什么是MEID号如何申请MEID,A0、A1、A2以及99开头的MEID号的区别?
英利检测 2023-04-05 06:00 次阅读
MEID/ESN号段ESN Manufacturer’s (MFR) Codes (ESN 厂家代码段) 主要适用于CDMA类的产品Mobile Equipment IDentifier(MEID)是全球唯一的56bit移动终端标识号需要向美国申请。标识号会被输入终端里,无法修改。可用来对移动式设备进行身份识别和跟踪。由于ESN号段是有限的资源,于2002年已耗尽,可能还有少量回收利用的号段,所以制定了56位的MEID号段,用来取代32位的ESN号段。形象的说,MAC/OUI码、MEID/ESN和IMEI号就如同我们身份证上的身份证号码,具有全球唯一性是相关产品必可少的号码,如果忽略使用或不使用MEID号会造成手机根本无法正常工作。而IMEI号在国内也叫TAC码是GSM技术的机身串号最终都是需要向英国申请。
号段类型:
u=716413959,1627198004&fm=173&app=25&f=JPEG?w=639&h=240&s=2C2874338FF054035CDC60CA0000E0B3
常见四类号码的差别
资料信息
企业信息方面,姓名、职位、公司、地址、城市、省份、邮编、国家、电话、邮件;产品信息方面,品名、型号、频段、制式、功能;
注意事项:
以上填写企业资料
必须
是企业域名邮箱,并且不能填写Info和Support等企业公用邮箱;
时间周期:
1~2wkds(你没有看错是一到两个工作日完成,是目前业内最为快捷的申请服务商,当然这个也受美国假期的影响)
附上MIED号关于定价的原文Fee Structure for Mobile Equipment Identifier (MEID) Manufacturer’s ID Code AssignmentsMEID Administrator (see below) is the ONLY Global Administrator for MEID Code AssignmentsSinglemode Hexadecimal (base 16) MEID
Each singlemode segmented hexadecimal (base 16) MEID Manufacturer’s ID Code block assigned iscapable of producing 1,048,576 units [“A1” block] or 65,536 units [“A2” block]. It may be used for one ormultiple models [without limitation] based on manufacturer and operator requirements.- The administrative fee for each
“A1”
singlemode segmented block of 1,048,576 is $8,500 USD.- The administrative fee for each
“A2”
singlemode segmented block of 65,536 is $1,200 USD.- The administrative fee for each singlemode test block of 2,048 units [for testing use only] is $300 USD.For larger manufacturers, there is also an “A0” singlemode FULL hexadecimal (base 16) MEIDManufacturer’s ID Code block assigned capable of producing 16,777,216 units [= 16 x 1,048,576].It may also be used for one or multiple models based on manufacturer and operator requirements.- The administrative fee for each
“A0”
FULL singlemode block [16,777,216] is $119,900 USD.
Multimode Decimal (base 10) MEID
Each multimode IMEI/MEID decimal (base 10) MEID Manufacturer’s ID Code block assigned is capable ofproducing 1,000,000 units for CDMA – GSM – W-CDMA – TD-SCDMA – LTE use.From mid-May 2015, the global IMEI database can only accept only one (1) Model Name per block of1,000,000. Each unique Model Name requires a separate IMEI/MEID Manufacturer’s ID Code block toensure proper global interoperability.- The administrative fee for each
“99”
multimode block of 1,000,000 is $4,499 USD.- The administrative fee for each multimode test block of 2,000 units [for testing use only] is $300 USD.
  • 终端
    纳祥科技NX6806,8位A/D和D/A转换器,国产替代PCF8591
    NX6806是一种单芯片、单电源、低功耗的8位CMOS数据采集设备,具有四个模拟输入、一个模拟输出和一个串行I2C总线接口。 三个地址引脚A0A1A2用于对硬件地址进行编程,允许
    的头像 发表于 02-05 17:25 63次阅读
    纳祥科技NX6806,8位<b class='flag-5'>A</b>/D和D/<b class='flag-5'>A</b>转换器,国产替代PCF8591
    DSP能不能读取到AD的CH A1通道采样数据?
    如果我只用ADS7864的一个通道输入(CH A0),HOLAB和HOLDC固定为高电平,那么引脚A2A1A0是不是都要接低电平?这样CH A
    发表于 01-15 07:21
    dsp28027 A0为采样口,不接入电路时,A0口的电压是多少?
