英飞凌Psoc6-evaluationkit-062S2测评2_定时器中断和PWM
冬至子 来源:harry_oceana 作者:harry_oceana 2023-08-08 16:52 次阅读
定时器
使用定时器翻转LED电平
使能TIM1
使用硬件定时器,使能定时器后,需要主动添加构建
cyhal_pwm.c/cyhal_tcpwm_common.c/cy_tcpwm_counter.c 三个文件否则会出现函数未定义错误
#define LED_PIN1 GET_PIN(0, 0)
#define LED_PIN2 GET_PIN(0, 1)
#define HWTIMER_DEV_NAME "time1" /* 定时器名称 /
rt_device_t hw_dev; /
定时器设备句柄 /
rt_hwtimer_mode_t mode; /
定时器模式 /
rt_uint32_t freq = 10000; /
计数频率 /
定时器超时回调函数 /
static rt_err_t timeout_cb(rt_device_t dev, rt_size_t size)
static uint8_t state = 0;
if (state == 0)
state = 1;
rt_pin_write(LED_PIN1, PIN_HIGH);
rt_pin_write(LED_PIN2, PIN_LOW);
else {
state = 0;
rt_pin_write(LED_PIN2, PIN_HIGH);
rt_pin_write(LED_PIN1, PIN_LOW);
rt_kprintf("this is hwtimer timeout callback fucntion!n");
rt_kprintf("tick is :%d !n", rt_tick_get());
return 0;
int main(void)
rt_err_t ret = RT_EOK;
rt_hwtimerval_t timeout_s; /
定时器超时值 /
rt_device_t hw_dev = RT_NULL; /
定时器设备句柄 /
定时器模式 /
计数频率 /
初始化LED引脚*/
rt_pin_mode(LED_PIN1, PIN_MODE_OUTPUT);
rt_pin_mode(LED_PIN2, PIN_MODE_OUTPUT);
/* 查找定时器设备 /
hw_dev = rt_device_find(HWTIMER_DEV_NAME);
if (hw_dev == RT_NULL)
rt_kprintf("hwtimer sample run failed! can't find %s device!n", HWTIMER_DEV_NAME);
return RT_ERROR;
以读写方式打开设备 /
ret = rt_device_open(hw_dev, RT_DEVICE_OFLAG_RDWR);
if (ret != RT_EOK)
rt_kprintf("open %s device failed!n", HWTIMER_DEV_NAME);
return ret;
设置超时回调函数 /
rt_device_set_rx_indicate(hw_dev, timeout_cb);
设置计数频率(若未设置该项,默认为1Mhz 或 支持的最小计数频率) /
rt_device_control(hw_dev, HWTIMER_CTRL_FREQ_SET, &freq);
设置模式为周期性定时器(若未设置,默认是HWTIMER_MODE_ONESHOT)/
mode = HWTIMER_MODE_PERIOD;
ret = rt_device_control(hw_dev, HWTIMER_CTRL_MODE_SET, &mode);
if (ret != RT_EOK)
rt_kprintf("set mode failed! ret is :%dn", ret);
return ret;
设置定时器超时值为5s并启动定时器 /
timeout_s.sec = 0; /
timeout_s.usec = 100000; /
微秒 /
if (rt_device_write(hw_dev, 0, &timeout_s, sizeof(timeout_s)) != sizeof(timeout_s))
rt_kprintf("set timeout value failedn");
return RT_ERROR;
延时3500ms /
rt_thread_mdelay(3500);
读取定时器当前值 */
rt_device_read(hw_dev, 0, &timeout_s, sizeof(timeout_s));
rt_kprintf("Read: Sec = %d, Usec = %dn", timeout_s.sec, timeout_s.usec);
for(;;)
return 0;
PWM
在led0上实现呼吸灯效果
默认的pwm0只有通道3,没有通道0,需要通过修改Kconfig文件来实现通道0
修改KCONFIG文件,增加PWM0通道0
PWM0通道0对应LED1
使能pwm0 CH0
在drv_pwm.h中添加通道信息
#define LED_PIN GET_PIN(0, 0)
#define PWM_DEV_NAME "pwm0" /* PWM设备名称 /
#define PWM_DEV_CHANNEL 0 /
PWM通道 */
struct rt_device_pwm pwm_dev; / PWM设备句柄 /
int main(void)
// rt_pin_mode(LED_PIN, PIN_MODE_OUTPUT);
rt_uint32_t period, pulse, dir;
period = 500000; /
周期为0.5ms,单位为纳秒ns /
dir = 1; /
PWM脉冲宽度值的增减方向 /
pulse = 0; /
PWM脉冲宽度值,单位为纳秒ns /
查找设备 */
pwm_dev = (struct rt_device_pwm )rt_device_find(PWM_DEV_NAME);
if (pwm_dev == RT_NULL)
rt_kprintf("pwm sample run failed! can't find %s device!n", PWM_DEV_NAME);
return RT_ERROR;
设置PWM周期和脉冲宽度默认值 /
rt_pwm_set(pwm_dev, PWM_DEV_CHANNEL, period, pulse);
使能设备 /
rt_pwm_enable(pwm_dev, PWM_DEV_CHANNEL);
while (1)
rt_thread_mdelay(50);
if (dir)
pulse += 12500; /
从0值开始每次增加5000ns /
else
pulse -= 12500; /
从最大值开始每次减少5000ns /
if (pulse >= period)
dir = 0;
if (0 == pulse)
dir = 1;
设置PWM周期和脉冲宽度 */
  • LED电平
  • PWM波
  • 定时器中断
  • 呼吸灯
  • RT-Thread
    使用PSoc 62系列板卡时遇到了无法烧录和调试的问题如何解决?
