【编者按】本案中,被告Versata在其DCM软件中使用了原告XimpleWare根据GPLv2.0开源的XML软件中的部分代码,并将DCM软件销售给其客户Ameriprise等公司(下称“Versata客户被告”)使用。XimpleWare基于其拥有的与XML软件相关的三项专利,向法院提出的诉讼主张之一是Versata客户被告使用DCM软件的行为构成专利直接侵权。在解决此争议点时法院指出,在Versata客户被告遵守GPLv2.0条款的前提下,GPLv2.0明确允许其对XML源代码进行纯粹的使用;即使上游分发方Versata违反许可证条款,在Versata客户被告本身不违反GPLv2.0的情况下,其使用行为不会受到限制。若要指控Versata客户被告构成专利直接侵权,必须证明Versata客户被告在违反GPLv2.0条款的情况下进行了分发。但由于XimpleWare无法举证证明Versata客户被告存在分发DCM软件(其中包含XML代码)的行为,法院驳回了XimpleWare该诉讼主张。从法院的论述中可看出,单纯的“使用”行为并不触发GPLv2.0的条件,“分发”行为才是GPLv2.0条件的触发器。
判决译文节选
译文全文请浏览“阅读原文”
The Customer Defendants each move to dismiss XimpleWare's claims of direct infringement on the basis that XimpleWare has failed to plead facts showing distribution of the DCM software by any Customer Defendant.
涉案客户被告均提出动议,以XimpleWare未能提出事实证明任何涉案客户被告分发了DCM软件为由,请求驳回XimpleWare的直接侵权主张。
In dismissing XimpleWare's claims for direct infringement against the Customer Defendants in the FAC, the court held that regardless of the actions of the Versata Defendants, under the GPL the Customer Defendants each "retain the right to use XimpleWare's software so long as the customer does not itself breach the license by 'distributing' XimpleWare's software." Unchanged in the SAC is XimpleWare's allegation that the Customer Defendants "infringe and continue to willfully infringe the Patents by using the infringing Versata products." As use is expressly permitted under the GPL, the court's conclusion on this point is likewise unchanged: the SAC fails to state a claim for direct infringement against the Customer Defendants based on their use of XimpleWare's code included in the DCM software.
在驳回XimpleWare在FAC中对涉案客户被告提出的直接侵权主张时,法院认为,无论涉案Versata被告的行为如何,根据GPL,“只要客户本身不因‘分发’XimpleWare的软件而违反许可证”,则涉案客户被告都“保留使用XimpleWare软件的权利。”XimpleWare在SAC中仍然保留对涉案客户被告“通过使用侵权的Versata产品侵犯并持续故意侵犯专利权”的指控。由于GPL明确允许使用行为,法院就这一点的结论仍然没有改变:SAC因涉案客户被告对包含在DCM软件中的XimpleWare代码使用行为而提出的直接侵权主张无法得到支持。
While use is unrestricted under the GPL, distribution is not. The GPL permits distribution only if the distributing party satisfies several specific conditions, including among other things including copy of the GPL along with the distributed program. The court previously held that XimpleWare had adequately alleged the Customer Defendants failed to satisfy the conditions for distribution of XimpleWare's software. Accordingly, the "only real issue to resolve" was "whether XimpleWare has sufficiently alleged that its software was 'distributed' by the customers when they shared the software with their independent contractors, franchisees, and producers." The court further held that XimpleWare had not, and dismissed its claims against the Customer Defendants. However, the court granted XimpleWare leave to amend to cure this defect.
虽然GPL不限制使用行为,但却对分发行为作出了限制。只有在分发方满足若干特定条件的情况下(包括随分发程序附上GPL的副本)GPL才允许分发。法院先前认为,XimpleWare已充分指控涉案客户被告未能满足分发XimpleWare软件的条件。因此,“唯一真正需要解决的问题”是“XimpleWare是否充分指控了客户在与其独立承包商、特许经营商和制造商共享软件时‘分发’了其软件”。法院进一步认为,XimpleWare没有就此进行充分指控,因此驳回了其对涉案客户被告的诉讼请求。不过,法院准许XimpleWare修正起诉状以弥补这一缺陷。
翻译:薛杨洁
审校:刘伟、郭雪雯
判决英文原文:
https://law.justia.com/cases/federal/district-courts/california/candce/5:2013cv05161/271648/142/
免责声明:本译文由开放原子开源基金会组织翻译和审定,依据CC BY-NC-SA 4.0向公众开放共享,允许任何人自由使用、复制及传播。同时请注意,相关译文不属于法院指定的官方译文,也不提供任何明示或默示保证。如您对本译文有任何建议或意见,欢迎您联系我们:legal@openatom.org
项目介绍:“源译识”翻译项目是由开放原子开源基金会发起的开源公益翻译项目,旨在通过共译凝聚对开源的共识。目前本项目主要涉及开源许可证翻译、开源案例翻译、开源书籍翻译及开源资讯翻译等。详情请见:https://atomgit.com/OpenAtomFoundation/translation
点击阅读原文
浏览译文全文
原文标题:源译识 | 译文分享:XimpleWare诉Versata Software等一审判决(2014)
文章出处:【微信公众号:开放原子】欢迎添加关注!文章转载请注明出处。
OpenHarmony
25文章
3558浏览量
15785 -
开放原子基金会
1文章
477浏览量
5061
文章出处:【微信号:开放原子,微信公众号:开放原子】欢迎添加关注!文章转载请注明出处。
