米尔基于瑞萨RZ/G2L开发板在工控领域的应用-基于SOEM的EtherCAT主站
米尔MYIR 2023-08-24 18:57 次阅读
本篇测评由优秀测评者“qinyunti”提供。
前言
本文介绍【米尔MYD-YG2LX开发板】在工控领域的应用,实现基于SOEM的EtherCAT主站。开发环境基于WSL2。
下载代码
git clone
‍https://github.com/OpenEtherCATsociety/SOEM‍
PC端
编译
cd SOEM/
export CC=gcc
mkdir build_pc
cd build_pc/
cmake ..
lhj@lhj:~/SOEM/build_pc$ cmake ..
-- The C compiler identification is GNU 9.4.0
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- OS is linux
-- LIB_DIR: lib
-- Configuring done
-- Generating done
-- Build files have been written to: /home/lhj/SOEM/build_pc
make
lhj@lhj:~/SOEM/build_pc$ make
Scanning dependencies of target soem
[4%] Building C object CMakeFiles/soem.dir/soem/ethercatbase.c.o
[9%] Building C object CMakeFiles/soem.dir/soem/ethercatcoe.c.o
[ 14%] Building C object CMakeFiles/soem.dir/soem/ethercatconfig.c.o
[ 19%] Building C object CMakeFiles/soem.dir/soem/ethercatdc.c.o
[ 23%] Building C object CMakeFiles/soem.dir/soem/ethercateoe.c.o
[ 28%] Building C object CMakeFiles/soem.dir/soem/ethercatfoe.c.o
[ 33%] Building C object CMakeFiles/soem.dir/soem/ethercatmain.c.o
[ 38%] Building C object CMakeFiles/soem.dir/soem/ethercatprint.c.o
[ 42%] Building C object CMakeFiles/soem.dir/soem/ethercatsoe.c.o
[ 47%] Building C object CMakeFiles/soem.dir/osal/linux/osal.c.o
[ 52%] Building C object CMakeFiles/soem.dir/oshw/linux/nicdrv.c.o
[ 57%] Building C object CMakeFiles/soem.dir/oshw/linux/oshw.c.o
[ 61%] Linking C static library libsoem.a
[ 61%] Built target soem
Scanning dependencies of target simple_ng
[ 66%] Building C object test/simple_ng/CMakeFiles/simple_ng.dir/simple_ng.c.o
[ 71%] Linking C executable simple_ng
[ 71%] Built target simple_ng
Scanning dependencies of target slaveinfo
[ 76%] Building C object test/linux/slaveinfo/CMakeFiles/slaveinfo.dir/slaveinfo.c.o
[ 80%] Linking C executable slaveinfo
[ 80%] Built target slaveinfo
Scanning dependencies of target eepromtool
[ 85%] Building C object test/linux/eepromtool/CMakeFiles/eepromtool.dir/eepromtool.c.o
[ 90%] Linking C executable eepromtool
[ 90%] Built target eepromtool
Scanning dependencies of target simple_test
[ 95%] Building C object test/linux/simple_test/CMakeFiles/simple_test.dir/simple_test.c.o
[100%] Linking C executable simple_test
[100%] Built target simple_test
部署
生成的文件如下
其中libsoem.a为库文件
test/linux/下的
simple_test,slaveinfo,eepromtool为测试Demo。
lhj@lhj:~/SOEM/build_pc$ tree .
