fluxion创建AP卡住(5G)解决方法
jf_21653183 来源:jf_21653183 作者:jf_21653183 2023-08-02 11:59 次阅读
1、配置内核信道监管域
WiFi信道根据国家地区的不同,有着严格的频道划分,某些5G信道可以作为雷达探测使用,这意味着 如果有路由器工作在雷达探测保留信道,那么意味着你很可能不能在上边注入,解除认证,以及创建虚假克隆 AP。因此我们需要根据WiFi信道顺从表,修改内核监管域国家代码,以影响无线网卡工作频段,使其 能正常注入、解除认证、创建AP等
WLAN信道顺从表案例:https://www.docin.com/p-2253061296.html
编辑开机启动配置文件
# 编辑配置,使得每次开机将无线网卡工作频率
# 国家代码设置为CN(中国),特别推荐PA(巴拿马)可以避开雷达信道,解除认证5G杠杠的
╰─ vim /etc/rc.local
#!/bin/bash
# THIS FILE IS ADDED FOR COMPATIBILITY PURPOSES
# It is highly advisable to create own systemd services or udev rules
# to run scripts during boot instead of using this file.
# In contrast to previous versions due to parallel execution during boot
# this script will NOT be run after all other services.
# Please note that you must run 'chmod +x /etc/rc.d/rc.local' to ensure
# that this script will be executed during boot.
# set wlan frequency country code to PA/CN
iw reg set PA
exit 0
# 添加执行权限
╰─ chmod +x /etc/rc.local
复制
使配置生效
# 重启服务
╰─ systemctl restart rc-local.service
╰─ systemctl status rc-local.service
# 或者重启机器
╰─ reboot
复制
之后你会发现8812au将能够成功deauth解除认证所有5G信号
#配置完成后验证信道
#你应该能看到如下输出
#信道后边应该没有任何特殊标记
#说明我们可以在上边执行deauth与创建AP
╰─ iw list
Wiphy phy0
        Frequencies:
            * 2412 MHz [1] (20.0 dBm)
            * 2417 MHz [2] (20.0 dBm)
            * 2422 MHz [3] (20.0 dBm)
            * 2427 MHz [4] (20.0 dBm)
            * 2432 MHz [5] (20.0 dBm)
            * 2437 MHz [6] (20.0 dBm)
            * 2442 MHz [7] (20.0 dBm)
            * 2447 MHz [8] (20.0 dBm)
            * 2452 MHz [9] (20.0 dBm)
            * 2457 MHz [10] (20.0 dBm)
            * 2462 MHz [11] (20.0 dBm)
            * 2467 MHz [12] (20.0 dBm)
            * 2472 MHz [13] (20.0 dBm)
            * 2484 MHz [14] (20.0 dBm)
        Frequencies:
            * 5075 MHz [15] (30.0 dBm)
            * 5080 MHz [16] (30.0 dBm)
            * 5085 MHz [17] (30.0 dBm)
            * 5090 MHz [18] (30.0 dBm)
            * 5100 MHz [20] (30.0 dBm)
            * 5120 MHz [24] (30.0 dBm)
            * 5140 MHz [28] (30.0 dBm)
            * 5160 MHz [32] (30.0 dBm)
            * 5180 MHz [36] (30.0 dBm)
            * 5200 MHz [40] (30.0 dBm)
            * 5220 MHz [44] (30.0 dBm)
            * 5240 MHz [48] (30.0 dBm)
            * 5260 MHz [52] (30.0 dBm)
            * 5280 MHz [56] (30.0 dBm)
            * 5300 MHz [60] (30.0 dBm)
            * 5320 MHz [64] (30.0 dBm)
            * 5340 MHz [68] (30.0 dBm)
            * 5360 MHz [72] (30.0 dBm)
            * 5380 MHz [76] (30.0 dBm)
            * 5400 MHz [80] (30.0 dBm)
            * 5420 MHz [84] (30.0 dBm)
            * 5440 MHz [88] (30.0 dBm)
            * 5460 MHz [92] (30.0 dBm)
            * 5480 MHz [96] (30.0 dBm)
            * 5500 MHz [100] (30.0 dBm)
            * 5520 MHz [104] (30.0 dBm)
            * 5540 MHz [108] (30.0 dBm)
            * 5560 MHz [112] (30.0 dBm)
            * 5580 MHz [116] (30.0 dBm)
            * 5600 MHz [120] (30.0 dBm)
            * 5620 MHz [124] (30.0 dBm)
            * 5640 MHz [128] (30.0 dBm)
            * 5660 MHz [132] (30.0 dBm)
            * 5680 MHz [136] (30.0 dBm)
            * 5700 MHz [140] (30.0 dBm)
            * 5720 MHz [144] (30.0 dBm)
            * 5745 MHz [149] (30.0 dBm)
            * 5765 MHz [153] (30.0 dBm)
            * 5785 MHz [157] (30.0 dBm)
            * 5805 MHz [161] (30.0 dBm)
            * 5825 MHz [165] (30.0 dBm)
            * 5845 MHz [169] (30.0 dBm)
            * 5865 MHz [173] (30.0 dBm)
            * 5885 MHz [177] (30.0 dBm)