    我的板卡型号是Psoc6-evaluationkit-062S2我的板卡型号是 Psoc6-evaluationkit-062S2。 1.在 RTT Studio 中可以正常烧录,但无法调试
    发表于 05-29 06:06
    PSoC6-CY8CKIT-062S2-43012开发板简介
    简介PSoC6-CY8CKIT-062S2-43012 是英飞凌推出的一款32位双核CPU子系统( ARM Cortex-M4 和 ARM Cortex-M0)的开发板,具有单周期乘法
    发表于 10-14 11:08
    【资料下载】英飞凌PSoC 6 RTT物联网开发板
    Psoc6-evaluationkit-062S2 是 RT-Thread 联合英飞凌推出的一款集成32位双核CPU子系统( ARM Cortex-M4 和 ARM Cortex-M0)的开发板,其具有单周期
    发表于 04-13 13:38
    英飞凌PSoC 6 RTT开发板试用】
    首先感谢发烧友、RT-Thread和英飞凌! 一、开箱 Psoc6-evaluationkit-062S2 是 RT-Thread 联合英飞凌推出的一款集成32位双核CPU子系统( ARM
    发表于 05-30 20:47
    英飞凌PSoC 6 RTT开发板试用】以搭积木方式实现简单的互联型家庭网关
    本文基于RT-Studio,采用搭积木的方式实现一个简单的互联型家庭网关,采集各类传感数据并传输至云端。硬件除了Psoc6-evaluationkit-062S2开发板之外,还有一块RW007
    发表于 05-31 22:19
    英飞凌PSoC 6 RTT开发板试用】+开箱测试
    英飞凌PSoC 6 RTT开发板试用】+开箱测试 硬件资源介绍 Psoc6-evaluationkit-062S2 是 RT-Thread 联合
    发表于 06-05 01:06
    C51编程15-中断篇(定时器中断2
    使用定时器/计数中断,需要将满足以下的条件。 1)中断总允许打开 EA = 1; 2中断源允
    发表于 11-23 17:51 6次下载
    C51编程15-<b class='flag-5'>中断</b>篇(<b class='flag-5'>定时器</b><b class='flag-5'>中断</b><b class='flag-5'>2</b>)
    STM32CubeMX_定时器中断_PWM
    中断PWM的使用. 仍用NUCLEO-F767ZI的板子, 使用定时器3的中断实现LED2(Blue, PB7)的翻转, 然后刚好LED
    发表于 12-05 13:51 13次下载
    STM32CubeMX_<b class='flag-5'>定时器</b><b class='flag-5'>中断</b>_<b class='flag-5'>PWM</b>
    RT-Thread文档_英飞凌 Psoc6-CY8CKIT-062S2-43012上手指南
    RT-Thread文档_英飞凌 Psoc6-CY8CKIT-062S2-43012 上手指南
    发表于 02-22 18:27 3次下载
    RT-Thread文档_<b class='flag-5'>英飞凌</b> <b class='flag-5'>Psoc6-CY8CKIT-062S2</b>-43012上手指南
    基于PSOC6开发板构建的智能小车
    本项目是基于Psoc6-evaluationkit-062S2开发板构建的智能小车。该开发板由RT-Thread与英飞凌联合推出,集成了一颗32位双核CPU子系统,包括150MHz的ARM
    发表于 07-28 15:14 885次阅读
    基于<b class='flag-5'>PSOC6</b>开发板构建的智能小车
    如何设计一种基于PSOC6的人体交互式智能家居系统呢?
    Psoc6-evaluationkit-062S2 是 RT-Thread 联合英飞凌推出的一款集成 32 位双核 CPU 子系统( ARM Cortex-M4 和 ARM Cortex-M0
    的头像 发表于 07-28 16:02 1141次阅读
    如何设计一种基于<b class='flag-5'>PSOC6</b>的人体交互式智能家居系统呢?
    英飞凌Psoc6-evaluationkit-062S2测评1_LED
    Psoc6-evaluationkit-062S2开发板使用DAP_LINK方式下载,开发板有两个芯片,其中一块芯片用作DAP_LINK下载,在安装好插件的前提下,可以直接通过DAP_TYPEC下载
    发表于 08-08 17:18 686次阅读
    <b class='flag-5'>英飞凌</b><b class='flag-5'>Psoc6-evaluationkit-062S2</b><b class='flag-5'>测评</b>1_LED
    RA2E1定时器带死区互补PWM中断延时问题分析
    的头像 发表于 10-27 10:56 861次阅读
    RA<b class='flag-5'>2</b>E1<b class='flag-5'>定时器</b>带死区互补<b class='flag-5'>PWM</b><b class='flag-5'>中断</b>延时问题分析
    英飞凌测评英飞凌PSoC™ 62开发板试用报告-LCD ILI9341 8080 DEMO
    介绍 `Psoc6-evaluationkit-062S2` 是 RT-Thread 联合英飞凌推出的一款集成32位双核CPU子系统( ARM Cortex-M4 和 ARM Cortex-M0
    的头像 发表于 03-07 21:07 871次阅读
    【<b class='flag-5'>英飞凌</b><b class='flag-5'>测评</b>】<b class='flag-5'>英飞凌</b><b class='flag-5'>PSoC</b>™ 62开发板试用报告-LCD ILI9341 8080 DEMO
    基于PSOC6的智能环境监控系统
    本项目是基于PSOC6进行开发,它具有以下特性Psoc6-evaluationkit-062S2是RT-Thread联合英飞凌推出的一款集成32位双核CPU子系统(ARMCortex-M4
    的头像 发表于 01-07 19:54 351次阅读
    基于<b class='flag-5'>PSOC6</b>的智能环境监控系统
