本文基于IDO-SBC3528主板演示Debian/Ubuntu 系统任何安装Docker,方法适用于RK3568全系列产品。
IDO-SBC3528-V1采用RK3568四核64位开发的智能主板,可作为RK3568开发评估板,支持8G大内存;支持PCIE2.0接口,可扩展大容量固态硬盘;支持双千兆以太网口;支持双频WiFi、蓝牙4.2以上,可扩展4G/5G网络通讯功能;具有丰富的视频输出接口(HDMI2.0/eDP1.3/MIPI1.2/LVDS) ;工业互联接口(RS232/RS485、CAN)。
支持Android11/Debian10/Ubuntu20/Buildroot/麒麟OS/开源鸿蒙等多种操作系统。
内核配置
使用check_config.sh脚本检查当前内核配置是否适配Docker
# ./check_config.sh ./kernel/.config info: reading kernel config from ./kernel/.config ... Generally Necessary: - cgroup hierarchy: properly mounted [/sys/fs/cgroup] - apparmor: enabled and tools installed - CONFIG_NAMESPACES: enabled - CONFIG_NET_NS: enabled - CONFIG_PID_NS: enabled - CONFIG_IPC_NS: enabled - CONFIG_UTS_NS: enabled - CONFIG_CGROUPS: enabled - CONFIG_CGROUP_CPUACCT: enabled - CONFIG_CGROUP_DEVICE: enabled - CONFIG_CGROUP_FREEZER: enabled - CONFIG_CGROUP_SCHED: enabled - CONFIG_CPUSETS: enabled - CONFIG_MEMCG: missing - CONFIG_KEYS: enabled - CONFIG_VETH: missing - CONFIG_BRIDGE: missing - CONFIG_BRIDGE_NETFILTER: missing - CONFIG_IP_NF_FILTER: missing - CONFIG_IP_NF_TARGET_MASQUERADE: missing - CONFIG_NETFILTER_XT_MATCH_ADDRTYPE: missing - CONFIG_NETFILTER_XT_MATCH_CONNTRACK: missing - CONFIG_NETFILTER_XT_MATCH_IPVS: missing - CONFIG_IP_NF_NAT: missing - CONFIG_NF_NAT: missing - CONFIG_POSIX_MQUEUE: missing Optional Features: - CONFIG_USER_NS: enabled - CONFIG_SECCOMP: enabled - CONFIG_SECCOMP_FILTER: enabled - CONFIG_CGROUP_PIDS: missing - CONFIG_MEMCG_SWAP: missing - CONFIG_MEMCG_SWAP_ENABLED: missing - CONFIG_BLK_CGROUP: missing - CONFIG_BLK_DEV_THROTTLING: missing - CONFIG_CGROUP_PERF: missing - CONFIG_CGROUP_HUGETLB: missing - CONFIG_NET_CLS_CGROUP: missing - CONFIG_CGROUP_NET_PRIO: missing - CONFIG_CFS_BANDWIDTH: enabled - CONFIG_FAIR_GROUP_SCHED: enabled - CONFIG_RT_GROUP_SCHED: missing - CONFIG_IP_NF_TARGET_REDIRECT: missing - CONFIG_IP_VS: missing - CONFIG_IP_VS_NFCT: missing - CONFIG_IP_VS_PROTO_TCP: missing - CONFIG_IP_VS_PROTO_UDP: missing - CONFIG_IP_VS_RR: missing - CONFIG_SECURITY_SELINUX: missing - CONFIG_SECURITY_APPARMOR: missing
./kernel/.config为当前内核的配置
提示"missing"的选项,需要到kernel目录进行make menuconfig加上,直到执行check_config.sh不再报missing项
内核配置完成后,需重新编译kernel并更新boot分区:
#./build.sh kernel安装Docker
主板上执行以下命令安装Docker:
linaro@linaro-alip:~$ sudo apt-getupdate linaro@linaro-alip:~$ curl -sSL https://get.docker.com/ | sudo sh
安装过程需要花费大约10分钟
安装完成后查看Docker版本:
linaro@linaro-alip:~$ docker -v Docker version 24.0.2, build cb74dfc linaro@linaro-alip:~$验证
linaro@linaro-alip:~$ sudo docker run hello-world Unable tofindimage 'hello-world:latest'locally latest:Pulling from library/hello-world 70f5ac315c5a:Pull complete Digest:sha256:a13ec89cdf897b3e551bd9f89d499db6ff3a7f44c5b9eb8bca40da20eb4ea1fa Status:Downloaded newer image forhello-world:latest [ 1228.015617] docker0: port 1(veth9b45dd3) entered blocking state [ 1228.015735] docker0: port 1(veth9b45dd3) entered disabled state [ 1228.017169] device veth9b45dd3 entered promiscuous mode [ 1228.027619] IPv6: ADDRCONF(NETDEV_UP): veth9b45dd3: link isnot ready [ 1228.343879] cgroup: cgroup: disabling cgroup2 socket matching due tonet_prio ornet_cls activation [ 1228.596774] eth0: renamed from vethc46e61e [ 1228.611961] IPv6: ADDRCONF(NETDEV_CHANGE): veth9b45dd3: link becomes ready [ 1228.612131] docker0: port 1(veth9b45dd3) entered blocking state [ 1228.612147] docker0: port 1(veth9b45dd3) entered forwarding state [ 1228.612346] IPv6: ADDRCONF(NETDEV_CHANGE): docker0: link becomes ready Hello from Docker! This message shows that your installation appears tobeworking correctly. To generate this message, Docker took the following steps: 1. The Docker client contacted the Docker daemon. 2. The Docker daemon pulled the "hello-world"image from the Docker Hub. (arm64v8) 3. The Docker daemon created anewcontainer from that image which runs the executablethat produces the output you are currently reading. 4. The Docker daemon streamed that output tothe Docker client, which sent it toyour terminal. To trysomething more ambitious, you can run anUbuntu container with: $ docker run -it ubuntu bash Share images, automate workflows, andmore with afree Docker ID: https://hub.docker.com/ For more examples andideas, visit: https://docs.docker.com/get-starte
提示"Hello from Docker!"说明Docker验证通过。
审核编辑:刘清
以太网
40文章
5426浏览量
171735 -
RS232接口
85浏览量
20548 -
Ubuntu系统
91浏览量
3943 -
RK3568
4文章
514浏览量
5054
原文标题:【技术分享】RK356X Debian/Ubuntu 系统安装Docker
文章出处:【微信号:industio,微信公众号:深圳触觉智能】欢迎添加关注!文章转载请注明出处。
