VICOR产品旗下BCM系列和VTM系列产品,具备空间紧凑,效率高的特点,
BCM系列产品选型如下:
Vicor 型号 | 输入电压 | 输出电压 | 功率 | 工作电流 | 规格 | |
BCM6123x60E10A5yzz | 36 – 60V | 6 – 10V | 1500W | 150A | ChiP | Digital / Analog |
BCM6123x60E15A3yzz | 9 – 15V | 1950W | 130A | 150A | ChiP | Digital / Analog |
BCM3814x60E10A5yzz | 6 – 10V | 1500W | 150A | VIA | Digital | |
BCM3814x60E15A3yzz | 9 – 15V | 1950W | 130A | VIA | Digital | |
BCM48Bx030x210A00 | 38 – 55V | 2.4 – 3.4V | 210W | 70A | Full | Analog |
VI Chip | ||||||
BCM48Bx040y200B00 | 3.2 – 4.6V | 200W | 50A | |||
BCM48Bx060y240A00 | 4.75 – 6.87V | 240W | 40A | |||
BCM48Bx080y240A00 | 6.34 – 9.16V | 30A | ||||
BCM48Bx096y240A00 | 7.6 – 11.0V | 25A | ||||
BCM48Bx120y300A00 | 9.5 – 13.8V | 300W | 25A | |||
BCM48Bx160y240A00 | 12.7 – 18.3V | 240W | 15A | |||
BCM48Bx240y300A00 | 19 – 27.5V | 300W | 12A | |||
BCM48Bx320y300A00 | 25.3 – 36.7V | 9A | ||||
BCM48Bx480y300A00 | 38.0 – 55V | 6A | ||||
BCM48Bx120y120B00 | 9.5 – 13.75V | 120W | 11.3A | Half VI Chip |
Vicor 型号 | 输入电压(V) | 输出电压 | 功率 | 工作电流(A) | 规格 |
VTM48EF012T130A00 | 26 – 55 | 0.65 – 1.37 | 130 | 32.5 x 22 x 6.73mm - Full | |
VTM48EF015T115A00 | 26 – 55 | 0.81 – 1.71 | 115 | 32.5 x 22 x 6.73mm - Full | |
VTM48EH015T050A00 | 26 – 55 | 0.81 – 1.72 | 50 | 22 x 16.5 x 6.73mm - Half | |
VTM48EF020T080A00 | 26 – 55 | 1.08 – 2.29 | 80 | 32.5 x 22 x 6.73mm - Full | |
VTM48EF030T070A00 | 26 – 55 | 1.63 – 3.44 | 70 | 32.5 x 22 x 6.73mm - Full | |
VTM48EF040T050B00 | 26 – 55 | 2.17 – 4.58 | 50 | 32.5 x 22 x 6.73mm - Full | |
VTM48EF040T050B0R | 26 – 55 | 2.17 – 4.58 | 50 | 32.5 x 22 x 6.73mm - Full | |
VTM48EH040T025B00 | 26 – 55 | 2.17 – 4.58 | 25 | 22 x 16.5 x 6.73mm - Half | |
VTM48EF060T040A00 | 26 – 55 | 3.25 – 6.88 | 40 | 32.5 x 22 x 6.73mm - Full | |
VTM48EF080T030A00 | 26 – 55 | 4.33 – 9.17 | 30 | 32.5 x 22 x 6.73mm - Full | |
VTM48EF096T025A00 | 32 – 55 | 6.40 – 11.00 | 25 | 32.5 x 22 x 6.73mm - Full | |
VTM48EF120T025A00 | 26 – 55 | 6.50 – 13.75 | 25 | 32.5 x 22 x 6.73mm - Full | |
VTM48EF120T025A0R | 26 – 55 | 6.50 – 13.75 | 25 | 32.5 x 22 x 6.73mm - Full | |
