Banana Pi BPI-M2 Pro是Banana Pi公司于2021年推出的下一代单板机。它采用Amlogic S905X3四核Cortex-A55 (2.0 XXGHz)处理器。板载2GB LPDDR4内存和16GB EMMC存储,支持2个USB 3.0接口,1个千兆网口。板载RT8821CU wifi&BT。1 HDMI输出 905X3是晶晨半导体旗下最新的8K智能家庭影音芯片,采用四颗64位ARM A55架构 CPU芯片,集成G31图形处理器,支持8K视频解码和8K视频输出,运行开放的安卓9.0系统和Linux系统。
BPI-M2 Pro与香蕉派 BPI-M2+一样大小,接口也一样,所以可以使用BPI-M2+的外壳。
硬件接口:
香蕉派BPI-M2 Pro 与香蕉派 BPI-M5一样采用Amlogic S905x3芯片方案,但在尺寸与接口上完全与香蕉派 BPI-M2+一致,用BPI-M2+做产品的客户,可以直接升级替换。
硬件规格:
Banana pi BPI-M2 Pro 硬件规格 | |||
| CPU | Amlogic S905X3 Quad-Core Cortex-A55 (2.0xxGHz) | ||
| GPU | Mali-G31 MP2 GPU with 4 x Execution Engines (650Mhz) | ||
| Memory | 2 GB LPDDR4 | ||
| Storage | MicroSD slot with support for up to 256GB expansion and 16G eMMC flash with support for up to 64GB | ||
| Network | 10/100/1000 Mbit/s Ethernet | ||
| Wifi&BT | Dual-band 802.11 b/g/n/ac WiFi 5 1×1 and Bluetooth 4.2 via Realtek RTL8821CU | ||
| Video Output(s) | 1 x HDMI 2.0 (up to4K@60Hzwith HDR, CEC, EDID) | ||
| Audio Output(s) | 1 x HDMI digital output | ||
| USB ports | 2x USB 3.0 host ports, 1x micro USB OTG port | ||
| GPIO | 40 Pin Header: GPIO (x28) and Power (+5V, +3.3V and GND). GPIO pins can be used for UART, I2C, SPI or PWM | ||
| Switches | Reset, Power and U-boot | ||
| LED | Power Status and Activity status | ||
| Power Source | 5 volt @3A via DC port | ||
| Size & Weight | 65mm×65mm, 58g | ||
| OS | Android and Linux | ||
BPI-M2 Pro ,BPI-M5 , Odroid C4 , 树莓派4 规格比较表
BPI-M2 Pro VS BPI-M5 VS Odroid C4 VS RPI 4 | |||||
香蕉派 BPI-M2 Pro | 香蕉派 BPI-M5 | Odroid C4 | 树莓派 4 | ||
| Processor | Amlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHz | Amlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHz | Amlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHz | Broadcom BCM2711, Quad core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz | |
| GPU | Mali-G31 MP2 GPU | Mali-G31 MP2 GPU | Mali-G31 MP2 GPU | Broadcom VideoCore VI | |
| RAM | 2GB LPDDR4 | 4GB LPDDR4 | DDR4 4GiB with 32-bit bus width | 2GB, 4GB or 8GB LPDDR4-3200 SDRAM | |
| Storage | micro SD card slot & 16GB eMMC flash on board | micro SD card slot & 16GB eMMC flash on board | micro SD card slot , eMMC connector for option | micro SD card slot, non EMMC | |
| Network | 1 GbE ,WiFi&BT5.0 onbard | GbE ,Optional WiFi USB dongle | GbE | GbE, 2.4 GHz and 5.0 GHz IEEE 802.11ac wireless, Bluetooth 5.0, BLE | |
| Video Output | 1 x HDMI 2.1 (up to4K@60Hzwith HDR, CEC, EDID) | 1 x HDMI 2.1 (up to4K@60Hzwith HDR, CEC, EDID) | 1 x HDMI 2.1 (up to4K@60Hzwith HDR, CEC, EDID) | 2 × micro-HDMI 2.0 | |
| Audio Output | 1 x HDMI digital output | 3.5mm jack and 1 x HDMI digital output | Optional SPDIF optical output | 3.5 mm analogue audio-video jack | |
| DSI | N/A | N/A | N/A | 2-lane MIPI DSI display port | |
| CSI | N/A | N/A | N/A | 2-lane MIPI CSI camera port | |
| USB | USB 3.0 x 2 1 Micro USB 2.0 | USB 3.0 x 4 TYPE C | USB 3.0 x 4, 1 x Micro USB 2.0 port (OTG) | 2 USB 3.0 ports; 2 USB 2.0 ports; | |
