收到芒果派之后我看了一下这块板子的基本情况
拿到手以后尝试着使用HDMI连接到自己的便携显示器上面,发现这块板子是MINI HDMI,我的便携显示器也是MINI HDMI,然后就买了一条双mini hdmi口的线,现在是能连接上了。
其实我是想装一个FFmpeg到这块板子上的,但是官方提供的镜像似乎默认并不能直接用OpenMax跑,可是看datasheet上面介绍的还是挺全的。
2.4.1. Video Decoding • Supports video decoding up to 4K@60fps • Supports multi-formats: - H.265 Main10@L5.1 up to 4K@60fps, or 6K@30fps - VP9 Profile 2 up to 4K@60fps - AVS2 JiZhun 10bit Profile up to 4K@60fps - H.264 BP/MP/HP@L4.2 up to 4K@30fps - H.263 BP up to 1080p@60fps - MPEG-4 SP/ASP@L5 up to 1080p@60fps - MPEG-2 MP/HL up to 1080p@60fps - MPEG-1 MP/HL up to 1080p@60fps - Xvid up to 1080p@60fps - Sorenson Spark up to 1080p@60fps - VP8 up to 1080p@60fps - AVS/AVS+ JiZhun Profile up to 1080p@60fps - WMV9/VC1 SP/MP/AP up to 1080p@60 - JPEG HFIF file format up to 45MPPS 2.4.2. Video Encoding • H.264 BP/MP/HP • H.264 supports I/P frame, and only supports single reference frame • MJPEG/JPEG baseline • Maximum 16-megapixel(4096 x 4096) resolution for H.264 encoding • H.264 encoding capability: 4K@25fps • JPEG snapshot performance of 1080p@60fps independently • Supports the constant bit rate(CBR)/variable bit rate(VBR) bit rate control mode, ranging from 256kbit/s to 100Mbit/s • Encoding of eight regions of interest(ROIs)
看芯片是H616,是Allwinner的,那么他的Codec如果想要支持的,应该是可以考虑用 https://linux-sunxi.org/Sunxi-Cedrus 来支持。
但是配置sunxi-cedrus还是比较费劲的,所以可以先试试编译一个ffmpeg来感受一下。
只跑低分辨率的mpeg2的话问题不大,但是分辨率稍微高一些可能就不行了,其实主要还是得上H264的编码器,并且还是要用硬件编码器。
root@orangepizero2:/home/orangepi/build_ffmpeg# ./ffmpeg -hwaccels ffmpeg version N-111376-g13ef5025e3 Copyright (c) 2000-2023 the FFmpeg developers built with gcc 10 (Debian 10.2.1-6) configuration: libavutil 58. 14.100 / 58. 14.100 libavcodec 60. 22.100 / 60. 22.100 libavformat 60. 10.100 / 60. 10.100 libavdevice 60. 2.101 / 60. 2.101 libavfilter 9. 8.102 / 9. 8.102 libswscale 7. 3.100 / 7. 3.100 libswresample 4. 11.100 / 4. 11.100 Hardware acceleration methods: vdpau
看上去硬件加速器只有vdpau可以支持。
root@orangepizero2:/home/orangepi/build_ffmpeg# ifconfig enx00e04cb24f01: flags=4099< UP,BROADCAST,MULTICAST > mtu 1500 ether 00:e0:4c:b2:4f:01 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 eth0: flags=4099< UP,BROADCAST,MULTICAST > mtu 1500 ether 7e:5e:e0:76:44:18 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 33 lo: flags=73< UP,LOOPBACK,RUNNING > mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10< host > loop txqueuelen 1000 (Local Loopback) RX packets 18 bytes 1148 (1.1 KiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 18 bytes 1148 (1.1 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 wlan0: flags=4163< UP,BROADCAST,RUNNING,MULTICAST > mtu 1500 inet 192.168.3.18 netmask 255.255.255.0 broadcast 192.168.3.255 inet6 fe80::3031:1b37:2020:7f16 prefixlen 64 scopeid 0x20< link > ether 2c:d2:6b:44:0b:ee txqueuelen 1000 (Ethernet) RX packets 151313 bytes 201176906 (191.8 MiB) RX errors 0 dropped 731 overruns 0 frame 0 TX packets 89332 bytes 10280764 (9.8 MiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
开机第一件事肯定是希望能连上个网,然后用自己的高配电脑可以ssh登录到这块板子上,毕竟这块板子上跑界面还是比较慢的。
目前这块板子上的硬件视频编解码能力还有跑起来,allwinner的芯片好像硬件视频编解码器跑起来比较折腾,可能需要自己重新build一个镜像。这个过程比较漫长,我继续去build了。
芯片
449文章
48562浏览量
413040 -
嵌入式
5017文章
18489浏览量
293065 -
Linux
87文章
11030浏览量
207241 -
开发板
25文章
4599浏览量
95101 -
编译
628浏览量
32504 -
芒果派
11浏览量
53
