DDR3缓存模块仿真平台构建步骤
FPGA快乐学习 来源:FPGA快乐学习 2023-08-12 11:08 次阅读
1. 复制Vivado工程路径vivado_prjat7.srcssources_1ipmig_7series_0下的mig_7series_0文件夹。粘贴到仿真路径testbench b_ddr3_cache(新建用于DDR3仿真的文件夹)下。
2. 拷贝一个glbl.v文件到testbench b_ddr3_cachemig_7series_0example_designsim文件夹下。
3. 打开testbench b_ddr3_cachemig_7series_0example_designsim文件夹下的sim.do文件中。进行编译的文件路径需要做移植修改。
将vlib work以及后面的内容删除
复制下面的脚本到sim.do中。
vlib work
vmap work work
vlog -work workglbl.v
#Compile all modules#
vlog../../../../../design/m_ddr3_cache.v
vlog../../../../../vivado_prj/at7.srcs/sources_1/ip/fifo_ddr3_write/fifo_ddr3_write_sim_netlist.v
vlog../rtl/traffic_gen/mig_7series*.v
vlog../rtl/example_top.v
vlog ../../user_design/rtl/mig_7series_0.v
vlog../../user_design/rtl/mig_7series_0_mig_sim.v
vlog -incr../../user_design/rtl/clocking/*.v
vlog -incr../../user_design/rtl/controller/*.v
vlog -incr../../user_design/rtl/ecc/*.v
vlog -incr../../user_design/rtl/ip_top/*.v
vlog -incr../../user_design/rtl/phy/*.v
vlog -incr../../user_design/rtl/ui/*.v
#Compile files in sim folder (excluding model parameterfile)#
vlog *.vh
vlog *.sv
vlog *.v
#Pass the parametersfor memory model parameter file#
vlog -sv +define+x2Gb+define+sg15E +define+x16 ddr3_model.sv
#Load the design. Userequired libraries.#
vsim -voptargs=+acc-L unisims_ver -L unisim -L work -Lfunisims_ver +notimingchecks -Lsecureipwork.glblwork.sim_tb_top
add wavesim:/sim_tb_top/uut_m_ddr3_cache/*
4. 打开testbench b_ddr3_cachemig_7series_0example_designsim文件夹下的sim_tb_top.v文件(测试脚本),进行必要的修改,将用户设计移植到这个测试脚本中。
example_top模块的例化可以用用户设计模块替代,接口一一映射即可。
5. 打开modelsim,点击菜单Compile--> Compile options,修改Verilog &SystemVerilog下,勾选Use SystemVerilog选项。
6. 打开run_simulation.bat文件,增加新的仿真自动运行项。
@echo off
@cls
title FPGA Auto Simulation batch script
echo ModelSim simulation
echo.
echo Press '1' to start tb_pll simulation
echo.
echo Press '2' to start tb_fifo_img simulation
echo.
echo Press '3' to start tb_image_capture simulation
echo.
echo Press '4' to start tb_fifo_ddr3_write simulation
echo.
echo Press'5' to start tb_ddr3_cache simulation
echo.
:input
set INPUT=
set /P INPUT=Type test number: %=%
if "%INPUT%"=="1" goto run1
if "%INPUT%"=="2" goto run2
if "%INPUT%"=="3" goto run3
if "%INPUT%"=="4" goto run4
if"%INPUT%"=="5" goto run5
goto end
:run1
@cls
echo Start tb_pll Simulation;
echo.
echo.
cd testbench/tb_pll
vsim -do "do compile.do"
gotoclean_workspace
:run2
@cls
echo Start tb_fifo_img Simulation;
echo.
echo.
cd testbench/tb_fifo_img
gotoclean_workspace
:run3
@cls
echo Start tb_image_capture Simulation;
echo.
echo.
cd testbench/tb_image_capture
gotoclean_workspace
:run4
@cls
echo Start tb_fifo_ddr3_write Simulation;
echo.
echo.
cd testbench/tb_fifo_ddr3_write
gotoclean_workspace
:run5
@cls
echo Starttb_ddr3_cache Simulation;
echo.
echo.
cdtestbench/tb_ddr3_cache/mig_7series_0/example_design/sim
vsim -do"do sim.do"
gotoclean_workspace
:clean_workspace
rmdir /S /Q work
del vsim.wlf
del transcript.
