安科瑞DJSF1352-RN直流电表在俄罗斯UPS电能计量系统中的应用
江苏安科瑞微电网研究院有限公司 2022-06-10 16:09 次阅读
安科瑞 华楠
摘要:本文介绍了安科瑞DJSF1352-RN直流电表在俄罗斯UPS计量系统中的应用。主要用于UPS系统中的输出电能的计量,通过霍尔对电路系统进行计量、通讯和控制等。
  Abstract: This article introduces the application of “Acrel” DJSF1352-RN DC meter in the Russian UPS metering system. It is mainly used for the measurement of the output energy in the UPS system, and the measurement, communication and control of the circuit system through the Hall sensor.
  1.项目概述:Project Overview
  该公司位于俄罗斯,是一家电池生产公司。主要在俄罗斯从事工业电池及UPS的生产和供应。客户要使用直流电表,用于UPS输出端电能的监测计量。
  The company is located in Russia and is a battery production company. Mainly engaged in the production and supply of industrial batteries and UPS in Russia. The customer needs to use a DC meter for monitoring and measuring the electrical energy at the output of the UPS.
  2.DJSF1352-RN介绍 DJSF1352-RN DC Energy Meters
  DJSF1352-RN导轨式直流电能表,主要针对电信基站、直流充电桩、太阳能光伏等应用场合而设计,该系列仪表可测量直流系统中的电压、电流、功率以及正反向电能等。在实际使用现场,即可计量总电能,又可计量规定时间段内的电能。检测的结果既可用于本地显示,又能与工控设备、计算机连接,组成测控系统。
  仪表可具有红外通讯接口RS-485通讯接口,同时支持Modbus-RTU协议和DLT645-97(07)协议;可带继电器警报输出和开关量输入功能;根据不同要求,通过仪表面板按键,对变比、警报、通讯进行设置;具有开关量事件记录(Modbus协议)、编程和事件设置记录(645协议)、数据瞬时和定时冻结功能(645协议)、电压电流功率峰值、谷值记录功能。
  DJSF1352-RN rail-mounted DC power meter designed for telecommunications base stations, DC charging piles, solar photovoltaic and other applications, this series of meters can measure the voltage, current, power and forward and reverse energy and so on in the DC system.The actual use of the site, you can measure the total power, but also measure the energy within a specified period of time. The test results can be used for local display, but also with industrial control equipment, computers to form a measurement and control system.
  The meter can have infrared communication interface and RS-485 communication interface, and supports Modbus-RTU protocol and DLT645-97 (07) protocol at the same time.The meter can have relay alarm output and digital input function;You can set the ratio, alarm, and communication through the meter panel keys according to different requirements.The meter can have event recording of switch (Modbus protocol), programming and event setting records (645 protocol), instantaneous and timing freeze function of data (645 protocol), maximum and minimum value recording function of voltage and current power.
  3.型号及功能介绍 Type and Function Description
  Note:when dual DC input(D)function is selected,if Hall current sensor input is used in current channel, a power supply module shall be provided to supply power to the second Hall sensor; if D function is not provided, the built-in power supply of electric meter can be used.
  4.客户要求 Customer Requirements
  客户想计量UPS的实际输出电能,来计算UPS储能与耗能的转化比,UPS输入端用的是我们ADL系列的电表,输出端用的是DJSF1352-RN直流电表,通过分流器采取电信号,达到输出端测量的目的。
  The customer wants to measure the actual output power of the UPS to calculate the conversion ratio of UPS energy storage to energy consumption. The UPS input end uses our ADL series electric meter, the output end uses DJSF1352-RN DC meter, and the electrical signal is taken through the shunt in order to achieve the purpose of output measurement.
  参考文献 Bibliography
  1.Solutions For Enterprise Micro-grid System 2021.04
  • 智能电表
    安科DJSF1352新能源直流监控电表
    1.概述   DJSF1352新能源直流监控电表 带有双路直流输入,主要针对电信基站、直流充电桩、太阳能光伏等应用场合而设计,该系列仪表可测
    的头像 发表于 02-11 10:24 55次阅读
    <b class='flag-5'>安科</b><b class='flag-5'>瑞</b><b class='flag-5'>DJSF1352</b>新能源<b class='flag-5'>直流</b>监控<b class='flag-5'>电表</b>
    安科DJSF1352-RN直流电能表 新能源计量 带UL认证
