APT32F110X 系列串口功能强大:可以完成STM32串口功能,驱动AT物联网模组不在话下。
资源串行通信接口:1 × I2C,3 x UART,1 x USART,1 x SPI,1 x SIO
通用异步收发器(UART)
3个通道
8位数据长度,支持校验位(奇偶校验,0/1校验)
单独的8x8位收发FIFO
可编程的波特率
同步异步收发器(USART)
- 1个通道
- 支持5、6、7和8位数据长度
- 单独的8x8位收发FIFO可编程的波特率
- 校验位,帧检测和缓存溢出错误报告
- 支持Loop-back模式
- 支持同步全双工模式
- 支持LIN总线协议:LIN1.2或者LIN2.0
- 支持智能卡协议:ISO7816-3兼容
编程实践:
时钟配置
void system_init(void)
CK_CPU_DISALLNORMALIRQ;
csi_iwdt_close();//close iwdt
csi_sysclk_config();//sysclk config
csi_get_sclk_freq();
csi_get_pclk_freq();
csi_tick_init();
csi_clk_calib();
CK_CPU_ENALLNORMALIRQ;
串口配置:115200波特率
__attribute__((weak)) void board_init(void)
//console config for print
console.uart_id = (uint32_t)CONSOLE_IDX;
console.baudrate = 115200U;
console.tx.pin = CONSOLE_TXD;
console.tx.func = CONSOLE_TXD_FUNC;
console.rx.pin = CONSOLE_RXD;
console.rx.func = CONSOLE_RXD_FUNC;
console.uart = (csp_uart_t *)(APB_UART0_BASE + CONSOLE_IDX * 0x1000);
console_init(&console);
#ifdef CONFIG_USER_PM//low power manage switch
if(csi_get_rst_reason() & RST_SRC_SNOOZE_WKUP)//wake up from snooze mode
g_tPmCore.wkup_frm_snooze = (void *)csi_ureg_read(USER_REG0);
if(g_tPmCore.wkup_frm_snooze)
g_tPmCore.wkup_frm_snooze();
else if(csi_get_rst_reason() & RST_SRC_SHD_WKUP)//wake up from shutdown mode
g_tPmCore.wkup_frm_shutdown = (void *)csi_ureg_read(USER_REG0);
if(g_tPmCore.wkup_frm_shutdown)
g_tPmCore.wkup_frm_shutdown();
#endif
花式打印表白啊,程序员哄女孩子的利器!!
先上图案:
代码实现很简单, printf打印就可以了:
int main()
//start_system();
system_init();
board_init();
csi_pin_set_mux(PB02, PB02_OUTPUT); //PA06 output
csi_pin_set_high(PB02); //PA06 output high;
int a[23][80] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,1,1,1,1,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,0,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2,2,2,2,2,0,0,0,0,0,2,2,2,2,2,2,2,2,0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,1,1,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2,2,2,2,2,2,0,0,0,0,2,2,2,2,2,2,2,2,2,0,0,2,2,2,2,2,2,2,2,2,2,0,0,0,1,1,1,1,1,1,1,1,0,0,1,1,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2,2,2,2,2,2,2,2,2,2,0,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,1,1,1,1,1,1,1,1,1,0,0,0,0,0,1,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,1,1,1,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,1,1,1,1,1,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,1,1,1,1,1,2,2,2,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,1,2,2,2,2,2,2,2,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1,1,1,1,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,0,0,0,0,0,0,0,0,0,3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,1,1,1,1,2,2,2,2,2,2,2,2,2,2,2,2,2,0,0,2,2,2,2,2,2,2,2,2,0,0,0,0,0,0,0,0,0,0,3,3,3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,1,1,1,1,1,0,0,0,0,0,0,2,2,2,2,2,2,2,2,2,0,0,0,0,0,0,2,2,2,2,0,0,0,0,3,3,3,0,0,3,3,3,0,3,3,3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,0,1,1,1,1,1,1,1,1,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,2,2,2,2,2,0,0,0,0,0,0,0,0,0,2,0,0,0,0,0,0,0,3,0,0,0,0,3,0,0,0,3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,1,1,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,3,3,3,0,0,3,0,0,3,3,3,0,0,3,0,0,0,3,0,0,3,3,3,3,0,0,3,0,0,0,0,3,0,0,0,3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3,0,0,0,3,0,3,0,0,0,3,0,0,3,0,3,0,0,3,3,0,0,3,3,0,3,0,0,0,0,3,0,0,0,3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3,0,0,0,3,0,3,0,0,0,3,0,0,3,0,3,0,0,3,3,3,3,3,3,0,3,0,0,0,0,3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3,0,0,0,3,0,3,0,0,0,3,0,0,0,3,0,0,0,3,3,0,0,0,0,0,3,0,0,0,0,3,0,0,0,3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3,3,3,0,0,3,0,0,3,3,3,0,0,0,0,3,0,0,0,0,0,3,3,3,0,0,0,3,3,3,3,0,0,0,3,3,3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
for(int i=0;i<23;i++)
for(int j=0;j<80;j++)
if(a[i][j] == 0)
my_printf(" ",a[i][j]);
else if(a[i][j] == 1)
my_printf("*",a[i][j]);
else if(a[i][j] == 2)
my_printf("o",a[i][j]);
else if(a[i][j] == 3)
my_printf("u",a[i][j]);
//my_printf("%d",a[i][j]);
my_printf("\n");
while(1)
//my_printf("Best wishes to every one\n"); //print message
mdelay(1000); //delay 100ms
csi_pin_toggle(PB02); //PA06 toggle
物联网
2919文章
45361浏览量
381360 -
开发板
25文章
5244浏览量
99502
再升级!爱普特微电子推出超高性价比全国产RISC核32位触控MCU——APT32F104X
爱普特微电子推出国产RISC核32位触控MCU—APT32F104X
爱普特微电子发布高性价比国产RISC核32位MCU
爱普特微电子推出超高性价比全国产RISC核32位MCU—APT32F004X
再升级!爱普特微电子推出超高性价比全国产RISC核32位MCU——APT32F104X
【敏矽微ME32G070开发板免费体验】使用JLINK的RTT功能实现类似串口printf打印功能
FacenetPytorch人脸识别方案--基于米尔全志T527开发板
【干货】有了这份HK32F407ZGT7开发板介绍,1万个项目轻松拿捏!
【北京迅为】《stm32mp157开发板嵌入式linux开发指南》第五章 Ubuntu使用apt-get下载
PY32F002A单片机开发板 PY32F002AF15P6开发板 32位MCU,M0+内核
爱普特微电子芯片封测基地项目签约
爱普特再推超高性价比全国产32位MCU—APT32F1025B
