Banana pi BPI-M2 Zero 是一款极小形的开源单板计算机,采用全志H2+芯片方案设计,也可以直接使用全志H3,尺寸大小完全与Raspberry pi Zero W 一样,尺寸大小为60mm *30mm支持板载WIFI与蓝牙,512M 内存,Mini HDMI 接口。
Banana Pi BPI-M2 Zero 支持Android,Debian linux,Ubuntu linux, Raspbian系统 ,可以方便的做物联网,教育应用开发。
硬件接口:
硬件规格:
香蕉派BPI-P2 Zero , BPI-M2 zero 与 Raspberry Pi Zero W硬件规格比较 | |||
| Module | Banana Pi BPI-P2 Zero | Banana Pi BPI-M2 Zero | Raspberry Pi Zero W |
| CPU | H3+ Quad-core Cortex-A7 H265/HEVC 1080P | H3+ Quad-core Cortex-A7 H265/HEVC 1080P | Broadcom BCM2835 32 Bit 1 GHz ARM1176JZF-S single-core |
| GPU | Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0 | Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0 | VideoCore IV |
| Memory (SDRAM) | 512M DDR3(shared with GPU) | 512M DDR3(shared with GPU) | 512 MB DDR2 |
| Onboard Storage | TF card (Max. 64GB) | TF card (Max. 64GB) | TF card (Max. 64GB) |
| Onboard Network | 100M LAN | NOPE (but can extension with PIN define) | NOPE |
| PoE power | PoE function support | NOPE | NOPE |
| Onboard flash | 8G eMMC | NOPE | NOPE |
| Onboard WIFI | SDIO AP6212(option AP6181、AP6335) | SDIO AP6212(option AP6181、AP6335) | 802.11n wireless, Bluetooth 4.1 |
| Video decoding | 1080p@60fps,H.264 Video encoding1080p@30fps,H.264 | 1080p@60fps,H.264 Video encoding1080p@30fps,H.264 | 1080p30 H.264/MPEG-4 AVC high-profile decoder and encoder |
| Video input | A CSI input connector Camera | A CSI input connector Camera | CSI camera connector |
| Video Outputs | mini HDMI 1.4,1080P@30fps, DHCP | mini HDMI 1.4,1080P@30fps, DHCP | Mini HDMI and USB On-The-Go ports |
| Audio Output | Mini HDMI | Mini HDMI | Mini HDMI |
| Power Source | Micro USB with 5V/2A or PoE power | Micro USB with 5V/2A | 5V/2A |
| USB 2.0 Ports | one USB 2.0 OTG | one USB 2.0 OTG | one USB 2.0 OTG |
| Buttons | Power Button, Reset Button | Power Button, Reset Button | Composite video and reset headers |
| Low-level peripherals | 40 Pins Header,compatible with Raspberry Pi 3 | 40 Pins Header,compatible with Raspberry Pi 3 | 40 PIN |
| uart GPIO(1x3) pin | UART, ground | UART, ground | UART |
| LED | Power led & Status led | Power led & Status led | Power Status LED |
