ARM+FPGA开发板的强劲图形系统体验——米尔基于NXP i.MX 8M Mini+Artix-7处理器的开发板
米尔电子 2023-04-03 18:06 次阅读
本篇测评由电子发烧友的优秀测评者“qinyunti”提供。
01.
MYD-JX8MMA7开发板简单介绍
MYD-JX8MMA7 拥有2个GPU核,一个用来做3D数据处理,另一个用来做2D和 3D加速。3D GPU核支持:
  • OpenGL ES 1.1,2.0
  • Open VG 1.1
  • 2D GPU核支持
  • 多图层混合
MYD-JX8MMA7开发板具备非常强的图形处理能力,板子自带了很多测试程序,我们就来跑一跑看看。
02.
板卡测试
GPU
cd /opt/imx-gpu-sdk/GLES2./Bloom/GLES2.Bloom_Wayland716f8ff6-d1fa-11ed-ad0d-dac502259ad0.jpg
./Blur/GLES2.Blur_Wayland719471d6-d1fa-11ed-ad0d-dac502259ad0.jpg
./EightLayerBlend/GLES2.EightLayerBlend_Wayland71c1c3a2-d1fa-11ed-ad0d-dac502259ad0.jpg
./FractalShader/GLES2.FractalShader_Wayland71d8b288-d1fa-11ed-ad0d-dac502259ad0.jpg./LineBuilder101/GLES2.LineBuilder101_Wayland7205a4dc-d1fa-11ed-ad0d-dac502259ad0.jpg./ModelLoaderBasics/GLES2.ModelLoaderBasics_Wayland7218c5ee-d1fa-11ed-ad0d-dac502259ad0.jpg
./ModelViewer/GLES2.ModelViewer_Wayland72336386-d1fa-11ed-ad0d-dac502259ad0.jpg
./S01_SimpleTriangle/GLES2.S01_SimpleTriangle_Wayland72336386-d1fa-11ed-ad0d-dac502259ad0.jpg
./S02_ColoredTriangle/GLES2.S02_ColoredTriangle_Wayland7281d264-d1fa-11ed-ad0d-dac502259ad0.jpg
./S03_Transform/GLES2.S03_Transform_Wayland72ac2f50-d1fa-11ed-ad0d-dac502259ad0.jpg
./S04_Projection/GLES2.S04_Projection_Wayland72cfd7ca-d1fa-11ed-ad0d-dac502259ad0.jpg
./S06_Texturing/GLES2.S06_Texturing_Wayland72f777d0-d1fa-11ed-ad0d-dac502259ad0.jpg
./S07_EnvMapping/GLES2.S07_EnvMapping_Wayland7327147c-d1fa-11ed-ad0d-dac502259ad0.jpg
./S08_EnvMappingRefraction/GLES2.S08_EnvMappingRefraction_Wayland734a0c2a-d1fa-11ed-ad0d-dac502259ad0.jpg
./S09_VIV_direct_texture/GLES2.S09_VIV_direct_texture_Wayland736fa566-d1fa-11ed-ad0d-dac502259ad0.jpg
./SdfFonts/GLES2.SdfFonts_Wayland73a4737c-d1fa-11ed-ad0d-dac502259ad0.jpg73d7b8fe-d1fa-11ed-ad0d-dac502259ad0.jpg
./Stats/GLES2.Stats_Wayland7410d512-d1fa-11ed-ad0d-dac502259ad0.jpg
./System/DFGraphicsBasic2D/GLES2.System.DFGraphicsBasic2D_Wayland7441e918-d1fa-11ed-ad0d-dac502259ad0.jpg
./System/DFNativeBatch2D/GLES2.System.DFNativeBatch2D_Wayland746fedb8-d1fa-11ed-ad0d-dac502259ad0.jpg ./System/DevBasicRender/GLES2.System.DevBasicRender_Wayland746fedb8-d1fa-11ed-ad0d-dac502259ad0.jpg
./System/DevNativeTexture2D/GLES2.System.DevNativeTexture2D_Wayland74bc45c8-d1fa-11ed-ad0d-dac502259ad0.jpg
./System/InputEvents/GLES2.System.InputEvents_Wayland74e26b54-d1fa-11ed-ad0d-dac502259ad0.jpg
./T3DStressTest/GLES2.T3DStressTest_Wayland74f56b78-d1fa-11ed-ad0d-dac502259ad0.jpg
./TextureCompression/GLES2.TextureCompression_Wayland7518d3a6-d1fa-11ed-ad0d-dac502259ad0.jpg
./UI/Benchmark/GLES2.UI.Benchmark_Wayland755be6c8-d1fa-11ed-ad0d-dac502259ad0.jpg
./UI/DpiScale/GLES2.UI.DpiScale_Wayland758585dc-d1fa-11ed-ad0d-dac502259ad0.jpg
./UI/PixelPerfect/GLES2.UI.PixelPerfect_Wayland75a7683c-d1fa-11ed-ad0d-dac502259ad0.jpg
./UI/SimpleUI100/GLES2.UI.SimpleUI100_Wayland75d1b4ca-d1fa-11ed-ad0d-dac502259ad0.jpg
./UI/SimpleUI101/GLES2.UI.SimpleUI101_Wayland760045ce-d1fa-11ed-ad0d-dac502259ad0.jpg
./UI/SmoothScroll/GLES2.UI.SmoothScroll_Wayland76383d08-d1fa-11ed-ad0d-dac502259ad0.jpg
