Banana PI BPI-W2是一个高度集成的多媒体网络路由器,可用于高无线性能、Nas路由,家庭娱乐、家庭自动化等…
BPI-W2集成了一个四核ARM cortex- a53 MPcore,运行到1.5 ghz,路由器还包括各种外设,包括HDMI RX/ TX,Mini DP,PCIe2.0,pcie1.1 & sdio,M.2接口、USB2.0 USB3.0端口,SATA端口,2 Gbps端口千兆以太网端口,也支持802.11 ac / n WLAN连接通过PCI-e接口连接,BPI-W2可以运行Android6.0。它还可以运行OpenWRT,Debian linux,Ubuntu linux,Raspbian和其他操作系统。它还可以运行OpenWRT,Debian linux,Ubuntu linux,Raspbian和其他操作系统。
BPI-W2的大小与BPI-R2的尺寸大小相同,它可以很容易的运行它支持1080P高清视频输出,GPIO与Raspberry PI 3 兼容。
硬件接口示意图:
硬件规格:
香蕉派 BPI-W2 硬件规格表 | |||
| Soc芯片 | Realtek RTD1296 quad-core ARM A53 | ||
| GPU | Mali T820 MP3 GPU | ||
| SDRAM | 2GB DDR4 (shared with GPU) | ||
| 供电 | 12V @ 2A via DC power 5.0mmx2.0mm jack | ||
| Low-level peripherals | 40 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S. | ||
| 有线网口 | 2x 10/100/1000Mbps Ethernet | ||
| Wifi无线/Bluetooth蓝牙 | **Option** ,not support onboard WIFI & BT | ||
| RGMII | 1 RGMII interface with PIN | ||
| 存储 | MicroSD (TF) card; 2 native SATA 3 6Gbps;eMMC;SIM card slot | ||
| 显示 | HDMI (Type A) output with HDCP 1.4, resolutions up 1920x1200; MIPI DP | ||
| Video decoder/encode | The Video DSP of RTD1296 is dedicated to manipulating,decoding and encoding of video streams in various formats, e.g. decoding 4K2K H.265,Full HD MPEG1/2/4/H.264/H.264 MVC,AVC/VC-1,VP8,AVS,AVS Plus,HD jpeg,etc.Video decoding and encoding can run simultaneously. support 3D de-intrlacing,video scaling up to 4K2K and so on. | ||
| Aideo decoding | Audio decoding is carried out by an Audio DSP that is capable of decoding a set of audio formats,e.g. DTS HD,Dolby Digital Plus,TrueHD,and other popular formats.the Audio DSP also performs audio post processing | ||
| Audio | support two audio device HDMI and headphone, also support Audio In/Out with PIN define. support 2 MIC in | ||
| HDMI 输入/输出 | 1* HDMI 2.0a out port and 1* HDMI 2.0a In port | ||
| Audio outputs/Inputs | HDMI, I2S audio,Audio micro out, Audio out/in with PIN define | ||
| M.2 KEY E:PCIE 2.0/USB 2.0 | 1 pcie 2.0 interface | ||
| M.2 KEY E:PCIe 1.1 / SDIO / USB 2.0 | 1 pcie 1.1 and SDIO interface | ||
| USB 3.0 | 1x USB 3.0 host | ||
| USB 2.0 | 2x USB 2.0 OTG, 1 with standard USB port , 1 define with PIN | ||