复制
2、配置fluxion以修复5Ghz创建AP
配置fluxion以支持创建5G频段的AP
#编辑ap脚本文件
╰─ cat 桌面/fluxion-fix-for-5Ghz/lib/ap/hostapd.sh
function ap_service_prep() {
  if [ ${#@} -lt 5 ]; then return 1; fi
  APServiceInterface=$1
  APServiceInterfaceAddress=$2
  APServiceSSID=$3
  APServiceMAC=$4
  APServiceChannel=$5
  ap_service_stop
  # Prepare the hostapd config file.
  country_code="$(iw reg get | awk 'FNR == 2 {print $2}' | cut -f 1 -d ":" 2> /dev/null)"
  [[ ! ${country_code} =~ ^[A-Z]{2}$ ]] && country_code="00"
  rm -rf "$APServiceConfigDirectory/$APServiceMAC-hostapd.conf" > /dev/null 2>&1
  echo "
interface=$APServiceInterface
driver=nl80211
ssid=$APServiceSSID
channel=$APServiceChannel"
  if [[ ${APServiceChannel} -gt 14 ]];then
      echo -e "hw_mode=a"
      } >> "$APServiceConfigDirectory/$APServiceMAC-hostapd.conf"
  else
      echo -e "hw_mode=g"
  fi
  if [[ "${country_code}" != "00" ]];then
      echo -e "country_code=${country_code}"
  fi
复制
添加如下代码
之后,你会发现fluxion将会正常创建5G频段的AP,不会卡住
  • AP
    AP
  • WIFI
  • 5G
    5G
    [5.7.2]--5G关键技术和应用场景#硬声创作季 #5G
    5G5G网络
    学习电子知识
    发布于 :2022年11月02日 20:37:56
    5G是什么?5G到底什么时候来?
    `我国5G推进组6月1日在第一届全球5G大会上正式发布了《5G网络架构设计》白皮书,这体现了我国5G网络技术研究的最新成果,这意味着我国从5G
    发表于 06-14 17:02
    什么是5G NR?
    在聆听在纽约大学Tandon工学院举行的布鲁克林5G高峰论坛上的许多优秀的技术5G演示,今年由纽约大学无线和诺基亚共同主办,听说了5G NR这个术语。对于那些不熟悉5G NR的人来说,
    发表于 05-03 11:34
    5G为什么叫5G
    `本文转载于网优雇佣军,本文作者: 蜉蝣采采。众说周知,3GPP 5G的Logo已经近一年前在出炉,这也坐实了的5G标准的名称:5G标准的大名就叫5G,就是这么直白,就是这么任性。要知
    发表于 01-20 12:36
    中国5G海外工程屡屡触礁,5G实力得到肯定
    进度,心平气和地与他国沟通与商洽,以合作共赢的态度去维护彼此之间的关系,才是5G战役下对双方都有利的解决方法。`
    发表于 08-27 16:59
    怎么在5G测试wifi性能
    我使用控制台项目来测试两个CYW43907 EVKS中的WiFi性能。一个是AP,另一个是STA。如果我想在AP和STA之间进行5G的测试,我应该设置命令吗?我猜想,在StaseTap AP
    发表于 11-27 11:17
    什么是5G天线及射频?
    5G基站投资占网络总投资约60%,并预期5G基站数量为4G基站约1.5倍:5G 产业链投资跨度长,主要包括网络规划,无线侧、传输网、核心网和网络建设运维等环节。当中,参考2017年4
    发表于 09-17 08:02
    人人都在聊5G5G真的安全吗?
    `` 5G诞生之初就万众瞩目,2019年世界各国围绕5G的争夺日益的白热化,2020年,全球正奔向5G! 随着5G商用发牌,我国已正式进入5G
    发表于 01-02 19:27
    5G工业网关与5G工业路由器优势对比
    一、5G特点  5G网络的峰值速度比4G高出20倍。新的编码技术、超密集组网、高带宽、高速率、低时延,5G应用将深刻地影响娱乐、制造、汽车、能源、医疗、交通、教育、养老等各个行业。目前
    发表于 08-06 17:29
    5G工业网关和5G工业路由器对比分析
    `“5G网络比较现在4G网络,5G网络的峰值速度比4G高出20倍。新的编码技术、超密集组网、高带宽、高速率、低时延,5G应用将深刻地影响娱乐
    发表于 09-01 16:48
    5G学习笔记相关资料分享
    第一节 5G网络架构概述第二节 5G核心架构与部署第三节 5G接入网架构与部署第零章大唐5G产品与解决方法第三章 物理层过程第一节 物理层概
    发表于 07-01 07:12
    5G智能网关WIFI功能的测试
    功能的测试。关于FCU2303(5G智能网关3.0)如果想将4G/5G模块的流量通过以太网或者wifi AP模式分享出去的方式在《5G智能网
    发表于 12-23 07:30
    5G智能网关WIFI功能的测试
    AP模式分享出去的方式在《5G智能网关功能测试第一章4G/5G 上网测试》中已经有所设计,此章节就不在赘述。转存失败重新上传取消...
    发表于 12-23 06:15
    AP6356S的5G传输速率偏低怎么解决?
    发表于 03-02 10:50
    5G 器件的设计与开发: 5G 性能范围
    关键。5G 网络使用波束形成使信号传输最大化,在波束形成中,发射机和接收机之间传递形状指向的信号。同样重要的是保持在5g 市场的竞争力是模块的有效转换模拟数字和确定什么连接器和互连方法工作最好的高频率
    发表于 04-10 21:31
