数字电源软件中经常会用到低通滤波函数,如对AD采样数据或对上传监控数据的滤波等,那么本文首先介绍一阶低通滤波器的软硬件实现,最后给出dsPIC33C系列MCU 低通滤波器的代码实现给大家作为参考。
1. 模拟滤波器
import numpy as np
C = 220e-12
fc = 1000
R=1/(2np.piC*fc)
print("R =", R)
图 2 - RC低通滤波器Bode图
获得上面Bode图的Python代码如下:
import numpy as np
import matplotlib.pyplot as plt
import control as ctrl
s = ctrl.tf('s')
C = 220e-12
R = 750e3
fc = 1e3
Hp = 1/(1+(R*C)*s)
f = np.logspace(-1, 6, 1000)
w = 2 * np.pi * f
mag,phase,omega=ctrl.bode_plot(Hp,w,dB=True,Hz=True,deg=True,Plot=True,label='Hp')
plt.legend()
plt.show()
pole=ctrl.pole(Hp)
print("pole =", pole/(2*np.pi), "Hz")
2. 数字滤波器
import numpy as np
############ continuous s transfer function. ############
s = ctrl.tf('s')
fc = 1e3 # low pass filter cut-off frequency is 1kHz
t = 1/(2*np.pi*fc)
Hp = 1/(1+t*s)
w = 2 * np.pi * f
mag,phase,omega=ctrl.bode_plot(Hp,w,dB=True,Hz=True,deg=True,Plot=True, grid=True, label='Hp')
pole=ctrl.pole(Hp)
############ discrete z transfer function. ############
z = ctrl.tf('z')
fs = 100e3 # sample frequency is 100kHz, fc is still 1kHz
Ts = 1/fs
Hpd = (1+z**(-1))/((Ts+2*t)/Ts - (2*t-Ts)/Ts*z**(-1))
print(Hpd)
Hpd.dt = Ts
mag,phase,omega=ctrl.bode_plot(Hpd,w,dB=True,Hz=True,deg=True,Plot=True, grid=True, label='Hpd')
plt.legend()
plt.show()
公式(2)进一步转化为软件可实现的差分方程见公式(3)。
求得上面系数的Python代码如下:
import numpy as np
Ts = 1/fs
t = 1/(2*np.pi*fc)
Kxn = Ts/(Ts+2*t)
Kyn = (2*t-Ts)/(Ts+2*t)
print("Kxn =", Kxn, "Kyn=", Kyn)
由一阶低通滤波器的离散化差分方程 - 公式(3),可进行软件编码实现该滤波函数,dsPIC33C系列MCU的低通滤波函数参考代码如下。
#include "libq.h"
typedef struct{
/* Parameters */
int16_t Kxn;
int16_t Kyn;
int16_t xn;
int16_t yn;
}LPF_Obj;
int16_t LPF(int16_t x, LPF_Obj *L_obj)
int16_t y;
//y = Kxn * x + Kxn * xn + Kyn * yn
//yn = y;
//xn = x;
y = _Q15add(_Q15add(__builtin_mulss(L_obj- >Kxn,x) > >15, __builtin_mulss(L_obj- >Kxn,L_obj- >xn) > >15), __builtin_mulss(L_obj- >Kyn,L_obj- >yn) > >15);
L_obj- >yn = y;
L_obj- >xn = x;
return y;
为了调用定点Q格式数学函数,需要包含头文件libq.h,因此linker需要包含相应的库,生成连接属性-lq或-lq-dsp。操作如下图所示。
图 4 - 链接属性设置
最后若一阶低通滤波函数不能满足要求可以两个该一阶低通滤波器进行级联获得二阶滤波器的效果。
低通滤波器
14文章
471浏览量
47318 -
数字电源
28文章
510浏览量
109270 -
python
56文章
4781浏览量
84442 -
MCU芯片
3文章
246浏览量
11383 -
AD采样芯片
3浏览量
2252