    A0为采样口,不接入电路时,A0口的电压是多少,0或其他。还有参考电压为内部时,VREFLO要接地,那VREFLO是在芯片外部的那个地方
    发表于 01-14 07:40
    TLC1514 CFR寄存器的D7位不论写入的是0还是1,读CFR的时候D7位一直是1,什么原因?
    ,即A1口接地,只有A0,A2,A3三个模拟输入。现在虽然D7位显示为1,但是仍然可以采A1端口
    发表于 01-01 07:35
    闪极科技发布首款AI眼镜闪极A1
    科技携手索尼半导体、AAC瑞声科技、LOHO、云天励飞等多个领域的标杆厂商,共同为闪极A1注入了独特的魅力。这些合作伙伴在各自领域的深厚积累,为闪极A1在外观设计、佩戴舒适度以及功能实用性上提供了强有力的支持。 闪极
    的头像 发表于 12-20 10:22 937次阅读
    LM75B如何设定I2C的地址的呢?
    x48上可能有读数。 将A2与GND连接,在地址0x4C得不到数据,却在0x4F或是0x48上有数据。 这是什么问题导致的呢? 问题二: 在焊接好后
    发表于 12-05 07:48
    DAC7624的四路模拟输出是可以同时输出么,还是用A0A1控制信号来选择输出通道?
    各位工程师们好,关于DAC7624的使用我想咨询一下,DAC7624的四路模拟输出是可以同时输出么,还是用A0A1控制信号来选择输出通道?
    发表于 12-05 06:26
    A0A4的图框只要一个图纸模板就搞定了?
    “  图纸模板规范了图纸的尺寸大小,同时可以在标题栏显示与图纸相关的信息,如产品名称、版本、日期等。从标准化的角度考虑,公司通常会定义A0~A4的图纸模板,用于不同的设计场合。KiCad提供了一种
    的头像 发表于 11-13 18:13 642次阅读
    <b class='flag-5'>A0</b>到<b class='flag-5'>A</b>4的图框只要一个图纸模板就搞定了?
    MEID是什么?申请条件是什么?
    终端标识,可能是基于不同表述或版本产生的差异),用于设备的身份识别和跟踪。以下是英利检测收集的关于MEID的详细解释以及申请条件,供大家
    的头像 发表于 11-11 17:12 755次阅读
    <b class='flag-5'>MEID</b><b class='flag-5'>号</b>是什么?<b class='flag-5'>申请</b>条件是什么?
    INA226AA0A1引脚作为选址引脚在你们demo中同时接了上拉电阻至高电平和下拉电阻到地是为什么?
    您好,请问INA226AA0A1引脚作为选址引脚在你们demo中同时接了上拉电阻至高电平和下拉电阻到地是因为什么,这不是相当于不起作用吗?
    发表于 08-06 07:17
    INA226的地址设置,A0A1需要与I2C信号连接时,串个电阻方便地址可调节,电阻串多少欧姆的合适?
    INA226的地址设置,A0A1需要与I2C信号连接时,串个电阻方便地址可调节,电阻串多少欧姆的合适?直连还是串电阻更好?
    发表于 08-06 06:11
    24V交流接触器A1是正极还是负极
    的工作电压是24V交流电。这意味着,无论是A1还是A2(这两个通常是线圈的两个接线端子),它们都不区分正极或负极,因为交流电的特点是电流的方向会周期性改变。因此,在接线时,只需将线圈的两端(即A1
    的头像 发表于 07-24 09:50 3053次阅读
    CYUSB3017 A1 A0地址位(J5 H5)的作用是什么?
    我正在使用 16 位数据总线。 A1A0 地址位(J5H5)的作用是什么?
    发表于 07-24 07:36
    请问CYW43439A2和不带A2有什么不同?
    请问 CYW43439A2 和不带 A2 有什么不同? 如果 A2 意味着什么,那么是否有 A1A3 .... 等?
    发表于 05-21 06:50
    IMEI申请条件与申请周期指南
    在现代社会中,无线通信设备已经成为人们生活和工作的必备品,而IMEI则是每个设备的唯一标识符。然而,要想让您的设备在市场上合规上市,您需要了解IMEI申请条件以及
    的头像 发表于 04-22 17:18 847次阅读
    IMEI<b class='flag-5'>号</b><b class='flag-5'>申请</b>条件与<b class='flag-5'>申请</b>周期指南
