1、实验环境
RT-Thread 4.03
STM32F407VET6
STM3F4库版本 0.2.2
在SDK资源管理器中可以查看版本信息如下图。(小编遇见过因版本不兼容出现的编译错误问题)
2、创建RT-Thread项目
此时编译结果没有错误
打开CubeMX软件(不使用CubeMX Setting)step1:配置时钟。step2、配置ADC+DMA。
根据自己板子晶振确定时钟
根据ADC引脚配置
配置ADC1通道
配置DMA
ADC参数设置
生成项目
在RTT中如图文件夹下新建源文件
从CubeMX生成的工程中复制如下图函数到RTT文件中;具体代码有所修改,可参考代码部分
参考代码
#include "stm32f4xx_hal.h"
ADC_HandleTypeDef hadc1;
DMA_HandleTypeDef hdma_adc1;
static void MX_DMA_Init(void)
/* DMA controller clock enable /
__HAL_RCC_DMA2_CLK_ENABLE();
/ DMA interrupt init /
/ DMA2_Stream0_IRQn interrupt configuration /
HAL_NVIC_SetPriority(DMA2_Stream0_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(DMA2_Stream0_IRQn);
void HAL_ADC_MspInit(ADC_HandleTypeDef hadc)
GPIO_InitTypeDef GPIO_InitStruct = {0};
MX_DMA_Init();
if(hadc->Instance==ADC1)
/* USER CODE BEGIN ADC1_MspInit 0 /
/ USER CODE END ADC1_MspInit 0 /
/ Peripheral clock enable /
__HAL_RCC_ADC1_CLK_ENABLE();
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
/ADC1 GPIO Configuration
PC0 ------> ADC1_IN10
PC1 ------> ADC1_IN11
PC2 ------> ADC1_IN12
PC3 ------> ADC1_IN13
PA0-WKUP ------> ADC1_IN0
PA1 ------> ADC1_IN1
GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3;
GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
GPIO_InitStruct.Pull = GPIO_NOPULL;
HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
/ ADC1 DMA Init /
/ ADC1 Init /
hdma_adc1.Instance = DMA2_Stream0;
hdma_adc1.Init.Channel = DMA_CHANNEL_0;
hdma_adc1.Init.Direction = DMA_PERIPH_TO_MEMORY;
hdma_adc1.Init.PeriphInc = DMA_PINC_DISABLE;
hdma_adc1.Init.MemInc = DMA_MINC_ENABLE;
hdma_adc1.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
hdma_adc1.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
hdma_adc1.Init.Mode = DMA_CIRCULAR;
hdma_adc1.Init.Priority = DMA_PRIORITY_LOW;
hdma_adc1.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
HAL_DMA_Init(&hdma_adc1);
__HAL_LINKDMA(hadc,DMA_Handle,hdma_adc1);
/ USER CODE BEGIN ADC1_MspInit 1 /
/ USER CODE END ADC1_MspInit 1 /
void MX_ADC1_Init(void)
/ USER CODE BEGIN ADC1_Init 0 /
/ USER CODE END ADC1_Init 0 /
ADC_ChannelConfTypeDef sConfig = {0};
/ USER CODE BEGIN ADC1_Init 1 /
/ USER CODE END ADC1_Init 1 /
/ Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
hadc1.Instance = ADC1;
hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV8;
hadc1.Init.Resolution = ADC_RESOLUTION_12B;
hadc1.Init.ScanConvMode = ENABLE;
hadc1.Init.ContinuousConvMode = ENABLE;
hadc1.Init.DiscontinuousConvMode = DISABLE;
hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc1.Init.NbrOfConversion = 6;
hadc1.Init.DMAContinuousRequests = ENABLE;
hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
HAL_ADC_Init(&hadc1);
/ Configure for the selected ADC regular channel its corresponding rank in the sequencer and its sample time.
sConfig.Channel = ADC_CHANNEL_0;
sConfig.Rank = 1;
sConfig.SamplingTime = ADC_SAMPLETIME_3CYCLES;
HAL_ADC_ConfigChannel(&hadc1, &sConfig);
sConfig.Channel = ADC_CHANNEL_1;
sConfig.Rank = 2;
/ * Configure for the selected ADC regular channel its corresponding rank in the sequencer and its sample time.
