Banana Pi BPI-M5是新一代单板计算机设计,采用Amlogic S905X3四核Cortex-A55 (2.0xxGHz)处理器。MP2 GPU(650Mhz)。支持4GB LPDDR4和16G eMMC板载存储。它有4个USB 3.0端口,1个千兆网口。 905X3是晶晨半导体旗下最新的8K智能家庭影音芯片,采用四颗64位ARM A55架构 CPU芯片,集成G31图形处理器,支持4K视频解码和4K视频输出,运行开放的安卓9.0系统和Linux系统。
硬件接口示意图:
硬件规格:
香蕉派BPI-M5 硬件规格表 | |||
CPU | Amlogic S905X3 Quad-Core Cortex-A55 (2.0xxGHz) | ||
GPU | Mali-G31 MP2 GPU with 4 x Execution Engines (650Mhz) | ||
Memory | 4 GB LPDDR4 | ||
Storage | MicroSD slot with support for up to 256GB expansion and 16G eMMC flash with support for up to 64GB | ||
Network | 10/100/1000 Mbit/s Ethernet | ||
Video Output(s) | 1 x HDMI 2.0 (up to4K@60Hzwith HDR, CEC, EDID) | ||
Audio Output(s) | 3.5mm jack and 1 x HDMI digital output | ||
USB ports | USB 3.0 PORT (x4) | ||
GPIO | 40 Pin Header: GPIO (x28) and Power (+5V, +3.3V and GND). GPIO pins can be used for UART, I2C, SPI or PWM | ||
Switches | Reset, Power and U-boot | ||
LED | Power Status and Activity status | ||
Power Source | 5 volt @3A via Micro USB (TYPE C) | ||
Size & Weight | 92x60mm, 48g | ||
OS | Android and Linux |
BPI-M2 Pro ,BPI-M5 , Odroid C4 , 树莓派4 规格比较表
BPI-M2 Pro VS BPI-M5 VS Odroid C4 VS RPI 4 | |||||
香蕉派 BPI-M2 Pro | 香蕉派 BPI-M5 | Odroid C4 | 树莓派 4 | ||
Processor | Amlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHz | Amlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHz | Amlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHz | Broadcom BCM2711, Quad core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz | |
GPU | Mali-G31 MP2 GPU | Mali-G31 MP2 GPU | Mali-G31 MP2 GPU | Broadcom VideoCore VI | |
RAM | 2GB LPDDR4 | 4GB LPDDR4 | DDR4 4GiB with 32-bit bus width | 2GB, 4GB or 8GB LPDDR4-3200 SDRAM | |
Storage | micro SD card slot & 16GB eMMC flash on board | micro SD card slot & 16GB eMMC flash on board | micro SD card slot , eMMC connector for option | micro SD card slot, non EMMC | |
Network | 1 GbE ,WiFi&BT5.0 onbard | GbE ,Optional WiFi USB dongle | GbE | GbE, 2.4 GHz and 5.0 GHz IEEE 802.11ac wireless, Bluetooth 5.0, BLE | |
Video Output | 1 x HDMI 2.1 (up to4K@60Hzwith HDR, CEC, EDID) | 1 x HDMI 2.1 (up to4K@60Hzwith HDR, CEC, EDID) | 1 x HDMI 2.1 (up to4K@60Hzwith HDR, CEC, EDID) | 2 × micro-HDMI 2.0 | |
Audio Output | 1 x HDMI digital output | 3.5mm jack and 1 x HDMI digital output | Optional SPDIF optical output | 3.5 mm analogue audio-video jack | |
DSI | N/A | N/A | N/A | 2-lane MIPI DSI display port | |
