迎添加关注!文章转载请注明出处。
  • 开发板
    【RA8D1试用活动】RA8D1B-CPKCOR开发板移植linux
    的头像 发表于 11-16 01:02 108次阅读
    【RA<b class='flag-5'>8</b>D1<b class='flag-5'>试用</b>活动】RA<b class='flag-5'>8</b>D1B-CPKCOR<b class='flag-5'>开发板</b>移植linux
    米尔-Xilinx XC7A100T FPGA开发板试用】+01.开箱(zmj)
    米尔-Xilinx XC7A100T FPGA开发板试用】+01.开箱(zmj) 1.感谢 感谢米尔电子和电子发烧友提供的此次试用机会,可
    发表于 11-12 15:45
    有奖丨米尔 瑞芯微RK3576开发板免费试用
    米尔与瑞芯微合作发布的新品基于瑞芯微RK3576应用处理器的MYD-LR3576开发板免费试用活动来啦~~米尔提供了7块价值849元的MYD-LR3576
    的头像 发表于 11-12 01:00 150次阅读
    有奖丨<b class='flag-5'>米尔</b> 瑞芯微RK3576<b class='flag-5'>开发板</b>免费<b class='flag-5'>试用</b>
    米尔RK3576开发板特惠活动!
    近日,米尔电子发布基于瑞芯微RK3576核心开发板,RK3576作为国产热门处理器,其高性能数据处理能力、领先的AI智能分析、强大的扩展性与兼容性受到广大开发者的关注。
    的头像 发表于 11-12 01:00 114次阅读
    <b class='flag-5'>米尔</b>RK3576<b class='flag-5'>开发板</b>特惠活动!
    有奖试用!!RA-Eco-RA4E2-64PIN-V1.0开发板试用活动开始报名
    的头像 发表于 11-09 01:02 115次阅读
    有奖<b class='flag-5'>试用</b>!!RA-Eco-RA4E2-64PIN-V1.0<b class='flag-5'>开发板</b><b class='flag-5'>试用</b>活动开始报名
    米尔-紫光PG2L100H国产FPGA开发板试用米尔-紫光PG2L100H国产FPGA开发板开箱评测
    很荣幸收到电子发烧友论坛申请的 米尔-紫光PG2L100H国产FPGA开发板,现在特地来写篇测评报告,米尔-紫光PG2L100H国产FPGA由核心
    发表于 11-07 12:21
    基于OPENCV的相机捕捉视频进行人脸检测--米尔NXP i.MX93开发板
    本文将介绍基于米尔电子MYD-LMX93开发板米尔基于NXPi.MX93开发板)的基于OpenCV的人脸检测方案测试。OpenCV提供了一个非常简单的接口,用于相机捕捉一个视频(我用
    的头像 发表于 11-07 09:03 946次阅读
    基于OPENCV的相机捕捉视频进行人脸检测--<b class='flag-5'>米尔</b>NXP i.MX93<b class='flag-5'>开发板</b>
    198元,米尔NXP i.MX 93开发板,限购300套
    米尔NXPi.MX93开发板凭借其卓越的性能、强劲的推理能力以及丰富的接口资源,在众多行业应用中都得到了广泛认可,为回馈广大行业客户的支持与厚爱,进一步激发开发者的创新潜能,共同推动技术的发展与进步
    的头像 发表于 09-27 08:00 305次阅读
    198元,<b class='flag-5'>米尔</b>NXP i.MX 93<b class='flag-5'>开发板</b>,限购300套
    点击参与米尔NXP i.MX 93开发板有奖试用
    米尔与NXP合作发布的新品基于NXPi.MX93应用处理器的MYD-LMX9X开发板免费试用活动来啦~~米尔提供了3块价值678元的MYD-LMX9X
    的头像 发表于 06-13 08:02 462次阅读
    点击参与<b class='flag-5'>米尔</b>NXP i.MX 93<b class='flag-5'>开发板</b>有奖<b class='flag-5'>试用</b>
    米尔NXP i.MX 93开发板的Qt开发指南
    1.概述Qt是一个跨平台的图形应用开发框架,被应用在不同尺寸设备和平台上,同时提供不同版权版本供用户选择。米尔NXPi.MX93开发板(MYD-LMX9X开发板)使用Qt6.5版本进行
    的头像 发表于 06-07 08:01 1647次阅读
    <b class='flag-5'>米尔</b>NXP i.MX 93<b class='flag-5'>开发板</b>的Qt<b class='flag-5'>开发</b>指南
    免费!NXP i.MX 93开发板有奖试用
    米尔与NXP合作发布的新品基于NXPi.MX93应用处理器的MYD-LMX9X开发板免费试用活动来啦~~米尔提供了2块价值678
    的头像 发表于 05-23 08:01 667次阅读
    免费!NXP i.MX 93<b class='flag-5'>开发板</b>有奖<b class='flag-5'>试用</b>
    通过物联网管理多台MQTT设备-基于米尔T527开发板
    本篇测评由电子工程世界的优秀测评者“JerryZhen”提供。本文将介绍基于米尔电子MYD-LT527开发板的网关方案测试。一、系统概述基于米尔
    的头像 发表于 05-10 08:01 627次阅读
    通过物联网管理多台MQTT设备-基于<b class='flag-5'>米尔</b>T527<b class='flag-5'>开发板</b>
    G2D图像处理硬件调用和测试-基于米尔-全志T113-i开发板
    本篇测评由电子工程世界的优秀测评者“jf_99374259”提供。本文将介绍基于米尔电子MYD-YT113i开发板的G2D图像处理硬件调用和测试。MYC-YT113i核心
    的头像 发表于 04-12 08:01 599次阅读
    G2D图像处理硬件调用和测试-基于<b class='flag-5'>米尔</b>-全志T113-i<b class='flag-5'>开发板</b>
    ROS系统的智能车开发-基于米尔芯驰MYD-JD9X开发板
    本篇测评由电子工程世界的优秀测评者“mameng”提供。本文将介绍基于米尔电子MYD-JD9X开发板的ROS系统智能车开发。目前实现ROS的
    的头像 发表于 01-26 08:01 850次阅读
    ROS系统的智能车<b class='flag-5'>开发</b>-基于<b class='flag-5'>米尔</b>芯驰MYD-JD9X<b class='flag-5'>开发板</b>
    米尔电子和瑞萨电子推出首款MPU生态开发板瑞米派
    近日,米尔电子和瑞萨电子共同定义和开发了瑞萨第一款MPU生态开发板——瑞米派(Remi Pi)正式上市了!在各种Pi板卡琳琅满目的当下,Remi Pi是一款与众不同的开发板,它兼顾了严
    的头像 发表于 01-25 09:21 1016次阅读