./UI/ThemeBasicUI/GLES2.UI.ThemeBasicUI_Wayland7648e572-d1fa-11ed-ad0d-dac502259ad0.jpg
./VIVDirectTextureMultiSampling/GLES2.VIVDirectTextureMultiSampling_Wayland7677c1c6-d1fa-11ed-ad0d-dac502259ad0.jpg
glmark2
glmark2是开源的对OpenGL 2.0和 ES 2.0的基准测试程序,对GPU进行基准测试。glmark提供了一系列丰富的测试,涉及图形单元性能(缓冲,建筑,照明,纹理等)的不同方面,允许进行更全面和有意义的测试, 每次测试进行10秒,并且单独计算帧速率。
测试得分为252分。https://ubuntuforums.org/showthread.php?t=2131425 有一个对比数据测试得分如下:
root@myd-jx8mma7:/opt/imx-gpu-sdk/GLES2# glmark2-es2-wayland
EGL: Warning: No default display support on wayland
glmark2 2021.02
OpenGL Information
GL_VENDOR: Vivante Corporation
GL_RENDERER: Vivante GC7000NanoUltra
GL_VERSION: OpenGL ES 2.0 V6.4.3.p2.336687
[build] use-vbo=false: FPS: 610 FrameTime: 1.639 ms
[build] use-vbo=true: FPS: 688 FrameTime: 1.453 ms
[texture] texture-filter=nearest: FPS: 605 FrameTime: 1.653 ms
[texture] texture-filter=linear: FPS: 580 FrameTime: 1.724 ms
[texture] texture-filter=mipmap: FPS: 559 FrameTime: 1.789 ms
[shading] shading=gouraud: FPS: 430 FrameTime: 2.326 ms
[shading] shading=blinn-phong-inf: FPS: 291 FrameTime: 3.436 ms
[shading] shading=phong: FPS: 180 FrameTime: 5.556 ms
[shading] shading=cel: FPS: 136 FrameTime: 7.353 ms
[bump] bump-render=high-poly: FPS: 194 FrameTime: 5.155 ms
[bump] bump-render=normals: FPS: 437 FrameTime: 2.288 ms
[bump] bump-render=height: FPS: 352 FrameTime: 2.841 ms
[effect2d] kernel=0,1,0;1,-4,1;0,1,0;: FPS: 108 FrameTime: 9.259 ms
[effect2d] kernel=1,1,1,1,1;1,1,1,1,1;1,1,1,1,1;: FPS: 40 FrameTime: 25.000 ms
[pulsar] light=false:quads=5:texture=false: FPS: 401 FrameTime: 2.494 ms
[desktop] blur-radius=5:effect=blur:passes=1:separable=true:windows=4: FPS: 54 FrameTime: 18.519 ms
[desktop] effect=shadow:windows=4: FPS: 177 FrameTime: 5.650 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 80 FrameTime: 12.500 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=subdata: FPS: 80 FrameTime: 12.500 ms
[buffer] columns=200:interleave=true:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 97 FrameTime: 10.309 ms
[ideas] speed=duration: FPS: 202 FrameTime: 4.950 ms
[jellyfish] : FPS: 99 FrameTime: 10.101 ms
[terrain] : FPS: 1 FrameTime: 1000.000 ms
[shadow] : FPS: 152 FrameTime: 6.579 ms
[refract] : FPS: 28 FrameTime: 35.714 ms
[conditionals] fragment-steps=0:vertex-steps=0: FPS: 383 FrameTime: 2.611 ms
[conditionals] fragment-steps=5:vertex-steps=0: FPS: 115 FrameTime: 8.696 ms
[conditionals] fragment-steps=0:vertex-steps=5: FPS: 382 FrameTime: 2.618 ms
[function] fragment-complexity=low:fragment-steps=5: FPS: 223 FrameTime: 4.484 ms
[function] fragment-complexity=medium:fragment-steps=5: FPS: 97 FrameTime: 10.309 ms
[loop] fragment-loop=false:fragment-steps=5:vertex-steps=5: FPS: 216 FrameTime: 4.630 ms
[loop] fragment-steps=5:fragment-uniform=false:vertex-steps=5: FPS: 217 FrameTime: 4.608 ms
[loop] fragment-steps=5:fragment-uniform=true:vertex-steps=5: FPS: 121 FrameTime: 8.264 ms
glmark2 Score: 252
Opengl
cd /usr/share/examples/opengl/如下有一些测试程序,这里不再截图
root@myd-jx8mma7:/usr/share/examples/opengl# ls -al
total 68
drwxr-xr-x 15 root root 4096 Mar 9 2018 .