sConfig.Channel = ADC_CHANNEL_13;
sConfig.Rank = 3;
sConfig.Channel = ADC_CHANNEL_12;
sConfig.Rank = 4;
sConfig.Channel = ADC_CHANNEL_11;
sConfig.Rank = 5;
sConfig.Channel = ADC_CHANNEL_10;
sConfig.Rank = 6;
/ USER CODE BEGIN ADC1_Init 2 /
/ USER CODE END ADC1_Init 2 /
void DMA2_Stream0_IRQHandler(void)
/ USER CODE BEGIN DMA2_Stream0_IRQn 0 /
/ USER CODE END DMA2_Stream0_IRQn 0 /
HAL_DMA_IRQHandler(&hdma_adc1);
// rt_kprintf("11111111 n");
/ USER CODE BEGIN DMA2_Stream0_IRQn 1 /
/ USER CODE END DMA2_Stream0_IRQn 1 */
配置RT-Thread Setting
编译通过,结果如下图
修改drv_adc.c文件
编译通过,结果如下图
3、添加业务测试代码
新建user_adc.c源文件添加业务测试代码如下
#include
#include
#include
rt_thread_t Adc_thread1= RT_NULL;
#define ADC_MAX_SAMPLE 12
#define ADC_MAX_CHANLE 6
extern ADC_HandleTypeDef hadc1;
extern rt_uint16_t value[ADC_MAX_SAMPLE][ADC_MAX_CHANLE];
rt_uint16_t ADC_ConvertedValue[ADC_MAX_SAMPLE][ADC_MAX_CHANLE];
rt_uint16_t ADC_AverageValue[ADC_MAX_CHANLE];
static void CalADC_Average(void)
unsigned short i, j;
unsigned short uIntMax,uIntMin,i_Max,i_Min;
unsigned int sum;
for(i=0;i<(ADC_MAX_CHANLE);i++)
uIntMax = ADC_ConvertedValue[0][i];
uIntMin = ADC_ConvertedValue[1][i];
i_Max = 0; i_Min = 1;
for(j=0;j if(uIntMax uIntMax=ADC_ConvertedValue[j][i];
i_Max = j;
if(uIntMin>ADC_ConvertedValue[j][i]){
uIntMin=ADC_ConvertedValue[j][i];
i_Min = j;
ADC_ConvertedValue[i_Max][i]=0;
ADC_ConvertedValue[i_Min][i]=0;
sum = 0;
for(j=0; j sum += ADC_ConvertedValue[j][i];
if(i_Min==i_Max){
ADC_AverageValue[i] = sum/(ADC_MAX_SAMPLE-1)/11.91;
else {
ADC_AverageValue[i] = sum/(ADC_MAX_SAMPLE-2)/11.91;
static void Adc_entry(void *parameter)
HAL_ADC_Start_DMA(&hadc1, ADC_ConvertedValue, (uint32_t)(ADC_MAX_SAMPLE * ADC_MAX_CHANLE));
while (1)
CalADC_Average();
rt_kprintf("/************************/n");
rt_kprintf("avg0 is :%d n",ADC_AverageValue[0]);
rt_kprintf("avg1 is :%d n",ADC_AverageValue[1]);
rt_kprintf("avg2 is :%d n",ADC_AverageValue[2]);
rt_kprintf("avg3 is :%d n",ADC_AverageValue[3]);
rt_kprintf("avg4 is :%d n",ADC_AverageValue[4]);
rt_kprintf("avg5 is :%d n",ADC_AverageValue[5]);
rt_thread_mdelay(500);
static int adc_deal(void)
rt_err_t ret = RT_EOK;
/*创建第一个线程,用于采集IN8的值*/
Adc_thread1 = rt_thread_create("adc1",
Adc_entry,
(void*)0,
512,
16,
20);
if(Adc_thread1 != RT_NULL)
rt_thread_startup(Adc_thread1);
else
ret = RT_ERROR;
return ret;
INIT_APP_EXPORT(adc_deal);
测试结果
本测试板模拟量是采集4~20MA电流。使用信号发生器输出电流信号对各个通道测试正常。下图是对chanle_10通道采集数据(12MA电流显示118。其他通道接输入信号也可以正常采集,其他通道不超过40为干扰信号,不会计入有效采集)。
adc
99文章
6538浏览量
546017 -
信号发生器
28文章
1482浏览量
109101 -
dma
3文章
566浏览量
101100 -
ADC采样
134浏览量
12918 -
RTThread
8文章
132浏览量
41020 -
STM32F407VET6
2文章
5浏览量
2992
使用STM32L031F6在hal库下进行ADC+DMA多通道采集,采集的电压值始终为0的原因?
stm32cubemx建立多通道ADC+DMA,想使用DMA中断要怎么实现?
STM32G4 ADC+DMA中断异常是什么原因导致的?
使用rt-thread的ADC框架,增加了DMA采集部分,采集到的两通道数据中,有一个通道数据异常,为什么?
为什么STM32F103C8T6加上ADC+DMA后液晶不能显示?
STM32多通道ADC+DMA为什么无法进入中断
STM32F103定时器触发ADC+DMA传输 精选资料分享
怎样去解决STM32多通道ADC+DMA无法进入中断的问题
![STM32F103定时器触发<b class='flag-5'>ADC+DMA</b>传输](https://file.elecfans.com/web1/M00/D9/4E/pIYBAF_1ac2Ac0EEAABDkS1IP1s689.png)
STM32U5 ADC+DMA配置演示
![STM32U5 <b class='flag-5'>ADC+DMA</b>配置演示](https://file1.elecfans.com/web2/M00/8E/5F/wKgaomTEy8OAFMDmAABHP6f7rrc790.png)
