RA MCU 生态工作室致力于构建一个完善的 RA 生态,这将会是一个好玩有趣的开放社区,也提供各种RA相关问题的解决方法。
1.概述
通过RASC创建一个串口工程,具体配置如下,用户可以根据自己定义来配置串口相关的基本参数。
2.创建工程
STEP1:RASC创建工程
STEP2:选芯片型号跟IDE类型
STEP3:选择芯片型号
STEP4:选择无操作系统
STEP5:勾选确认工程
STEP6:配置串口号跟IO口
STEP7:添加串口驱动
STEP8:配置串口
STEP9:配置串口基本属性
STEP10:生成工程
3.代码
STEP11:打开工程
STEP12:添加代码
STEP13:具体代码如下
void hal_entry( void )
/* TODO: add your own code here */
fsp_err_t err = R_SCI_UART_Open( &g_uart9_ctrl, &g_uart9_cfg );
assert( FSP_SUCCESS == err );
while ( true )
printf( "Hello RA MCU \r\n" );
#if BSP_TZ_SECURE_BUILD
/* Enter non-secure code */
R_BSP_NonSecureEnter();
#endif
STEP14:添加头文件跟串口回调函数
STEP15:具体代码如下
#include "hal_data.h"
#include "stdio.h"
FSP_CPP_HEADER
void R_BSP_WarmStart( bsp_warm_start_event_t event );
FSP_CPP_FOOTER
uint8_t g_transfer_complete = 0;
void g_uart9_cb( uart_callback_args_t* p_args )
/* Handle the UART event */
switch ( p_args->event )
/* Received a character */
case UART_EVENT_RX_CHAR:
break;
/* Receive complete */
case UART_EVENT_RX_COMPLETE:
break;
/* Transmit complete */
case UART_EVENT_TX_COMPLETE:
g_transfer_complete = 1;
break;
default:
STEP16:添加打印接口重定向代码,具体如下
* Copyright 1998-2017 IAR Systems AB.
* This is a template implementation of the "__write" function used by
* the standard library. Replace it with a system-specific
* implementation.
* The "__write" function should output "size" number of bytes from
* "buffer" in some application-specific way. It should return the
* number of characters written, or _LLIO_ERROR on failure.
* If "buffer" is zero then __write should perform flushing of
* internal buffers, if any. In this case "handle" can be -1 to
* indicate that all handles should be flushed.
* The template implementation below assumes that the application
* provides the function "MyLowLevelPutchar". It should return the
* character written, or -1 on failure.
#include
#pragma module_name = "?__write"
int MyLowLevelPutchar(int x)
R_SCI_UART_Write(&g_uart9_ctrl, (uint8_t *)&x, 1);
while(g_transfer_complete == 0);
return x;
* If the __write implementation uses internal buffering, uncomment
* the following line to ensure that we are called with "buffer" as 0
* (i.e. flush) when the application terminates.
size_t __write(int handle, const unsigned char * buffer, size_t size)
/* Remove the #if #endif pair to enable the implementation */
#if 1
size_t nChars = 0;
if (buffer == 0)
* This means that we should flush internal buffers. Since we
* don't we just return. (Remember, "handle" == -1 means that all
* handles should be flushed.)
return 0;
/* This template only writes to "standard out" and "standard err",
* for all other file handles it returns failure. */
if (handle != _LLIO_STDOUT && handle != _LLIO_STDERR)
return _LLIO_ERROR;
for (/* Empty */; size != 0; --size)
if (MyLowLevelPutchar(*buffer++) < 0)
return _LLIO_ERROR;
++nChars;
return nChars;
#else
/* Always return error code when implementation is disabled. */
return _LLIO_ERROR;
#endif
4.工程配置
STEP17:工程配置
STEP18:弹出如下窗口
5.结果
STEP19:接上串口工具,打印如下
举报投诉
mcu
146文章
16707浏览量
348075
【GD32 MCU 入门教程】一、GD32 MCU 开发环境搭建(2)使用 IAR 开发 GD32
GD32系列为通用型MCU,所以开发环境也可以使用通用型的IDE,目前使用较多的是KEIL、IAR、 GCC和Embedded Builder,客户可以根据个人喜好来选择相应的开发环境。
芯海通用 MCU应用笔记 :在 IAR 及 MDK 开发环境下使用 printf 函数重定向移植差异指南
和调试中,printf 函数是常用的打印函数,通常通过 fputc 接口的重定向,即可以通过 printf 输出串口的信息。
但在 IAR8.x 下,需要一些 IDE 的额外配置,MCU
发表于 05-16 11:56
瑞萨电子RA家族推出RA8系列高算力通用MCU
瑞萨电子RA家族推出RA8系列高算力通用MCU,是业界首款基于Arm® Cortex®-M85(CM85)内核的32位MCU,主频高达480Mhz,超过3000 CoreMark跑分。
瑞萨电子推出全新RA MCU家族产品RA8
瑞萨电子推出的全新RA MCU家族产品RA8,是业界首款搭载Arm Cortex-M85内核超高性能MCU,可满足工业自动化、家电、智能家居、消费电子、楼宇/家庭自动化、医疗和AI领域
基于RASC的keil电子时钟制作(瑞萨RA)(2)----配置keil以及使用串口进行打印
本篇文章主要介绍了一种基于瑞萨RA系列微控制器的电子时钟制作方法,重点关注如何利用瑞萨RA Smart Configurator生成串口配置,以及在具体实践中如何对瑞萨RA2E1开发板
IAR为瑞萨RA8系列MCU开发提供支持
嵌入式开发软件和服务的全球领导者IAR今日宣布,其最新发布的IAR Embedded Workbench for Arm 9.40.2版本中无缝集成了对瑞萨(Renesas)RA8系列MCU
RA2L1移植SEGGER RTT日志打印功能
因为RA2L1开发板板载了JLINK-OB,那么我们完全可以通过SWD调试口去打印日志,从而不去用物理串口,这样不仅省了硬件串口资源占用,而且可以很快速的