drwxr-xr-x 19 root root 4096 Mar 9 2018 ..
drwxr-xr-x 2 root root 4096 Mar 9 2018 2dpainting
-rw-r--r-- 1 root root 408 Mar 9 2018 README
drwxr-xr-x 2 root root 4096 Mar 9 2018 computegles31
drwxr-xr-x 2 root root 4096 Mar 9 2018 contextinfo
drwxr-xr-x 2 root root 4096 Mar 9 2018 cube
drwxr-xr-x 2 root root 4096 Mar 9 2018 hellogl2
drwxr-xr-x 2 root root 4096 Mar 9 2018 hellogles3
drwxr-xr-x 2 root root 4096 Mar 9 2018 hellowindow
drwxr-xr-x 10 root root 4096 Mar 9 2018 legacy
-rw-r--r-- 1 root root 415 Mar 9 2018 opengl.pro
drwxr-xr-x 2 root root 4096 Mar 9 2018 paintedwindow
drwxr-xr-x 2 root root 4096 Mar 9 2018 qopenglwidget
drwxr-xr-x 2 root root 4096 Mar 9 2018 qopenglwindow
drwxr-xr-x 3 root root 4096 Mar 9 2018 textures
drwxr-xr-x 2 root root 4096 Mar 9 2018 threadedqopenglwidget
Opengv
cd /opt/imx-gpu-sdk/OpenVG如下有一些测试程序,这里不再截图
root@myd-jx8mma7:/usr/share/examples/opengl# ls /opt/imx-gpu-sdk/OpenVG -al
total 40
drwxr-xr-x 10 root root 4096 Mar 9 2018 .
drwxr-xr-x 12 root root 4096 Mar 9 2018 ..
drwxr-xr-x 2 root root 4096 Mar 9 2018 BitmapFont
drwxr-xr-x 2 root root 4096 Mar 9 2018 CoverFlow
drwxr-xr-x 2 root root 4096 Mar 9 2018 Example1
drwxr-xr-x 2 root root 4096 Mar 9 2018 Example2
drwxr-xr-x 2 root root 4096 Mar 9 2018 Example3
drwxr-xr-x 2 root root 4096 Mar 9 2018 SimpleBench
drwxr-xr-x 3 root root 4096 Mar 9 2018 System
drwxr-xr-x 2 root root 4096 Mar 9 2018 VGStressTest
Qt
/usr/share/examples/widgets/touch/pinchzoom/pinchzoom
03.
测试总结
通过以上众多的测试程序可以看出MYD-JX8MMA7开发板的3D和2D图形性能非常不错,通过glmark2基准测试也可以和其他芯片进行对比,可以看到MYD-JX8MMA7开发板处理能力甚至媲美某些桌面级的芯片。所以本开发板也特别适合多媒体产品开发,具备比较强的图形处理能力。
  • FPGA
  • ARM
    ARM
  • 开发板
    正点原子fpga开发板不同型号
    处理器FPGA逻辑单元。ZYNQ-7000系列的开发板通常具备以下特点: 低成本 :适合预算有限的个人和教育机构。
    的头像 发表于 11-13 09:30 799次阅读
    ARM开发板FPGA的结合应用
    大的功能和更高的灵活性,满足各种复杂应用的需求。 二、ARM开发板FPGA的优势 高性能:ARM处理器具有高性能的特点,可以
    的头像 发表于 11-05 11:42 506次阅读
    ARM开发板与树莓派的比较
    处理器 ARM开发板通常采用不同的ARM处理器,如Cortex-A系列、Cortex-M系列等
    的头像 发表于 11-05 11:11 477次阅读
    i.MX Linux开发实战指南—基于野火i.MX系列开发板
    电子发烧友网站提供《i.MX Linux开发实战指南—基于野火i.MX系列开发板.pdf》资料免费下载
    发表于 10-10 17:23 11次下载
    198元,米尔NXP i.MX 93开发板,限购300套
    米尔NXPi.MX93开发板凭借其卓越的性能、强劲的推理能力以及丰富的接口资源,在众多行业应用中都得到了广泛认可,为回馈广大行业客户的支持与厚爱,进一步激发
    的头像 发表于 09-27 08:00 374次阅读
    198元,<b class='flag-5'>米尔</b><b class='flag-5'>NXP</b> <b class='flag-5'>i.MX</b> 93<b class='flag-5'>开发板</b>,限购300套
    使用TPS6521825和LP873347 PMIC为NXP i.MX 8M Mini和Nano供电