CSI | N/A | N/A | N/A | 2-lane MIPI CSI camera port | |
USB | USB 3.0 x 2 1 Micro USB 2.0 | USB 3.0 x 4 TYPE C | USB 3.0 x 4, 1 x Micro USB 2.0 port (OTG) | 2 USB 3.0 ports; 2 USB 2.0 ports; | |
Power | 5 volt @3A via DC power | 5 volt @3A via Micro USB (TYPE C) | 1 x DC power jack (Outer diameter: 5.5mm, inner diameter: 2.1mm) | 5V DC via USB-C connector (minimum 3A*) | |
IR | Yes | Yes | Yes | N/A | |
GPIO | 40 Pin Header: GPIO (x28) and Power (+5V, +3.3V and GND). | 40 Pin Header: GPIO (x28) and Power (+5V, +3.3V and GND). | 40 x GPIO pins | 40-pin GPIO header, populated | |
Button | Reset, user and U-boot | Reset, user and U-boot | N/A | N/A | |
LED | Power Status and Activity status | Power Status and Activity status | Power Status and Activity status | Power Status and Activity status | |
Dimensions & weight | 65mm x 65mm,58g | 85mm x 56mm, 48g | 85mm x 56mm 59g | 88 mm × 58 mm, 46 g | |
System Support | Linux & Android | Linux & Android | Linux & Android | Linux & Android |
举报投诉
开发板
25文章
5038浏览量
97398 -
智能工业控制
5浏览量
6458 -
智能医疗
27文章
1383浏览量
74475 -
智能硬件
205文章
2346浏览量
107543 -
banana pi
1文章
113浏览量
3010
Banana Pi 推出 BPI-F5 SBC,配备 8 核 Allwinner T527 CPU 和双 SIM 卡槽
计算、机器人、工业智能、边缘计算网关、后安装集中控制系统、商用车和工业计算机。
香蕉派 BPI-F5
发表于 10-31 18:55
Banana Pi BPi-M4 Zero 开源硬件开发板评测试: 全志科技H618 方案设计 ,板载4G 内存,32G eMMC
RISC-V架构下DSA-AI算力的更多可能性:Banana Pi BPI-F3进迭时空
8核RISC-V芯片设计,CPU集成2.0 TOPs AI计算能力。2/4/8/16G DDR和8/16/32/128
Banana Pi BPI-F3 进迭时空 RISC-V K1芯片开发板支持8G/16G内存
香蕉派BPI-F3是一款工业级 8核RISC-V开源硬件开发板,它采用进迭时空(SpacemiT) K1 8核RISC-V芯片设计,CPU集
Banana Pi BPI-M4 Berry开源硬件开发板采用全志H618芯片设计
BPI-M4 Berry 开发板作为一款强大的单板计算机(SBC),充分挖掘了全志 H618 系统级芯片(SoC)的功能,为开发人员提供了令人印象深刻的性能和丰富的特性。与树莓派
香蕉派 BPI-3A6000 信创迷你计算机采用龙芯3A6000芯片设计
A6000 MINIPC 整机支持 2 个 DDR4 SODIMM 插槽,内存速率 3200M,单条内存支持 8GB/16GB/32GB,
基于RK3576开发的Banana Pi BPI-M5 Pro 开发板
Banana Pi BPI-M5 Pro采用第二代8nm高性能AIOT平台瑞芯微RK3576,拥有6 TOPS算力NPU,支持最高32GB大内存。支持8K视频编解码,提供双千兆网口、WiFi 6
发表于 05-02 19:44
Banana Pi 推出采用瑞芯微 RK3576芯片设计开源硬件:BPI-M5 Pro,比树莓派5性能强大
发表于 05-02 19:42
信用卡大小的 RISC-V 单板计算机介绍
RISC-V 单板计算机的尺寸为 86mm x 56mm,搭载 1.5GHz 的昉・惊鸿 -7110 SoC,可选 1/2/4/8GB 的 LPDDR4
发表于 04-12 16:39
【飞腾派4G版免费试用】飞腾派4G版开发板套装测试及环境搭建
和2个FTC310核,其中FTC664核主频可达1.8GHz,FTC310核主频可达1.5GHz。主板板载64位 DDR4内存,分2G和4G两个版本,支持SD或者
发表于 01-22 00:47
【飞腾派4G版免费试用】大家来了解飞腾派4G版开发板
国产高性能、低功耗通用计算微处理器的设计研发和产业化推广。飞腾派是一款面向行业工程师、学生和爱好者的开源硬件,采用飞腾嵌入式四核处理器,兼容ARM V8架构,板载64位 DDR4
发表于 01-02 22:43
【飞腾派4G版免费试用】初步认识飞腾派4G版开发板
发表于 01-02 22:23
