惠州亿纬动力电池有限公司(以下简称“亿纬动力”)成立于2021年2月5日,系上市公司惠州亿纬锂能股份有限公司下属子公司、亿纬动力香港有限公司全资子公司,是一家专注于发展高端锂电池的技术型企业。
惠州亿纬动力电池有限公司选购我司HS-DR-5导热系数测试仪,现已安装调试完毕。
部分使用HS-DR-5导热系数客户SCI论文
1、Hydrogel beads derived from chrome leather scraps for the preparation of lightweight gypsum
2、Size-controlled graphite nanoplatelets_ thermal conductivity enhancers for epoxy resin
3、Thermal, morphological, and mechanical characteristics of sustainable tannin bio-based foams reinforced with wood cellulosic fibers
4、Improved thermal conductivity of epoxy resin by graphene–nickel three-dimensional filler
5、A synergistic strategy for fabricating an ultralight and thermal insulating aramid nanofiber/polyimide aerogel
6、Fabrication of Graphene/TiO 2 /Paraffin Composite Phase Change Materials for Enhancement of Solar Energy Efficiency in Photocatalysis and Latent Heat Storage
7、Improved thermal conductivity of styrene acrylic resin with carbon nanotubes, graphene and boron nitride hybrid fillers
8、Preparation and characterization of paraffin/expanded graphite composite phase change materials with high thermal conductivity
9、Tailoring of bifunctional microencapsulated phase change materials with CdS/SiO2 double-layered shell for solar photocatalysis and solar thermal energy storage
10、Functional aerogels with sound absorption and thermal insulation derived from semi-liquefied waste bamboo and gelatin
11、Lamellar-structured phase change composites based on biomass-derived carbonaceous sheets and sodium acetate trihydrate for high-efficient solar photothermal energy harvest
12、Construction of double cross-linking PEG/h-BN@GO polymeric energy-storage composites with high structural stability and excellent thermal performances
13、Gelatin as green adhesive for the preparation of a multifunctional biobased cryogel derived from bamboo industrial waste
14、A novel self-thermoregulatory electrode material based on phosphorene-decorated phase-change microcapsules for supercapacitors
15、Development of poly(ethylene glycol)/silica phase-change microcapsules with well-defined core-shell structure for reliable and durable heat energy storage
16、Experimental and numerical study on heat emission characteristics of ventilated air annular in tunneling roadway
17、Construction of polyaniline/carbon nanotubes-functionalized phase-change microcapsules for thermal management application of supercapacitors
18、Mechanical, thermal and acoustical characteristics of composite board kneaded by leather fiber and semi-liquefied bamboo
19、Tuning the oxidation degree of graphite toward highly thermally conductive graphite/epoxy composites
20、Thermal self-regulatory smart biosensor based on horseradish peroxidase-immobilized phase-change microcapsules for enhancing detection of hazardous substances
21、Morphology-controlled synthesis of microencapsulated phase change materials with TiO2 shell for thermal energy harvesting and temperature regulation
22、Size-tunable CaCO3@n-eicosane phase-change microcapsules for thermal energy storage
23、High-Efficiency Preparation of Reduced Graphene Oxide by a Two-Step Reduction Method and Its Synergistic Enhancement of Thermally Conductive and Anticorrosive Performance for Epoxy Coatings
24、Temperature and pH dual-stimuli-responsive phase-change microcapsules for multipurpose applications in smart drug delivery
25、Development of Renewable Biomass-Derived Carbonaceous Aerogel/Mannitol Phase-Change Composites for High Thermal-Energy-Release Efficiency and Shape Stabilization
26、Immobilization of laccase on phase-change microcapsules as self-thermoregulatory enzyme carrier for biocatalytic enhancement
27、Microencapsulating n-docosane phase change material into CaCO3/Fe3O4 composites for high-efficient utilization of solar photothermal energy
28、Integration of Magnetic Phase-Change Microcapsules with Black Phosphorus Nanosheets for Efficient Harvest of Solar Photothermal Energy
29、Surface construction of Ni(OH)2 nanoflowers on phase-change microcapsules for enhancement of heat transfer and thermal response
30、Design and fabrication of bifunctional microcapsules for solar thermal energy storage and solar photocatalysis by encapsulating paraffin phase change material into cuprous oxide
31、Design and construction of mesoporous silica/n-eicosane phase-change nanocomposites for supercooling depression and heat transfer enhancement
32、Development of reversible and durable thermochromic phase-change microcapsules for real-time indication of thermal energy storage and management
33、Nanoflaky nickel-hydroxide-decorated phase-change microcapsules as smart electrode materials with thermal self-regulation function for supercapacitor application
34、Biodegradable wood plastic composites with phase change microcapsules of honeycomb-BN-layer for photothermal energy conversion and storage
35、Hierarchical microencapsulation of phase change material with carbon-nanotubes/polydopamine/silica shell for synergistic enhancement of solar photothermal conversion and storage
36、Molecularly Imprinted Phase-Change Microcapsule System for Bifunctional Applications in Waste Heat Recovery and Targeted Pollutant Removal
37、Pomegranate-like phase-change microcapsules based on multichambered TiO2 shell engulfing multiple n-docosane cores for enhancing heat transfer and leakage prevention
38、Innovative Integration of Phase-Change Microcapsules with Metal–Organic Frameworks into an Intelligent Biosensing System for Enhancing Dopamine Detection
39、Morphology-controlled fabrication of magnetic phase-change microcapsules for synchronous efficient recovery of wastewater and waste heat
40、Polyimide/phosphorene hybrid aerogel-based composite phase change materials for high-efficient solar energy capture and photothermal conversion
测试仪
6文章
3839浏览量
55413 -
电池
84文章
10767浏览量
132225
西北大学选购我司HS-DR-5导热系数测试仪
烟台先进材料与绿色制造山东省实验室选购我司HS-DR-5导热系数测试仪