|-- CMakeCache.txt
|-- CMakeFiles
|  |-- 3.16.3
|  |  |-- CMakeCCompiler.cmake
|  |  |-- CMakeDetermineCompilerABI_C.bin
|  |  |-- CMakeSystem.cmake
|  |  `-- CompilerIdC
|  |     |-- CMakeCCompilerId.c
|  |     |-- a.out
|  |     `-- tmp
|  |-- CMakeDirectoryInformation.cmake
|  |-- CMakeOutput.log
|  |-- CMakeTmp
|  |-- Export
|  |  `-- share
|  |     `-- soem
|  |      `-- cmake
|  |          |-- soemConfig-noconfig.cmake
|  |          `-- soemConfig.cmake
|  |-- Makefile.cmake
|  |-- Makefile2
|  |-- TargetDirectories.txt
|  |-- cmake.check_cache
|  |-- progress.marks
|  `-- soem.dir
|     |-- C.includecache
|     |-- DependInfo.cmake
|     |-- build.make
|     |-- cmake_clean.cmake
|     |-- cmake_clean_target.cmake
|     |-- depend.internal
|     |-- depend.make
|     |-- flags.make
|     |-- link.txt
|     |-- osal
|     |  `-- linux
|     |     `-- osal.c.o
|     |-- oshw
|     |  `-- linux
|     |     |-- nicdrv.c.o
|     |     `-- oshw.c.o
|     |-- progress.make
|     `-- soem
|      |-- ethercatbase.c.o
|      |-- ethercatcoe.c.o
|      |-- ethercatconfig.c.o
|      |-- ethercatdc.c.o
|      |-- ethercateoe.c.o
|      |-- ethercatfoe.c.o
|      |-- ethercatmain.c.o
|      |-- ethercatprint.c.o
|      `-- ethercatsoe.c.o
|-- Makefile
|-- cmake_install.cmake
|-- libsoem.a
`-- test
|-- linux
|  |-- eepromtool
|  |  |-- CMakeFiles
|  |  |  |-- eepromtool.dir
|  |  |  |  |-- C.includecache
|  |  |  |  |-- DependInfo.cmake
|  |  |  |  |-- build.make
|  |  |  |  |-- depend.internal
|  |  |  |  |-- depend.make
|  |  |  |  |-- eepromtool.c.o
|  |  |  |  |-- flags.make
|  |  |  |  |-- link.txt
|  |  |  |  `-- progress.make
|  |  |  `-- progress.marks
|  |  |-- Makefile
|  |  `-- eepromtool
|  |-- simple_test
|  |  |-- CMakeFiles
|  |  |  |-- progress.marks
|  |  |  `-- simple_test.dir
|  |  |     |-- C.includecache
|  |  |     |-- DependInfo.cmake
|  |  |     |-- build.make
|  |  |     |-- depend.internal
|  |  |     |-- depend.make
|  |  |     |-- flags.make
|  |  |     |-- link.txt
|  |  |     |-- progress.make
|  |  |     `-- simple_test.c.o
|  |  |-- Makefile
|  |  `-- simple_test
|  `-- slaveinfo
|     |-- CMakeFiles
|     |  |-- progress.marks
|     |  `-- slaveinfo.dir
|     |     |-- C.includecache
|     |     |-- DependInfo.cmake
|     |     |-- build.make
|     |     |-- depend.internal
|     |     |-- depend.make
|     |     |-- flags.make
|     |     |-- link.txt
|     |     |-- progress.make
|     |     `-- slaveinfo.c.o
|     |-- Makefile
|     `-- slaveinfo
`-- simple_ng
|-- CMakeFiles
|  |-- progress.marks
|  `-- simple_ng.dir
|     |-- C.includecache
|     |-- DependInfo.cmake
|     |-- build.make
|     |-- depend.internal
|     |-- depend.make
|     |-- flags.make
|     |-- link.txt
|     |-- progress.make
|     `-- simple_ng.c.o
|-- Makefile
`-- simple_ng
29 directories, 100 files
开发板端
编译
cd SOEM/
export CC=aarch64-linux-gnu-gcc
mkdir build
cd build/
cmake ..
lhj@lhj:~/SOEM/build$ cmake ..
-- Check for working C compiler: /usr/bin/aarch64-linux-gnu-gcc
-- Check for working C compiler: /usr/bin/aarch64-linux-gnu-gcc -- works
-- OS is linux
-- LIB_DIR: lib
-- Configuring done
-- Generating done
make
lhj@lhj:~/SOEM/build$ make
部署
cp libsoem.a /mnt/d
cp test/linux/simple_test/simple_test /mnt/d
cp test/linux/slaveinfo/slaveinfo/mnt/d
将上述文件rz导入开发板
chmod +x simple_test slaveinfo
运行
root@myir-yg2lx:~# ./slaveinfo eth0
SOEM (Simple Open EtherCAT Master)
Slaveinfo
Starting slaveinfo
ec_init on eth0 succeeded.
No slaves found!
End slaveinfo, close socket
End program
root@myir-yg2lx:~# ./simple_test eth0
Simple test
Starting simple test
No slaves found!
