大家好,这里是射频学堂,今天给大家整理了一下一些知名外企射频类岗位面试题集,这些外企包括:Apple, Qualcomm, MediaTek, Intel, Samsung, Skyworks, Keysight, pSemi, Qorvo, Anokiwave 等等。
所以无论是初级岗位面试还是高级岗位,面试前最好能把这些问题搞清楚,做到有备无患。
直接上题了:
How will you design a PA with 30 dBm output power? What load impedance for PA will you choose, at what point will you start thinking of power combining?
Breakdown mechanisms in MOS. How it happens? What is gate breakdown, what is drain source breakdown etc.? Go into physics of breakdown.
Have you designed any ESD protection circuit?
What is the impedance looking into gate of transistor with degeneration inductor?
Say you have matched LNA by doing source degeneration and a series inductor at input. What is the overall transconductance of the circuit?
How can you introduce real part in input impedance of CS amplifier?
How does device size affect noise in LNA design?
Can you derive the noise figure of common source amplifier?
How do you optimize transistor (in terms of bias, device size and layout) for ft, fmax and NF?
Do you know how to design bandgap, PTAT etc?
There are two current mirror transistor, one mirroring current from other. How do you increase the matching between the transistors?
How can you match Vth of transistors?
Vth increases with channel length or decreases? why?
Increasing bias current of cmos increases the voltage gain or decreases it?
How would you design two stage amplifier? Do you know how to compensate it?
Why Miller compensation does pole splitting? You also add some resistor in Miller compensation, why?
What is input impedance of CS amplifier with and without Cgd cap?
Derive output impedance expression of CS amplifier including Cgd.
How to increase gain of amplifier? How do you increase output impedance? Add current source load, stack devices, super transistor, how else? What about current? Is there a sweet spot for it?
What is the IIP3 of two cascaded blocks? Under what conditions this cascade IIP3 formula is not valid?
How is IM3 affected when you increase one tone amplitude and other remains fixed?
What is the relation between IIP3 and HD3?
What is the noise figure of two cascaded amplifiers?
Say you are given two amplifiers with some NF. You cannot change the amplifier design. Is there anything you can do to reduce the system noise?
What linearity metrics do you use for PAs? (P1,IIP3,ACLR,EVM,AM-AM, AM-PM)
How does AM-AM or AM-PM effect EVM?
Do you know what is memory effect?
Draw Pout vs Efficiency curve of class A, B and AB amplifier
If you are in class AB, how can you increase efficiency of the PA? assume passives are ideal.
How do you bias PA? How do you take care of thermal runaway?
What breakdown voltage in lower in CMOS and why? gate to drain or drain to source?
For which impedance do you match your PA? Your signal has PAPR, your output impedance is dynamically varying. Which impedance would you choose?
What is active load pull? Why do you use it?
Cascode LNA. How do you choose device size of input transistor? How do you choose Lg and Ls inductors? How do you choose cascode transistor size? How does cascode affect NF?
Draw time domain waveform of output of RC and RL low pass and high pass filters if the input is square wave.
What is current crowding in inductors? what are step symmetric inductors? pros and cons between signle ended and differential inductors?
If you have CS amplifier, and gate is terminated with very high impedance, assume there is Cgd capacitance. What is the output impedance?
How do you match 200 to 50 ohms? what is S21? Suppose the matching inductor has 1ohm series resistance. What will be the S21 now? (popular question)
What is the resonance frequency, Q and BW of parallel RLC tank?
Series resistor and inductor. If you adjust there values in such a way that Q remains same. How would it move on Smith chart for different values of R?
Say a typical oscillator circuit with LC load. What is the output impedance when it oscillates? What is the output impedance when it is in transient phase where oscillations are trying to build-up?
Say parallel LC tank. What is the current in tank during resonance vs source current?
What happens if I,Q are mismatched in RX? what about in TX?
How do you layout a transistor? what techniques do you use to reduce parasitis? How to choose number of fingers?
Pole zero analysis of typical OTA
Say single stage differential opamp. If load transistors have mismatch, dc offset is produced. How would you take care it? Like how would you size the transistors, big or small?
What is the significance of ft (transition frequency) and fmax (frequency at which unilateral gain becomes one) of transistor
This is a current mirror circuit. Say noise is added at this point. What will be its transfer function to output?
Input impedance of CG? What is impact of positive feedback from ro on input impedance?
How does AM-AM and AM-PM affects IM3s?
What is single side band modulation? Typical in TX where you only want to transmit one side band that is either flo+fbb or flo-fbb but not both together
Movement of constellation points (in EVM measurements) with AM-AM, AM-PM, noise, memory effect etc
If antenna impedance is varying, how do you take care of it in PA design?
An ideal amplifier with gain -1, input output connected with resistor R, what is the Zin?
How does the spectrum of square wave look like? What if you change the duty cycle to 25%?
哈哈,这么多题,看完之后发现大部分我也答不上来。继续搬砖学习啦。
编辑:黄飞
ESD
49文章
2030浏览量
172938 -
射频
104文章
5575浏览量
167704 -
RFIC
1文章
60浏览量
24463
原文标题:知名外企射频面试题集 之 RFIC 篇
文章出处:【微信号:射频学堂,微信公众号:射频学堂】欢迎添加关注!文章转载请注明出处。