VTM48EH120T010B00 | 26 – 55 | 6.50 – 13.75 | 10 | 22 x 16.5 x 6.73mm - Half | |
VTM48EF160T015A00 | 26 – 55 | 8.67 – 18.33 | 15 | 32.5 x 22 x 6.73mm - Full | |
VTM48EF240T012A00 | 26 – 53 | 14.00 – 26.50 | 12 | 32.5 x 22 x 6.73mm - Full | |
VTM48EF320T009A00 | 26 – 55 | 17.33 – 36.67 | 9 | 32.5 x 22 x 6.73mm - Full | |
VTM48EF480T006A00 | 26 – 55 | 26.00 – 55.00 | 6 | 32.5 x 22 x 6.73mm - Full |
VICOR这2个系列的电源模块被推荐应用于紧凑空间的产品项目,可以提供大电流和大功率,但由于较多的客户反馈目前交期和价格很不理想。
这里给市场推荐的台达旗下Cyntec的M block 电源模块产品MPN541382-PV
这颗电源模块参数如下:
Model Name | Input | Output | Peak Eff | Others | ||
MPN541382-PV | 40~60V | 25A | 10~15V | 80A | 98.1% | Open frame |
10~15V | 90A | 40~60v | 20A |
可以支持正负2中接线方式,提供高达1000w负载功率,而封装体积仅2.8*17.3*7.7mm 。
Cnytec成立于1991年,主要研发、生产和销售高精度和高密度模块、传感器和应用领域功能模块。产品主要包含集成化电感、功率模块和高精度电阻器。普遍采用于移动设备、通信基站、机械设备等。
深圳市立维创展科技授权代理Cyntec全线产品,致力为客户提供高品质、高质量、价格公正的电源产品。目前,立维创展存有大批量Cyntec电源库存,例如型号:MUN12AD03-SEC,MUN3CAD03-SE等。产品原装原厂,质量保证,并为中国大陆市场提供技术支持,欢迎咨询。
审核编辑黄宇
电源
185文章
17870浏览量
252177 -
电源模块
32文章
1723浏览量
93240 -
BCM
12文章
121浏览量
53048 -
Vicor
4文章
198浏览量
58675 -
VTM
12浏览量
4207
设计基于VICOR电源模块的电源滤波器
![设计基于<b class='flag-5'>VICOR</b><b class='flag-5'>电源模块</b>的<b class='flag-5'>电源</b>滤波器](https://file1.elecfans.com/web3/M00/07/A0/wKgZO2eoEoyABTCzAAAqKF0ksNY987.png)
电源模块的使用方法 IN和OUT说明 SMP15-35W系列
Vicor电源模块助力电动汽车转型
![](https://file1.elecfans.com/web2/M00/09/EE/wKgZomcXGxqAc7VZAAUwJHLiqJs855.png)
Vicor发布三款全新车规级电源模块
Vicor 发布最高密度车规级电源模块,支持电动汽车实现 48V 电源系统
![<b class='flag-5'>Vicor</b> 发布最高密度车规级<b class='flag-5'>电源模块</b>,支持电动汽车实现 48V <b class='flag-5'>电源</b>系统](https://file1.elecfans.com/web1/M00/F3/23/wKgZoWcQslaAA-ecAAExcRCKEBs827.jpg)
使用Vicor高热效能电源模块实现紧凑的可扩展设计
常用的电源模块有哪些
宽电压输入稳压电源模块 E48_UHFCS-3W系列
![宽电压输入稳压<b class='flag-5'>电源模块</b> E48_UHFCS-3W<b class='flag-5'>系列</b>](https://file.elecfans.com/web2/M00/50/DA/pYYBAGLH6TyAB71EAAAPQ7KgtYA038.png)
非隔离电源模块PTV 12010系列数据手册
![非隔离<b class='flag-5'>电源模块</b>PTV 12010<b class='flag-5'>系列</b>数据手册](https://file.elecfans.com/web1/M00/D9/4E/pIYBAF_1ac2Ac0EEAABDkS1IP1s689.png)