:end
审核编辑:刘清
  • DDR3
  • 缓存器
  • FIFO存储
  • MODELSIM仿真
  • Verilog语言
原文标题:Verilog边码边学 Lesson47 图像采集与显示设计之DDR3缓存模块仿真平台构建【免费视频】
文章出处:【微信号:FPGA快乐学习,微信公众号:FPGA快乐学习】欢迎添加关注!文章转载请注明出处。
    DDR3、4拓扑仿真
    DDR3DDR
    电子学习
    发布于 :2022年12月07日 22:34:02
    xilinx平台DDR3设计教程
    看完保证你会做DDR3仿真
    发表于 09-18 14:33
    如何自建仿真DDR3
    自建Spartan6 DDR3仿真平台
    发表于 08-01 06:08
    xilinx平台DDR3设计教程之仿真
    xilinx平台DDR3设计教程之仿真
    发表于 03-12 08:54
    什么是全数字仿真平台
    全数字仿真平台作为工业领域不可缺少的重要软件之一,除了可以与MATLAB或者Simulink集成外,还支持哪些优秀的功能?在了解新一代全数字仿真平台SkyEye之前,先来学习一下什么是全数字仿真平台
    发表于 12-17 07:48
    什么是全数字仿真平台
    发表于 12-21 06:42
    OBS系统仿真平台构建及分析
    分析了光突发交换网络核心交换节点的基本交换结构、交换控制模块的主要功能以及核心交换模块的构成;对光突发交换系统进行了仿真平台构建,讨论了系统仿真
    发表于 03-08 18:06 15次下载
    Quamtum-SI DDR3仿真解析
    Quamtum-SI DDR3仿真解析 Automated DDR3 Analysis
    发表于 04-29 09:00 4515次阅读
    Quamtum-SI <b class='flag-5'>DDR3</b><b class='flag-5'>仿真</b>解析
    xilinx平台DDR3设计教程之仿真篇_中文版教程
    用ise工具调用DDR3 IP核教程,内容非常的详细
    发表于 11-20 11:56 0次下载
    基于硬件加速的实时仿真平台构建技术
    基于硬件加速的实时仿真平台构建技术_孔璐
    发表于 01-03 17:41 1次下载
    基于SystemC构建多核DSP软件仿真平台
    基于SystemC构建多核DSP软件仿真平台_韦祎
    发表于 01-03 17:41 3次下载
    ddr4和ddr3内存的区别,可以通用吗
    虽然新一代电脑/智能手机用上了DDR4内存,但以往的产品大多还是用的DDR3内存,因此DDR3依旧是主流,DDR4今后将逐渐取代DDR3,成
    发表于 11-08 15:42 3.2w次阅读
    基于FPGA的DDR3多端口读写存储管理的设计与实现
    为了解决视频图形显示系统中多个端口访问DDR3的数据存储冲突,设计并实现了基于FPGA的DDR3存储管理系统。DDR3存储器控制模块使用MIG生成D
    发表于 11-18 18:51 7340次阅读
    基于FPGA的<b class='flag-5'>DDR3</b>多端口读写存储管理的设计与实现
    简述 Cyclone 10 GX DDR3 设计的步骤
    Cyclone 10 GX DDR3 示例设计的步骤
    的头像 发表于 06-20 00:12 6256次阅读
    简述 Cyclone 10 GX <b class='flag-5'>DDR3</b> 设计的<b class='flag-5'>步骤</b>
    DDR3DDR4的设计与仿真学习教程免费下载
    DDR3 SDRAM是DDR3的全称,它针对Intel新型芯片的一代内存技术(但目前主要用于显卡内存),频率在800M以上。DDR3是在DDR2基础上采用的新型设计,与
    发表于 10-29 08:00 0次下载
    <b class='flag-5'>DDR3</b>和<b class='flag-5'>DDR</b>4的设计与<b class='flag-5'>仿真</b>学习教程免费下载
