1.sort排序算法
sort(const _RanIt _First, const _RanIt _Last, _Pr _Pred) --默认为升序排序
形参:_First、_Last --容器的起始和结束迭代器
_Pred --排序规则,默认为从小到大
示例:
#include < iostream >
#include < vector >
#include < algorithm >
using namespace std;
class Print
public:
void operator()(int val)
cout < < val < < " ";
void test()
vector< int >vtr;
vtr.push_back(rand()%50);
vtr.push_back(rand() % 50);
for_each(vtr.begin(), vtr.end(), Print());
cout < < endl;
cout < < "升序排序:" < < endl;
sort(vtr.begin(), vtr.end());
cout < < endl;
cout < < "降序排序:" < < endl;
sort(vtr.begin(), vtr.end(), greater< int >());
cout < < endl;
int main()
test();
system("pause");
2.random_shuffle打乱顺序(洗牌)
打乱有序数列,重新洗牌:
void random_shuffle(_RanIt _First, _RanIt _Last);
形参:_First、_Last --起始和结束迭代器
#include < vector >
#include < map >
#include < ctime >
class Person
friend class Print;
public:
Person() {}
Person(string name, int age) :name(name), age(age) {
bool operator< (const Person p)const
if (age == p.age)
return name < p.name;
return age < p.age;
string name;
int age;
class Print
public:
void operator()(Person& p)
cout < < "姓名:" < < p.name < < "t年龄:" < < p.age < < endl;
void test()
vector< int >vtr;
vtr.resize(10);
for (int i = 0; i < 10; i++)
vtr[i] = i;
cout < < endl;
cout < < "洗牌后:" < < endl;
random_shuffle(vtr.begin(), vtr.end());
cout < < endl;
void test02()
cout < < "t自定义数据:" < < endl;
vector< Person >vtr;
vtr.push_back(Person("小王", 1));
vtr.push_back(Person("小王", 2));
vtr.push_back(Person("小王", 3));
vtr.push_back(Person("小李", 1));
vtr.push_back(Person("小李", 2));
class mapPrint
public:
void operator()(pair< Person, int >p)
cout < < "姓名:" < < (p.first).name < < "t年龄:" < < (p.first).age < < "t得分:" < < p.second < < endl;
int main()
srand(time(NULL));//random_shuffle底层需要随机数种子,否则每次生成结果一样
test();
test02();
system("pause");
3.merge合并容器
容器合并:
merge()实现吧两个容器合并在一起,存放到第三个容器中。
注意:merge()合并一定要保证容器元素有序,默认是从小到大的顺序。
merge(_InIt1 _First1, _InIt1 _Last1, _InIt2 _First2, _InIt2 _Last2, _OutIt _Dest) -->默认从小到大
merge(_InIt1 _First1, _InIt1 _Last1, _InIt2 _First2, _InIt2 _Last2, _OutIt _Dest, _Pr _Pred) -->重载版本,支持自定义排序规则
_First1、_Last1 --第一个容器的起始和结束迭代器
_Last2、_Dest --第二个元素的起始和结束迭代器
_Dest --要存储的新容器起始迭代器
_Pred --谓词,设定排序规则
谓词:
函数对象返回中为bool类;
函数对象形参只有一个 --> 一元谓词
函数对象形参有两个 --> 二元谓词
示例:
#include < vector >
#include < map >
class Print
public:
void test01()
vector< int >v1;
vector< int >v2;
for (int i = 0; i < 5; i++)
v1.push_back(i);
v2.push_back(2);
v2.push_back(16);
v2.push_back(12);
v2.push_back(14);
sort(v2.begin(), v2.end(), less< int >());
vector< int >v3;
v3.resize(v1.size() + v2.size());
cout < < "从小到大于有序合并:" < < endl;
merge(v1.begin(), v1.end(), v2.begin(), v2.end(), v3.begin());
for_each(v3.begin(), v3.end(), Print());
cout< ());
sort(v2.begin(), v2.end(), greater< int >());
merge(v1.begin(), v1.end(), v2.begin(), v2.end(), v3.begin(),greater< int >());
cout < < endl;
int main()
test01();
system("pause");
4.reverse元素反转
函数功能: 元素反转,将容器中的元素前后颠倒
reverse(const _BidIt _First, const _BidIt _Last)
#include < vector >
class Person
public:
Person() {}
Person(const Person& p)
this->age = p.age;
name = p.name;
bool operator< ( Person p)const
if (age == p.age)return name < p.name;
return age < p.age;
string name;
int age;
class Print
public:
void operator()(Person p)
void test()
vtr.push_back(Person("小王",18));
vtr.push_back(Person("小刘", 15));
vtr.push_back(Person("小林", 20));
