MXeval has been updated with some unique features once more. The workflow is now based on the latest trends in UX with its vertical and horizontal processes. The revised GUI also offers more space for the essentials – which are data and KPIs. The MXevalApp Manager opens a whole new world. Now you can check out MXevalApp licenses via QR code and download subjective questionnaires with your tablet. In the future, it finally will be possible to correlate objective and subjective data!
车辆动力学、自动驾驶辅助系统性能评估工具MXeval在新版本中又更新了一些独特功能。现在的工作流程已基于UX中最新的垂直与水平流程。修改后的GUI 还为数据和 KPI 等基本要素提供了更多空间。MXevalAppManager开启了一个全新的世界。 现在您可以通过二维码查看 MXevalApplicense,并可以使用平板电脑下载主观问卷。在未来,它将终于可以关联客观和主观数据!
GUI Redesign
GUI从新设计
The new GUI design offers a better overview by using a full window approach for each sub sections of the evaluation. It is also now aligned with the evaluation workflow which generally improved the overall usability of the GUI.
新的GUI设计通过为每个评估子集提供全窗口的方法来提供了更好的总览,,同时也提供了评估工作流来改进了GUI的整体实用性。
Projects Redesign
项目重新设计
The projects feature has been completed redesigned. It now stores all of the configurations and plot related settings. In combination with the included input data the project folder can now be shared and imported on any other computer without any loss of data or configurations.
项目功能现已被彻底重新设计。它现在可存储所有的配置和绘制相关的设置。在结合了导入数据后,项目文件夹现在可以被分享和导入到任何电脑且不会丢失任何数据或配置。
Lateral Guidance Library Renewed
横向引导库更新
The lateral guidance library has been completely renewed by restructuring redundant tests and removing obsolete ones. Also new tests have been added and are now structured with an orientation along NCAP and other standards.
横向引导库现在已彻底更新为重组冗余测试和移除过时测试。此外还增加了新的测试且现在结构是以NCAP和其他标准为导向的。
MXeval APP Manager
MXeval APP管理器
MXeval and MXeval APP are now combined. The new APP device registration feature allows to easily manage the APP registrations of a related license using a convenient QR code approach. MXeval now also handles theinstallation of the MXeval APP as well as the transfer of configuration and report data.
MXeval和MXeval APP现在已结合到一起了。现在新的APP设备注册功能可以通过便捷的二维码方式轻松处理APP注册。MXeval现在也可以处理MXeval APP的安装及配置和报告数据的转换。
Ground Truth Mapping for Lateral Guidance
横向引导的地面实况制图
The additional ground truth mapping addon for lateral guidance evaluation allows to easily benchmark external vehicles by just needing the GPS position. The vehicle trajectory can be placed on a high accurate road data which is then being postprocessed to deliver the relevant data channels for the evaluation.
用于横向引导评估的额外地面实况制图插件,只需提供GPS位置就可以轻松地对外部车辆进行基准评估。车辆的轨迹可以放在高精度的道路数据上,然后进行后处理来为评估提供相关数据通道。
自动驾驶
781文章
13442浏览量
165183