| M.2 KEY B | 1 * M.2 interface USB 2.0 for 4G with Micro SIM card slot | ||
| Mini DP | 1* Mini DP | ||
| TYPE C | 1 type C interface | ||
| RTC 实时时钟供电 | RTC battery power interface | ||
| 按键 | Reset button, Power button, U-boot button | ||
| Led灯 | Red, Green, Blue | ||
| 红外 | IR 红外遥控接收 | ||
| 尺寸 | 148 mm × 100.5mm | ||
| 重量 | 100g | ||
举报投诉
NAS
11文章
325浏览量
115167 -
嵌入式开发
18文章
1176浏览量
50233 -
嵌入式主板
7文章
6107浏览量
37168 -
工业平板电脑
1文章
189浏览量
8830 -
banana pi
1文章
134浏览量
4315
热点推荐
[公开发售] 香蕉派开源社区联合进迭进空重磅打造: BPI‑SM10(K3-Com260) 和 K3 Pico‑ITX 计算机将于5月11日全球发
香蕉派 BPI-SM10 (K3-Com260) 和 K3 Pico-ITX 工业计算机公开发售
Banana Pi开源社区发布最强Wifi7路由器开发板及套件:BPI-R4 Pro
Banana Pi 香蕉派BPI - R4 Pro 联发科MT7988A Wi-Fi 7开源路由器主板公
发表于 11-18 16:14
香蕉派 BPI-2K3000 工业计算机开发板采用龙芯2K3000芯片设计
/V11
统信
鸿蒙、欧拉,适配中……
Product photo
香蕉派 BPI-2K3000 产品图集
BPI-2K3000整机产品解决方案
Banana Pi
发表于 11-15 11:43
【作品合集】玄铁BPI-CanMV-K230D-Zero开发板测评
RISC-V Vector1.0 的前沿技术,选择嘉楠科技的 Canmv K230D Zero 开发板。这款创新的开发板是由嘉楠科技与香蕉派开源
发表于 09-18 10:13
【作品合集】玄铁Banana Pi BPI-RV2开发板测评
BPI-RV2 开源网关是矽昌和⾹蕉派开源社区(Banana Pi )合作设计。
活动详情地址:【RISC-V专题】Banana Pi BPI-R
发表于 09-17 10:58
香蕉派 BPI-R4 Lite Wifi 7 开源路由器开发板采用联发科MT7987芯片方案
BPI-R4 Lite 产品介绍
Banana Pi BPI-R4 Lite 智能路由器板采用联发科MT7987A四核Arm Cortex
发表于 08-26 17:26
【BPI-CanMV-K230D-Zero开发板体验】开箱以及开发板简介
嘉楠科技的 Canmv K230D Zero 开发板。这款创新的开发板是由嘉楠科技与香蕉派开源社区联合设计研发,搭载了先进的勘智 K230D
发表于 08-25 22:49
【Banana Pi BPI-RV2开发板试用体验】开箱与系统体验~
开源。至于智能,因为SoC带NPU,可以实现一些AI应用。
盒子背面也很有设计感,就是PCB的简笔图,要是BPI-RV2开发板的简笔图就更好了。
打开后,主题赫然其中,湖蓝色PCB很大。
二、简单介绍
发表于 07-14 23:48
【Banana Pi BPI-RV2开发板试用体验】开发环境搭建及编译
BPI-RV2 RISC-V开源路由器之开发环境搭建及编译
背景
BPI-RV2 RISC-V开源
发表于 07-14 23:05
【Banana Pi BPI-RV2开发板试用体验】开箱上电
BPI-RV2 RISC-V开源路由器之开箱上电
背景
现在刚好正在研究短距及网络相关的东东。
最近刚好有幸得到了一块香蕉派
发表于 06-26 19:51
【BPI-CanMV-K230D-Zero开发板体验】香蕉派 K230D 视觉开发板开箱+CamMV 环境搭建
【开箱】
今天收到了香蕉派 Banana Pi BPI-CanMV-K230D-Zero 开发板,先上图一睹为快。
【处理器介绍】
这款开发板
发表于 06-24 22:54
基于RISC-V处理器,Banana Pi BPI-RV2开发板试用
、128 MiB NAND、16 MiB NOR、M.2接⼝,MINI PCIE和USB 2.0接⼝等。 Banana Pi BPI-RV2 开源网关是矽昌和⾹蕉派
香蕉派BPI-RV2 RISC-V路由器开发板矽昌 SF21H8898网关SOC设计
香蕉派BPI-RV2开源网关是一款基于Siflower SF21H8898 SoC、1 × 2.5G WAN网络接口、5千兆LAN网络接口、板载512MB DDR3内存、128 MiB
香蕉派 BPI-W2 Nas 开源路由开发板采用Realtek RTD1296设计