     DJSF1352-RN采用液晶显示,具有 RS485 功能可与微机进行数据交换。适合充电桩直流计量、蓄电池、太阳能电池板等直流信号设备电量测量和
    的头像 发表于 02-06 15:01 93次阅读
    <b class='flag-5'>安科</b><b class='flag-5'>瑞</b><b class='flag-5'>DJSF1352-RN</b><b class='flag-5'>直流电能</b>表 新能源<b class='flag-5'>计量</b> 带UL认证
    DJSF1352-RN导轨式直流电能表安装使用说明书V2.1
    电子发烧友网站提供《DJSF1352-RN导轨式直流电能表安装使用说明书V2.1.pdf》资料免费下载
    发表于 01-15 14:49 0次下载
    安科DJSF1352-RN光储直柔直流电表 光伏发电储能计量 485通信直流电能表逆变器
    安科 程瑜 187 0211 2087 产品简介   DJSF1352型电子式直流电能表采用液晶显示,具有RS485功能可与微机进行数据交换。产品由测量单元、数据处理单元、通讯单元、
    的头像 发表于 01-08 10:25 195次阅读
    <b class='flag-5'>安科</b><b class='flag-5'>瑞</b><b class='flag-5'>DJSF1352-RN</b>光储直柔<b class='flag-5'>直流电表</b> 光伏发电储能<b class='flag-5'>计量</b> 485通信<b class='flag-5'>直流电能</b>表逆变器
    DJSF1352-RN 导轨式直流电能表 输入电压1500V 带双路计量,电信基站、直流桩、太阳能光伏可用
    安科戴婷 187+0616=8553 1 概述 DJSF1352-RN导轨式直流电能表带有双路直流输入,主要针对电信基站、
    的头像 发表于 12-13 17:30 266次阅读
    <b class='flag-5'>DJSF1352-RN</b> 导轨式<b class='flag-5'>直流电能</b>表 输入电压1500V 带双路<b class='flag-5'>计量</b>,电信基站、<b class='flag-5'>直流</b>桩、太阳能光伏可用
    DJSF1352双通道直流计量电能储能行业、直流充电桩等的应用
    安科徐赟杰18706165067 1 两路直流电能表概述 DJSF1352-RN导轨式直流电能表带有双路
    的头像 发表于 11-29 11:03 455次阅读
    <b class='flag-5'>DJSF1352</b>双通道<b class='flag-5'>直流</b><b class='flag-5'>计量</b><b class='flag-5'>电能</b>表<b class='flag-5'>在</b>储能行业、<b class='flag-5'>直流</b>充电桩等的应用
    直流充电桩计量双回路导轨式电能DJSF1352-RN/D
    计量 Modbus-RTU、645规约、698规约 导轨结构,4模体积小巧方便安装 支持分流器或霍尔传感器输入方式 可支持双通讯 2、产品概述 DJSF1352-RN导轨式直流电能表带有双路
    的头像 发表于 11-19 15:16 541次阅读
    <b class='flag-5'>直流</b>充电桩<b class='flag-5'>计量</b>双回路导轨式<b class='flag-5'>电能</b>表<b class='flag-5'>DJSF1352-RN</b>/D
    DJSF1352-RN导轨式直流电能表安装使用说明书 V2.1
    冯东铖  17821170233DJSF1352-RN导轨式直流电能表带有双路直流输入,主要针对电信基站、直流充电桩、太阳能光伏等应用场合而设计,该系列仪表可测量
    发表于 11-08 15:48 0次下载
    安科ul认证导轨式直流电能
    1、产品概述 DJSF1352-RN导轨式直流电能表带有双路直流输入,主要针对电信基站、直流充电桩、太阳能光伏等应用场合而设计,该系列仪表可测量直流
    的头像 发表于 11-07 09:50 540次阅读
    <b class='flag-5'>安科</b><b class='flag-5'>瑞</b>ul认证导轨式<b class='flag-5'>直流电能</b>表
    安科风力发电储能直流电表DJSF1352-RN 带CE认证
    安科CE认证储能计量直流表主要针对电信基站、直流充电桩、太阳能光伏等应用场合而设计,该系列仪表可测量
    的头像 发表于 09-18 10:05 865次阅读
    <b class='flag-5'>安科</b><b class='flag-5'>瑞</b>风力发电储能<b class='flag-5'>直流电表</b><b class='flag-5'>DJSF1352-RN</b> 带CE认证
    双路设计,满足光伏电站与充电桩多样化计量需求——安科丁佳雯
    的理想选择。  DJSF1352-RN电子式直流电能表采用液晶显示,可通过RS485接口与微机进行数据交换,并具有电能测量、数据处理、实时监测等功能。除了广泛应用于光伏电站与充电桩的计量
    的头像 发表于 09-09 12:54 285次阅读
    双路设计,满足光伏电站与充电桩多样化<b class='flag-5'>计量</b>需求——<b class='flag-5'>安科</b><b class='flag-5'>瑞</b>丁佳雯
    哪款直流电能表可在电信基站、直流充电桩、太阳能光伏用
    安科徐赟杰18706165067 电信基站、直流充电桩、太阳能光伏等应用场合,可使用DJSF135
    的头像 发表于 09-03 13:38 1262次阅读
    哪款<b class='flag-5'>直流电能</b>表可在电信基站、<b class='flag-5'>直流</b>充电桩、太阳能光伏用
    安科DJSF1352型电子式直流电能表 CE/UL等资质认证
    产品概述 DJSF1352型电子式直流电能表采用液品显示,具有RS485功能可与微机进行数据交换。适合充电桩直流计量、电池、太阳能电池板等直流
    的头像 发表于 09-03 12:24 245次阅读
    <b class='flag-5'>安科</b><b class='flag-5'>瑞</b><b class='flag-5'>DJSF1352</b>型电子式<b class='flag-5'>直流电能</b>表 CE/UL等资质认证
    安科DJSF系列光伏直流电能计量DJSF1352-RN
    DJSF1352型电子式直流电能表采用液晶显示,具有RS485功能可与微机进行数据交换。产品由测量单元、数据处理单元、通讯单元、显示单元等组成,具有电能测量、数据处理、实时监测等功能。
    的头像 发表于 07-19 09:57 482次阅读
    <b class='flag-5'>安科</b><b class='flag-5'>瑞</b><b class='flag-5'>DJSF</b>系列光伏<b class='flag-5'>直流电能</b><b class='flag-5'>计量</b>表 <b class='flag-5'>DJSF1352-RN</b>
    双路直流输入,正反向电能计量导轨式UL认证直流电表DJSF1352-RN
    ★ 概述 DJSF1352-RN导轨式直流电能表带有双路直流输入,主要针对 电信基站、直流充电桩、太阳能光伏 等应用场合而设计,该系列仪表可测量直流
    的头像 发表于 05-13 10:42 1096次阅读
    双路<b class='flag-5'>直流</b>输入,正反向<b class='flag-5'>电能</b><b class='flag-5'>计量</b>导轨式UL认证<b class='flag-5'>直流电表</b><b class='flag-5'>DJSF1352-RN</b>