| IR | N/A | N/A | N/A |
| Supported OS | android linux | android linx | Linux |
| Product size | 65mm X 52.5mm | 65mm × 30mm | 65mm x 30mm |
| Weight | 30g | 15g | 9g |
举报投诉
嵌入式主板
7文章
6107浏览量
37191 -
工业物联网
25文章
2556浏览量
67773 -
Raspberry Pi
2文章
622浏览量
24116 -
树莓派
122文章
2086浏览量
110879
热点推荐
探索PCM - 3343:高性能PC/104单板计算机的卓越之选
探索PCM - 3343:高性能PC/104单板计算机的卓越之选 在电子工程师的日常工作中,选择一款合适的单板计算机(SBC)对于项目的成功至关重要。今天,我们就来深入了解一款备受关注的产品
[公开发售] 香蕉派开源社区联合进迭进空重磅打造: BPI‑SM10(K3-Com260) 和 K3 Pico‑ITX 计算机将于5月11日全球发
香蕉派 BPI-SM10 (K3-Com260) 和 K3 Pico-ITX 工业计算机公开发售
[公开发售] 香蕉派开源社区联合进迭时空重磅打造: BPI‑SM10(K3-Com260) 和 K3 Pico‑ITX 计算机将于5月11日全球发
香蕉派BPI-SM10(K3-Com260)和K3Pico-ITX工业计算机公开发售进迭时空RI
香蕉派 BPI-2K3000 工业计算机开发板采用龙芯2K3000芯片设计
BPI-2K3000 工业计算机
Banana Pi BPI-2K3000工业计算机开发平台,基于龙芯最新一代2K3000(
发表于 11-15 11:43
贸泽电子开售全新Arduino UNO Q单板计算机
贸泽电子开售全新Arduino UNO Q单板计算机。Arduino UNO Q单板计算机(SBC)将高性能计算与实时控制结合,提供理想的创新平台。
【作品合集】赛昉科技VisionFive 2单板计算机开发板测评
赛昉科技VisionFive 2单板计算机开发板测评作品合集
产品介绍:
昉·星光 2是全球首款集成了3D GPU的高性能量产RISC-V单板计算机
发表于 09-04 09:08
Banana Pi BPI-R4 Lite:新型单板计算机比 Raspberry Pi 5 更具优势
Banana Pi BPI-R4 Lite 现已上市。具体来说,这款单板计算机在 Youyeetoo 上的售价约为 86 美元,但客户在下单前请务必查看运输条款和费用。这是一款单板计算机,有望成为
【Banana Pi BPI-RV2开发板试用体验】开箱与系统体验~
(一)SF2H8898
SF21H8898是由矽昌通信开发的一款高性能工业级 SOC 网关芯片,采用先进的 TSMC 12nm FFC 工艺,内部集成了四核 64-bit RISC-
发表于 07-14 23:48
【VisionFive 2单板计算机试用体验】VisionFive 2一个霸气的游戏机
单板计算机,搭载昉·惊鸿-7110(型号:JH-7110)RISC-V应用处理器,拥有极强的计算能力和图形处理能力。开源的昉·星光 2具有强大的软件适配性,官方适配Debian操作系统,同时通过社区合作适配
发表于 07-13 20:41
【VisionFive 2单板计算机试用体验】SD卡分区
适用场景 :RVspace防-星光2单板计算机(Debian11),SD卡根分区扩容
核心原理
三步操作流程 : graph LR
A[删除旧分区] --> B[重建分区-保持起始扇区
发表于 07-09 20:50
【Banana Pi BPI-RV2开发板试用体验】开箱上电
⼝、板载 512MB DDR3 内存 、128 MiB NAND、16 MiB NOR、M.2接⼝,MINI PCIE和USB 2.0接⼝等
发表于 06-26 19:51
【Banana Pi BPI-RV2开发板试用体验】开发板介绍视频
一. 开发板介绍香蕉派 BPI-RV2 RISC-V 路由器开发板采用矽昌通信 SF21H8898 芯片
发表于 06-24 23:51
基于RISC-V处理器,Banana Pi BPI-RV2开发板试用
Banana Pi BPI-RV2 开源网关是⼀款基于矽昌 SF21H8898 SoC的设备,1 × 2.5 G WAN⽹络接⼝、5 个千兆LAN ⽹络接⼝、板载
香蕉派BPI-RV2 RISC-V路由器开发板矽昌 SF21H8898网关SOC设计
香蕉派BPI-RV2开源网关是一款基于Siflower SF21H8898 SoC、1 × 2.5G WAN网络接口、5千兆LAN网络接口、
香蕉派BPI-M2 Zero单板计算机采用全志H3(可选H2+/H5)芯片设计,板载512M RAM内存