    电子发烧友网站提供《使用TPS6521825和LP873347 PMIC为NXP i.MX 8M Mini和Nano供电.pdf》资料免费下载
    发表于 09-13 09:42 0次下载
    使用TPS6521825和LP873347 PMIC为<b class='flag-5'>NXP</b> <b class='flag-5'>i.MX</b> <b class='flag-5'>8M</b> <b class='flag-5'>Mini</b>和Nano供电
    使用TPS6521815 PMIC为NXP i.MX 7处理器供电
    电子发烧友网站提供《使用TPS6521815 PMIC为NXP i.MX 7处理器供电.pdf》资料免费下载
    发表于 09-13 09:40 0次下载
    使用TPS6521815 PMIC为<b class='flag-5'>NXP</b> <b class='flag-5'>i.MX</b> <b class='flag-5'>7</b><b class='flag-5'>处理器</b>供电
    米尔基于NXP iMX.93开发板M33处理器应用开发笔记
    资源MYD-LMX9X开发板米尔基于NXPiMX.93开发板)3.软件资源Windows7及以上版本软件:IAREmbeddedWorkbench4.板载固件调试
    的头像 发表于 06-29 08:01 1389次阅读
    <b class='flag-5'>米尔</b>基于<b class='flag-5'>NXP</b> iMX.93<b class='flag-5'>开发板</b>的<b class='flag-5'>M</b>33<b class='flag-5'>处理器</b>应用<b class='flag-5'>开发</b>笔记
    点击参与米尔NXP i.MX 93开发板有奖试用
    米尔NXP合作发布的新品基于NXPi.MX93应用处理器的MYD-LMX9X开发板免费试用活动来啦~~
    的头像 发表于 06-13 08:02 552次阅读
    点击参与<b class='flag-5'>米尔</b><b class='flag-5'>NXP</b> <b class='flag-5'>i.MX</b> 93<b class='flag-5'>开发板</b>有奖试用
    米尔NXP i.MX 93开发板的Qt开发指南
    的 SDK 工具作为交叉编译系统,配合 QtCreator 快速开发图形类应用程序。 2. 硬件资源 米尔 NXP
    发表于 06-07 20:45
    1.概述Qt是一个跨平台的图形应用开发框架,被应用在不同尺寸设备和平台上,同时提供不同版权版本供用户选择。米尔NXPi.MX93开发板(MY
    的头像 发表于 06-07 08:01 1756次阅读
    <b class='flag-5'>米尔</b><b class='flag-5'>NXP</b> <b class='flag-5'>i.MX</b> 93<b class='flag-5'>开发板</b>的Qt<b class='flag-5'>开发</b>指南
    端午好礼丨米尔喊你抽奖啦!NXP i.MX开发板、吸尘、定制背包等你带回家
    喜迎端午节好礼相送!米尔联合NXP福利送~免费赠送i.MX开发板、吸尘、定制背包、京东购物卡快来参与,你就是锦鲤~一等奖(3名)
    的头像 发表于 06-07 08:01 473次阅读
    端午好礼丨<b class='flag-5'>米尔</b>喊你抽奖啦!<b class='flag-5'>NXP</b> <b class='flag-5'>i.MX</b><b class='flag-5'>开发板</b>、吸尘<b class='flag-5'>器</b>、定制背包等你带回家
    免费!NXP i.MX 93开发板有奖试用
    的头像 发表于 05-23 08:01 738次阅读
    免费!<b class='flag-5'>NXP</b> <b class='flag-5'>i.MX</b> 93<b class='flag-5'>开发板</b>有奖试用
    米尔NXP i.MX 93开发板限量6折!赋能入门级边缘处理市场
    NXP处理器板块耕耘多年,从早期的i.MX6→i.MX7i.MX8,再到最新的i.MX9都已
    的头像 发表于 04-29 08:01 579次阅读
    <b class='flag-5'>米尔</b><b class='flag-5'>NXP</b> <b class='flag-5'>i.MX</b> 93<b class='flag-5'>开发板</b>限量6折!赋能入门级边缘<b class='flag-5'>处理</b>市场
    重新定义入门级嵌入式处理器模组-米尔NXP i.MX 93核心
    近日,米尔电子推出基于NXP i.MX 93系列产品-MYC-LMX9X核心开发板NXP
    的头像 发表于 04-19 17:50 549次阅读
    重新定义入门级嵌入式<b class='flag-5'>处理器</b>模组-<b class='flag-5'>米尔</b><b class='flag-5'>NXP</b> <b class='flag-5'>i.MX</b> 93核心<b class='flag-5'>板</b>