| Power | 5 volt @3A via DC power | 5 volt @3A via Micro USB (TYPE C) | 1 x DC power jack (Outer diameter: 5.5mm, inner diameter: 2.1mm) | 5V DC via USB-C connector (minimum 3A*) | |
| IR | Yes | Yes | Yes | N/A | |
| GPIO | 40 Pin Header: GPIO (x28) and Power (+5V, +3.3V and GND). | 40 Pin Header: GPIO (x28) and Power (+5V, +3.3V and GND). | 40 x GPIO pins | 40-pin GPIO header, populated | |
| Button | Reset, user and U-boot | Reset, user and U-boot | N/A | N/A | |
| LED | Power Status and Activity status | Power Status and Activity status | Power Status and Activity status | Power Status and Activity status | |
| Dimensions & weight | 65mm x 65mm,58g | 85mm x 56mm, 48g | 85mm x 56mm 59g | 88 mm × 58 mm, 46 g | |
| System Support | Linux & Android | Linux & Android | Linux & Android | Linux & Android | |
BPI-M2 Pro 外壳设计:
举报投诉
开源硬件
8文章
233浏览量
31397 -
嵌入式主板
7文章
6107浏览量
37171 -
Amlogic
13浏览量
16417 -
banana pi
1文章
134浏览量
4317
热点推荐
[公开发售] 香蕉派开源社区联合进迭进空重磅打造: BPI‑SM10(K3-Com260) 和 K3 Pico‑ITX 计算机将于5月11日全球发
香蕉派 BPI-SM10 (K3-Com260) 和 K3 Pico-ITX 工业计算机公开发售
[公开发售] 香蕉派开源社区联合进迭时空重磅打造: BPI‑SM10(K3-Com260) 和 K3 Pico‑ITX 计算机将于5月11日全球发
香蕉派BPI-SM10(K3-Com260)和K3Pico-ITX工业计算机公开发售进迭时空RI
树莓派5还是香橙派5 Pro?两款热门开发板的详细对比
在单板计算机(SBC)细分领域,树莓派确实主导市场多年,但市场上也存在不少替代选择。在形态与功能方面,香橙派是树莓派积极的竞争者之一。树莓派
发表于 03-04 19:29
Banana Pi BPI-CM6 – 一款与 Raspberry Pi CM4/CM5 载板兼容的 SpacemiT K1 RISC-V 系统模块
至 85°C
BPI-CM6 系统模块受益于基于相同 SpacemiT K1 处理器的 Banana Pi BPI-F3 单板计算机 (SBC) 的开发成果,该公司提供基于 Linux 6.1 内核
发表于 11-28 16:59
香蕉派 BPI-2K3000 工业计算机开发板采用龙芯2K3000芯片设计
BPI-2K3000 工业计算机
Banana Pi BPI-2K3000工业计算机开发平台,基于龙芯最新一代2K3000(
发表于 11-15 11:43
贸泽电子开售全新Arduino UNO Q单板计算机
贸泽电子开售全新Arduino UNO Q单板计算机。Arduino UNO Q单板计算机(SBC)将高性能计算与实时控制结合,提供理想的创新平台。
【作品合集】赛昉科技VisionFive 2单板计算机开发板测评
赛昉科技VisionFive 2单板计算机开发板测评作品合集
产品介绍:
昉·星光 2是全球首款集成了3D GPU的高性能量产RISC-V单板计算机
发表于 09-04 09:08
Banana Pi BPI-R4 Lite:新型单板计算机比 Raspberry Pi 5 更具优势
Banana Pi BPI-R4 Lite 现已上市。具体来说,这款单板计算机在 Youyeetoo 上的售价约为 86 美元,但客户在下单前请务必查看运输条款和费用。这是一款单板计算机,有望成为
【VisionFive 2单板计算机试用体验】VisionFive 2一个霸气的游戏机
单板计算机,搭载昉·惊鸿-7110(型号:JH-7110)RISC-V应用处理器,拥有极强的计算能力和图形处理能力。开源的昉·星光 2具有强大的软件适配性,官方适配Debian操作系统,同时通过社区合作适配
发表于 07-13 20:41
【VisionFive 2单板计算机试用体验】SD卡分区
适用场景 :RVspace防-星光2单板计算机(Debian11),SD卡根分区扩容
核心原理
三步操作流程 : graph LR
A[删除旧分区] --> B[重建分区-保持起始扇区
发表于 07-09 20:50
【VisionFive 2单板计算机试用体验】 + 开箱体验
在x86与ARM架构主导的单板计算机市场,中国团队打造的VisionFive 2(防星光2)如同一颗新星,凭借开源开放的RISC-V架构和成熟的桌面体验,为开发者与极客提供了全新的选择
发表于 06-27 09:06
【Banana Pi BPI-RV2开发板试用体验】开箱上电
⼝、板载 512MB DDR3 内存 、128 MiB NAND、16 MiB NOR、M.2接⼝,MINI PCIE和USB 2.0接⼝等。
Banana Pi
发表于 06-26 19:51
【Banana Pi BPI-RV2开发板试用体验】开发板介绍视频
一. 开发板介绍香蕉派 BPI-RV2 RISC-V 路由器开发板采用矽昌通信 SF21H8898 芯片
发表于 06-24 23:51
香蕉派BPI-RV2 RISC-V路由器开发板矽昌 SF21H8898网关SOC设计
香蕉派BPI-RV2开源网关是一款基于Siflower SF21H8898 SoC、1 × 2.5G WAN网络接口、5千兆LAN网络接口、板载
Banana Pi BPI-R4 Pro Wifi7 路由器开发板采用联发科MT7988A芯片设计,支持4个2.5G网口,支持2个10G光电口,支持4G/5G扩展
Banana Pi BPI-R4 Pro 路由器板采用联发科 MT7988A(Filogic 880)四核 ARM Corex-A73 设计,板载 4
香蕉派BPI-M2 Pro单板计算机采用Amlogic S905x3 芯片方案设计,板载2G RAM 和16GB eMMC
