RK628是一款多功能视频桥接芯片,支持多种显示接口的转换。本文基于RK3568平台,分享使用RK628桥接芯片实现RGB信号转换为HDMI输出的适配过程。
IDO-SOM3568-V2采用 Rockchip 新一代 64 位处理器 RK3568(四核A55, 主频高达 2.0GHz, 22nm 工艺),集成双核心架构 GPU 以及高效能 NPU;最大支持 8GB 内存;内置独立的 NPU,32Bit位宽LPDDR4/LPDDR4x,频率最高可达1600MHz,支持全链路ECC ,支持Android 11,Ubuntu , Debian,OpenHamoney,麒麟OS等多种系统。
产品规格书:IDO-SOM3568-V2(金手指) 产品手册
硬件连接
RK628与RK3568的硬件连接,主要有以下几点:
24MHz时钟:给RK628提供时钟信号;
I2S:用于音频信号传输;
RGB:给RK628显示信号源;
其它GPIO:控制供电和复位。
添加驱动
本文调试使用的是RK的rk628-for-all v21驱动。将驱动补丁文件添加至 kernel/drivers/misc/rk628/ 目录。
在原有的驱动文件中添加
kernel/drivers/misc/Kconfig
source"drivers/misc/rk628/Kconfig"
kernel/drivers/misc/Makefile
obj-y += rk628/添加设备树配置
dts配置分显示和音频两部分,显示部分在i2c中添加rk628节点,并将其与rgb绑定;音频部分使用i2s通信,新增一路simple-audio-card。
/ { rk628_hdmi_sound: rk628-hdmi-sound { compatible = "simple-audio-card"; simple-audio-card,format = "i2s"; simple-audio-card,name = "rk628-hdmi-sound"; status = "okay"; simple-audio-card,cpu { sound-dai = <&i2s1_8ch>; }; simple-audio-card,codec { sound-dai = <&rk628>; }; }; }; &i2s1_8ch { status = "okay"; rockchip,clk-trcm = <1>; pinctrl-names = "default"; pinctrl-0= <&i2s1m1_sclktx &i2s1m1_lrcktx &i2s1m1_sdo0>; }; &i2c1 { status = "okay"; clock-frequency = <400000>; rk628: rk628@50{ compatible = "rockchip,rk628"; reg = <0x50>; pinctrl-names = "default"; interrupt-parent = <&gpio1>; interrupts =运行测试; enable-gpios = <&gpio3 RK_PD5 GPIO_ACTIVE_HIGH>; reset-gpios = <&gpio3 RK_PC4 GPIO_ACTIVE_LOW>; pinctrl-0= <&refclk_pins>; assigned-clocks = <&pmucru CLK_WIFI>; assigned-clock-rates = <24000000>; clocks = <&pmucru CLK_WIFI>; clock-names = "soc_24M"; #sound-dai-cells = <0>; rk628,rgb-in; rk628,hdmi-out; mode-sync-pol=<0>; status = "okay"; port { rgb_in_hdmi: endpoint { remote-endpoint = <&rgb_out_hdmi>; }; }; }; }; &rgb { status = "okay"; ports { port@1{ reg = <1>; rgb_out_hdmi: endpoint { remote-endpoint = <&rgb_in_hdmi>; }; }; }; }; &rgb_in_vp2 { status = "okay"; }; &route_rgb { status = "okay"; connect = <&vp2_out_rgb>; }; &pinctrl { refclk { /omit-if-no-ref/ refclk_pins: refclk-pins { rockchip,pins = /* refclk_ou */ <0 RK_PA0 1 &pcfg_pull_none>; }; }; }
修改驱动编译,更新内核后;插入HDMI显示器,正常的情况下可以成功显示
查看显示参数
cat /sys/kernel/debug/dri/0/summary
声卡注册情况如下,可通过播放音乐来测试HDMI是否有声音输出
问题排查
确认供电和复位时序是否正常
测量软件24MHz时钟信号是否正常输出
审核编辑:刘清
处理器
68文章
19276浏览量
229767 -
RGB
4文章
798浏览量
58494 -
HDMI接口
1文章
134浏览量
34050 -
GPIO
16文章
1204浏览量
52085 -
RK3568
4文章
514浏览量
5040
原文标题:【技术分享】RK3568适配RK628 RGB to HDMI
文章出处:【微信号:industio,微信公众号:深圳触觉智能】欢迎添加关注!文章转载请注明出处。
