【NuMaker-M2354试用】microSD实验
冬至配饺子 来源:sixer 作者:sixer 2023-08-02 17:18 次阅读
1.测评任务
​ 测试M2354的硬件RTC,开启RTC功能,运用RT-Thread提供的bsp及库函数,实现一个RTC功能。
​ 实现功能:初始化RTC时间,通过控制台每秒打印一次时间。
2.测评硬件
​ 本次使用的硬件是Nuvoton官方的NuMaker-M2354开发板
mcu型号:M2354KJFAE
​ 内核:cortex-M23
3.环境搭建及工程创建
在bsp->nuvoton->numaker-m2354 下应用env工具进行配置
​ 配置完成后,保存退出使用命令 scons --target=mdk5 生成 keil 工程,打开工程编译下载
4.下载运行
​ 插入sd卡,复位后,控制台打印如下:
RT - Thread Operating System
/ | 4.0.4 build Dec 19 2021 23:03:10
2006 - 2021 Copyright by rt-thread team
[I/I2C] I2C bus [i2c1] registered
[I/slcd] Working frame rate is 64Hz on Type-A.
[I/sal.skt] Socket Abstraction Layer initialize success.
[I/utest] utest is initialize success.
[I/utest] total utest testcase num: (0)
[I/at.clnt] AT client(V1.3.1) on device uart4 initialize success.
[D/FAL] (fal_flash_init:63) Flash device | OnChip_APROM | addr: 0x00000000 | len: 0x00100000 | blk_size: 0x00000800 |initialized finish.
[D/FAL] (fal_flash_init:63) Flash device | OnChip_LDROM | addr: 0x00100000 | len: 0x00104000 | blk_size: 0x00000800 |initialized finish.
[I/FAL] ==================== FAL partition table ====================
[I/FAL] | name | flash_dev | offset | length |
[I/FAL] -------------------------------------------------------------
[I/FAL] | ldrom | OnChip_LDROM | 0x00000000 | 0x00001000 |
[I/FAL] | aprom | OnChip_APROM | 0x000f0000 | 0x00010000 |
[I/FAL] =============================================================
[I/FAL] RT-Thread Flash Abstraction Layer (V0.5.0) initialize success.
[I/dancemouse] Ready.
msh />Failed to mount sdh0 on /
[I/at.dev.esp] esp0 device wifi is disconnect.
[E/at.clnt] execute command (AT+CWJAP="NT_ZY_BUFFALO","12345678") failed!
[W/at.dev.esp] esp0 device wifi connect failed, check ssid(NT_ZY_BUFFALO) and password(12345678).
[I/at.dev.esp] esp0 device network initialize successfully.
5.实验现象
microSD挂载失败,不知所以然,试了好多配置,留着之后再做研究,另外使用nuvoton的bsp里的例程,可以正确读取扇区,说明硬件没有问题的,另外看了论坛上有一个相同microSD任务的配置了就可以。看他git的工程没有上传成功。很诧异。
  • RTC
    RTC
  • microSD卡
  • RT-Thread
  • Cortex-M23
    NuMaker-M2354开发板试用资料汇总
    转 TTL 2.测试任务 本次测试任务为 NuMaker-M2354 USCI 模块今天抽空驱动了收拾的一款兼容 UNO 接口的 SPI 屏幕~LCD 分辨率 240X320,驱动芯片
    发表于 03-16 15:27
    基于NuMaker-2354开发板的UART1与GPIO测评资料推荐
    1、NuMaker-M2354 UART1测评测试任务本次NuMaker-M2354试用的任务为UART,第一次接触新塘的开发板,发现新塘的芯片功能还是很强大的,由于时间关系我只简单测试一下UART
    发表于 06-14 17:18
    NuMaker-M2354开发板的正交编码器QEI模块进行测试
    任务为新唐 NuMaker-M2354正交编码器QEI模块3.资源介绍翻阅新唐M2354数据手册查看新唐开发板原理图及数据手册,PD10、PD11、PD12空闲,配置为QEI0_B、QEI0_A
    发表于 06-29 11:23
    一文解析SPI外设驱动W25Q128
    1、NuMaker-M2354试用之SPI 驱动W25Q128功能模块的硬件介绍开发版本身没有spi外设,没办法需要焊接或者连接spi外设。经过芯片文档查询M2354由四组spi总线0-3随机定使用SPI1 芯片手册、开发板用户
    发表于 08-19 14:51
    NuMaker-M2354开发板之CRYPTO硬件密码加速器测评
    1、【NuMaker-M2354试用M2354测评_CRYPTO  本次的任务是CRYPTO, 就是硬件密码加速器(Cryptographic Accelerator) 。  对应
    发表于 10-20 14:19
    NuMaker-M2354开发板之ECAP详解
    1、【NuMaker-M2354试用】ECAP测试分享  ECAP详解  ECAP既外部脉冲捕获功能,M2354提供了两个输入捕获计时器单元有三个输入捕获通道,可以用来测量脉冲宽度或者测量频率。根据
    发表于 10-20 14:40
    NuMaker-M2354 ADC测试分享
    文件夹下除了libraries和numaker-m2354其它都删除了,再然后将libraries下除了m2354和nu_packages以外的都删了。再然后回到numaker-m2354文件夹开始使用
    发表于 10-20 14:46
    基于NuMaker-M2354板的adc测试分享
    1、NuMaker-M2354的adc测试分享  模拟数字转换器即A/D转换器,或简称ADC,通常是指一个将模拟信号转变为数字信号的电子元件。通常的模数转换器是将一个输入电压信号转换为一个输出
    发表于 12-22 17:35
    基于NuMaker-M2354板的CAN总线通信功能评测
    、功能模块的硬件介绍使用了TJA1050作为CAN收发器,具体硬件介绍详见我的另一篇文章【NuMaker-M2354试用】CAN总线开发与测试分享【硬件篇】硬件连接如下图所示:目前,RTT中未开启CAN功能
    发表于 12-29 17:39
    NuMaker-IoT-M2354用户手册
    发表于 11-08 19:27 0次下载
    <b class='flag-5'>NuMaker-IoT-M2354</b>用户手册
    NuMaker-IoT-M2354原理图、PCB和Gerber文件
    <b class='flag-5'>NuMaker-IoT-M2354</b>原理图、PCB和Gerber文件
    NuMaker-M2354用户手册
    NuMaker-M2354用户手册
    发表于 11-08 19:27 1次下载
    <b class='flag-5'>NuMaker-M2354</b>用户手册
    NuMaker-M2354原理图、PCB和Gerber文件
    发表于 11-08 19:27 2次下载
    <b class='flag-5'>NuMaker-M2354</b>原理图、PCB和Gerber文件
    NuMaker-M2354试用】spi测试分享
    SPI是串行外设接口(Serial Peripheral Interface)的缩写,是一种高速的,全双工,同步的通信总线
    发表于 08-02 17:28 687次阅读
    【<b class='flag-5'>NuMaker-M2354</b><b class='flag-5'>试用</b>】spi测试分享
    新唐最新物联网安全开发平台NuMaker-IoT-M2354,保护您的物联网创新服务与设计
    的头像 发表于 08-09 15:24 713次阅读
    新唐最新物联网安全开发平台<b class='flag-5'>NuMaker-IoT-M2354</b>,保护您的物联网创新服务与设计