End simple test, close socket
End program
root@myir-yg2lx:~#
总结
本开发板接口资源丰富,性能强,特别适合工控领域的应用,比如作为EtherCAT主站。由于没有从站,所以暂时未能演示和从站通讯的功能。
  • 嵌入式
  • 瑞萨
  • 开发板
  • ethercat
  • 核心板
  • soem
    基于电子RZ/G2L的FET-G2LD-C核心和OK-G2LD-C开发板评测
    基于电子RZ/G2L处理器开发的FET-G2LD-C核心
    发表于 05-30 17:24 1227次阅读
    基于<b class='flag-5'>瑞</b><b class='flag-5'>萨</b>电子<b class='flag-5'>RZ</b>/<b class='flag-5'>G2L</b>的FET-<b class='flag-5'>G2</b>LD-C核心<b class='flag-5'>板</b>和OK-<b class='flag-5'>G2</b>LD-C<b class='flag-5'>开发板</b>评测
    米尔-RZ/G2UL开发板】6.基于SOEMEtherCat
    使用标准的以太网控制器,具有良好的兼容性,任何具有网络接口卡的计算机和具有以太网控制的嵌入式设备都可以作为EtherCAT。对于PC计算机而言,
    发表于 03-31 16:22
    米尔RZ/G2L开发板-试用体验】开箱
    感谢 感谢电子发烧友论坛、感谢米尔电子,把米尔RZ/G2L
    发表于 05-14 19:41
    米尔RZ/G2L开发板-试用体验】开箱 + 开机
    发表于 05-18 19:33
    米尔RZ/G2L开发板-试用体验】LCD 显示测试
    实验器材 1、米尔RZ/G2L开发板 2、MY-
    发表于 05-22 19:26
    米尔RZ/G2L开发板-试用体验】米尔-RZG2L - 64位双核MPU开发板开箱测评
    刚收到米尔RZ/G2L开发板打开包装后看到的很大的一块黑色PCB,做工精美的
    发表于 05-22 21:53
    米尔RZ/G2L开发板-试用体验】米尔RZ/G2L开发板开箱视频
    今天刚刚收到米尔RZ/G2L开发板,拆开包裹后给人的感觉是惊艳,板卡设计真的很棒,来看看视频
    发表于 05-22 21:58
    150套开发板免费送!还有5G手机拿?米尔RZ/G2L开发板创意秀
    /12 05 送的是哪款开发板米尔MYD-YG2LX开发板,该款产品采用
    发表于 05-24 16:36
    米尔RZ/G2L开发板-试用体验】米尔RZ/G2L开发板使用SSH登录
    收到的米尔RZ/G2L开发板上电测试一下SSH登录方式和其它测试! SSH登录
    发表于 06-11 21:47
    米尔RZ/G2L开发板-试用体验】认识一下米尔RZ/G2L开发板的核心
    解一下米尔RZ/G2L开发板的核心: MYC-
    发表于 07-29 00:21
    米尔RZ/G2L开发板-初体验
    介绍米尔RZ/G2L开发板
    的头像 发表于 05-15 09:10 1109次阅读
    <b class='flag-5'>米尔</b><b class='flag-5'>瑞</b><b class='flag-5'>萨</b><b class='flag-5'>RZ</b>/<b class='flag-5'>G2L</b><b class='flag-5'>开发板</b>-初体验
    米尔RZ/G2L开发板 TF卡读写速度测试
    米尔RZ/G2L开发板TF卡读写测试
    的头像 发表于 05-22 09:07 1545次阅读
    <b class='flag-5'>米尔</b><b class='flag-5'>瑞</b><b class='flag-5'>萨</b><b class='flag-5'>RZ</b>/<b class='flag-5'>G2L</b><b class='flag-5'>开发板</b> TF卡读写速度测试
    米尔RZ/G2L开发板 安装交叉编译器
    米尔RZ/G2L开发板安装交叉编译器
    的头像 发表于 05-26 22:05 2241次阅读
    <b class='flag-5'>米尔</b><b class='flag-5'>瑞</b><b class='flag-5'>萨</b><b class='flag-5'>RZ</b>/<b class='flag-5'>G2L</b><b class='flag-5'>开发板</b> 安装交叉编译器
    米尔RZ/G2L开发板-试用体验】创建TCP服务器
    米尔RZ/G2L开发板上用C 创建TCP服务器
    的头像 发表于 05-27 08:59 7906次阅读
    【<b class='flag-5'>米尔</b><b class='flag-5'>瑞</b><b class='flag-5'>萨</b><b class='flag-5'>RZ</b>/<b class='flag-5'>G2L</b><b class='flag-5'>开发板</b>-试用体验】创建TCP服务器
    RZ/G2L开发板工控领域的应用-基于SOEMEtherCAT
    本篇测评由优秀测评者“qinyunti”提供。前言本文介绍【米尔MYD-YG2LX开发板工控领域
    的头像 发表于 07-31 22:09 711次阅读
    <b class='flag-5'>瑞</b><b class='flag-5'>萨</b><b class='flag-5'>RZ</b>/<b class='flag-5'>G2L</b><b class='flag-5'>开发板</b><b class='flag-5'>在</b><b class='flag-5'>工控</b><b class='flag-5'>领域</b>的应用-基于<b class='flag-5'>SOEM</b>的<b class='flag-5'>EtherCAT</b><b class='flag-5'>主</b><b class='flag-5'>站</b>
