硕盟SM-T54是一款USB-C扩展坞,您可以将含有USB 3.1协议的电脑主机,通过此产品连接到具有HDMI或VGA的显示器、电视机或其他显示设备。产品可以接入硬盘、U盘、鼠标、键盘和光驱等HDMI或VGA设备。 另外,此产品还可以通过USB-C接口给电脑主机进行充电。
除此之外,还支持含有USB 3.1协议的智能手机和平板,及其他智能设备。
SHUOMENGSM-T54 is a USB-C docking station. You can connect a host computer with USB 3.1 protocol to a monitor, TV or other display device with HDMI or VGA through this product. The product can be connected to USB devices such as hard drives, U disks, mice, keyboards, and optical drives. In addition, this product can also charge the host computer through the USB-C interface.
In addition, it also supports smart phones and tablets with USB 3.1 protocol, and other smart devices.
应用示意图|How it Work
接口功能说明|Interface function description
- HDMI端口|HDMI port
最大输出分辨率3840 x 2160 @30Hz,音频同步。
Maximum output resolution 3840 x 2160 @ 30Hz, audio synchronization.
2. VGA端口|VGA port
最大输出分辨率1920 x 1080 @60Hz.
The maximum output resolution is 1920 x 1080 @ 60Hz.
3.同时插入HDMI和VGA时,HDMI和VGA显示相同画面1920 x 1080 @60Hz.
When HDMI and VGA are inserted at the same time, HDMI and VGA display the same picture 1920 x 1080 @ 60Hz.
4. USB3.0端口| USB3.0 port
- 支持USB3.0协议,数据传输速度最高支持5Gbps;
Support USB3.0 protocol, data transmission speed up to 5Gbps;
- 兼容USB2.0协议,数据传输速度最高支持480Mbps;
Compatible with USB2.0 protocol, data transmission speed up to 480mbps;
- 支持USB存储设备U盘、读卡器等数据交换;
Support USB storage device U disk, card reader and other data exchange;
- 支持USB通讯设备、手机、平板等智能设备数据交换;
Support data exchange of USB communication devices, mobile phones, Pad and other intelligent devices;
- 支持有线鼠标、键盘及无线鼠标;
Support wired mouse, keyboard and wireless mous;
- 支持双向数据传输,支持热插拔即插即用;
It supports bidirectional data transmission and hot plug and play;
- 苹果及三星等手机、平板等设备充电5V/900mA;
Apple and Samsung mobile phones, pad and other devices charge 5V / 900mA;
- 可以给支持BC1.2规范的手机快速充电5V/1.5A.
It can quickly charge 5V / 1.5A for mobile phones supporting bc1.2 specification.
5. Type C PD端口|Type C PD port
- 支持PD3.0协议充电;|Support pd3.0 protocol charging;
- 支持最大充电功率100W;|Support the maximum charging power of 100W;
- 支持热插拔即插即充。|Support hot plug, plug and charge.
Linux系统下配置FCB-EV9520L与LVDS转USB3.0编码采集模块教程
IP5328P支持双向 PD3.0 快充等多种协议的移动电源 SOC规格书
AS7173+VL171设计TypeC转DP双向8K60/4K240转接线方案电路图
TUSB8041:四端口 USB 3.0 集线器的卓越之选
TUSB8041-Q1汽车四端口USB 3.0集线器设计全解析
USB PD 3.0控制器MAX77958浪涌防护方案
L-com诺通推出新型工业级USB 3.0转接头
VLI威锋代理-VL103-扩展坞PD3.0协议芯片,typeCPD充电输出DP信号 替代VL102
IP2726H 集成多种协议、用于USB-A和TYPE-C双端口输出的快充协议 IC
电流功率检测USB3.0HUB,USB3.0扩展坞,可扩展的USB2.0
5050 RGBW 四合一全彩 LED 灯珠
EZ-PD CCG5 type-c反接的时候无法识别usb2.0、usb3.0,怎么解决?
USB PD 3.0控制器TPS25750浪涌防护方案
硕盟SM-T54|四合一扩展坞|TYPEC转HDMI+VGA+USB3.0+PD3.0