cout < < "反转:" < < endl;
reverse(vtr.begin(), vtr.end());
int main()
test();
system("pause");
5.copy元素拷贝
_OutIt copy(_InIt _First, _InIt _Last, _OutIt _Dest)
形参:_First、_Last --原容器的起始和结束位置
_Dest --目标容器的起始位置
该函数功能类似于重载运算符=功能
#include < vector >
void test()
std::vector< std::string >vtr, vtr2;
vtr.push_back("C++");
vtr.push_back("copy算法");
vtr.push_back("学习");
vtr.push_back("案例");
std::cout < < "copy算法使用示例:" < < std::endl;
vtr2.resize(vtr.size());
copy(vtr.begin(), vtr.end(), vtr2.begin());//copy函数类似于赋值操作,vtr2=vtr1
for (std::vector< std::string >::iterator p = vtr2.begin(); p != vtr2.end(); p++)
std::cout < < *p < < " ";
std::cout < < std::endl;
int main()
test();
system("pause");
6.replace元素替换
元素替换
void replace(const _FwdIt _First, const _FwdIt _Last, const _Ty& _Oldval, const _Ty& _Newval)
形参:_First、_Last --要替换的数据区间
_Oldval --要替换的内容
_Newval --替换后的内容
#include < vector >
class Print
public:
void test()
vector< int >vtr;
vtr.push_back(10);
vtr.push_back(10);
vtr.push_back(30);
vtr.push_back(10);
vtr.push_back(35);
vtr.push_back(10);
cout < < "替换前:" < < endl;
cout < < endl;
cout < < "将10替换成666" < < endl;
replace(vtr.begin(), vtr.end(), 10, 666);
cout < < endl;
int main()
test();
system("pause");
7.条件替换replace_if
条件替换
replace_if(const _FwdIt _First, const _FwdIt _Last, _Pr _Pred, const _Ty& _Val)
形参:_First、_Last --要替换的区间
_Pred --谓词,替换条件
_Val --替换后的值
示例:
#include < vector >
#include < functional >
class Myreplace
public:
bool operator()(int val)
return val >= 30;
void test()
vector< int >vtr;
vtr.push_back(10);
vtr.push_back(10);
vtr.push_back(30);
vtr.push_back(10);
vtr.push_back(50);
vtr.push_back(10);
cout < < "将所有的 >=30的值替换为666" < < endl;
replace_if(vtr.begin(), vtr.end(), Myreplace(), 666);
for (vector< int >::iterator ptr = vtr.begin();ptr != vtr.end();ptr++)
cout < < *ptr < < " ";
cout < < endl;
int main()
test();
system("pause");
8.容器互换swap
容器元素互换:
swap(container v1,container v2);
将v1和v2的容器元素进行互换,类似于成员函数swap();
#include < vector >
class Print
public:
void test()
vector< int >vtr1 = { 10,20,30,50 };
vector< int >vtr2 = { 10,29,88 };
for_each(vtr1.begin(), vtr1.end(), Print());
cout < < endl;
for_each(vtr2.begin(), vtr2.end(), Print());
cout < < endl;
swap(vtr1, vtr2);
cout < < "替换结果:" < < endl;
cout < < endl;
cout < < endl;
int main()
test();
system("pause");
举报投诉
算法
23文章
4637浏览量
93542 -
C++
22文章
2114浏览量
73987 -
STL
86浏览量
18420
c语言入门知识之STL篇
这周终于可以给大家把STL方面的面试题总结出来了,突然发现它里面的细节非常多,只有你想不到的,没有它没有的。对于C++程序员来说,STL库里面的知识也是非常重要的,只要想在技术这条路线上有长远的发展,那么就一定要掌握它。不管是学
密码编码学(加密方法的C与C++实现) pdf第二版
密码编码学(加密方法的C与C++实现)分分三个部分。第一部分描述密码学中的常用算法和数论算法,以及这些算法的
发表于 09-25 09:49
•0次下载
C++ STL的概念及举例
本篇文章是作者本人使用STL 后的一些看法, 对於想要靠此文章学习STL, 是不可能的. 建议叁后面介绍的一些书入门.
STL的概念
在STL 中, 大至上分三个主要的
发表于 08-30 11:39
•1430次阅读
STL算法在GIS中的应用
使用STL 算法实现GIS 算法可以保证它的简洁和高效该文结合C++代码实例抽象出了地理算子的概念应用在GIS 算法当中通过定制适配器来消除
发表于 06-28 16:55
•33次下载
C++编程思想第二卷_刁成嘉译
本书介绍C++实用的编程技术和最佳的实践方法,深入探究了异常处理方法和异常安全设计;介绍C++的字符串、输入输出流、STL算法、容器和模板的现代用法,包括模板元编程;解释多重
发表于 10-21 17:01
•0次下载
C++课程资料详细资料合集包括了:面向对象程序设计与C++,算法,函数等
本文档的主要内容详细介绍的是C++课程资料资料合集包括了:面向对象程序设计与C++,算法,函数,概述, C++语言基础,构造数据类型,数据类型,C+
发表于 07-09 08:00
•18次下载
C++ STL基本概念是什么
STL,英文全称 standard template library,中文可译为标准模板库或者泛型库,其包含有大量的模板类和模板函数,是 C++ 提供的一个基础模板的集合,用于完成诸如输入/输出、数学计算等功能。
C++入门之通用算法
C++ 是一种强大的编程语言,它提供了许多通用算法,可以用于各种容器类型。这些算法是通过迭代器来操作容器中的元素,因此它们是通用的,可以用于不同类型的容器。在本篇博客中,我们将详细介绍 C++
