前言
有童鞋说在gcc下,vsnprintf来替代rt_vsnprintf来打印浮点会引发死机
经过实际验证,没有发现死机
但并不建议直接用vsnprintf来替代rt_vsnprintf,打印浮点多半用于调试,可以独立成一个专门的打印函数
vsnprintf只是用于把浮点格式化到字符串,只要字符串长度不溢出,理论上不会造成死机
如果发现死机,需要确认打印的环境,如中断中,尤其在串口输出的情况下
测试例程
RT-Thread Studio arm-none-eabi-gcc 环境:未发现死机现象
Keil MDK5 环境:未发现死机现象
cygwin gcc 环境:未发现死机现象
可以正常的用于浮点数的调试打印
Copyright (c) 2006-2018, RT-Thread Development Team
SPDX-License-Identifier: Apache-2.0
Change Logs:
Date Author Notes
2018-11-06 SummerGift change to new framework
#include
#include
#include
#include "drv_gpio.h"
/ defined the LED0 pin: PA5 /
#define LED0_PIN GET_PIN(A, 5)
#include
#define DBG_BUFF_MAX_LEN 256
/ debug print : support float double */
int dbg_printf(const char fmt, ...)
va_list args;
static char rt_log_buf[DBG_BUFF_MAX_LEN] = { 0 };
va_start(args, fmt);
int length = vsnprintf(rt_log_buf, sizeof(rt_log_buf) - 1, fmt, args);
rt_kputs(rt_log_buf);
return length;
int main(void)
double a = 334455.00123345;
double b = 667788.14234234;
dbg_printf("double a = %lfrn", a);
int count = 1;
/ set LED0 pin mode to output */
rt_pin_mode(LED0_PIN, PIN_MODE_OUTPUT);
while (count++)
rt_pin_write(LED0_PIN, PIN_HIGH);
dbg_printf("double a + b = %lfrn", a+b+count);
rt_thread_mdelay(1000);
rt_pin_write(LED0_PIN, PIN_LOW);
rt_thread_mdelay(2000);
return RT_EOK;
cygwin的测试
/ vsnprintf example /
include
include
/ debug print : support float double /
int dbg_printf(const char *fmt, …)
va_list args;
printf("%srn", rt_log_buf);
return length;
int main ()
double a = 123453.0001444;
dbg_printf(“%lf”, a);
return 0;
## 输出效果
```c
msh >
- RT - Thread Operating System
/ | 4.1.0 build Feb 3 2022 21:11:28
2006 - 2022 Copyright by RT-Thread team
double a + b = 1002245.143576
msh >double a + b = 1002246.143576
double a + b = 1002247.143576
double a + b = 1002248.143576
double a + b = 1002249.143576
double a + b = 1002250.143576
double a + b = 1002251.143576
double a + b = 1002252.143576
double a + b = 1002253.143576
double a + b = 1002254.143576
double a + b = 1002255.143576
double a + b = 1002256.143576
double a + b = 1002257.143576
double a + b = 1002258.143576
double a + b = 1002259.143576
double a + b = 1002260.143576
double a + b = 1002261.143576
cygwin的打印:
$ ./a.exe
123453.000144
小结
rt_kprintf,采用不依赖标准C库的方式,主要目的是为了减少ROM(Flash)的占用
如果实际中需要浮点打印(如打印到串口、打印到文件),可以基于vsnprintf编写一个简单的全功能格式打印函数
RT-Thread ulog可以开启浮点支持,开启后使用:vsnprintf
ROM
4文章
527浏览量
85141 -
串口输出
16浏览量
7437 -
RT-Thread
31文章
1197浏览量
39059 -
Flash单片机
111浏览量
9322 -
gcc编译器
78浏览量
3265
如何使用RT-Thread Studio来新建项目
如何使用RT-Thread kprintf去打印数字呢
在RT-Thread中如何将串口重定向到rt_kprintf()呢
怎样去解决RT-Thread浮点数打印的问题呢
rt_vsnprintf完整功能版本不支持打印某些格式?
rt_vsnprintf函数内部数组分配为什么不在栈内?
RT-Thread编程指南
RT-Thread开发,如何有效学习RT-Thread的五个步骤
![<b class='flag-5'>RT-Thread</b>开发,如何有效学习<b class='flag-5'>RT-Thread</b>的五个步骤](https://file1.elecfans.com//web2/M00/A6/D1/wKgZomUMQKSAAGYNAADF5bX7DBc399.png)
【RT-Thread开源作品秀】基于RT-Thread的星务平台研究
![【<b class='flag-5'>RT-Thread</b>开源作品秀】基于<b class='flag-5'>RT-Thread</b>的星务平台研究](https://file.elecfans.com/web1/M00/D9/4E/pIYBAF_1ac2Ac0EEAABDkS1IP1s689.png)
RT-Thread学习笔记 RT-Thread的架构概述
![<b class='flag-5'>RT-Thread</b>学习笔记 <b class='flag-5'>RT-Thread</b>的架构概述](https://file.elecfans.com/web2/M00/52/31/pYYBAGLKk5WAA__jAADjdAdXhIs410.jpg)
RT-Thread文档_RT-Thread 潘多拉 STM32L475 上手指南
![<b class='flag-5'>RT-Thread</b>文档_<b class='flag-5'>RT-Thread</b> 潘多拉 STM32L475 上手指南](https://file.elecfans.com/web1/M00/D9/4E/pIYBAF_1ac2Ac0EEAABDkS1IP1s689.png)
